Zigate Beta - 4.1
Wolfen38
Re: Zigate Beta - 4.1
Message par Wolfen38 » 07 févr. 2019, 20:37
Ce soir, j'essaie de ré appairer mon capteur de porte, et j'ai ca en log
2019-02-07 20:35:56.901 Status: (Zigate) [0] NEW OBJECT: c84a Device Annouce IEEE: 00158d0001d87113
2019-02-07 20:36:00.562 Status: (Zigate) [0] NEW OBJECT: c84a Model Name: {}
2019-02-07 20:36:05.552 Status: (Zigate) [0] NEW OBJECT: c84a Model Name: {}
2019-02-07 20:36:10.571 Status: (Zigate) [0] NEW OBJECT: c84a Model Name: {}
2019-02-07 20:36:10.571 Status: (Zigate) [0] NEW OBJECT: c84a TimeOut in 0045 restarting at 0x004d
2019-02-07 20:36:10.572 Status: (Zigate) [0] NEW OBJECT: c84a Request Model Name
2019-02-07 20:36:15.555 Status: (Zigate) [1] NEW OBJECT: c84a Model Name: {}
2019-02-07 20:36:15.556 Status: (Zigate) [1] NEW OBJECT: c84a Model Name: {}
2019-02-07 20:36:20.578 Status: (Zigate) [1] NEW OBJECT: c84a Model Name: {}
2019-02-07 20:36:25.549 Status: (Zigate) [1] NEW OBJECT: c84a Model Name: {}
2019-02-07 20:36:25.549 Status: (Zigate) [1] NEW OBJECT: c84a TimeOut in 0045 restarting at 0x004d
2019-02-07 20:36:25.549 Status: (Zigate) [1] NEW OBJECT: c84a Request Model Name
2019-02-07 20:36:45.562 Status: (Zigate) [3] NEW OBJECT: c84a Not able to get all needed attributes on time
et il n'apparait pas dans les nouveaux devices de dz.
Message par pipiche » 09 févr. 2019, 21:25
As-tu joué avec les paramètres dans PluginConf.txt ? Peux-tu le copier ici ?
Message par deennoo » 10 févr. 2019, 01:37
idem ici avec un bouton aqara premiere generation
'channel':'16',
'self.eraseZigatePDM':'0',
'vibrationAqarasensitivity':'medium',
'resetMotiondelay':'5',
'enablegroupmanagement':'1',
'allowRemoveZigateDevice':'1',
'allowStoreDiscoveryFrames':'0',
'logLQI':'3600',
'logFORMAT':'0'
dans les logs
2019-02-10 01:36:59.120 Error: (Zigate) 'onHeartbeat' failed 'KeyError'.
2019-02-10 01:36:59.120 Error: (Zigate) ----> Line 490 in '/home/nico/domoticz/plugins/Domoticz-Zigate/plugin.py', function onHeartbeat
2019-02-10 01:36:59.120 Error: (Zigate) ----> Line 368 in '/home/nico/domoticz/plugins/Domoticz-Zigate/plugin.py', function onHeartbeat
2019-02-10 01:36:59.120 Error: (Zigate) ----> Line 352 in '/home/nico/domoticz/plugins/Domoticz-Zigate/Modules/heartbeat.py', function processListOfDevices
2019-02-10 01:36:59.120 Error: (Zigate) ----> Line 271 in '/home/nico/domoticz/plugins/Domoticz-Zigate/Modules/heartbeat.py', function processNotinDBDevices
2019-02-10 01:36:59.120 Error: (Zigate) ----> Line 83 in '/home/nico/domoticz/plugins/Domoticz-Zigate/Modules/domoticz.py', function CreateDomoDevice
2019-02-10 01:36:59.120 Error: (Zigate) ----> Line 1177 in '/home/nico/domoticz/plugins/Domoticz-Zigate/Modules/domoticz.py', function GetType
Message par pipiche » 10 févr. 2019, 11:59
C'est lié au plugin (Domoticz n'a rien a voir la dessus).
Je maintiens le plugin Zigate sur mon temps libre .
benp
Message par benp » 09 mars 2019, 19:34
Je viens de migrer en 4.1 depuis 4.08 en faisant:
git checkout beta // will move you to the beta channel
git pull
J'ai des erreurs dans mon log et plus moyen de contrôler mes dispositifs (2 lampes seulement).
Est-ce-que j'ai une solution autre que remettre à zero la zigate pour retomber sur mes pieds?
domoticz 4.97
firmware 3.0f
 2019-03-09 19:24:35.518 Error: (Zig) checkListOfDevice2Devices - veilleuse2 - 000b57fffe238bf1 not found in Plugin Database
2019-03-09 19:24:35.518 Error: (Zig) checkListOfDevice2Devices - Hue - 0017880102c47826 not found in Plugin Database
2019-03-09 19:24:36.076 Status: (Zig) Number of devices recently active in Zigate = 1
2019-03-09 19:24:44.918 Status: (Zig) Plugin with Zigate firmware 030f correctly initialized
2019-03-09 19:24:44.919 Status: (Zig) [1] NEW OBJECT: a52f Model Name: TRADFRI bulb E14 W op/ch 400lm
2019-03-09 19:24:44.921 Error: (Zig) processNotinDBDevices - Devices already exist. veilleuse with {'Heartbeat': '9', 'Version': '3', 'NbEp': '1', 'Battery': {}, 'HW Version': '1', 'ReadAttributes': {'TimeStamps': {'01-0000': 1552155704}, 'Ep': {'01': {'0000': {'0001': '00', '0003': '00', '0004': '00', '0000': '00', '0005': '00', '0007': '00', '0015': '86', '000f': '86', '0010': '86', '0006': '00', '0002': '00', '000a': '00'}}}}, 'Status': '8043', 'IEEE': '000b57fffe8be6bb', 'ConfigureReporting': {'TimeStamps': {'01-0b05': 0, '01-1000': 0, '01-0003': 0, '01-0006': 0, '01-0008': 1552155714, '01-0005': 0, '01-0004': 0}, 'Ep': {'01': {'0b05': '', '0005': {}, '0003': {}, '0008': '00', '1000': {}, '0004': {}, '0006': {}}}}, 'Type': '', 'App Version': '17', 'Manufacturer': 'IKEA of Sweden', 'RIA': '1', 'Stamp': {'MsgType': '8120', 'Time': '2019-03-09 19:21:59'}, 'RSSI': 52, 'Model': 'TRADFRI bulb E14 W op/ch 400lm', 'MacCapa': '8e', 'ZDeviceID': '0100', 'ProfileID': 'c05e', 'SQN': {}, 'Ep': {'01': {'0b05': {}, '0005': {}, '0003': {}, '0008': {}, '1000': {}, '0004': {}, '0006': {}, '0000': {}, 'Type': 'LvlControl'}}, 'Stack Version': '87'}
Domoticz 4.10549/ Plugin Zigate 4.1 beta/ Zigate Firmware 3.0f
Message par pipiche » 09 mars 2019, 19:54
As-tu suivi les indications qui étaient données dans le fichier 00-UPGRADE-FROM-STABLE-4.0
benp
Message par benp » 09 mars 2019, 20:13
Non.
J'ai migré DeviceList-xx.txt dans Data et tout est rentré dans l'ordre.
benp
Message par benp » 10 mars 2019, 13:36
Je poursuis mon post de 4.0.0
benp a écrit :
08 mars 2019, 20:29
Je suis toujours dans ma quête de la mise à jour du last update avec le device announce.
pipiche a écrit :
08 mars 2019, 20:31
Voir la version pre-4.1 ou c’est en place
J'ai pas trouvé comment faire. Avec la config par défaut: pas de mise à jour de l'heure par le device announce sur tradfri ou hue.
Je soupçonne que c'est la ligne du release note:
[Technical] - if allowed rebind_clusters when receiving a Device Annoucement
Mais j'ai pas trouvé comment "allowed" rebind_clusters dans DeviceConf ou ailleurs
Message par pipiche » 10 mars 2019, 15:29
Je ne comprends pas la question ? C'est quoi le problème ?
Pour ce qui est des paramètres l'ensemble est documenté sur le wiki
https://github.com/pipiche38/Domoticz-Z ... onf.txt.md
