[Résolu] Affolement du plugin
Je cherche à comprendre le fonctionnement de la zigate et/ou du plugin ou ce qui ressemble à un "affolement" dans les logs :
Hcapteur entrée est un Hue Motion Sensor. Il s'annonce par deux fois à un dixième de seconde près. Dans la foulée, la pizigate semble empiler des messages du sensor dans sa queue.
C'est normal ?
2020-04-07 12:25:06.226 Status: (PiZigate) Device Announcement: Hcapteur entrée(02fb, 001788010201f744) Join Flag: 0x00 - join a network through association RSSI: 135
2020-04-07 12:25:06.337 Status: (PiZigate) Device Announcement: Hcapteur entrée(02fb, 001788010201f744) Join Flag: 0x00 - join a network through association RSSI: 150
2020-04-07 12:25:17.753 (PiZigate) WARNING - ZigateCmd: 0120 0202fb010204060000000001001800000001012C0FFF00 ZigateQueue: 16
2020-04-07 12:25:17.754 (PiZigate) WARNING - ZigateCmd: 0120 0202fb0102040600000000010020003000051C200FFF01 ZigateQueue: 17
2020-04-07 12:25:17.754 (PiZigate) WARNING - ZigateCmd: 0120 0202fb01020400000000000100210000000002580FFF000F ZigateQueue: 18
2020-04-07 12:25:17.755 (PiZigate) WARNING - ZigateCmd: 0120 0202fb01020402000000000100290000000A012C0FFF0001 ZigateQueue: 19
2020-04-07 12:25:17.755 (PiZigate) WARNING - ZigateCmd: 0120 0202fb010200010000000001002000211C201C200FFF00 ZigateQueue: 20
2020-04-07 12:25:17.756 (PiZigate) WARNING - ZigateCmd: 0100 0202fb010200000000000003000000010002 ZigateQueue: 21
2020-04-07 12:25:17.757 (PiZigate) WARNING - ZigateCmd: 0100 0202fb010200000000000003000300040005 ZigateQueue: 22
2020-04-07 12:25:17.758 (PiZigate) WARNING - ZigateCmd: 0100 0202fb0102000000000000010006 ZigateQueue: 23
2020-04-07 12:25:17.758 (PiZigate) WARNING - ZigateCmd: 0100 0202fb0102000100000000010020 ZigateQueue: 24
2020-04-07 12:25:17.758 (PiZigate) WARNING - ZigateCmd: 0042 02fb ZigateQueue: 25
2020-04-07 12:25:17.750 Status: (PiZigate) Device Announcement: Hcapteur entrée(02fb, 001788010201f744) Join Flag: 0x00 - join a network through association RSSI: 135
2020-04-07 12:25:17.765 Status: (PiZigate) Device Announcement: Hcapteur entrée(02fb, 001788010201f744) Join Flag: 0x00 - join a network through association RSSI: 135
2020-04-07 12:25:17.767 Status: (PiZigate) Device Announcement: Hcapteur entrée(02fb, 001788010201f744) Join Flag: 0x00 - join a network through association RSSI: 111
2020-04-07 12:27:14.168 Status: (PiZigate) Device Announcement: Hcapteur entrée(02fb, 001788010201f744) Join Flag: 0x00 - join a network through association RSSI: 138
2020-04-07 12:27:14.272 Status: (PiZigate) Device Announcement: Hcapteur entrée(02fb, 001788010201f744) Join Flag: 0x00 - join a network through association RSSI: 147
Domoticz branche beta 11875
pizigate 3.1c
plugin zigate branche beta 4.8.010
le tout sur pi4
C'est normal ?
pizigate 3.1c
le tout sur pi4
Dernière modification par fjum le 09 avr. 2021, 08:08, modifié 1 fois.
NUC NiPoGi CK10 / i5-12450H CPU 4,4GHz / RAM 32 Go
Ubuntu Server 22.04.4 LTS
Domoticz 2025.1 beta build 16729
Zigbee : ConbeeIII 0x26550900 / Zigbee2MQTT 2.6.2-dev
Zwave : Aeon labs Gen5+ / zwave-js-ui 9.28.0 zwave-js: 14.3.7
Re: Affolement du plugin
Et rebelote avec un autre hue motion sensor :
2020-04-07 12:58:15.446 (PiZigate) WARNING - ZigateCmd: 0030 001788010201e83b0200010300158d0003af5f2f01 ZigateQueue: 16
2020-04-07 12:58:15.446 (PiZigate) WARNING - ZigateCmd: 0120 020d64010204060000000001001800000001012C0FFF00 ZigateQueue: 17
2020-04-07 12:58:15.446 (PiZigate) WARNING - ZigateCmd: 0120 020d640102040600000000010020003000051C200FFF01 ZigateQueue: 18
2020-04-07 12:58:15.446 (PiZigate) WARNING - ZigateCmd: 0120 020d6401020400000000000100210000000002580FFF000F ZigateQueue: 19
2020-04-07 12:58:15.446 (PiZigate) WARNING - ZigateCmd: 0120 020d6401020402000000000100290000000A012C0FFF0001 ZigateQueue: 20
2020-04-07 12:58:15.447 (PiZigate) WARNING - ZigateCmd: 0120 020d64010200010000000001002000211C201C200FFF00 ZigateQueue: 21
2020-04-07 12:58:15.447 (PiZigate) WARNING - ZigateCmd: 0100 020d64010200000000000003000000010002 ZigateQueue: 22
2020-04-07 12:58:15.447 (PiZigate) WARNING - ZigateCmd: 0100 020d64010200000000000003000300040005 ZigateQueue: 23
2020-04-07 12:58:15.448 (PiZigate) WARNING - ZigateCmd: 0100 020d640102000000000000010006 ZigateQueue: 24
2020-04-07 12:58:15.448 (PiZigate) WARNING - ZigateCmd: 0100 020d640102000100000000010020 ZigateQueue: 25
2020-04-07 12:58:15.448 (PiZigate) WARNING - ZigateCmd: 0042 0d64 ZigateQueue: 26
2020-04-07 12:58:15.445 Status: (PiZigate) Device Announcement: Hcapteur dressing(0d64, 001788010201e83b) Join Flag: 0x00 - join a network through association RSSI: 111
Comme indiqué, il s'agit d'un Warning ... aucun soucis .
Les HUE Motion sont effectivement consommateurs de ressources Zigate, du coup cela peut entraîner de la latence si au même moment il y a une autre action demandée
Ok ok
Oui en effet le plugin était en train de faire une analyse des niveaux d'énergie
Question peut être bête ...
Il n'est pas possible de limiter les ressources utilisées par les hue motion en laissant tomber les informations qu'ils remontent type lux ou température ?
Certainement, mais:fjum a écrit : 07 avr. 2020, 13:25 Question peut être bête ...
(1) le plugin se veut le plus générique possible afin de pouvoir satisfaire le maximum de Device et en limitant les éléments spécifiques dans le plugin
(2) Le plugin est le résultat de 'reverser engineering' , c'est à dire on regarde comment se comporte un équipement et on reproduit la même chose dans le plugin.
En résumé, il est difficile de savoir ce qu'il faut garder précisément et ce qu'il faut jeter ...
Je comprends.
Et en personnalisant le fichier SML001.json, il n'y aurait pas moyen de traiter ou non certains messages ?
Un SML001.json uniquement motion, un autre motion+temp, etc ... et on choisit celui qu'on veut ?
je viens de t'envoyer un MP pour essayer un truc ?fjum a écrit : 07 avr. 2020, 14:03 Je comprends.
Pas reçu encore
bonjour,
Pour le Motion Hue est les device annoucement a répétition, il est possible qu'on est identifié le problème.
Si tu souhaites vérifier il faudrait que tu bascules sur la branche 'beta', que tu supprimes de Domoticz les widgets associées et que tu re-appaiares le Motion Sensor ( Philips Hue)
