Vous avez des questions concernant les scripts dans Domoticz, posez vos questions ici, quelque soit le langage nous tenterons des réponses pertinentes ...
PpeFait=os.capture('sqlite3 '..dbPath..' "select sum(value3) from multimeter where devicerowid='..otherdevices_idx[dev_cptFl]..' and Date(date)=\''..today..'\'"')*5/cst_PpeFl_W
Dummy=os.capture('sqlite3 '..dbPath..' "select sum(value3) from multimeter where devicerowid='..otherdevices_idx[dev_cptFl]..' and Date(date)=\''..today..'\'"')
print("Retour sqlite",Dummy)
2020-04-09 10:31:00.503 Status: LUA: device => Temperature Piscine-svalues dev_TEau => 12.25-
2020-04-09 10:31:00.541 Status: LUA: Retour sqlite
2020-04-09 10:31:00.580 Error: EventSystem: in Filtration_Piscine: [string "--[[ Script de gestion de la piscine ..."]:231: attempt to perform arithmetic on a string value
Pi3b+ SSD
Zigbee Conbee II + Philips hue +Variateurs +smart buttons
Station meteo Netatmo
Plusieurs ESP8266 sous ESPEASY + DS18B20 + BMP280 +Relais
2020-04-09 11:01:00.540 Status: LUA: Script Piscine : Gestion de la filtration
2020-04-09 11:01:00.540 Status: LUA: device => Temperature Piscine-svalues dev_TEau => 13.25-
2020-04-09 11:01:00.566 Status: LUA: Retour sqlite
2020-04-09 11:01:00.592 Error: EventSystem: in Filtration_Piscine: [string "--[[ Script de gestion de la piscine ..."]:231: attempt to perform arithmetic on a string value
Pi3b+ SSD
Dummy='sqlite3 '..dbPath..' "select sum(value3) from multimeter where devicerowid='..otherdevices_idx[dev_cptFl]..' and Date(date)=\''..today..'\'"'
print("Requette sqlite",Dummy)
2020-04-09 11:16:00.366 Status: LUA: Script Piscine : Gestion de la filtration
2020-04-09 11:16:00.366 Status: LUA: device => Temperature Piscine-svalues dev_TEau => 13.75-
2020-04-09 11:16:00.366 Status: LUA: Requette sqlite
2020-04-09 11:16:00.366 Status: LUA: sqlite3 /home/pi/domoticz/domoticz.db "select sum(value3) from multimeter where devicerowid=78 and Date(date)='2020-04-09'"
2020-04-09 11:16:00.397 Error: EventSystem: in Filtration_Piscine: [string "--[[ Script de gestion de la piscine ..."]:231: attempt to perform arithmetic on a string value
note: l'IDX 78 correspond bien a dev_cptFl = "Consommation Piscine"
Pi3b+ SSD
