Mise à jour du Kernel plus de 1-wire...snif
Le bus 1-Wire, connectique, et intégration dans Domoticz
beuz33
Re: Mise à jour du Kernel plus de 1-wire...snif
Message par beuz33 »
Est ce que quelqu'un ayant fait la mise a jour kernel aurait le meme fichier config.txt a partagé svp.
patrice
Message par patrice »
Bonsoir
Voici celui que j'ai
# For more options and information see
# http://www.raspberrypi.org/documentation/configuration/config-txt.md
# Some settings may impact device functionality. See link above for details
# uncomment if you get no picture on HDMI for a default "safe" mode
#hdmi_safe=1
# uncomment this if your display has a black border of unused pixels visible
# and your display can output without overscan
#disable_overscan=1
# uncomment the following to adjust overscan. Use positive numbers if console
# goes off screen, and negative if there is too much border
#overscan_left=16
#overscan_right=16
#overscan_top=16
#overscan_bottom=16
# uncomment to force a console size. By default it will be display's size minus
# overscan.
#framebuffer_width=1280
#framebuffer_height=720
# uncomment if hdmi display is not detected and composite is being output
#hdmi_force_hotplug=1
# uncomment to force a specific HDMI mode (this will force VGA)
#hdmi_group=1
#hdmi_mode=1
# uncomment to force a HDMI mode rather than DVI. This can make audio work in
# DMT (computer monitor) modes
#hdmi_drive=2
# uncomment to increase signal to HDMI, if you have interference, blanking, or
# no display
#config_hdmi_boost=4
# uncomment for composite PAL
#sdtv_mode=2
#uncomment to overclock the arm. 700 MHz is the default.
#arm_freq=800
dtparam=spi=on
dtparam=i2c1=on
dtparam=i2c_arm=on
dtoverlay=w1-gpio
gpu_mem=16
Raspberry Pi model B+, RFXComm,8 interrupteurs Chacon, 5 ds180b 1-Wire, 3 douilles Chacon, 1 contact de porte Chacon, 1 module variateur,module emetteur 54700, Aeon Stick Z-wave, 1 MultiSensor Aeon, accés à distance.
aka thegritche@domoticz forum
