Domoticz, Homebridge et Homekit
latino3131
Re: Domoticz, Homebridge et Homekit
Message par latino3131 » 21 sept. 2017, 10:53
je n'arrive même plus a a voir Active: active (running) :roll:
Alors je reboot et je fait une serie de commande
login as: pi
pi@192.168.1.14's password:
Linux raspberrypi 4.9.41-v7+ #1023 SMP Tue Aug 8 16:00:15 BST 2017 armv7l
The programs included with the Debian GNU/Linux system are free software;
the exact distribution terms for each program are described in the
individual files in /usr/share/doc/*/copyright.
Debian GNU/Linux comes with ABSOLUTELY NO WARRANTY, to the extent
permitted by applicable law.
Last login: Thu Sep 21 11:06:23 2017
SSH is enabled and the default password for the 'pi' user has not been changed.
This is a security risk - please login as the 'pi' user and type 'passwd' to set a new password.
pi@raspberrypi:~ $ pm2 list
│ App name   │ id │ mode │ pid  │ status │ restart │ uptime │ cpu │ mem       │ user │ watching │
│ homebridge │ 0  │ fork │ 1426 │ online │ 36      │ 0s     │ 66% │ 20.4 MB   │ pi   │ disabled │
 Use `pm2 show <id|name>` to get more details about an app
│ homebridge │ 0  │ fork │ 1532 │ online │ 46      │ 0s     │ 99% │ 19.7 MB   │ pi   │ disabled │
│ homebridge │ 0  │ fork │ 1667 │ online │ 57      │ 0s     │ 0%  │ 956.0 KB   │ pi   │ disabled │
pi@raspberrypi:~ $ sudo systemctl status homebridge
● homebridge.service - Node.js HomeKit Server
   Loaded: loaded (/etc/systemd/system/homebridge.service; enabled; vendor preset: enabled)
   Active: active (running) since Thu 2017-09-21 11:07:27 CEST; 131ms ago
 Main PID: 1745 (node)
   CGroup: /system.slice/homebridge.service
           └─1745 node /usr/lib/node_modules/homebridge/bin/homebridge -U /var/homebridge
sept. 21 11:07:27 raspberrypi systemd[1]: Started Node.js HomeKit Server.
   Active: activating (auto-restart) (Result: exit-code) since Thu 2017-09-21 11:07:31 CEST; 1s ago
  Process: 1745 ExecStart=/usr/lib/node_modules/homebridge/bin/homebridge $HOMEBRIDGE_OPTS (code=exited, status=1/FAILURE)
 Main PID: 1745 (code=exited, status=1/FAILURE)
sept. 21 11:07:31 raspberrypi systemd[1]: homebridge.service: Failed with result 'exit-code'.
   Active: activating (auto-restart) (Result: exit-code) since Thu 2017-09-21 11:07:31 CEST; 7s ago
   Active: activating (auto-restart) (Result: exit-code) since Thu 2017-09-21 11:07:45 CEST; 1s ago
  Process: 1973 ExecStart=/usr/lib/node_modules/homebridge/bin/homebridge $HOMEBRIDGE_OPTS (code=exited, status=1/FAILURE)
 Main PID: 1973 (code=exited, status=1/FAILURE)
sept. 21 11:07:45 raspberrypi systemd[1]: homebridge.service: Unit entered failed state.
sept. 21 11:07:45 raspberrypi systemd[1]: homebridge.service: Failed with result 'exit-code'.
   Active: activating (auto-restart) (Result: exit-code) since Thu 2017-09-21 11:07:45 CEST; 8s ago
   Active: activating (auto-restart) (Result: exit-code) since Thu 2017-09-21 11:07:59 CEST; 439ms ago
  Process: 2180 ExecStart=/usr/lib/node_modules/homebridge/bin/homebridge $HOMEBRIDGE_OPTS (code=exited, status=1/FAILURE)
 Main PID: 2180 (code=exited, status=1/FAILURE)
sept. 21 11:07:59 raspberrypi systemd[1]: homebridge.service: Unit entered failed state.
sept. 21 11:07:59 raspberrypi systemd[1]: homebridge.service: Failed with result 'exit-code'.
│ homebridge │ 0  │ fork │ 2308 │ online │ 107     │ 0s     │ 200% │ 22.8 MB   │ pi   │ disabled │
│ homebridge │ 0  │ fork │ 2441 │ online │ 118     │ 0s     │ 149% │ 22.1 MB   │ pi   │ disabled │
   Active: active (running) since Thu 2017-09-21 11:08:23 CEST; 2s ago
 Main PID: 2591 (homebridge)
           ├─2591 homebridge
           ├─2607 /bin/sh -c /bin/echo -n "$(npm -g prefix)/lib/node_modules"
           └─2608 npm
sept. 21 11:08:24 raspberrypi homebridge[2591]: *** WARNING *** Please fix your application to use the native API of Avahi!
sept. 21 11:08:24 raspberrypi nodejs[2591]: *** WARNING *** Please fix your application to use the native API of Avahi!
sept. 21 11:08:24 raspberrypi homebridge[2591]: *** WARNING *** For more information see <http://0pointer.de/avahi-compat?s=libdns_sd&e=nodejs>
sept. 21 11:08:24 raspberrypi nodejs[2591]: *** WARNING *** For more information see <http://0pointer.de/avahi-compat?s=libdns_sd&e=nodejs>
sept. 21 11:08:24 raspberrypi homebridge[2591]: *** WARNING *** The program 'nodejs' called 'DNSServiceRegister()' which is not supported (or only supported partially)
sept. 21 11:08:24 raspberrypi nodejs[2591]: *** WARNING *** The program 'nodejs' called 'DNSServiceRegister()' which is not supported (or only supported partially) in t
sept. 21 11:08:24 raspberrypi homebridge[2591]: *** WARNING *** For more information see <http://0pointer.de/avahi-compat?s=libdns_sd&e=nodejs&f=DNSServiceRegister>
sept. 21 11:08:24 raspberrypi nodejs[2591]: *** WARNING *** For more information see <http://0pointer.de/avahi-compat?s=libdns_sd&e=nodejs&f=DNSServiceRegister>
...skipping...
           ├─2591 homebridge
           └─2608 npm
   Active: activating (auto-restart) (Result: exit-code) since Thu 2017-09-21 11:08:27 CEST; 7s ago
  Process: 2591 ExecStart=/usr/lib/node_modules/homebridge/bin/homebridge $HOMEBRIDGE_OPTS (code=exited, status=1/FAILURE)
 Main PID: 2591 (code=exited, status=1/FAILURE)
sept. 21 11:08:27 raspberrypi systemd[1]: homebridge.service: Unit entered failed state.
sept. 21 11:08:27 raspberrypi systemd[1]: homebridge.service: Failed with result 'exit-code'.
pi@raspberrypi:~ $
Je suis pas expert (vraiment pas) mais j'ai l'impression en fait quil redemarre en boucle ou je me trompe? le process fait que changer le nombre de restart fait peur et uptime est toujour a 0 ...normal ? je pense pas!
latino3131
Message par latino3131 » 22 sept. 2017, 17:58
je ne retrouve plus le tuto que j'ai suivi pour creer le redemarage automatique de homeridge...
la seul chose dont je me souvient c'est quil fallait creer deux fichiers (mais les quelles et ou :?: )
ToXiiK
Message par ToXiiK » 23 sept. 2017, 09:35
Je me permet de poster ici car je rencontre un soucis avec homebridge , j'ai une erreur que je n'arrive pas à pas résoudre, en effet, j'ai un arduino avec le module ip sur lequel est connecté une led(pour le moment , puis après je remplacerai par une lampe) et un capteur de température. Si j'indique seulement la led ou seulement le capteur de température dans le fichier de configuration de homebridge tout marche parfaitement, mais si je mets tous les deux dans le fichier de configuration, dès que je lance l'application Maison sur mon iPhone, homebridge plante et affiche un message d'erreur(voir image).
Est-ce que c'est un problème de compatibilité dans le plug-in http homebridge et le plug-in homebridge-http-temperature ?
Comment résoudre le problème ?
En vous remerciant par avance pour votre aide.
Cordialement
latino3131
Message par latino3131 » 25 sept. 2017, 14:45
Salut toXiik
envois le code de ton fichier config.json moi je vais peut etre pas te répondre mais les autres surement ;)
Trax
Message par Trax » 03 oct. 2017, 17:41
Je tente ma chance ici, j'ai mon installation Domoticz + homebridge sur une Raspberry Pi.
Et cela fonctionne parfaitement !
Sauf quand je met les mains dans Domoticz ou que je "bricole" sur la Pi.
En effet dès que j'ai un crash de Domoticz ou un reboot de la Pi, homebridge crash.
En supprimant le domicile de l'app sur mon iPhone et en supprimant les dossiers accessories et persist, un pm2 restart homebridge et c'est reparti!
Le problème est qu'a chaque fois il faut refaire la configuration du domicile ... vite ennuyeux ...
Voici mon config.json :
    "bridge": {
        "name": "Homebridge",
        "username": "B8:27:EB:XX:XX:XX",
        "port": 51826,
        "pin": "031-45-155"
    "description": "Configuration file for (e)xtended Domoticz platform.",
    "platforms": [
            "platform": "eDomoticz",
            "name": "eDomoticz",
            "server": "127.0.0.1",
            "port": "8080",
            "ssl": 0,
            "roomid": 0,
            "mqtt": 4
    "accessories": []
Et l'erreur dans les logs
HAP Warning: Characteristic undefined not in required or optional characteristics for service 24a8d81a-3d7b-4965-9086-7edc3ef4fab3. Adding anyway.
Error: Cannot add a Characteristic with the same UUID as another Characteristic in this Service: E863F10D-079E-48FF-8F27-9C2605A29F52
at Service.addCharacteristic (/usr/lib/node_modules/homebridge/node_modules/hap-nodejs/lib/Service.js:80:13)
at Service.getCharacteristic (/usr/lib/node_modules/homebridge/node_modules/hap-nodejs/lib/Service.js:162:19)
at eDomoticzAccessory.getCharacteristic (/usr/lib/node_modules/homebridge-edomoticz/lib/domoticz_accessory.js:102:32)
at eDomoticzAccessory.getServices (/usr/lib/node_modules/homebridge-edomoticz/lib/domoticz_accessory.js:1380:12)
at eDomoticzAccessory.publishServices (/usr/lib/node_modules/homebridge-edomoticz/lib/domoticz_accessory.js:76:23)
at eDomoticzAccessory (/usr/lib/node_modules/homebridge-edomoticz/lib/domoticz_accessory.js:68:7)
at eDomoticzPlatform.configureAccessory (/usr/lib/node_modules/homebridge-edomoticz/index.js:221:21)
at Server._configCachedPlatformAccessories (/usr/lib/node_modules/homebridge/lib/server.js:342:24)
at Server.run (/usr/lib/node_modules/homebridge/lib/server.js:83:8)
at module.exports (/usr/lib/node_modules/homebridge/lib/cli.js:40:10)
Si je comprend bien il essaye de re créé mes dispositifs, sans tenir compte de l'ancienne configuration.
Je ne sais pas trop ou chercher pour corrigé le problème ?
Y a t'il un intérêt à ajouter les accessoires en dur dans le fichier conf ?
Sachant que lorsque je ne touche pas et si le systeme ne reboot pas, il n'y a pas de problème...
Merci d'avance :)
Lalsacien
Message par Lalsacien » 07 oct. 2017, 19:43
J'ai fait une nouvelle installation sur un PI2 sous Stretch. Tout fonctionne à merveille même Homebridge quand il est lancé en ligne de commande. L'application Maison sur iPhone fonctionne.
J'ai tenté l'installation mode service en suivant ce tuto pour créer le service :
https://anderson69s.com/2017/03/18/domo ... que-diy/8/
Le service se lance bien, je n'ai à priori pas d'erreur mais impossible de se connecter avec l'application Maison. J'ai comme réponse dans l'application "Aucun accessoire ne répond." Si je coupe le service et je lance Homebridge en ligne de commande pas de problème cela fonctionne, je retrouve "mes petits". A y perdre son latin. Pourtant le status du service me parait bon :
pi@Domoticz:/usr/bin $ sudo systemctl status homebridge
● homebridge.service - HomeBridge Service
Loaded: loaded (/lib/systemd/system/homebridge.service; enabled; vendor preset: enabled)
Active: active (running) since Sat 2017-10-07 18:43:49 CEST; 16min ago
Main PID: 773 (homebridge)
└─773 homebridge
Oct 07 18:43:56 Domoticz homebridge[773]: ^ For: Vent Strasbourg
Oct 07 18:43:56 Domoticz homebridge[773]: HAP Warning: Characteristic undefined not in required or optional characteristics for service 24a8d81a-3d7b-4965-9086-7edc3ef4fab3. Adding anyway.
Oct 07 18:43:56 Domoticz homebridge[773]: ^ For: Vigilance_Meteo
Oct 07 18:43:56 Domoticz homebridge[773]: Scan this code with your HomeKit App on your iOS device to pair with Homebridge:
Oct 07 18:43:56 Domoticz homebridge[773]: ┌────────────┐
Oct 07 18:43:56 Domoticz homebridge[773]: │ 999-99-999 │
Oct 07 18:43:56 Domoticz homebridge[773]: └────────────┘
Oct 07 18:43:57 Domoticz homebridge[773]: [10/7/2017, 6:43:57 PM] Homebridge is running on port 51826.
Avez-vous déjà rencontré ce problème ? Si oui, comment l'avez vous résolu ?
Par avance merci pour votre aide.
Amitiés
Lal
Lalsacien
Message par Lalsacien » 07 oct. 2017, 20:16
Re Bonjour à tous,
Bon je vais répondre à moi-même à mon défaut.
Une fois le service installé j'ai supprimé ma config dans Maison et appairé à nouveau.
Cela semble aider.
Cordialement
Lal
eric
Message par eric » 18 oct. 2017, 08:17
Salut à tous,
J'ai domoticz (dernière stable) sur un RASPI avec homebridge et le plugin pour la gateway xiaomi.
Tout fonctionne très bien et mes capteurs remontent bien dans l'application 'Maison' d'iOS.
J'ai deux soucis pour lesquels j'aurais besoin d'aide:
1. J'ai remonté tous les accessoires de la passerelle xiaomi mais finalement j'aimerais en supprimer certains mais la seule possibilité que je vois est de supprimer toute la passerelle. Est-il possible de ne supprimer que certains accessoires?
2. Après le setup initial de homebridge j'ai rajouté mon Logitech Harmony Hub mais les actions liées ne remontent pas dans l'application Home au travers de Homebridge. A tout hasard j'ai rebooté le RASPI en me disant que la liste des devices serait peut être rafraichit dans l'appli Home mais ce n'est pas le cas. Y'a t-il une solution pour les faire remonter sans tout supprimer de l'appli Home et résintaller?
Merci pour votre aide!
Eric
eric
Message par eric » 18 oct. 2017, 17:53
Bon désolé je me réponds mais c'est moi qui fait n'importe quoi.
J'avais créé une room ID que j'ai indiqué dans le config.json et j'ai oublié de rajouter mes nouveaux capteurs/actions dans la room ID de domoticz.
Désolé...
Belinux
Message par Belinux » 27 nov. 2017, 23:17
bonjour,
J'ai installé domoticz dernière version sur pi 3 . l'ensemble fonctionne correctement j'ai qlq objet connecté (sation oregon; prises dio, sonos, harmony).
J'ai installe homebridge pour avoir la possibilité de l’intégration dans home kit et utiliser siri pour les commandes. Une fois installé le systeme homebridge a bien fonctionné pendant une 15 de jour et puis la panne .Pourtant lorsque je vérifie le fonctionnement de homebridge sur le pi tout semble normale (via commande pm2 show, pm2 list ).
J'ai redémarrer le système pi et malgré tout rien ne semble fonctionner sur l'iphone les objets sont présents mais avec un triangle signalant un mauvais fonctionnement.
dosi je aller vers une réinstallation complète du système ou y a t il une autre solution
Didier
