Voici le log avec toutes les options validées dans la conf du plugin, et avec Verbors and Debuging: à none
2019-11-12 21:53:33.805 Status: Domoticz V4.11474 (c)2012-2019 GizMoCuz
2019-11-12 21:53:33.807 Status: Build Hash: 12feb06f1, Date: 2019-11-08 16:33:53
2019-11-12 21:53:33.808 Status: Startup Path: /home/pi/domoticz/
2019-11-12 21:53:33.836 Sunrise: 07:31:00 SunSet: 17:11:00
2019-11-12 21:53:33.836 Day length: 09:41:00 Sun at south: 12:21:00
2019-11-12 21:53:33.836 Civil twilight start: 06:59:00 Civil twilight end: 17:43:00
2019-11-12 21:53:33.836 Nautical twilight start: 06:24:00 Nautical twilight end: 18:18:00
2019-11-12 21:53:33.836 Astronomical twilight start: 05:49:00 Astronomical twilight end: 18:53:00
2019-11-12 21:53:33.896 Status: PluginSystem: Started, Python version '3.7.3'.
2019-11-12 21:53:33.904 Active notification Subsystems: (0/13)
2019-11-12 21:53:33.905 Status: WebServer(HTTP) started on address: :: with port 8080
2019-11-12 21:53:33.910 Status: WebServer(SSL) started on address: :: with port 443
2019-11-12 21:53:33.949 Starting shared server on: :::6144
2019-11-12 21:53:33.949 Status: TCPServer: shared server started...
2019-11-12 21:53:33.950 Status: RxQueue: queue worker started...
2019-11-12 21:53:35.950 Status: (PiZigate) Started.
2019-11-12 21:53:35.951 Status: EventSystem: reset all events...
2019-11-12 21:53:35.952 Status: EventSystem: reset all device statuses...
2019-11-12 21:53:36.056 Status: Python EventSystem: Initalizing event module.
2019-11-12 21:53:36.057 Status: EventSystem: Started
2019-11-12 21:53:36.057 Status: EventSystem: Queue thread started...
2019-11-12 21:53:36.338 Status: PluginSystem: Entering work loop.
2019-11-12 21:53:36.657 Status: (PiZigate) Entering work loop.
2019-11-12 21:53:36.658 Status: (PiZigate) Initialized version beta-4.6, author 'zaraki673 pipiche38'
2019-11-12 21:53:36.660 Status: (PiZigate) Zigate plugin beta-4.6.017 started
2019-11-12 21:53:36.660 (PiZigate) Debug: 0
2019-11-12 21:53:36.660 Status: (PiZigate) Python Version - 3.7.3 (default, Apr 3 2019, 05:39:12)
[GCC 8.2.0]
2019-11-12 21:53:36.660 Status: (PiZigate) Switching Heartbeat to 5 s interval
2019-11-12 21:53:36.660 Status: (PiZigate) DomoticzVersion: 4.11474
2019-11-12 21:53:36.660 Status: (PiZigate) DomoticzHash: 12feb06f1
2019-11-12 21:53:36.660 Status: (PiZigate) DomoticzBuildTime: 2019-11-08 16:33:53
2019-11-12 21:53:36.661 Status: (PiZigate) load PluginConf
2019-11-12 21:53:36.662 Status: (PiZigate) enableReadAttributes set to 1
2019-11-12 21:53:36.662 Status: (PiZigate) enableAPSFailureLoging set to 1
2019-11-12 21:53:36.662 Status: (PiZigate) allowAutoPairing set to 1
2019-11-12 21:53:36.662 Status: (PiZigate) channel set to 11,15,19,20,25,26
2019-11-12 21:53:36.662 Status: (PiZigate) filename set to /home/pi/domoticz/plugins/Domoticz-Zigate/Conf/PluginConf-03.json
2019-11-12 21:53:36.662 Status: (PiZigate) pluginHome set to /home/pi/domoticz/plugins/Domoticz-Zigate/
2019-11-12 21:53:36.662 Status: (PiZigate) homedirectory set to /home/pi/domoticz/plugins/Domoticz-Zigate/
2019-11-12 21:53:36.662 Status: (PiZigate) pluginData set to /home/pi/domoticz/plugins/Domoticz-Zigate/Data/
2019-11-12 21:53:36.663 Status: (PiZigate) pluginConfig set to /home/pi/domoticz/plugins/Domoticz-Zigate/Conf/
2019-11-12 21:53:36.663 Status: (PiZigate) pluginOTAFirmware set to /home/pi/domoticz/plugins/Domoticz-Zigate/OTAFirmware/
2019-11-12 21:53:36.663 Status: (PiZigate) pluginReports set to /home/pi/domoticz/plugins/Domoticz-Zigate/Reports/
2019-11-12 21:53:36.663 Status: (PiZigate) pluginWWW set to /home/pi/domoticz/plugins/Domoticz-Zigate/www/
2019-11-12 21:53:36.663 Status: (PiZigate) logFORMAT set to 1
2019-11-12 21:53:36.663 Status: (PiZigate) capturePairingInfos set to 1
2019-11-12 21:53:36.663 Status: (PiZigate) debugInput set to 1
2019-11-12 21:53:36.663 Status: (PiZigate) debugOutput set to 1
2019-11-12 21:53:36.663 Status: (PiZigate) debugTransportTx set to 1
2019-11-12 21:53:36.663 Status: (PiZigate) debugTransportRx set to 1
2019-11-12 21:53:36.663 Status: (PiZigate) debugCluster set to 1
2019-11-12 21:53:36.663 Status: (PiZigate) debugHeartbeat set to 1
2019-11-12 21:53:36.663 Status: (PiZigate) debugWidget set to 1
2019-11-12 21:53:36.663 Status: (PiZigate) debugPlugin set to 1
2019-11-12 21:53:36.663 Status: (PiZigate) debugDatabase set to 1
2019-11-12 21:53:36.663 Status: (PiZigate) debugCommand set to 1
2019-11-12 21:53:36.663 Status: (PiZigate) debugPairing set to 1
2019-11-12 21:53:36.663 Status: (PiZigate) debugNetworkMap set to 1
2019-11-12 21:53:36.663 Status: (PiZigate) debugNetworkEnergy set to 1
2019-11-12 21:53:36.663 Status: (PiZigate) debugGroups set to 1
2019-11-12 21:53:36.663 Status: (PiZigate) debugOTA set to 1
2019-11-12 21:53:36.663 Status: (PiZigate) debugIAS set to 1
2019-11-12 21:53:36.663 Status: (PiZigate) debugAPS set to 1
2019-11-12 21:53:36.663 Status: (PiZigate) debugWebServer set to 1
2019-11-12 21:53:36.664 Status: (PiZigate) Opening DomoticzDB in raw
2019-11-12 21:53:36.664 (PiZigate) Opening /home/pi/domoticz/domoticz.db
2019-11-12 21:53:36.669 Error: (PiZigate) retreiveWebUserNamePassword - Exception: 'NoneType' object is not subscriptable
2019-11-12 21:53:36.670 Status: (PiZigate) Domoticz Website credentials None/None
2019-11-12 21:53:36.678 Status: (PiZigate) Plugin Database: DeviceList-3.txt
2019-11-12 21:53:36.703 Status: (PiZigate) DeviceConf loaded
2019-11-12 21:53:36.703 Status: (PiZigate) load ListOfDevice
2019-11-12 21:53:36.718 Status: (PiZigate) Entries loaded from /home/pi/domoticz/plugins/Domoticz-Zigate/Data/DeviceList-3.txt : 0
2019-11-12 21:53:36.718 Status: (PiZigate) Transport mode: PI
2019-11-12 21:53:36.735 Status: (PiZigate) Python version: ['3.7.3 (default, Apr 3 2019, 05:39:12) ', '[GCC 8.2.0]'] dist: ('debian', '10.1', '') linux_distribution: ('debian', '10.1', '') system: Linux machine: armv7l platform: Linux-4.19.75-v7+-armv7l-with-debian-10.1 uname: uname_result(system='Linux', node='domoticz', release='4.19.75-v7+', version='#1270 SMP Tue Sep 24 18:45:11 BST 2019', machine='armv7l', processor='') version: #1270 SMP Tue Sep 24 18:45:11 BST 2019 mac_ver: ('', ('', '', ''), '')
2019-11-12 21:53:36.737 (PiZigate) runmode_with_gpiocommand
2019-11-12 21:53:36.737 (PiZigate) + Checkint GPIO PINs
2019-11-12 21:53:36.843 (PiZigate) + Checkint GPIO PINs
2019-11-12 21:53:36.886 (PiZigate) STANDALONE_MESSAGE: [1024, 33793, 32769, 32771, 32772, 32773, 32774, 32775, 32785, 32840, 32901, 32917, 33025, 33026, 34561, 34562, 77]
2019-11-12 21:53:36.886 (PiZigate) CMD_ONLY_STATUS: [17, 18, 19, 22, 24, 25, 32, 33, 34, 35, 37, 38, 39, 41, 71, 73, 100, 101, 112, 113, 128, 129, 130, 131, 132, 146, 147, 148, 208, 210, 256, 1328, 2054]
2019-11-12 21:53:36.890 (PiZigate) ZIGATE_COMMANDS: {9: {'Sequence': (32768, 32777), 'Command': 'Get Network State (Firm v3.0d)', 'NwkId 2nd Bytes': False}, 16: {'Sequence': (32768, 32784), 'Command': 'Get Version', 'NwkId 2nd Bytes': False}, 17: {'Sequence': (32768,), 'Command': 'Reset', 'NwkId 2nd Bytes': False}, 18: {'Sequence': (32768,), 'Command': 'Erase Persistent Data', 'NwkId 2nd Bytes': False}, 19: {'Sequence': (32768,), 'Command': 'ZLO/ZLL “Factory New†Reset', 'NwkId 2nd Bytes': False}, 20: {'Sequence': (32768, 32788), 'Command': 'Permit Join', 'NwkId 2nd Bytes': False}, 21: {'Sequence': (32768, 32789), 'Command': 'Get devices list', 'NwkId 2nd Bytes': False}, 22: {'Sequence': (32768,), 'Command': 'Set Time server (v3.0f)', 'NwkId 2nd Bytes': False}, 23: {'Sequence': (32768, 32791), 'Command': 'GetTime server (v3.0f)', 'NwkId 2nd Bytes': False}, 24: {'Sequence': (32768,), 'Command': 'SetLed (v3.0f)', 'NwkId 2nd Bytes': False}, 25: {'Sequence': (32768,), 'Command': 'Set Certification (v3.0f)', 'NwkId 2nd Bytes': False}, 32: {'Sequence': (32768,), 'Command': 'Set Expended PANID', 'NwkId 2nd Bytes': False}, 33: {'Sequence': (32768,), 'Command': 'Set Channel Mask', 'NwkId 2nd Bytes': False}, 34: {'Sequence': (32768,), 'Command': 'Set Security State + Key', 'NwkId 2nd Bytes': False}, 35: {'Sequence': (32768,), 'Command': 'Set device Type', 'NwkId 2nd Bytes': False}, 36: {'Sequence': (32768, 32804), 'Command': 'Start Network', 'NwkId 2nd Bytes': False}, 37: {'Sequence': (32768,), 'Command': 'Start Network Scan', 'NwkId 2nd Bytes': False}, 38: {'Sequence': (32768,), 'Command': 'Remove Device', 'NwkId 2nd Bytes': False}, 39: {'Sequence': (32768,), 'Command': 'Enable Permissions Controlled Joins', 'NwkId 2nd Bytes': False}, 40: {'Sequence': (32768, 32808), 'Command': 'Authenticate Device', 'NwkId 2nd Bytes': False}, 41: {'Sequence': (32768,), 'Command': 'Out of Band Commissioning Data Request', 'NwkId 2nd Bytes': False}, 43: {'Sequence': (32768, 32811), 'Command': 'User Descriptor Set', 'NwkId 2nd Bytes': False}, 44: {'Sequence': (32768, 32812), 'Command': 'User Descritpor Request', 'NwkId 2nd Bytes': False}, 1329: {'Sequence': (32768, 34096), 'Command': 'Complex Descriptor request', 'NwkId 2nd Bytes': False}, 48: {'Sequence': (32768, 32816), 'Command': 'Bind', 'NwkId 2nd Bytes': False}, 49: {'Sequence': (32768, 32817), 'Command': 'Unbind', 'NwkId 2nd Bytes': False}, 64: {'Sequence': (32768, 32832), 'Command': 'Network Address request', 'NwkId 2nd Bytes': False}, 65: {'Sequence': (32768, 32833), 'Command': 'IEEE Address request', 'NwkId 2nd Bytes': False}, 66: {'Sequence': (32768, 32834), 'Command': 'Node Descriptor request', 'NwkId 2nd Bytes': False}, 67: {'Sequence': (32768, 32835), 'Command': 'Simple Descriptor request', 'NwkId 2nd Bytes': False}, 68: {'Sequence': (32768, 28740), 'Command': 'Power Descriptor request', 'NwkId 2nd Bytes': False}, 69: {'Sequence': (32768, 32837), 'Command': 'Active Endpoint request', 'NwkId 2nd Bytes': False}, 70: {'Sequence': (32768, 32838), 'Command': 'Match Descriptor request', 'NwkId 2nd Bytes': False}, 71: {'Sequence': (32768,), 'Command': 'Management Leave request', 'NwkId 2nd Bytes': False}, 73: {'Sequence': (32768,), 'Command': 'Permit Joining request', 'NwkId 2nd Bytes': False}, 74: {'Sequence': (32768, 32842), 'Command': 'Management Network Update request', 'NwkId 2nd Bytes': False}, 75: {'Sequence': (32768, 32843), 'Command': 'System Server Discovery request', 'NwkId 2nd Bytes': False}, 78: {'Sequence': (32768, 32846), 'Command': 'Management LQI request', 'NwkId 2nd Bytes': False}, 96: {'Sequence': (32768, 32864), 'Command': 'Group Add', 'NwkId 2nd Bytes': True}, 97: {'Sequence': (32768, 32865), 'Command': 'Group View', 'NwkId 2nd Bytes': True}, 98: {'Sequence': (32768, 32866), 'Command': 'Get Group membership', 'NwkId 2nd Bytes': True}, 99: {'Sequence': (32768, 32867), 'Command': 'Group Remove', 'NwkId 2nd Bytes': True}, 100: {'Sequence': (32768,), 'Command': 'Remove all Groups', 'NwkId 2nd Bytes': True}, 101: {'Sequence': (32768,), 'Command': 'Group Add by Identify', 'NwkId 2nd Bytes': True}, 112: {'Sequence': (32768,), 'Command': 'Identify Send', 'NwkId 2nd Bytes': True}, 113: {'Sequence': (32768,), 'Command': 'Identify Query', 'NwkId 2nd Bytes': True}, 128: {'Sequence': (32768,), 'Command': 'Move to Level', 'NwkId 2nd Bytes': True}, 129: {'Sequence': (32768,), 'Command': 'Move to Level with/without on/off', 'NwkId 2nd Bytes': True}, 130: {'Sequence': (32768,), 'Command': 'Move Step', 'NwkId 2nd Bytes': True}, 131: {'Sequence': (32768,), 'Command': 'Move Stop Move', 'NwkId 2nd Bytes': True}, 132: {'Sequence': (32768,), 'Command': 'Move Stop with On Off', 'NwkId 2nd Bytes': True}, 146: {'Sequence': (32768,), 'Command': 'Action ON/OFF', 'NwkId 2nd Bytes': True}, 147: {'Sequence': (32768,), 'Command': 'On/off timed send', 'NwkId 2nd Bytes': True}, 148: {'Sequence': (32768,), 'Command': 'On/off with effects send', 'NwkId 2nd Bytes': True}, 176: {'Sequence': (32768, 32770), 'Command': 'Move to Hue', 'NwkId 2nd Bytes': True}, 177: {'Sequence': (32768, 32770), 'Command': 'Move Hue', 'NwkId 2nd Bytes': True}, 178: {'Sequence': (32768, 32770), 'Command': 'Step Hue', 'NwkId 2nd Bytes': True}, 179: {'Sequence': (32768, 32770), 'Command': 'Move to saturation', 'NwkId 2nd Bytes': True}, 180: {'Sequence': (32768, 32770), 'Command': 'Move saturation', 'NwkId 2nd Bytes': True}, 181: {'Sequence': (32768, 32770), 'Command': 'Step saturation', 'NwkId 2nd Bytes': True}, 182: {'Sequence': (32768, 32770), 'Command': 'Move to hue and saturation', 'NwkId 2nd Bytes': True}, 183: {'Sequence': (32768, 32770), 'Command': 'Move to colour', 'NwkId 2nd Bytes': True}, 184: {'Sequence': (32768, 32770), 'Command': 'Move colour', 'NwkId 2nd Bytes': True}, 185: {'Sequence': (32768, 32770), 'Command': 'Step Colour', 'NwkId 2nd Bytes': True}, 186: {'Sequence': (32768, 32770), 'Command': 'Enhaced Move to Hue', 'NwkId 2nd Bytes': True}, 187: {'Sequence': (32768, 32770), 'Command': 'Enhanced Move Hue', 'NwkId 2nd Bytes': True}, 188: {'Sequence': (32768, 32770), 'Command': 'Enhanced Step Hue', 'NwkId 2nd Bytes': True}, 189: {'Sequence': (3
2019-11-12 21:53:36.890 (PiZigate) CMD_NWK_2NDBytes: {96: 96, 97: 97, 98: 98, 99: 99, 100: 100, 101: 101, 112: 112, 113: 113, 128: 128, 129: 129, 130: 130, 131: 131, 132: 132, 146: 146, 147: 147, 148: 148, 176: 176, 177: 177, 178: 178, 179: 179, 180: 180, 181: 181, 182: 182, 183: 183, 184: 184, 185: 185, 186: 186, 187: 187, 188: 188, 189: 189, 190: 190, 191: 191, 192: 192, 193: 193, 194: 194, 208: 208, 210: 210, 224: 224, 240: 240, 250: 250, 256: 256, 272: 272, 273: 273, 274: 274, 288: 288}
2019-11-12 21:53:36.891 Status: (PiZigate) Connection Name: Zigate, Transport: Serial, Address: /dev/ttyAMA0
2019-11-12 21:53:36.891 (PiZigate) Connection open: Name: 'ZiGate', Transport: 'Serial', Protocol: 'None', Address: '/dev/ttyAMA0', Port: '', Baud: 115200, Connected: False, Parent: 'None'
2019-11-12 21:53:36.893 (PiZigate) sendData - 0010 None FIFO: 0
2019-11-12 21:53:36.893 (PiZigate) sendData - zMode: ZigBee Q(Status): 0 Q(Data): 0 sendNow: True
2019-11-12 21:53:36.893 (PiZigate) --> _addCmdToWaitQueue - adding to Queue 0010 1573592016 0
2019-11-12 21:53:36.893 (PiZigate) --> _addCmdToWaitDataQueue - adding to Queue 0010 1573592016 0
2019-11-12 21:53:36.893 (PiZigate) --> _sendData - 0010 0
2019-11-12 21:53:36.895 (PiZigate) --> _sendData - sending encoded Cmd: 021010 length: 02100210 CRC: 10 Data:
2019-11-12 21:53:36.895 Status: (PiZigate) setTimeServer - Setting UTC Time to : 626910816
2019-11-12 21:53:36.895 (PiZigate) sendData - 0016 255de660 None FIFO: 0
2019-11-12 21:53:36.895 (PiZigate) sendData - zMode: ZigBee Q(Status): 1 Q(Data): 1 sendNow: False
2019-11-12 21:53:36.895 (PiZigate) sendData - put in waiting queue
2019-11-12 21:53:36.896 (PiZigate) --> _addCmdToSendQueue - adding to Queue 0016 255de660 1573592016 0
2019-11-12 21:53:36.896 (PiZigate) sendData - 0017 None FIFO: 1
2019-11-12 21:53:36.896 (PiZigate) sendData - zMode: ZigBee Q(Status): 1 Q(Data): 1 sendNow: False
2019-11-12 21:53:36.896 (PiZigate) sendData - put in waiting queue
2019-11-12 21:53:36.896 (PiZigate) --> _addCmdToSendQueue - adding to Queue 0017 1573592016 0
2019-11-12 21:53:36.896 Status: (PiZigate) Configure Permit To Join
2019-11-12 21:53:36.896 Status: (PiZigate) Request Accepting new Hardware for ever
2019-11-12 21:53:36.896 (PiZigate) sendData - 0049 FFFCff00 None FIFO: 2
2019-11-12 21:53:36.897 (PiZigate) sendData - zMode: ZigBee Q(Status): 1 Q(Data): 1 sendNow: False
2019-11-12 21:53:36.897 (PiZigate) sendData - put in waiting queue
2019-11-12 21:53:36.897 (PiZigate) --> _addCmdToSendQueue - adding to Queue 0049 FFFCff00 1573592016 0
2019-11-12 21:53:36.897 (PiZigate) Permit Join set :
2019-11-12 21:53:36.897 (PiZigate) ---> self.permitTojoin['Starttime']: 1573592016
2019-11-12 21:53:36.897 (PiZigate) ---> self.permitTojoin['Duration'] : 255
2019-11-12 21:53:36.897 (PiZigate) sendData - 0017 None FIFO: 3
2019-11-12 21:53:36.897 (PiZigate) --> _addCmdToSendQueue - adding to Queue 0017 1573592016 0
2019-11-12 21:53:36.898 (PiZigate) sendData - 0014 None FIFO: 4
2019-11-12 21:53:36.898 (PiZigate) sendData - zMode: ZigBee Q(Status): 1 Q(Data): 1 sendNow: False
2019-11-12 21:53:36.898 (PiZigate) sendData - put in waiting queue
2019-11-12 21:53:36.898 (PiZigate) --> _addCmdToSendQueue - adding to Queue 0014 1573592016 0
2019-11-12 21:53:36.898 (PiZigate) sendData - 0009 None FIFO: 5
2019-11-12 21:53:36.898 (PiZigate) --> _addCmdToSendQueue - adding to Queue 0009 1573592016 0
2019-11-12 21:53:36.898 (PiZigate) sendData - 0015 None FIFO: 6
2019-11-12 21:53:36.899 (PiZigate) sendData - zMode: ZigBee Q(Status): 1 Q(Data): 1 sendNow: False
2019-11-12 21:53:36.899 (PiZigate) sendData - put in waiting queue
2019-11-12 21:53:36.899 (PiZigate) --> _addCmdToSendQueue - adding to Queue 0015 1573592016 0
2019-11-12 21:53:36.899 Status: (PiZigate) Trigger a Topology Scan
2019-11-12 21:53:36.899 Status: (PiZigate) Trigger a Energy Level Scan
2019-11-12 21:53:37.000 (PiZigate) onMessage - b'\x01\x80$\x02\x10\x02\x1dP\x02\x11\x02\x10\x02\x10\x02\x10\x15\x8d\x02\x10\x02\x13\xaf_\x98\x02\x1b\x02\x10\x03\x01\x80\x02\x16\x02\x10\x02\x12\x85\x02\x11\x02\x10\x03\x01\x80\x02\x10\x02\x10\x02\x15\x95\x02\x10\x02\x10\x02\x10\x10\x02\x10\x03\x01\x80\x10\x02\x10\x02\x15\x8f\x02\x10\x02\x13\x02\x13\x1a\x02\x10\x03'
2019-11-12 21:53:37.001 (PiZigate) processFrame - Frame: 018024000d5001000000158d0003af5f980b0003
2019-11-12 21:53:37.001 (PiZigate) - MsgType: 8024 MsgLength: 000d MsgCRC: 50
2019-11-12 21:53:37.001 (PiZigate) - Status: 01 SEQ: 00 PacketType: 0000 RSSI: 00
2019-11-12 21:53:37.001 (PiZigate) receiveDataCmd - MsgType: 8024
2019-11-12 21:53:37.001 (PiZigate) - not waiting Data
2019-11-12 21:53:37.001 (PiZigate) Start Network: Network joined / formed Status: 01
2019-11-12 21:53:37.002 (PiZigate) setZigateIEEE - Set Zigate IEEE: 00158d0003af5f98
2019-11-12 21:53:37.002 Status: (PiZigate) Zigate details IEEE: 00158d0003af5f98, NetworkID: 0000, Channel: 0b, Status: 01: ZIGATE - [01] Incorrect Parameters
2019-11-12 21:53:37.417 (PiZigate) checkTOwaitFor - Cmd: 0000 waitQ: 1 dataQ: 1 SendingFIFO: 2
2019-11-12 21:53:37.517 (PiZigate) onMessage - b'\x01\x80\x02\x10\x02\x10\x02\x15\x91\x02\x10\x02\x10\x02\x10\x14\x02\x10\x03\x01\x80\x14\x02\x10\x02\x12\x97\x02\x11\x02\x10\x03'
