Perte de connexion vers volets roulants Legrand Netatmo
Wolfen38
Re: Perte de connexion vers volets roulants Legrand Netatmo
Message par Wolfen38 »
Ok donc comme pas le hub je peux pas.
Je vais déjà mettre le reste a jour
Wolfen38
Alors, j'ai fait un git pull, suivi d'un checout beta.
Au redémarrage de dz, j'ai ca :
2020-02-03 12:21:31.008 Status: (Zigate) load ListOfDevice
2020-02-03 12:21:31.010 Status: (Zigate) Entries loaded from /home/pi/domoticz/plugins/Domoticz-Zigate/./DeviceList-11.txt : 0
2020-02-03 12:21:31.016 Status: (Zigate) Check for Web update finished!
2020-02-03 12:21:31.016 Status: (Zigate) Connection Name: Zigate, Transport: Serial, Address: /dev/ttyUSB0
2020-02-03 12:21:31.020 Status: (Zigate) ZigateConf - Setting UTC Time to : 634047691
2020-02-03 12:21:31.021 Status: (Zigate) Start network
2020-02-03 12:21:31.021 Status: (Zigate) Zigate enter in discover mode for 0 Secs
2020-02-03 12:21:31.256 Status: Python EventSystem: Initalizing event module.
2020-02-03 12:21:31.257 Status: EventSystem: Started
2020-02-03 12:21:31.257 Status: EventSystem: Queue thread started...
2020-02-03 12:21:31.273 Status: (Zigate) Major Version Num: 0003
2020-02-03 12:21:31.274 Status: (Zigate) Installer Version Number: 030f
2020-02-03 12:21:31.382 Status: (Zigate) Decode8015 : Number of devices recently active in Zigate = 30
2020-02-03 12:21:31.382 Status: (Zigate) Decode8015 : [00] DevID = 00 Network addr = 0503 IEEE = 00158d0001f41a12 RSSI = 097 Power = 00 not found in ListOfDevices
2020-02-03 12:21:31.383 Status: (Zigate) Decode8015 : [01] DevID = 01 Network addr = a2c0 IEEE = 00158d00016d8632 RSSI = 134 Power = 00 not found in ListOfDevices
2020-02-03 12:21:31.383 Status: (Zigate) Decode8015 : [02] DevID = 02 Network addr = 598a IEEE = 00158d00019ca947 RSSI = 071 Power = 00 not found in ListOfDevices
2020-02-03 12:21:31.383 Status: (Zigate) Decode8015 : [03] DevID = 03 Network addr = c418 IEEE = 00158d0002499f62 RSSI = 098 Power = 00 not found in ListOfDevices
2020-02-03 12:21:31.383 Status: (Zigate) Decode8015 : [04] DevID = 04 Network addr = d801 IEEE = 00158d0002d4870e RSSI = 075 Power = 00 not found in ListOfDevices
2020-02-03 12:21:31.383 Status: (Zigate) Decode8015 : [05] DevID = 05 Network addr = 5f53 IEEE = 00158d0001b12866 RSSI = 072 Power = 00 not found in ListOfDevices
2020-02-03 12:21:31.383 Status: (Zigate) Decode8015 : [06] DevID = 06 Network addr = 9a8a IEEE = 00158d00016d7de2 RSSI = 055 Power = 00 not found in ListOfDevices
2020-02-03 12:21:31.384 Status: (Zigate) Decode8015 : [07] DevID = 07 Network addr = c924 IEEE = 00158d00016c0b11 RSSI = 065 Power = 00 not found in ListOfDevices
2020-02-03 12:21:31.389 Status: (Zigate) Decode8015 : [08] DevID = 08 Network addr = ef3d IEEE = 00158d000323fd5e RSSI = 069 Power = 00 not found in ListOfDevices
2020-02-03 12:21:31.390 Status: (Zigate) Decode8015 : [09] DevID = 09 Network addr = ad57 IEEE = 00158d000247fe53 RSSI = 128 Power = 00 not found in ListOfDevices
2020-02-03 12:21:31.391 Status: (Zigate) Decode8015 : [10] DevID = 0a Network addr = 0c9e IEEE = 00158d0001a922fc RSSI = 084 Power = 00 not found in ListOfDevices
2020-02-03 12:21:31.391 Status: (Zigate) Decode8015 : [11] DevID = 0b Network addr = c454 IEEE = 00158d0001d6a9af RSSI = 051 Power = 00 not found in ListOfDevices
2020-02-03 12:21:31.391 Status: (Zigate) Decode8015 : [12] DevID = 0c Network addr = 5ec8 IEEE = 00158d0001ab1e15 RSSI = 125 Power = 00 not found in ListOfDevices
2020-02-03 12:21:31.391 Status: (Zigate) Decode8015 : [13] DevID = 0e Network addr = 3385 IEEE = 00158d00019dcd87 RSSI = 101 Power = 00 not found in ListOfDevices
2020-02-03 12:21:31.392 Status: (Zigate) Decode8015 : [14] DevID = 0f Network addr = 3f2c IEEE = 00158d00016bfcdd RSSI = 137 Power = 00 not found in ListOfDevices
2020-02-03 12:21:31.392 Status: (Zigate) Decode8015 : [15] DevID = 10 Network addr = f56e IEEE = 00158d0001d61fd2 RSSI = 108 Power = 00 not found in ListOfDevices
2020-02-03 12:21:31.392 Status: (Zigate) Decode8015 : [16] DevID = 12 Network addr = e4e0 IEEE = 00158d00016d7ee4 RSSI = 087 Power = 00 not found in ListOfDevices
2020-02-03 12:21:31.392 Status: (Zigate) Decode8015 : [17] DevID = 14 Network addr = 0947 IEEE = 00158d0001dcb5d7 RSSI = 051 Power = 00 not found in ListOfDevices
2020-02-03 12:21:31.392 Status: (Zigate) Decode8015 : [18] DevID = 16 Network addr = 996c IEEE = 00158d00019ca979 RSSI = 140 Power = 00 not found in ListOfDevices
2020-02-03 12:21:31.392 Status: (Zigate) Decode8015 : [19] DevID = 17 Network addr = 772f IEEE = 00158d0001e45091 RSSI = 090 Power = 00 not found in ListOfDevices
2020-02-03 12:21:31.393 Status: (Zigate) Decode8015 : [20] DevID = 18 Network addr = f00d IEEE = 00158d0001dbc895 RSSI = 040 Power = 00 not found in ListOfDevices
2020-02-03 12:21:31.393 Status: (Zigate) Decode8015 : [21] DevID = 19 Network addr = ec9b IEEE = 00158d0002286922 RSSI = 062 Power = 00 not found in ListOfDevices
2020-02-03 12:21:31.393 Status: (Zigate) Decode8015 : [22] DevID = 28 Network addr = 7304 IEEE = 000d6ffffe2dda40 RSSI = 063 Power = 01 not found in ListOfDevices
2020-02-03 12:21:31.393 Status: (Zigate) Decode8015 : [23] DevID = 29 Network addr = 3a03 IEEE = 00047400008aed69 RSSI = 060 Power = 01 not found in ListOfDevices
2020-02-03 12:21:31.393 Status: (Zigate) Decode8015 : [24] DevID = 2a Network addr = 1696 IEEE = 000d6ffffe2fe576 RSSI = 052 Power = 01 not found in ListOfDevices
2020-02-03 12:21:31.394 Status: (Zigate) Decode8015 : [25] DevID = 2b Network addr = c1c2 IEEE = 00047400008aaa9a RSSI = 110 Power = 01 not found in ListOfDevices
2020-02-03 12:21:31.394 Status: (Zigate) Decode8015 : [26] DevID = 2c Network addr = 7622 IEEE = 00047400008aaad6 RSSI = 078 Power = 01 not found in ListOfDevices
2020-02-03 12:21:31.394 Status: (Zigate) Decode8015 : [27] DevID = 2d Network addr = 12e4 IEEE = 00047400008aed61 RSSI = 078 Power = 01 not found in ListOfDevices
2020-02-03 12:21:31.394 Status: (Zigate) Decode8015 : [28] DevID = 2e Network addr = dfd8 IEEE = 00047400008aac16 RSSI = 128 Power = 01 not found in ListOfDevices
2020-02-03 12:21:31.394 Status: (Zigate) Decode8015 : [29] DevID = 2f Network addr = aa25 IEEE = 00047400008af27c RSSI = 042 Power = 01 not found in ListOfDevices
2020-02-03 12:21:38.236 Status: Netatmo: No Weather Station devices found...
2020-02-03 12:21:40.425 (Thermostat) General/Percentage (Thermostat batterie)
2020-02-03 12:21:40.451 (Thermostat) Temp (Thermostat Température)
2020-02-03 12:21:40.465 (Thermostat) Thermostat (Thermostat Réglage)
2020-02-03 12:21:41.283 (Zigate) Start Network status : Success
2020-02-03 12:21:41.385 (Zigate) Ping - received
2020-02-03 12:21:41.181 Status: (Zigate) Decode8009 : Zigate addresses ieee: 00158d0001eded91 , short addr: 0000
2020-02-03 12:21:41.181 Status: (Zigate) Decode8009 - Network state UP, PANID: dd89 extPANID: 0xbbb048ca88a57dfa Channel: 11
2020-02-03 12:21:41.385 Status: (Zigate) Permit Join is On
2020-02-03 12:21:54.004 Error: OpenZWave: Driver Failed!!
2020-02-03 12:21:56.160 Error: (Zigate) Decode8102 - Receiving a message from unknown device : f56e with Data : b0f56e010000ff0200420013100121a60b21a81324010000000021d3002060
2020-02-03 12:22:01.386 Error: (Zigate) Decode8102 - Receiving a message from unknown device : 1696 with Data : 58169601000600000010000100
Ca fait un peu peur, j'ai l'impression que ca dit qu'il trouve aucun device....
Et maintenant, quand je refait un git pull, ca me dit ca
pi@raspberrypi:~/domoticz/plugins/Domoticz-Zigate $ git pull
Pas d'information de suivi distant pour la branche actuelle.
Veuillez spécifier une branche avec laquelle fusionner.
Référez-vous à git-pull(1) pour de plus amples détails.
    git pull <distant> <branche>
Si vous souhaitez indiquer l'information de suivi distant pour cette branche, vous pouvez le faire avec :
    git branch --set-upstream-to=origin/<branche> beta
A chaque fois que j'ai tenté la beta, j'ai eu des galères... c'est pour ca que je repassai systématiquement en stable.... Je comprends pas toutes ces erreurs
Comment fais-tu pour passer sur la branche bêta ?
Je maintiens le plugin Zigate sur mon temps libre .
Wolfen38
Git checkout beta
Et comment le plugins a-t-il été installé?
Wolfen38
Ça depuis le temps je me rappelle plus du tout.
J'avais du suivre un tuto sur github je pense
Et quand tu as fait le git checkout beta il n’y a pas eu d’erreur?
Wolfen38
Non,
par contre en relancant dz ca me marquait version beta 4.1, donc j'ai voulu faire un git pull a nouveau, et la ca marquait le message que j'ai ecrit plus haut
Ah mon avis t’es sur un truc complètement désynchronisé .
Il faudrait que tu repartes d’un git clone frais et récent
Il faudra simplement que tu recopies les répertoires Conf et Data de la version stable
Wolfen38
Et tu vois comment le régler ?
