Zigate + Synology en panne
mick_ban
Message par mick_ban »
Depuis hier plus rien ne marche , enfin presque...
J'ai 6 sondes de temperature Xiaomi qui gerent les radiateurs par intermédiaire de Domoticz.
Mais j'ai plus que 3 sondes qui s'actualise et aucune prise.
De plus je gere aussi l'ouverture du cabanon , et donc impossible de l'ouvrir.
Qui a une idee du probleme?
J'ai tenté de reconnecter un capteur , Zigate le trouve mais toujours aucune actualisation.Je l'ai donc supprimé pour le re-creer mais impossible.
J'ai plusieurs erreurs:
2019-11-04 21:14:04.820 Error: (Zigate) ATTENTION: the WebServer part is not supported with this version of Domoticz. Please upgrade to a version greater than 4.10901
    2019-11-04 21:35:34.489 Status: (Zigate) [3] NEW OBJECT: 9727 TimeOut in 0045 restarting at 0x004d
    2019-11-04 21:35:34.490 Status: (Zigate) [3] NEW OBJECT: 9727 Request Model Name
    2019-11-04 21:38:29.946 Status: (Zigate) Network Energy Level Report: 0000
    2019-11-04 21:38:29.946 Status: (Zigate) -----------------------------------------------
    2019-11-04 21:38:29.946 Status: (Zigate) router <- nwkid Tx Failure 11 15 19 20 25 26
    2019-11-04 21:38:29.946 Status: (Zigate) 0000 <- 8755 None None 0 0 0 0 0 0
    2019-11-04 21:38:29.946 Status: (Zigate) 0000 <- e419 None None 0 0 0 0 0 0
    2019-11-04 21:38:29.947 Status: (Zigate) 0000 <- bba5 None None 0 0 0 0 0 0
    2019-11-04 21:38:29.947 Status: (Zigate) 0000 <- 0bef None None 0 0 0 0 0 0
    2019-11-04 21:38:29.947 Status: (Zigate) 0000 <- a819 None None 0 0 0 0 0 0
    2019-11-04 21:38:29.947 Status: (Zigate) 0000 <- 80f2 None None 0 0 0 0 0 0
    2019-11-04 21:38:29.947 Status: (Zigate) 0000 <- 6ea6 None None 0 0 0 0 0 0
    2019-11-04 21:38:29.947 Status: (Zigate) 0000 <- 4db2 None None 0 0 0 0 0 0
    2019-11-04 21:38:46.556 Status: Incoming connection from: 192.168.0.254
    2019-11-04 21:38:46.911 Status: Incoming connection from: 192.168.0.254
    2019-11-04 21:38:47.340 Status: Incoming connection from: 192.168.0.254
    2019-11-04 21:38:49.921 Status: User: Famille initiated a switch command (35/Ouvrir garage/On)
    2019-11-04 21:39:15.527 Status: User: Famille initiated a switch command (36/Fermer Garage/On)
    2019-11-04 21:40:17.017 Status: Incoming connection from: 192.168.0.254
    2019-11-04 21:40:17.307 Status: Incoming connection from: 192.168.0.254
    2019-11-04 21:41:25.395 Status: (Zigate) Network Topology report
    2019-11-04 21:41:25.395 Status: (Zigate) ------------------------------------------------------------------------------------------
    2019-11-04 21:41:25.395 Status: (Zigate) Node Node Relation Type Deepth LQI Rx-Idle
    2019-11-04 21:41:25.395 Status: (Zigate) 8755 - - - - - - TimedOut
    2019-11-04 21:41:25.395 Status: (Zigate) 0000 a3c0 Child End Device 1 136 Rx-Off
    2019-11-04 21:41:25.395 Status: (Zigate) 0000 80f2 Sibling Router 0 48 Rx-On
    2019-11-04 21:41:25.395 Status: (Zigate) 0000 bba5 Sibling Router 0 84 Rx-On
    2019-11-04 21:41:25.396 Status: (Zigate) 0000 517d Child End Device 1 177 Rx-Off
    2019-11-04 21:41:25.396 Status: (Zigate) 0000 11f4 Child End Device 1 109 Rx-Off
    2019-11-04 21:41:25.396 Status: (Zigate) 0000 996c Child End Device 1 133 Rx-Off
    2019-11-04 21:41:25.396 Status: (Zigate) e419 - - - - - - TimedOut
    2019-11-04 21:41:25.396 Status: (Zigate) bba5 - - - - - - TimedOut
    2019-11-04 21:41:25.396 Status: (Zigate) 0bef - - - - - - TimedOut
    2019-11-04 21:41:25.396 Status: (Zigate) a819 - - - - - - TimedOut
    2019-11-04 21:41:25.396 Status: (Zigate) 80f2 - - - - - - TimedOut
    2019-11-04 21:41:25.396 Status: (Zigate) 6ea6 - - - - - - TimedOut
    2019-11-04 21:41:25.396 Status: (Zigate) 4db2 - - - - - - TimedOut
    2019-11-04 21:41:25.396 Status: (Zigate) --
Re: Zigate + Synology en panne
Je ne vois pas réellement d’erreur, car cela manque de contexte.
Il y en a bien une qui vraisemblablement correspond à un appairage qui ne se fait , mais comme il n’y a qu’un extrait c’est assez difficile.
Depuis combien de temps ton système est-il installé, est-ce que quelque chose a été fait ? Arrêt, mise à jour , coupure de courant...,
Peux-tu :
- mettre le fichier Data/DeviceList-xx.txt ou XX est le numéro HardwareId du plugin dans Domoticz
- mettre plutôt un log total plutôt que des extraits
Pour tes capteurs Xiaomi, il faudrait mettre le plugin en mode appairage et refaire L’appairage pour qu’ils reviennent dans le réseau.
Je maintiens le plugin Zigate sur mon temps libre .
mick_ban
Pour le contexte:
Zigate installé sur un NAS Synology depuis 1 ou 2 mois.
Jusqu'a maintenant ca fonctionnait parfaitement.Capteur Xiaomi pour chaque piece plus prise Xiaomi derriere chaque radiateur.J'ai egalement un volet roulant qui me ferme le cabanon commandé par un inter double Xiaomi et un bouton Xiaomi dans la maison.
Tout fonctionnait bien y compris depuis android.
La semaine dernière j'ai rajouté une ampoule Tradfri ainsi qu'un bouton pour le commander.Samedi j'ai rajouté un 2eme ampoule/bouton.Tout fonctionnait.
Mais depuis la nuit de samedi a dimanche 3 des 6 capteurs de temperature n'emette plus et impossible de commander les prises (domoticz envoie bien la commande mais sans resultat).
J'ai tenté de reappairer un capteur ca fonctionne mais toujours pas de mise a jour de la temperature.J'ai supprimé ce capteur pour le reappairer :impossible (erreur ci dessus).
J'ai supprimer tous les element Tradfri au cas ou : RAS.
Ou trouver le fichier Data/DeviceList-xx.txt?
Voila le log apres redemarrage:
Domoticz
V4.10717
2019-11-05 10:17:50.720 Status: Domoticz V4.10717 (c)2012-2019 GizMoCuz
2019-11-05 10:17:50.740 Status: Build Hash: b38b49e-modified, Date: 2019-05-09 13:04:08
2019-11-05 10:17:50.740 Status: Startup Path: /usr/local/domoticz/
2019-11-05 10:17:51.234 Sunrise: 07:46:00 SunSet: 17:46:00
2019-11-05 10:17:51.234 Day length: 10:01:00 Sun at south: 12:46:00
2019-11-05 10:17:51.234 Civil twilight start: 07:15:00 Civil twilight end: 18:17:00
2019-11-05 10:17:51.235 Nautical twilight start: 06:40:00 Nautical twilight end: 18:52:00
2019-11-05 10:17:51.235 Astronomical twilight start: 06:06:00 Astronomical twilight end: 19:26:00
2019-11-05 10:17:52.255 Active notification Subsystems: (0/13)
2019-11-05 10:17:52.417 Starting shared server on: 0.0.0.0:6144
2019-11-05 10:17:52.238 Status: PluginSystem: Started, Python version '3.5.1'.
2019-11-05 10:17:52.370 Status: WebServer(HTTP) started on address: 0.0.0.0 with port 8084
2019-11-05 10:17:52.396 Status: WebServer(SSL) started on address: 0.0.0.0 with port 8443
2019-11-05 10:17:52.421 Status: TCPServer: shared server started...
2019-11-05 10:17:52.433 Status: RxQueue: queue worker started...
2019-11-05 10:17:54.883 Status: (Zigate) Started.
2019-11-05 10:17:54.887 Status: XiaomiGateway (ID=4): Delaying worker startup...
2019-11-05 10:17:59.887 Status: XiaomiGateway (ID=4): Selected as main Gateway
2019-11-05 10:17:59.888 Status: XiaomiGateway (ID=4): Worker started...
2019-11-05 10:17:59.888 Status: XiaomiGateway (ID=4): Using 192.168.0.253 for local IP address.
2019-11-05 10:17:59.889 Status: EventSystem: reset all events...
2019-11-05 10:17:59.891 Status: PluginSystem: Entering work loop.
2019-11-05 10:17:59.913 Status: EventSystem: reset all device statuses...
2019-11-05 10:18:00.020 (Xiaomi Gateway) Color Switch (Xiaomi RGB Gateway (192.168.0.17))
2019-11-05 10:18:00.014 Status: XiaomiGateway: RGB Gateway Detected
2019-11-05 10:18:02.145 (Zigate) Debug: 0
2019-11-05 10:18:02.046 Status: (Zigate) Initialized version 4.5, author 'zaraki673 pipiche38'
2019-11-05 10:18:02.054 Status: (Zigate) Entering work loop.
2019-11-05 10:18:02.145 Status: (Zigate) Zigate plugin stable-4.5.4 started
2019-11-05 10:18:02.147 Status: (Zigate) Python Version - 3.5.1 (default, Jan 29 2018, 14:18:59)
2019-11-05 10:18:02.147 [GCC 4.9.3 20150311 (prerelease)]
2019-11-05 10:18:02.147 Status: (Zigate) Switching Heartbeat to 5 s interval
2019-11-05 10:18:02.148 Status: (Zigate) DomoticzVersion: 4.10717
2019-11-05 10:18:02.148 Status: (Zigate) DomoticzHash: b38b49e-modified
2019-11-05 10:18:02.148 Status: (Zigate) DomoticzBuildTime: 2019-05-09 13:04:08
2019-11-05 10:18:02.148 Status: (Zigate) load PluginConf
2019-11-05 10:18:02.161 Status: (Zigate) pluginHome set to /usr/local/domoticz/var/plugins/Domoticz-Zigate/
2019-11-05 10:18:02.161 Status: (Zigate) pluginConfig set to /usr/local/domoticz/var/plugins/Domoticz-Zigate/Conf/
2019-11-05 10:18:02.162 Status: (Zigate) pluginData set to /usr/local/domoticz/var/plugins/Domoticz-Zigate/Data/
2019-11-05 10:18:02.162 Status: (Zigate) pluginWWW set to /usr/local/domoticz/var/plugins/Domoticz-Zigate/www/
2019-11-05 10:18:02.162 Status: (Zigate) pluginOTAFirmware set to /usr/local/domoticz/var/plugins/Domoticz-Zigate/OTAFirmware/
2019-11-05 10:18:02.162 Status: (Zigate) homedirectory set to /usr/local/domoticz/var/plugins/Domoticz-Zigate/
2019-11-05 10:18:02.162 Status: (Zigate) filename set to /usr/local/domoticz/var/plugins/Domoticz-Zigate/Conf/PluginConf-02.json
2019-11-05 10:18:02.162 Status: (Zigate) pluginReports set to /usr/local/domoticz/var/plugins/Domoticz-Zigate/Reports/
2019-11-05 10:18:02.162 Status: (Zigate) Opening DomoticzDB in raw
2019-11-05 10:18:02.180 Status: (Zigate) Plugin Database: DeviceList-2.txt
2019-11-05 10:18:02.249 Status: (Zigate) DeviceConf loaded
2019-11-05 10:18:02.251 Status: (Zigate) load ListOfDevice
2019-11-05 10:18:02.470 Status: (Zigate) Not Loading 2d60 as Status: UNKNOW
2019-11-05 10:18:02.478 Status: (Zigate) Not Loading 8511 as Status: UNKNOW
2019-11-05 10:18:02.499 Status: (Zigate) Not Loading 2aea as Status: UNKNOW
2019-11-05 10:18:02.669 Status: (Zigate) Not Loading 9850 as Status: UNKNOW
2019-11-05 10:18:02.670 Status: (Zigate) Entries loaded from /usr/local/domoticz/var/plugins/Domoticz-Zigate/Data/DeviceList-2.txt : 18
2019-11-05 10:18:02.690 Status: (Zigate) Transport mode: USB
2019-11-05 10:18:02.690 Status: (Zigate) Connection Name: Zigate, Transport: Serial, Address: /dev/ttyUSB0
2019-11-05 10:18:03.070 (Zigate) setTimeServer - Setting UTC Time to : 626264283
2019-11-05 10:18:03.092 (Xiaomi Gateway) Color Switch (Xiaomi RGB Gateway (192.168.0.17))
2019-11-05 10:18:03.095 (Xiaomi Gateway) Lux (Xiaomi Gateway Lux)
2019-11-05 10:18:03.487 (Zigate) Permit Join status: 01
2019-11-05 10:18:03.488 (Zigate) ---> self.permitTojoin['Starttime']: 1572945483
2019-11-05 10:18:03.488 (Zigate) ---> Current time : 1572945483
2019-11-05 10:18:03.488 (Zigate) ---> self.Ping['Permit'] (prev) : None
2019-11-05 10:18:03.488 (Zigate) ---> self.Ping['Permit'] (new ) : On
2019-11-05 10:18:03.058 Status: Python EventSystem: Initalizing event module.
2019-11-05 10:18:03.065 Status: EventSystem: Queue thread started...
2019-11-05 10:18:03.067 Status: EventSystem: Started
2019-11-05 10:18:03.069 Status: (Zigate) Zigate set Time Server
2019-11-05 10:18:03.070 Status: (Zigate) Configure Permit To Join
2019-11-05 10:18:03.070 Status: (Zigate) Request Accepting new Hardware for 254 seconds
2019-11-05 10:18:03.070 Status: (Zigate) Trigger a Topology Scan
2019-11-05 10:18:03.071 Status: (Zigate) Trigger a Energy Level Scan
2019-11-05 10:18:03.177 Status: (Zigate) Major Version Num: 0003
2019-11-05 10:18:03.177 Status: (Zigate) Installer Version Number: 031a
2019-11-05 10:18:03.488 Status: (Zigate) Accepting new Hardware: On
2019-11-05 10:18:03.596 Status: (Zigate) Zigate addresses ieee: 00158d0001c5e89b , short addr: 0000
2019-11-05 10:18:03.596 Status: (Zigate) Network state UP, PANID: 9d4f extPANID: 0x5d2971dc26d34b64 Channel: 11
2019-11-05 10:18:03.711 Status: (Zigate) Number of devices recently active in Zigate = 5
2019-11-05 10:18:12.222 Status: (Zigate) Zigate set to Certification : CE
2019-11-05 10:18:12.223 Status: (Zigate) Start Web Server connection
2019-11-05 10:18:12.225 Status: (Zigate) Web backend for Web User Interface started on port: 9440
2019-11-05 10:18:12.225 Status: (Zigate) Plugin with Zigate firmware 031a correctly initialized
2019-11-05 10:18:12.222 Error: (Zigate) ATTENTION: the WebServer part is not supported with this version of Domoticz. Please upgrade to a version greater than 4.10901
2019-11-05 10:18:13.355 (Zigate) TxPower set to: 00
2019-11-05 10:18:13.141 Status: (Zigate) checkPluginVersion - Upgrade available: 4.5.6
2019-11-05 10:18:13.142 Status: (Zigate) There is a newer plugin version available on gitHub
Wolfen38
Message par Wolfen38 »
Le fichier que demande pipiche est dans le répertoire data.
Moi j'ai le même truc dans un inter de volet. Le widget dans dz fonctionne mais pas de retour d'état
mick_ban
Comment mettre a jour le plugin sur Synology?
mick_ban a écrit :
05 nov. 2019, 10:31
Comment l'as-tu installé ?
normalement si l'installation a été effectuée avec la commande
git clone .....
il suffit d'etre dans le repertoire du plugin et effectuer la commande
git pull
Il y a des informations ici: https://github.com/pipiche38/Domoticz-Z ... ng/Home.md
Peux-tu faire un essai de re-appairage et mettre les logs ?
mick_ban
C'etait une sacre epreuve pour moi de trouver comment lire ce txt (premiere fois que j'utilise Putty)
0000 : {'IEEE': '00158d0001c5e89b', 'version': '3', 'Ep': {'01': {'0008': {}, '0006': {}, '0004': {}}}, 'PowerSource': 'Main'}
6ea6 : {'Attributes List': {'Ep': {'01': {'0102': {'0008': '20', '0009': '20'}, '0000': {'ffe1': '48', 'ffe0': '48', 'ffe3': '48', 'ffe2': '20', '0002': '20', '0003': '20', '0000': '20', '0001': '20', '0006': '42', '0007': '30', '0004': '42', '0005': '42', 'fffd': '21', 'fffe': '30'}, '0004': {'fffd': '21', '0000': '18'}, '0005': {'fffd': '21', '0002': '21', '0003': '10', '0000': '20', '0001': '20', '0004': '18'}}}}, 'ZDeviceName': '', 'Bind': {'0102': {'Stamp': 1572919318, 'Status': '', 'Phase': 'requested'}}, 'MacCapa': '8e', 'Stamp': {'MsgType': '8702', 'Time': '2019-11-02 12:00:55', 'LastSeen': 1571940256}, 'Model': 'TS0302', 'Heartbeat': '201226', 'Manufacturer': '1002', 'ZDeviceID': '0202', 'NbEp': '1', 'SWBUILD_1': 'None', 'Health': '', 'Status': 'inDB', 'Type': 'WindowCovering', 'Ep': {'01': {'0019': {}, '0102': 50, 'ClusterType': {'78': 'WindowCovering'}, '0000': {}, '0004': {}, '0005': {}}}, 'Battery': {}, 'LogicalType': 'Router', 'ReadAttributes': {'TimeStamps': {'01-0000': 1571936268}, 'Ep': {'01': {'0000': {'ffe1': '89', 'ffe0': '89', 'ffe3': '89', 'ffe2': '00', '0002': '00', '0003': '00', '0000': '00', '0001': '00', '0006': '00', '0007': '00', '0004': '00', '0005': '00', 'fffd': '00', 'fffe': '00'}}}}, 'Stack Version': '0', 'Last Cmds': [(1572768051.5212286, '0120', None), (1572843660.343258, '0120', None), (1572843660.551224, '0120', None), (1572919318.4845583, '0120', None), (1572919318.6965604, '0120', None)], 'ReceiveOnIdle': 'On', 'PowerSource': 'Main', 'App Version': '66', 'RIA': '3', 'Manufacturer Name': '_TYZB01_dazsid15', 'Version': '3', 'HW Version': '1', 'ConfigureReporting': {'TimeStamps': {'01-0000': 1572919318, '01-0102': 1572919318}, 'Ep': {'01': {'0102': {}, '0000': {}}}}, 'RSSI': 150, 'Maufacturer Name': '', 'IEEE': 'ec1bbdfffe65c2d8', 'ProfileID': '0104', 'ZCL Version': '3', 'SQN': '', 'DeviceType': 'FFD'}
80f2 : {'Attributes List': {'Ep': {'01': {'0000': {'0002': '20', '0003': '20', '0000': '20', '0001': '20', '0006': '42', '0007': '30', '0004': '42', '0005': '42'}, '0006': {'0000': '10'}, '0004': {'0000': '18'}}, '02': {'000c': {'0055': '39', '0100': '23', '0051': '10', '0106': '39', '0105': '39', '006f': '18'}}}}, 'ZDeviceName': '', 'Bind': {'0006': {'Stamp': 1572938636, 'Status': '', 'Phase': 'requested'}}, 'MacCapa': '8e', 'Stamp': {'MsgType': '8102', 'Time': '2019-11-03 04:33:33', 'LastSeen': 1572752013}, 'Model': 'lumi.plug', 'Heartbeat': '11120', 'Manufacturer': '115f', 'ZDeviceID': '0051', 'NbEp': '3', 'SWBUILD_1': '09-29-2017', 'Health': '', 'Status': 'inDB', 'Type': 'Power/Meter/Plug', 'Ep': {'01': {'Type': 'Plug', 'ClusterType': {'47': 'Plug'}, '000c': {}, '0000': {}, '0006': '00', '0004': {}}, '02': {'000c': '0.0', 'Type': 'Power/Meter', 'ClusterType': {'45': 'Power', '46': 'Meter'}}}, 'Battery': {}, 'LogicalType': 'Router', 'ReadAttributes': {'TimeStamps': {'01-0000': 1572333660}, 'Ep': {'01': {'0000': {'ff02': '86', 'ff01': '00', '0002': '00', '0003': '00', '0000': '00', '0001': '00', '0006': '00', '0007': '00', '0004': '00', '0005': '00'}}}}, 'Stack Version': '2', 'Last Cmds': [(1572807601.2952368, '0092', None), (1572863028.42722, '0120', None), (1572879601.74294, '0092', None), (1572894001.7365406, '0092', None), (1572938636.3865364, '0120', None)], 'ReceiveOnIdle': 'On', 'PowerSource': 'Main', 'App Version': '30', 'RIA': '2', 'Manufacturer Name': 'LUMI', 'Version': '3', 'HW Version': '18', 'ConfigureReporting': {'TimeStamps': {'01-0000': 1572333715, '01-0006': 1572938636}, 'Ep': {'01': {'0000': '8c', '0006': '00'}}}, 'RSSI': 99, 'Maufacturer Name': '', 'IEEE': '00158d0002677858', 'ProfileID': '0104', 'ZCL Version': '1', 'SQN': '', 'DeviceType': 'FFD'}
8755 : {'Attributes List': {'Ep': {'01': {'0000': {'0002': '20', '0003': '20', '0000': '20', '0001': '20', '0006': '42', '0007': '30', '0004': '42', '0005': '42'}, '0006': {'0000': '10'}, '0004': {'0000': '18'}}, '02': {'000c': {'0055': '39', '0100': '23', '0051': '10', '0106': '39', '0105': '39', '006f': '18'}}}}, 'ZDeviceName': '', 'Bind': {'0006': {'Stamp': 1572938636, 'Status': '', 'Phase': 'requested'}}, 'MacCapa': '8e', 'Stamp': {'MsgType': '8102', 'Time': '2019-11-03 07:53:34', 'LastSeen': 1572764014}, 'Model': 'lumi.plug', 'Heartbeat': '718', 'Manufacturer': '115f', 'ZDeviceID': '0051', 'NbEp': '3', 'SWBUILD_1': '09-29-2017', 'Health': '', 'Status': 'inDB', 'Type': 'Power/Meter/Plug', 'Ep': {'01': {'Type': 'Plug', 'ClusterType': {'50': 'Plug'}, '000c': {}, '0000': {}, '0006': '00', '0004': {}}, '02': {'000c': '0.0', 'Type': 'Power/Meter', 'ClusterType': {'48': 'Power', '49': 'Meter'}}}, 'Battery': {}, 'LogicalType': 'Router', 'ReadAttributes': {'TimeStamps': {'01-0000': 1572333660}, 'Ep': {'01': {'0000': {'ff02': '86', 'ff01': '00', '0002': '00', '0003': '00', '0000': '00', '0001': '00', '0006': '00', '0007': '00', '0004': '00', '0005': '00'}}}}, 'Stack Version': '2', 'Last Cmds': [(1572863028.6402943, '0120', None), (1572886983.707949, '0092', None), (1572887408.5739424, '0092', None), (1572938636.1735303, '0120', None), (1572946414.8496892, '0092', None)], 'ReceiveOnIdle': 'On', 'PowerSource': 'Main', 'App Version': '30', 'RIA': '0', 'Manufacturer Name': 'LUMI', 'Version': '3', 'HW Version': '18', 'ConfigureReporting': {'TimeStamps': {'01-0000': 1572333775, '01-0006': 1572938636}, 'Ep': {'01': {'0000': '8c', '0006': '00'}}}, 'RSSI': 92, 'Maufacturer Name': '', 'IEEE': '00158d00028a53d1', 'ProfileID': '0104', 'ZCL Version': '1', 'SQN': '', 'DeviceType': 'FFD'}
3781 : {'Attributes List': {}, 'ZDeviceName': '', 'Bind': {'0000': {'Stamp': 1572104903, 'Status': '', 'Phase': 'requested'}}, 'MacCapa': '80', 'Stamp': {'MsgType': '8102', 'Time': '2019-11-03 04:13:06', 'LastSeen': 1572750695}, 'Model': 'lumi.weather', 'Heartbeat': '168383', 'Manufacturer': '', 'ZDeviceID': '5f01', 'NbEp': '1', 'Health': '', 'Status': 'inDB', 'Type': 'Temp/Humi/Baro', 'Ep': {'01': {'ffff': {}, 'Type': 'Temp/Humi/Baro', '0405': 96.5, 'ClusterType': {'31': 'Humi', '30': 'Temp', '32': 'Baro', '28': 'Temp+Hum+Baro', '29': 'Temp+Hum'}, '0003': {}, '0000': {}, '0001': '2985;2985;2985;2985', '0402': 13.2, '0403': 981.0}}, 'Battery': 59, 'LogicalType': '', 'ReadAttributes': {'TimeStamps': {'01-0000': 1572104903}, 'Ep': {'01': {'0000': {'ff01': '00'}}}}, 'Stack Version': '', 'Last Cmds': [(1570263666.7972198, '0100', None), (1570263666.9022148, '0100', None), (1570263667.0072188, '0100', None), (1572104904.5172155, '0100', None), (1572104904.6222386, '0100', None)], 'ReceiveOnIdle': '', 'PowerSource': '', 'App Version': '3', 'RIA': '0', 'Version': '3', 'HW Version': '', 'RSSI': 126, 'Maufacturer Name': '', 'IEEE': '00158d00027a3b2f', 'ProfileID': '0104', 'ZCL Version': '', 'SQN': '', 'DeviceType': ''}
4db2 : {'Attributes List': {'Ep': {'01': {'0000': {'0002': '20', '0003': '20', '0000': '20', '0001': '20', '0006': '42', '0007': '30', '0004': '42', '0005': '42'}, '0006': {'0000': '10'}, '0004': {'0000': '18'}}, '02': {'000c': {'0055': '39', '0100': '23', '0051': '10', '0106': '39', '0105': '39', '006f': '18'}}}}, 'ZDeviceName': '', 'Bind': {'0006': {'Stamp': 1572938696, 'Status': '', 'Phase': 'requested'}}, 'MacCapa': '8e', 'Stamp': {'MsgType': '8102', 'Time': '2019-11-03 04:13:35', 'LastSeen': 1572750573}, 'Model': 'lumi.plug', 'Heartbeat': '43', 'Manufacturer': '115f', 'ZDeviceID': '0051', 'NbEp': '3', 'SWBUILD_1': '09-29-2017', 'Health': '', 'Status': 'inDB', 'Type': 'Power/Meter/Plug', 'Ep': {'01': {'Type': 'Plug', 'ClusterType': {'44': 'Plug'}, '000c': {}, '0000': {}, '0006': '00', '0004': {}}, '02': {'000c': '0.0', 'Type': 'Power/Meter', 'ClusterType': {'42': 'Power', '43': 'Meter'}}}, 'Battery': {}, 'LogicalType': 'Router', 'ReadAttributes': {'TimeStamps': {'01-0000': 1572333659}, 'Ep': {'01': {'0000': {'ff02': '86', 'ff01': '00', '0002': '00', '0003': '00', '0000': '00', '0001': '00', '0006': '00', '0007': '00', '0004': '00', '0005': '00'}}}}, 'Stack Version': '2', 'Last Cmds': [(1572945500.7307057, '0092', None), (1572946657.2086864, '0092', None), (1572947552.693686, '0092', None), (1572949704.712687, '0092', None), (1572949795.4806864, '0092', None)], 'ReceiveOnIdle': 'On', 'PowerSource': 'Main', 'App Version': '30', 'RIA': '0', 'Manufacturer Name': 'LUMI', 'Version': '3', 'HW Version': '18', 'ConfigureReporting': {'TimeStamps': {'01-0000': 1572333775, '01-0006': 1572938696}, 'Ep': {'01': {'0000': '8c', '0006': '00'}}}, 'RSSI': 120, 'Maufacturer Name': '', 'IEEE': '00158d00028f1ba6', 'ProfileID': '0104', 'ZCL Version': '1', 'SQN': '', 'DeviceType': 'FFD'}
a3c0 : {'Attributes List': {}, 'ZDeviceName': '', 'Bind': {'0000': {'Stamp': 1570262934, 'Status': '00', 'Phase': 'received'}}, 'MacCapa': '80', 'Stamp': {'MsgType': '8102', 'Time': '2019-11-05 11:29:55', 'LastSeen': 1572949704}, 'Model': 'lumi.weather', 'Heartbeat': '535798', 'Manufacturer': '', 'ZDeviceID': {}, 'NbEp': '1', 'Health': 'Live', 'Status': 'inDB', 'Type': 'Temp/Humi/Baro', 'Ep': {'01': {'ffff': {}, 'Type': 'Temp/Humi/Baro', '0405': 77.0, 'ClusterType': {'10': 'Temp', '9': 'Temp+Hum', '12': 'Baro', '11': 'Humi', '8': 'Temp+Hum+Baro'}, '0003': {}, '0000': {}, '0001': '2985;2985;2985;2985', '0402': 19.3, '0403': 991.4}}, 'Battery': 59, 'LogicalType': '', 'ReadAttributes': {'TimeStamps': {'01-0405': 1570262930, '01-0000': 1570262930, '01-0403': 1570262930, '01-0402': 1570262930}, 'Ep': {'01': {'0000': {'ff01': '00'}, '0405': {'0000': '00'}, '0402': {'0000': '00'}, '0403': {'0010': '00', '0000': '00', '0014': '00'}}}}, 'Stack Version': '', 'Last Cmds': [(1570262968.2492204, '0100', None), (1570262968.354232, '0100', None), (1570262968.4602213, '0100', None), (1570262968.5662234, '0100', None), (1570262968.6732285, '0100', None)], 'ReceiveOnIdle': '', 'PowerSource': '', 'App Version': '3', 'BatteryUpdateTime': 1572949795, 'RIA': '0', 'Version': '3', 'HW Version': '', 'ConfigureReporting': {'TimeStamps': {'01-0405': 1570262930, '01-0000': 1570262930, '01-0403': 1570262930, '01-0402': 1570262930}, 'Ep': {'01': {'0000': {}, '0405': {}, '0402': {}, '0403': {}}}}, 'RSSI': 144, 'Maufacturer Name': '', 'IEEE': '00158d00027aee87', 'ProfileID': {}, 'ZCL Version': '', 'SQN': '', 'DeviceType': ''}
e419 : {'Attributes List': {'Ep': {'04': {'000c': {'0055': '39', '0100': '23', '0051': '10', '0106': '39', '0105': '39', '006f': '18'}}, '01': {'0000': {'0002': '20', '0003': '20', '0000': '20', '0001': '20', '0006': '42', '0007': '30', '0004': '42', '0005': '42'}, '0006': {'0000': '10'}, '0004': {'0000': '18'}}, '02': {'0006': {'0000': '10'}}, '03': {'000c': {'0055': '39', '0100': '23', '0051': '10', '0106': '39', '0105': '39', '006f': '18'}}}}, 'ZDeviceName': '', 'Bind': {'0006': {'Stamp': 1572946089, 'Status': '', 'Phase': 'requested'}}, 'MacCapa': '8e', 'Stamp': {'MsgType': '8102', 'Time': '2019-11-03 04:14:16', 'LastSeen': 1572750612}, 'Model': 'lumi.ctrl_ln2.aq1', 'Heartbeat': '727', 'Manufacturer': '115f', 'ZDeviceID': '0053', 'NbEp': '7', 'SWBUILD_1': '06-25-2018', 'Health': '', 'Status': 'inDB', 'Type': 'Power/Meter/Switch', 'Ep': {'04': {'000c': {}, 'Type': 'Power/Meter', 'ClusterType': {'38': 'Meter', '37': 'Power'}}, '05': {'0012': {}}, '06': {'0012': {}}, '07': {'0012': {}}, '01': {'Type': 'Switch', 'ClusterType': {'36': 'Switch'}, '0006': '00', '0000': {}, '0402': -255.2, '0004': {}}, '02': {'ClusterType': {'35': 'Switch'}, 'Type': 'Switch', '0006': '00', '0004': {}}, '03': {'000c': '0.0', 'Type': 'Power/Meter', 'ClusterType': {'33': 'Power', '34': 'Meter'}}}, 'Battery': {}, 'LogicalType': 'Router', 'ReadAttributes': {'TimeStamps': {'01-0000': 1570980093}, 'Ep': {'01': {'0000': {'ff02': '86', 'ff01': '00', '0002': '00', '0003': '00', '0000': '00', '0001': '00', '0006': '00', '0007': '00', '0004': '00', '0005': '00'}}}}, 'Stack Version': '2', 'Last Cmds': [(1572946089.5576859, '0120', None), (1572946324.1657016, '0092', None), (1572946324.2746985, '0092', None), (1572946324.3786871, '0092', None), (1572946369.2206955, '0092', None)], 'ReceiveOnIdle': 'On', 'PowerSource': 'Main', 'App Version': '33', 'RIA': '0', 'Manufacturer Name': 'LUMI', 'Version': '3', 'HW Version': '18', 'ConfigureReporting': {'TimeStamps': {'01-0000': 1570980100, '02-0006': 1572946089, '01-0402': 1572879108, '01-0006': 1572946089}, 'Ep': {'01': {'0006': '00', '0000': '8c', '0402': {}}, '02': {'0006': '00'}}}, 'RSSI': 114, 'Maufacturer Name': '', 'IEEE': '00158d0002a6dad2', 'ProfileID': '0104', 'ZCL Version': '1', 'SQN': '', 'DeviceType': 'FFD'}
mick_ban
J'avais essayé mais :
Mick@NASMick:/volume1/@appstore/domoticz/var/plugins/Domoticz-Zigate$ git pull
error: cannot open .git/FETCH_HEAD: Permission denied
mick_ban
pipiche a écrit :
05 nov. 2019, 11:21
Re-appairage de quoi capteur ou Zigate?
 2019-11-05 12:18:12.873 Status: (Zigate) [0] NEW OBJECT: c12e TimeOut in 0045 restarting at 0x004d
2019-11-05 12:18:12.873 Status: (Zigate) [0] NEW OBJECT: c12e Request Model Name
2019-11-05 12:18:27.925 Status: (Zigate) [1] NEW OBJECT: c12e TimeOut in 0045 restarting at 0x004d
2019-11-05 12:18:27.925 Status: (Zigate) [1] NEW OBJECT: c12e Request Model Name
2019-11-05 12:18:42.954 Status: (Zigate) [2] NEW OBJECT: c12e TimeOut in 0045 restarting at 0x004d
2019-11-05 12:18:42.954 Status: (Zigate) [2] NEW OBJECT: c12e Request Model Name
Modifié en dernier par mick_ban le 05 nov. 2019, 12:19, modifié 1 fois.
