Cozytouch Thermor
elgarne
Re: Cozytouch Thermor
Message par elgarne »
Dutchandre a écrit :
22 janv. 2020, 15:53
Where came the idea from that a heatpump can do this at high temperatures?
It is a heat pump designed to produce enough water at 55° for that house size.
This one delivers 16kW of heat in water of 35C when outside is 7 degrees.
When the water is 55 degrees and outside is -7 degrees then the power is reduced to only 10,9kW.
That does not make sense no? Why should it reduce the power when it's colder outside and that it should produce higher temperature water?
Did you check whether your current heating supply can heat your home with water of 55 degrees and how long that takes?
My current heater uses oil and it's able to do it.
Also you need a big buffer (water tank) to get the heatpump work more stable and even more when you want it to make domestic hot water.
That last one means that the heatpump cannot heat the radiators all the time because it also heats a boiler.
The one we plan to use does not produce domestic hot water.
That's how we do it in my country and we discourage heatpumps when there is no low temperature floor heating available or at least low temperature radiators.
We don't have any of them.
I suppose the heatpump would have to work full power for a very long time to get this done and that could get expensive..
Maybe it's a bad idea to use a heatpump in our case indeed. I started looking for gas heater too.
Thanks for all the time you spend here helping me.
Dutchandre
Message par Dutchandre »
It would be a pitty when you invest this much money and you get high electricity bills in return :|
On the dutch forum we advise to get better isolation of floors, walls and roof before looking for a heatpump.
Lowering the demand of your home pays off whatever heating source you have.
16kW would be enormous here, most of the members have 5 to 9kW heatpumps and floor heating.
A heatpump gets heat from the air outside, how colder the air is how more energy extracting the heat will cost.
I am heating with airco's (inverter type), before that I had traditional radiators with gas central heating.
The radiators are still there and I use them sometimes with my heatpump boiler that has an extra spiral in it.
This is only for rooms where is no airco.
macieiks
Message par macieiks »
Hi,
I have four Atlantic Solius WiFi for heating rooms and one Vertigo Wi-Fi boiler for heating water. At this moment it is being controlled automatically by Cozytouch app on my iOS and Android phone. App is working perfect on Android phone, however on iOS sometimes it is working, sometimes not. Ideally, it would be cool to control through Domoticz and I see that this script is solution for that, since flat is controlled by iPad.
I have followed all the steps described at github webpage:
1. Domoticz IP and port has been provided,
2. Cozy username / password has been provided,
3. No authentication has been adjusted to meet apartment network subnet,
4. Library has been installed
I ran the test once. I translated output to english and apparently there is successful connectivity with Cozytouch server. It created the entity "Cozytouch_V4" in hardware page, but there are not any new devices created. Could anyone please take a look? Appreciate help.
Logs from Raspberry:
I am pasting output with debug=2 mode, so it has a lot of lines :) I guess we need to provide new "class" for my unrecognised devices? Could someone help me with that, since script is in French? :)
https://pastebin.com/HkiyEhbj
Domoticz log:
2020-01-26 07:25:05.857 Status: Incoming connection from: 192.168.2.8
2020-01-26 07:25:05.891 Status: Creation nouvelle configuration ...
2020-01-26 07:25:10.852 Status: Cozytouch : Recherche des devices connectes ...
2020-01-26 07:25:10.876 Status: Cozytouch : Device avec classe internal:UPodComponent inconnu
2020-01-26 07:25:10.898 Status: Cozytouch : Device avec classe internal:UPodNetWorkComponent inconnu
2020-01-26 07:25:10.921 Status: Cozytouch : Device avec classe internal:UPodComponent inconnu
2020-01-26 07:25:10.944 Status: Cozytouch : Device avec classe internal:UPodNetWorkComponent inconnu
2020-01-26 07:25:10.967 Status: Cozytouch : Device avec classe internal:UPodComponent inconnu
2020-01-26 07:25:10.989 Status: Cozytouch : Device avec classe internal:UPodNetWorkComponent inconnu
2020-01-26 07:25:11.011 Status: Cozytouch : Device avec classe internal:UPodComponent inconnu
2020-01-26 07:25:11.034 Status: Cozytouch : Device avec classe internal:UPodNetWorkComponent inconnu
2020-01-26 07:25:11.056 Status: Cozytouch : Device avec classe internal:UPodComponent inconnu
2020-01-26 07:25:11.078 Status: Cozytouch : Device avec classe internal:UPodNetWorkComponent inconnu
2020-01-26 07:25:11.101 Status: Cozytouch : Device avec classe modbuslink:AtlanticElectricalHeaterWithAdjustableTemperatureSetpointMBLComponent inconnu
2020-01-26 07:25:11.124 Status: Cozytouch : Device avec classe modbuslink:TemperatureInCelciusMBLSystemDeviceSensor inconnu
2020-01-26 07:25:11.147 Status: Cozytouch : Device avec classe core:OccupancySensor inconnu
2020-01-26 07:25:11.171 Status: Cozytouch : Device avec classe modbuslink:CumulatedElectricalEnergyConsumptionMBLSystemDeviceSensor inconnu
2020-01-26 07:25:11.193 Status: Cozytouch : Device avec classe modbuslink:AtlanticElectricalHeaterWithAdjustableTemperatureSetpointMBLComponent inconnu
2020-01-26 07:25:11.216 Status: Cozytouch : Device avec classe modbuslink:TemperatureInCelciusMBLSystemDeviceSensor inconnu
2020-01-26 07:25:11.238 Status: Cozytouch : Device avec classe core:OccupancySensor inconnu
2020-01-26 07:25:11.258 Status: Cozytouch : Device avec classe modbuslink:CumulatedElectricalEnergyConsumptionMBLSystemDeviceSensor inconnu
2020-01-26 07:25:11.277 Status: Cozytouch : Device avec classe modbuslink:AtlanticElectricalHeaterWithAdjustableTemperatureSetpointMBLComponent inconnu
2020-01-26 07:25:11.296 Status: Cozytouch : Device avec classe modbuslink:TemperatureInCelciusMBLSystemDeviceSensor inconnu
2020-01-26 07:25:11.315 Status: Cozytouch : Device avec classe core:OccupancySensor inconnu
2020-01-26 07:25:11.334 Status: Cozytouch : Device avec classe modbuslink:CumulatedElectricalEnergyConsumptionMBLSystemDeviceSensor inconnu
2020-01-26 07:25:11.353 Status: Cozytouch : Device avec classe modbuslink:AtlanticElectricalHeaterWithAdjustableTemperatureSetpointMBLComponent inconnu
2020-01-26 07:25:11.373 Status: Cozytouch : Device avec classe modbuslink:TemperatureInCelciusMBLSystemDeviceSensor inconnu
2020-01-26 07:25:11.392 Status: Cozytouch : Device avec classe core:OccupancySensor inconnu
2020-01-26 07:25:11.411 Status: Cozytouch : Device avec classe modbuslink:CumulatedElectricalEnergyConsumptionMBLSystemDeviceSensor inconnu
2020-01-26 07:25:11.430 Status: Cozytouch : Device avec classe modbuslink:AtlanticDomesticHotWaterProductionMBLComponent inconnu
2020-01-26 07:25:11.450 Status: Cozytouch : Device avec classe modbuslink:DHWCumulatedElectricalEnergyConsumptionMBLSystemDeviceSensor inconnu
Thanks,
Maciek
Obone
Message par Obone »
macieiks a écrit :
29 janv. 2020, 18:53
Thanks,
Maciek
Hi, the script doesnt know your devices.
can you send me a copy of your JSON data in mail or PM ? (with debug=2)
macieiks
Obone a écrit :
04 févr. 2020, 08:45
Thanks,
Maciek
Hi,
Please see my last post, I have attached debug=2 on „pastebin” website :)
Appreciate your help.
Jeff
Message par Jeff »
Je suis possesseur d'une PAC atlantic Alféa Extensa Duo A.I et à mon retour anticipé de vacances, la maison était à 14°C.
Je me suis dit, il faut absolument domotiser cette PAC. J'ai alors découvert Cozytouch que je me suis empressé d'acheter ce soir.
Ayant découvert ce script hier à mon grand bonheur : bravo à toi Odone, gros travail :D
Je viens de créer mon compte, j'ai 2 thermostat, l'application fonctionne très bien mais concernant le script, il ne semble pas reconnaitre ce matériel. Il crée bien le dummy Cosytouch_V4 mais aucun device créé !
@Obone puis-je t'envoyer les logs pour ajouter le matériel manquant ?
Version: 4.9700; RFXCOM Rfxtrx433e ext/1007 ; Zwave (Z-stick GEN5, Fibaro...), Zigbee2MQTT.
Obone
Message par Obone »
Jeff a écrit :
24 févr. 2020, 21:09
Hello, oui tu peux m'envoyer cela en MP. Vous êtes nombreux avec des PAC Alfea, ca fait pas mal de demande pour ajouter ce produit. J'essaye d'avancer dessus au mieux, j'ai pas bcp de temps à y consacrer en ce moment.
jojomul1983
Message par jojomul1983 »
Juste pour infos, si quelqu'un ne l'avait pas vu, Atlantic Cozytouch est compatible avec google assistant.
Hélas pour moi, il n'y a que certains radiateurs connectés.
https://www.atlantic.fr/Piloter-les-app ... ant-Google
Jeff
Message par Jeff »
Obone a écrit :
29 févr. 2020, 22:45
@Obone, j'ai enfin pris le temps de générer le log, j'ai voulu te l'envoyer par MP mais la taille des logs et l'envoie de pièce jointe ne marche pas.
Donc voici les logs, une partie car je n'ai pas le début, le tampon du terminal étant trop petit. Je n'ai pas réussi à générer un fichier de log à partir du script.
Merci pour ton aide.
log_cozytouch_alfea_extensa_duo.zip
(4.86 Kio) Téléchargé 3 fois
FantoM
Message par FantoM »
J'ai pris le temps de faire un peu de lecture, et je suis content d'avoir peut être trouvé une solution sympathique à ajouter à Domoticz pour gérer mon planning de chauffage. Malheureusement, j'ai peur de ne pas avoir tout compris :roll:
Je suis débutant (première source possible de mon problème)
Je possède :
- un CozyTouch Thermor (deuxième source possible mon problème, car je ne sais pas si c'est le même cloud que Atlantic)
- deux interfaces fil-pilote
J'ai récupérer le cozytouch.py et j'ai suivi le GitHub pour modifier les paramètres serveur de Domoticz et les paramètres de connexion au compte "Thermor", ainsi que pour ajouter la ligne dans le CronTab.
C'est là que je bloque ! J'ai cru comprendre que les éléments doivent apparaître tout seul dans Domoticz, mais je ne vois rien. J'ai voulu essayer de créer "le log", mais je n'ai pas trop compris la procédure à utiliser hormis le fait de changer la valeur "debug".
Du coup, comment dois-je procéder pour vous transmettre des infos utilisables ?!
A bientôt.
