Je sais pas si cela peut expliquer mais...
Woops t'as quoi comme alim sur ton rasp ?
[ 10.899308] platform regulatory.0: Direct firmware load for regulatory.db failed with error -2
[ 10.899334] cfg80211: failed to load regulatory.db
[ 21.272618] Under-voltage detected! (0x00050000)
[ 21.453715] cfg80211: Loading compiled-in X.509 certificates for regulatory database
[ 21.497001] cfg80211: Loaded X.509 cert 'sforshee: 00b28ddf47aef9cea7'
[ 21.498940] platform regulatory.0: Direct firmware load for regulatory.db failed with error -2
[ 21.498959] cfg80211: failed to load regulatory.db
[ 21.869433] Adding 102396k swap on /var/swap. Priority:-2 extents:2 across:118780k FS
[ 22.677153] smsc95xx 1-1.1:1.0 eth0: hardware isn't capable of remote wakeup
[ 23.352544] Voltage normalised (0x00000000)
[ 24.333038] smsc95xx 1-1.1:1.0 eth0: link up, 100Mbps, full-duplex, lpa 0xC5E1
[ 33.763812] Bluetooth: Core ver 2.22
[ 33.764009] NET: Registered protocol family 31
[ 33.764018] Bluetooth: HCI device and connection manager initialized
[ 33.766436] Bluetooth: HCI socket layer initialized
[ 33.766461] Bluetooth: L2CAP socket layer initialized
[ 33.766536] Bluetooth: SCO socket layer initialized
[ 33.817069] Bluetooth: BNEP (Ethernet Emulation) ver 1.3
[ 33.817087] Bluetooth: BNEP filters: protocol multicast
[ 33.817116] Bluetooth: BNEP socket layer initialized
[19935.998898] usb 1-1.2: USB disconnect, device number 4
[19937.925514] usb 1-1.2: new full-speed USB device number 10 using dwc_otg
[19938.058792] usb 1-1.2: New USB device found, idVendor=0658, idProduct=0200, bcdDevice= 0.00
[19938.058808] usb 1-1.2: New USB device strings: Mfr=0, Product=0, SerialNumber=0
[19938.059995] cdc_acm 1-1.2:1.0: ttyACM2: USB ACM device
[25157.223158] usb 1-1.5-port4: disabled by hub (EMI?), re-enabling...
[25157.223518] usb 1-1.5.4: USB disconnect, device number 9
[25157.224430] ftdi_sio ttyUSB0: error from flowcontrol urb
[25157.225020] ftdi_sio ttyUSB0: FTDI USB Serial Device converter now disconnected from ttyUSB0
[25157.225142] ftdi_sio 1-1.5.4:1.0: device disconnected
[25157.520589] usb 1-1.5.4: new full-speed USB device number 11 using dwc_otg
[25157.620532] usb 1-1.5.4: device descriptor read/64, error -71
[25157.840532] usb 1-1.5.4: device descriptor read/64, error -71
[25158.060542] usb 1-1.5.4: new full-speed USB device number 12 using dwc_otg
[25158.218165] usb 1-1.5.4: New USB device found, idVendor=0403, idProduct=6015, bcdDevice=10.00
[25158.218182] usb 1-1.5.4: New USB device strings: Mfr=1, Product=2, SerialNumber=3
[25158.218190] usb 1-1.5.4: Product: FT230X Basic UART
[25158.218198] usb 1-1.5.4: Manufacturer: FTDI
[25158.218205] usb 1-1.5.4: SerialNumber: DN04SF1J
[25158.226674] ftdi_sio 1-1.5.4:1.0: FTDI USB Serial Device converter detected
[25158.226950] usb 1-1.5.4: Detected FT-X
[25158.237274] usb 1-1.5.4: FTDI USB Serial Device converter now attached to ttyUSB0
[29357.415168] usb 1-1.5-port4: disabled by hub (EMI?), re-enabling...
[29357.415538] usb 1-1.5.4: USB disconnect, device number 12
[29357.416229] ftdi_sio ttyUSB0: FTDI USB Serial Device converter now disconnected from ttyUSB0
[29357.416346] ftdi_sio 1-1.5.4:1.0: device disconnected
[29357.712033] usb 1-1.5.4: new full-speed USB device number 13 using dwc_otg
[29357.879805] usb 1-1.5.4: New USB device found, idVendor=0403, idProduct=6015, bcdDevice=10.00
[29357.879821] usb 1-1.5.4: New USB device strings: Mfr=1, Product=2, SerialNumber=3
[29357.879829] usb 1-1.5.4: Product: FT230X Basic UART
[29357.879837] usb 1-1.5.4: Manufacturer: FTDI
[29357.879844] usb 1-1.5.4: SerialNumber: DN04SF1J
[29357.888210] ftdi_sio 1-1.5.4:1.0: FTDI USB Serial Device converter detected
[29357.888379] usb 1-1.5.4: Detected FT-X
[29357.889367] usb 1-1.5.4: FTDI USB Serial Device converter now attached to ttyUSB0
[31414.119226] usb 1-1.5-port4: disabled by hub (EMI?), re-enabling...
[31414.119593] usb 1-1.5.4: USB disconnect, device number 13
[31414.120290] ftdi_sio ttyUSB0: FTDI USB Serial Device converter now disconnected from ttyUSB0
[31414.120405] ftdi_sio 1-1.5.4:1.0: device disconnected
[31414.422469] usb 1-1.5.4: new full-speed USB device number 14 using dwc_otg
[31414.581183] usb 1-1.5.4: New USB device found, idVendor=0403, idProduct=6015, bcdDevice=10.00
[31414.581199] usb 1-1.5.4: New USB device strings: Mfr=1, Product=2, SerialNumber=3
[31414.581207] usb 1-1.5.4: Product: FT230X Basic UART
[31414.581215] usb 1-1.5.4: Manufacturer: FTDI
[31414.581222] usb 1-1.5.4: SerialNumber: DN04SF1J
[31414.589602] ftdi_sio 1-1.5.4:1.0: FTDI USB Serial Device converter detected
[31414.589767] usb 1-1.5.4: Detected FT-X
[31414.590836] usb 1-1.5.4: FTDI USB Serial Device converter now attached to ttyUSB0
[33440.615288] usb 1-1.5-port4: disabled by hub (EMI?), re-enabling...
[33440.615633] usb 1-1.5.4: USB disconnect, device number 14
[33440.616353] ftdi_sio ttyUSB0: FTDI USB Serial Device converter now disconnected from ttyUSB0
[33440.616480] ftdi_sio 1-1.5.4:1.0: device disconnected
[33440.912734] usb 1-1.5.4: new full-speed USB device number 15 using dwc_otg
[33441.070714] usb 1-1.5.4: New USB device found, idVendor=0403, idProduct=6015, bcdDevice=10.00
[33441.070732] usb 1-1.5.4: New USB device strings: Mfr=1, Product=2, SerialNumber=3
[33441.070740] usb 1-1.5.4: Product: FT230X Basic UART
[33441.070749] usb 1-1.5.4: Manufacturer: FTDI
[33441.070757] usb 1-1.5.4: SerialNumber: DN04SF1J
[33441.081794] ftdi_sio 1-1.5.4:1.0: FTDI USB Serial Device converter detected
[33441.081980] usb 1-1.5.4: Detected FT-X
[33441.083426] usb 1-1.5.4: FTDI USB Serial Device converter now attached to ttyUSB0
[33443.175189] usb 1-1.5-port4: disabled by hub (EMI?), re-enabling...
[33443.175564] usb 1-1.5.4: USB disconnect, device number 15
[33443.176457] ftdi_sio ttyUSB0: FTDI USB Serial Device converter now disconnected from ttyUSB0
[33443.176569] ftdi_sio 1-1.5.4:1.0: device disconnected
[33443.482699] usb 1-1.5.4: new full-speed USB device number 16 using dwc_otg
[33443.640200] usb 1-1.5.4: New USB device found, idVendor=0403, idProduct=6015, bcdDevice=10.00
[33443.640219] usb 1-1.5.4: New USB device strings: Mfr=1, Product=2, SerialNumber=3
[33443.640227] usb 1-1.5.4: Product: FT230X Basic UART
[33443.640235] usb 1-1.5.4: Manufacturer: FTDI
[33443.640242] usb 1-1.5.4: SerialNumber: DN04SF1J
[33443.651588] ftdi_sio 1-1.5.4:1.0: FTDI USB Serial Device converter detected
[33443.651791] usb 1-1.5.4: Detected FT-X
[33443.653206] usb 1-1.5.4: FTDI USB Serial Device converter now attached to ttyUSB0
