Domotique Piscine
Gardaux
Re: Domotique Piscine
Message par Gardaux » 30 avr. 2018, 09:15
le belge a écrit :'soir ,
@aleph0
je viens de m'apercevoir que je ne t'avais pas donné de nouvelles à propos de mon erreur !!
voici mes logs avec le print :
2017-10-24 18:46:00.197 dzVents: 14.2;93;3
2017-10-24 18:46:00.198 Error: EventSystem: in gestion piscine: [string "--[[ Script de gestion de la piscine ..."]:258: attempt to compare nil with number
2017-10-24 18:47:33.995 (RFlink ) Temp (Auriol V2)
2017-10-24 18:48:30.897 (RFlink ) Temp (Auriol V2)
2017-10-24 18:48:43.398 (RFlink ) Temp (chambre Loulou)
2017-10-24 18:49:26.825 (RFlink ) Temp (chambre Loulou)
2017-10-24 18:49:27.722 (RFlink ) Temp (Auriol V2)
2017-10-24 18:49:37.033 User: domoticz initiated a switch command (742/Radio/Set Level)
2017-10-24 18:49:37.166 (virtuel) Light/Switch (Radio)
2017-10-24 18:49:37.255 Executing script: /home/pi/domoticz/scripts/stop_radio.sh
2017-10-24 18:50:10.663 (RFlink ) Temp (chambre Loulou)
2017-10-24 18:50:24.924 (RFlink ) Temp (Auriol V2)
2017-10-24 18:51:21.723 (RFlink ) Temp (Auriol V2)
2017-10-24 18:54:32.682 (RFlink ) Temp (chambre Loulou)
2017-10-24 18:58:00.732 (RFlink ) Temp (Auriol V2)
2017-10-24 18:58:10.869 (RFlink ) Temp (chambre Loulou)
2017-10-24 18:59:54.733 (RFlink ) Temp (Auriol V2)
2017-10-24 19:01:00.245 dzVents: 14.2;93;3
2017-10-24 19:01:00.245 Error: EventSystem: in gestion piscine: [string "--[[ Script de gestion de la piscine ..."]:258: attempt to compare nil with number
2017-10-24 19:01:49.046 (RFlink ) Temp (Auriol V2)
2017-10-24 19:03:42.732 (RFlink ) Temp (Auriol V2)
2017-10-24 19:04:44.158 (RFlink ) Temp (chambre Loulou)
2017-10-24 19:07:38.847 (RFlink ) Temp (chambre Loulou)
2017-10-24 19:12:44.309 (RFlink ) Temp (chambre Loulou)
2017-10-24 19:16:00.071 dzVents: 14.2;93;3
2017-10-24 19:16:00.071 Error: EventSystem: in gestion piscine: [string "--[[ Script de gestion de la piscine ..."]:258: attempt to compare nil with number
2017-10-24 19:19:17.715 (RFlink ) Temp (chambre Loulou)
2017-10-24 19:20:01.161 (RFlink ) Temp (chambre Loulou)
2017-10-24 19:20:45.082 (RFlink ) Temp (chambre Loulou)
la température de l'eau est à 10.94°
la température de l'air est à 14.2°
ce ne serait pas un problème de virgule ??
Mike
As-tu réussi à solutionner ton problème, car je rencontre le même :
2018-04-30 09:01:00.154 Error: EventSystem: in Gestion_Piscine: [string "--[[ Script de gestion de la piscine ..."]:220: attempt to compare number with nil
J'ai ajouté la ligne : un print(otherdevices_svalues[dev_TAir]) entre la ligne val_TAir = tonumber(otherdevices_svalues[dev_TAir]) et if (val_TAir <= 1) and val_PpeFl == "Off" then
Mais ça ne dit rien de plus.
De plus depuis l'ajout du morceau de code capteur texte heure début de filtration et fin de filtration mon compteur conso ne répond plus quand le switch pompe est sur "On".
Les gars, on a perdu quelque chose en route....
Domoticz + Raspberry Pi3 x2 + RFXCOM (IFTTT)
Domoticz + Synology + RFLink
Gardaux
Message par Gardaux » 05 mai 2018, 10:48
Voila j'ai enfin réussi à recoller tous les morceaux du script :
Fonctions :
1. Gestion de la filtration
1.1 Calculer la durée et la période optimale de filtration
1.2 Démarrer / arrêter la filtration
     Si température eau > 12°C, selon planning calculé au dessus
     Sinon, marche si température air <1°C, arrêt si >2°C
1/ Les devices :
- dev_Tair et dev_Teau de type thermomètres, ras
- dev_PpeFl : le switch qui commande la pompe de filtration , de type On/Off
- dev_ModeFl : un interrupteur selecteur pour le mode de filtration. Doit contenir 4 niveaux :
* Off (Caché)
* Manu (Level 10) Dans ce mode, le script fait seulement les calculs de durée et de début, mais ne gère pas la pompe
* Auto HC (Level 20) pour filtration en heures creuses
* Auto HP (Level 30) pour filtration en journée
- dev_HC : Un switch on/off avec planning pour indiquer les heures pleines ou creuses (On=HC, Off=HP)
- dev_cptFl : Un P1 smart counter pour comptabiliser la consommation électrique de la pompe
Le script a été conçu pour qu'on puisse à tout moment prendre la pompe en manuel (pour passer l'aspirateur, nettoyer les filtres, etc) et faire ce qu'on veut (arrêter, démarrer comme on veut) et, lorsqu'on repasse en mode automatique, il reprends la filtration là où elle avait élé laissée. Il faut donc un compteur qui stocke le temps de filtration effectué chaque jour pour pouvoir le comparer au temps calculé à minuit. La version la plus simple aurait été d'accumuler des minutes dans une variable. Mais finalement, la gestion qui consiste plutôt à accumuler des kWh dans un compteur n'est pas beaucoup plus compliquée, et elle donne l'avantage d'avoir un historique de la filtration ainsi que les rapports de coûts de celle-ci. C'est pour ça que j'ai choisi un compteur électrique plutôt qu'un compteur de minutes. En divisant les kWh par la puissance de la pompe, on retrouve la durée de filtration effectuée.
2/ Les variables :
2 variables à définir :
- var_PPStart, de type "Heure" stocke l'heure de début de filtration calculée à minuit
- var_PPDuree, de type "Entier" stocke la durée de filtration calculée, en minutes
3/ Les constantes
Elles servent à calculer la durée de filtration en fonction des caractéristiques du bassin et de la pompe :
- cst_PpeFl_Q Le débit nominal de la pompe de filtration en m3/h
- cst_Pisc_V Le volume du bassin, en m3
- cst_PpeFl_W La puissance électrique de la pompe piscine, pour pouvoir calculer la durée de filtration quotidienne ainsi que la consommation électrique correspondante
- cst_Adj Un coefficient à ajuster en + ou en - pour filtrer plus ou moins longtemps
-- Paramètres
local dbPath      = "/volume1/@appstore/domoticz/var/domoticz.db"
local gst_HorsGel = false                   -- gestion ou non du mode hors gel
local dev_TAir    = "Température"           --"Température Extérieure"  idx 46 -- Température extérieure (nécessaire seulement pour le mode hors gel)
local dev_TEau    = "T° Piscine"            --"Température piscine"     idx 106-- Température eau piscine
local dev_PpeFl   = "Pompe"                 --"Filtration piscine"      idx 110-- Interrupteur de commande de la pompe
local dev_ModeFl  = "Auto_HC/HP"            --"Mode filtration piscine" idx 104-- Selecteur du mode de la pompe (Manu/Auto HC/AutoHP)
local dev_cptFl   = "Conso_Piscine"         --"Consommation Piscine"    idx 109-- Compteur de consommation électrique piscine
local dev_HC      = "Témoin_HC"             --"Heures creuses EDF"      idx 108-- Indicateur d'heure creuses EdF
local tps_Fl      = "Temps filtration"      -- Capteur texte pour afficher le temps de filtration
local rest_Fl     = "Restant filtration"    -- Capteur texte pour afficher le temps restant de filtration
local heure_Fl    = "Debut filtration"      -- Capteur texte pour afficher l'heure de début de filtration
local fin_Fl      = "Fin filtration"      -- Capteur texte pour afficher l'heure de fin de filtration
local var_PPStart = "PpePiscStart"  -- Variable contenant l'heure de départ de la filtration
local var_PPDuree = "PpePiscDuree"  -- Variable contenant la durée de la filtration
-- Réglages du temps de filtration
local cst_PpeFl_Qn=20               -- Débit nominal de la pompe de filtration en m3/h
local cst_Pisc_V  =35               -- volume du bassin, en m3
local cst_Adj     =0.175            -- Coefficient à ajuster en + ou en - pour filtrer plus ou moins longtemps
local cst_PpeFl_W =900              -- Puissance électrique de la pompe piscine
-- Bibliothèque de fonctions
local CmdIdx=1
local debug=1
function round(num, dec)
    if num == 0 then
        return 0
        local mult = 10^(dec or 0)
function os.capture(cmd, raw)
    f:close()
    if raw then return s end
    return s
function UpdateSw(device,commande)
    --Update un switch Domoticz
    commandArray[CmdIdx] = {[device] = commande}
    CmdIdx=CmdIdx+1
function UpdateVar(variable,valeur)
    --Update une variable Domoticz
    commandArray[CmdIdx] = {['Variable:'..variable] = tostring(valeur)}
    CmdIdx=CmdIdx+1
function UpdateDev(device,nvalue,svalues)
    --Met à jour un device numérique Domotica
    commandArray[CmdIdx] = {['UpdateDevice'] = otherdevices_idx[device]..'|'..tostring(nvalue)..'|'..tostring(svalues)}
    CmdIdx=CmdIdx+1
function UpdateP1(device,HC,conso,prod,freq)
    -- Met à jour un P1 smart counter
    -- device : nom du compteur
    -- HC     : "On" si heures creuses, "Off" si heures pleines
    -- conso  : consommation instantannée
    -- prod   : production instantannée
    -- freq   : frequence d'exécution du script (en minutes)
    local u1, u2, p1, p2
    local dbg=0
    u1, u2, p1, p2 = string.match(otherdevices_svalues[device],"(.-);(.-);(.-);(.-);.*")
    -- Utile pour les compteurs nouvellement crées
    u1=u1 or 0
    u2=u2 or 0
    p1=p1 or 0
    p2=p2 or 0
    if dbg == 1 then
        print("Mise à jour de "..tostring(device))
        print("u1 "..tostring(u1))
        print("u2 "..tostring(u2))
        print("p1 "..tostring(p1))
        print("p2 "..tostring(p2))
        print("conso "..tostring(conso))
        print("prod "..tostring(prod))
    if otherdevices[HC] == 'Off' then
        -- svalue=USAGE1;USAGE2;RETURN1;RETURN2;CONS;PROD
        commandArray[CmdIdx] = {['UpdateDevice'] = otherdevices_idx[device]..'|0|'..tostring(u1+conso*freq/60)..';'..tostring(u2)..';'..tostring(p1+prod*freq/60)..';'..tostring(p2)..';'..tostring(conso)..';'..tostring(prod)}
        CmdIdx=CmdIdx+1
        commandArray[CmdIdx] = {['UpdateDevice'] = otherdevices_idx[device]..'|0|'..tostring(u1)..';'..tostring(u2+conso*freq/60)..';'..tostring(p1)..';'..tostring(p2+prod*freq/60)..';'..tostring(conso)..';'..tostring(prod)}
        CmdIdx=CmdIdx+1
function ConsoDev(switch,ConsoMarche,ConsoVeille)
    -- Retourne la consommation d'un appareil commandé
    -- selon qu'il est en marche ou en veille
    if otherdevices[switch] == 'On' then
        return ConsoMarche
        return ConsoVeille
function CalcFiltration()
    --[[ Calcule
    * La durée optimale de filtration en fonction de la Température
    de l'eau, du débit de la pompe et du volume du bassin
    * L'heure de début de la filtration selon qu'on veut filtrer en heure creuses ou pleines
    Utilise les variables globales suivantes
    dev_Teau    : device du thermomètre d'eau
    dev_ModeFl  : le sélecteur de mode de filtration
    cst_PpeFl_Qn: débit nominal de la pompe en m3/h
    cst_Pisc_V : Volume du bassin en m3
    cst_Adj     : Coefficient d'ajustement
    var_PPStart : Nom de la variable qui va stocker l'heure de départ de la filtration
    var_PPDuree : Nom de la vatiable qui va stocker la durée de filtration
    local val_TEau, MidiSol, DebutFiltration, dureeFiltration, HDebFilt
    print("Script Piscine : Calcul de la filtration")
    val_TEau=os.capture('sqlite3 '..dbPath..' "select temp_avg from temperature_calendar where devicerowid='..otherdevices_idx[dev_TEau]..' order by date desc limit 1"')
    val_TEau=round(val_TEau,1)
    print("Température moyenne hier : "..val_TEau.." °C")
    dureeFiltration=round(60*math.max(0,cst_Adj*cst_Pisc_V/cst_PpeFl_Qn*(val_TEau-10)),0) -- Résultat en minutes
    print("Durée de filtration : "..dureeFiltration.." min")
    if otherdevices[dev_ModeFl] == "Auto HC" then
        -- Mode Auto Heures Creuses
        -- On filtre jusqu'à 7h00 si possible (=420 min), et on déborde si nécessaire
        DebutFiltration=math.max(10,420-dureeFiltration)
        -- Mode Auto Heures Pleines ou Manu
        -- On filtre en journée, centré sur le midi solaire
        MidiSol=round((timeofday['SunriseInMinutes']+timeofday['SunsetInMinutes'])/2,0) -- en minutes
        DebutFiltration=round(MidiSol-dureeFiltration/2,0) -- en minutes
    UpdateVar(var_PPStart,HDebFilt)
    UpdateVar(var_PPDuree,dureeFiltration)
function ChkFiltration()
    --[[Gestion de la filtration
    Start / Stop de la pompe
    Demandes de chloration automaique --]]
    -- Mode de la filtration :
    -- Manu / Auto HC / Auto HP
    local PpeDuree, val_TEau, val_PpeFl, MinDuJour, PpeStart, today, PpeFait
    print("Script Piscine : Gestion de la filtration")
    PpeDuree=tonumber(uservariables[var_PPDuree])
    if (otherdevices[dev_ModeFl] ~= "Manu") then
        val_TEau = tonumber(string.match(otherdevices_svalues[dev_TEau],"(%d+.%d*);.*"))
        val_PpeFl=otherdevices[dev_PpeFl]
        if (val_TEau >= 12) then
            -- La témpérature d'eau est >=12°C : on utilise la temporisation
            MinDuJour=60*time.hour+time.min
            PpeStart=tonumber(string.sub(uservariables[var_PPStart],1,2))*60+tonumber(string.sub(uservariables[var_PPStart],4,5))
            -- Calcul de la durée de fonctionnement de la pompe aujourd'hui
            -- Basé sur le compteur de puissance piscine
            today = os.date("%Y-%m-%d")
            PpeFait=os.capture('sqlite3 '..dbPath..' "select sum(value3) from multimeter where devicerowid='..otherdevices_idx[dev_cptFl]..' and Date(date)=\''..today..'\'"')*5/cst_PpeFl_W
            print("Déjà effectué : "..PpeFait.." minutes sur "..PpeDuree)
            -- Calcul du temps restant de filtration
            PpeRest=PpeDuree-PpeFait
            if (PpeRest > 0) then
                print("Temps restant de filtration piscine : "..PpeRest.." minutes ")
                commandArray[#commandArray+1] = {['UpdateDevice'] = otherdevices_idx[rest_Fl]..'|0|'..tonumber(PpeRest)..' min'}
                print("Filtration piscine finie")
                commandArray[#commandArray+1] = {['UpdateDevice'] = otherdevices_idx[rest_Fl]..'|0|'..'Arrêtée'}
                if (MinDuJour >= PpeStart and PpeFait < PpeDuree and val_PpeFl == "Off") then
                    print("Filtration piscine : Démarrage par timer")
                    UpdateSw(dev_PpeFl,'On')
                elseif (PpeFait >= PpeDuree and val_PpeFl == "On") then
                    print("Filtration piscine : Arrêt par timer")
                    UpdateSw(dev_PpeFl,'Off')
            -- Calcul de l'heure de début de filtration
            HDebFilt=os.date("%H:%M", PpeStart*60-3600)
            print("Début de filtration : "..HDebFilt)
            commandArray[#commandArray+1] = {['UpdateDevice'] = otherdevices_idx[heure_Fl]..'|0|'..HDebFilt}
            -- Calcul de l'heure de fin de filtration
            HFinFilt=os.date("%H:%M", ((PpeStart*60-3600)+(PpeDuree*60)))
            print("Fin de la filtration a : "..HFinFilt)
            commandArray[#commandArray+1] = {['UpdateDevice'] = otherdevices_idx[fin_Fl]..'|0|'..HFinFilt}
            if gst_HorsGel then
                --[[ La température de l'eau est <12°C : on utilise la température
                Démarrage si température d'air <= 1
                Arrêt si température d'air >= 1.5 et température eau >= 0.5
                val_Tair = tonumber(otherdevices_svalues[dev_TAir])
                if (val_Tair <= 1) and val_PpeFl == "Off" then
                    print("Filtration piscine : Démarrage par température")
                elseif (val_Tair >= 1.5) and (val_TEau>=0.5) and val_PpeFl == "On" then
                    print("Filtration piscine : Arrêt par température")
        end -- filtration timer/temperature
        print("Mode manu, pas de changement")
    end -- end mode auto/manu
-- Fin bibliothèque de fonctions
time = os.date("*t")
--Calcul de la durée optimale de filtration et de l'heure de démarrage tous le jours à minuit une
if time.hour==0 and time.min ==1 then CalcFiltration() end
-- Marche/Arrêt de la pompe de filtration tous les quart d'heures
if (((time.min-1) % 15)== 0) then ChkFiltration() end
-- Mise à jour du compteur de consommation de la piscine toutes les 5min
if (((time.min-2) % 5)== 0) then
    UpdateP1(dev_cptFl,dev_HC,ConsoDev(dev_PpeFl,cst_PpeFl_W,0),0,5)
:P
miralant
Message par miralant » 15 mai 2018, 13:12
Jeff a écrit :J'ai rajouté des capteurs text dans domoticz et je les ai déclaré au début du script après les "dev" :
Puis ceci après le calcul de la filtration :
--print("Durée de filtration : "..dureeFiltration.." min")
commandArray[#commandArray+1] = {['UpdateDevice'] = otherdevices_idx[tps_Fl]..'|0|'..tonumber(dureeFiltration)..' min'}
Ceci après l'heure de début de filtration :
HDebFilt=os.date("%H:%M", DebutFiltration*60-3600)
--print("Début de filtration : "..HDebFilt)
Et ceci pour calculer le temps restant, en ayant rajouter PpeRest après la déclaration des local dans la fonction :
print("Temps restant de filtration : "..PpeRest.." minutes ")
print("Filtration finie")
Le résultat est celui-ci
Gros déterrage de post :) Je souhaite suivre l'évolution du temps de filtration.
En suivant l'exemple de jeff, j'ai créé un dummy et un créé un virtual sensor de type texte. Ajouté la ligne dans la partie qui calcule la durée de filtration la nuit.
Mon soucis, c'est que le virtual sensor text reste désespérément sur Hello world :(
ou comment faire autrement avec un dispositif qui serait adapté ?
vous avez une idée ?
Gardaux
Message par Gardaux » 17 mai 2018, 06:59
Est-ce que tu as vérifié que ton sensor porte bien le nom de : "Restant filtration" ?
Jeff
Message par Jeff » 17 mai 2018, 21:12
Pourquoi avoir créer un dummy et un seul capteur text !
As tu créé tous les capteurs texte, variable et possèdes tu tous les sondes : extérieure et piscine ?
Version: 4.9700; RFXCOM Rfxtrx433e ext/1007 ; Zwave (Z-stick GEN5, Fibaro...), Zigbee2MQTT.
miralant
Message par miralant » 17 mai 2018, 22:16
Jeff a écrit :Pourquoi avoir créer un dummy et un seul capteur text !
J'en ai créé 1 seul car je n'ai pas besoin des autres données :) du coup, je n'ai évidemment pas mis le code lié aux autres. J'ai aussi mis le bon nom en respectant la case.
Alors pkoi un dummy ? J'avoue que j'ai pas tout bien compris. En général, je créé un dummy puis le capteur dans la foulée. Mais peut être que je me trompe. C'est pas la bonne méthode ? (1 dummy pour chaque capteur virtuel)
Le script de gestion de base de la piscine fonctionne parfaitement donc oui, j'ai bien tout ce qu'il faut.
Gardaux
Message par Gardaux » 01 juin 2018, 07:18
Dans mes logs j'ai une erreur dans le script pour l'heure de démarrage :
2018-06-01 00:01:00.516 Error: EventSystem: Error updating variable PpePiscStart: Not a valid time notation (HH:MM)
Voici le bout de script :
Si vous avez une idée, je suis preneur....
Gardaux
Message par Gardaux » 10 juin 2018, 20:22
Gardaux a écrit :Bonjour,
Personne n'a d'idée ???
aleph0
Message par aleph0 » 10 juin 2018, 20:30
Tu as une erreur sur la mise à jour de l'heure de départ mais tu nous met un extrait de script qui parle de l'heure d'arrêt :-o
Met nous le bon bout de script ainsi que la définition de tes variables pour qu'on puisse t'aider
Gardaux
Message par Gardaux » 15 juin 2018, 08:03
Merci pour ce retour rapide
Effectivement méa culpa :oops:
Mon script
HDebFilt=os.date("%H:%M", (PpeStart*60-3600))
Ma variable
5 PpePiscStart Heure 02:28 2018-05-03 00:01:00
Mon erreur :
Le script complet :
Fonctions :
-- Paramètres
local dbPath      = "/home/pi/domoticz/domoticz.db"
local CmdIdx=1
local debug=1
    if num == 0 then
        return 0
    f:close()
    return s
    CmdIdx=CmdIdx+1
    CmdIdx=CmdIdx+1
    CmdIdx=CmdIdx+1
    local dbg=0
    u1=u1 or 0
    u2=u2 or 0
    p1=p1 or 0
    p2=p2 or 0
    if dbg == 1 then
        CmdIdx=CmdIdx+1
        CmdIdx=CmdIdx+1
        return ConsoMarche
        return ConsoVeille
    --[[ Calcule
            if gst_HorsGel then
-- Calcul de la durée optimale de filtration et de l'heure de démarrage tous le jours à minuit une
Merci :)
