[DzVents] Alerte Pollens avec sélection des risques à surveiller
Wolfen38
Re: [DZVents] Alerte Pollens avec sélection des risques à surveiller
Message par Wolfen38 »
Voila les logs
2019-05-04 11:59:43.350 Status: EventSystem: Script event triggered: /home/pi/domoticz/scripts/lua/script_device_palier-essai.lua
2019-05-04 12:00:00.190 Status: dzVents: Info: Alerte Pollens v1.1: ------ Start external script: pollens2.lua:, trigger: every 6 hours
2019-05-04 12:00:00.192 Status: dzVents: Debug: Alerte Pollens v1.1: OpenURL: url = https://www.pollens.fr/risks/thea/counties/38
2019-05-04 12:00:00.192 Status: dzVents: Debug: Alerte Pollens v1.1: OpenURL: method = GET
2019-05-04 12:00:00.192 Status: dzVents: Debug: Alerte Pollens v1.1: OpenURL: post data = nil
2019-05-04 12:00:00.192 Status: dzVents: Debug: Alerte Pollens v1.1: OpenURL: headers = nil
2019-05-04 12:00:00.192 Status: dzVents: Debug: Alerte Pollens v1.1: OpenURL: callback = Pollens_Trigger
2019-05-04 12:00:00.193 Status: dzVents: Info: Alerte Pollens v1.1: ------ Finished pollens2.lua
2019-05-04 12:00:00.194 Status: EventSystem: Script event triggered: /home/pi/domoticz/dzVents/runtime/dzVents.lua
2019-05-04 12:00:00.699 Status: Starting automatic database backup procedure...
2019-05-04 12:00:01.751 Status: Ending automatic database backup procedure...
2019-05-04 12:00:01.843 Status: dzVents: Info: Handling httpResponse-events for: "Pollens_Trigger
2019-05-04 12:00:01.843 Status: dzVents: Info: Alerte Pollens v1.1: ------ Start external script: pollens2.lua: HTTPResponse: "Pollens_Trigger"
2019-05-04 12:00:01.855 Status: dzVents: Debug: Alerte Pollens v1.1: alerte de niveau 2
2019-05-04 12:00:01.855 Status: dzVents: Debug: Alerte Pollens v1.1: Graminées, Chêne, Platane, Bouleau
2019-05-04 12:00:01.876 Status: dzVents: Debug: Alerte Pollens v1.1: Processing device-adapter for Pollens2: Alert sensor adapter
2019-05-04 12:00:01.876 Status: dzVents: Info: Alerte Pollens v1.1: Alerte de niveau 1 pour les pollens de : Graminées, Chêne, Platane, Bouleau
2019-05-04 12:00:01.877 Status: dzVents: Info: Alerte Pollens v1.1: ------ Finished pollens2.lua
2019-05-04 12:00:01.878 Status: EventSystem: Script event triggered: /home/pi/domoticz/dzVents/runtime/dzVents.lua
C'est tout bon maintenant avec la dernière version de ton script, l'icone dans DZ est bien passé de jaune a vert.
Lou Castelou
Message par Lou Castelou »
Bonjour papoo,
Je souhaie connaître les alertes Pollens pour 2 départements, mais lorsque que le second département s'affiche, il modifie aussi le premier département avec les informations du second alors que les Idx sont correctement libéllés.
Merci de ton appui.
Bonne journée.
papoo
Message par papoo »
Il faut personnaliser le nom de la variable http_response pour ton deuxième script afin qu’il soit unique en ajoutant par exemple le numéro de département dans le nom :
Pollens87_Trigger Pour le premier script
Pollens06_Trigger pour le deuxième script
https://pon.fr github
papoo
Message par papoo »
je viens de mettre mon script à jour (v1.11) pour que cela règle le problème des multiples instances de ce script automatiquement
Lou Castelou
Merci Papoo,
Cela fonctionne super.
Bonne soirée
frtoto
Message par frtoto »
j'ai un souci, l'alerte pollens graminées est passée à 2 sur le site pollens.fr, mon device reste à 1 et quand je regarde les logs j'ai ça :
2019-05-14 17:18:01.463 Status: dzVents: Debug: Alerte Pollens v1.11: alerte de niveau 2
2019-05-14 17:18:01.463 Status: dzVents: Debug: Alerte Pollens v1.11: Graminées
2019-05-14 17:18:01.479 Status: dzVents: Debug: Alerte Pollens v1.11: Processing device-adapter for Pollens Graminées: Alert sensor adapter
2019-05-14 17:18:01.479 Status: dzVents: Info: Alerte Pollens v1.11: Alerte de niveau 1 pour les pollens de : Graminées
2019-05-14 17:18:01.481 Status: dzVents: Info: Alerte Pollens v1.11: ------ Finished Script #1
visiblement il passe bien à 2 mais repasse à 1 tout de suite
infos :
À propos de Domoticz
Version: 4.10688
Build Hash: 88a90c32
Compile Date: 2019-05-05 08:52:52
dzVents Version: 2.4.18
Dz 2025.11_16729 - Conbee II
frtoto
Bon j'ai compris que le site pollens.fr codait son risque de 0 à 5 et a priori le dummy alerte ne va que jusqu'à 4 d'où un "regroupement" des niveaux 1 et 2 en un seul niveau 1.
Tu confirmes Papoo ?
papoo
Message par papoo »
c'est exactement ça
les risques 1 et 2 ayant peu d'impact sur nous j'ai jugé plus cohérent de regrouper c'est deux là plutôt que les 4 et 5.
si des personnes sont très sensibles dès l'apparition de certains pollens il est très simple d'adapter le script pour modifier cela, mais pour le plus grand nombre cela me semble mieux ainsi
Wolfen38
Chez moi ca marche top, mais je vais faire le chiant vu que j'y connais pas grand chose...
Y aurait moyen d'afficher le niveau d'alerte dans le widget dz ? Car j'ai du mal a voir la différence de couleur, par ex aujourd'hui je suis passé de 3 à 4, et je vois pas de différence de jaune....
et est ce possible de recevoir une notification en cas de changement de niveau d'alerte ?
papoo
Message par papoo »
tu peux éventuellement modifier le commentaire pour ajouter le niveau d'alerte, mais pour ma part cela fait double emploi avec la couleur.
surtout si tu paramètres une notification. pour cela plusieurs solutions, le script JsonDescription ou directement dans l'onglet notification du widget concerné
2019-05-15 21_35_09-Window.png (10.38 Kio) Consulté 5508 fois
