bon .... je crois que je vais y passé mes vacances ...
aprés je sais plus combien d'instal , ...
J'ai plus d'interface graphique sur le raspberry ...
j'ai retrouvé ma zigate dans domoticz avec la partie admin ( la même qu'au début) avec le plugin a jour !
- 5.jpg (153.43 Kio) Consulté 1383 fois
MAIS j'ai toujours pas de températures !!!!
- Image6.jpg (72.43 Kio) Consulté 1383 fois
zigate - Zigate Status
2021-08-16 15:04:24 Ready
2021-08-16 15:03:53 Startup
2021-08-16 15:03:37 No Communication
2021-08-16 14:55:01 Ready
2021-08-16 14:54:56 Busy
2021-08-16 14:53:41 Ready
2021-08-16 14:53:11 Startup
zigate - Zigate Notifications
2021-08-16 15:04:09 Zigate Channel: 11
2021-08-16 15:04:09 Zigate IEEE: 00158d00050072de
2021-08-16 14:54:56 Successful creation of Widget for :TH01 DeviceID: 61e3
2021-08-16 14:53:26 Zigate Channel: 11
2021-08-16 14:42:54 Zigate IEEE: 00158d00050072de
au niveau des log :
2021-08-16 15:03:50.381 Sunrise: 07:12:00 SunSet: 20:43:00
2021-08-16 15:03:50.381 Day length: 13:31:00 Sun at south: 13:58:00
2021-08-16 15:03:50.381 Civil twilight start: 06:45:00 Civil twilight end: 21:11:00
2021-08-16 15:03:50.381 Nautical twilight start: 06:12:00 Nautical twilight end: 21:44:00
2021-08-16 15:03:50.381 Astronomical twilight start: 05:38:00 Astronomical twilight end: 22:18:00
2021-08-16 15:03:50.869 Active notification Subsystems: (0/13)
2021-08-16 15:03:50.904 Starting shared server on: :::6144
2021-08-16 15:03:50.112 Status: Domoticz V2021.1 (c)2012-2021 GizMoCuz
2021-08-16 15:03:50.115 Status: Build Hash: 8547c5b7e, Date: 2021-04-17 17:29:11
2021-08-16 15:03:50.119 Status: Startup Path: /home/pi/domoticz/
2021-08-16 15:03:50.863 Status: PluginSystem: Started, Python version '3.7.3'.
2021-08-16 15:03:50.882 Status: WebServer(HTTP) started on address: :: with port 8080
2021-08-16 15:03:50.900 Status: WebServer(SSL) started on address: :: with port 443
2021-08-16 15:03:50.904 Status: TCPServer: shared server started...
2021-08-16 15:03:50.905 Status: RxQueue: queue worker started...
2021-08-16 15:03:52.905 zigate hardware started.
2021-08-16 15:03:52.905 Status: zigate: (zigate) Entering work loop.
2021-08-16 15:03:52.905 Status: zigate: (zigate) Started.
2021-08-16 15:03:52.905 Status: NotificationSystem: thread started...
2021-08-16 15:03:52.908 Status: EventSystem: reset all events...
2021-08-16 15:03:52.921 Status: EventSystem: reset all device statuses...
2021-08-16 15:03:52.932 Status: PluginSystem: 1 plugins started.
2021-08-16 15:03:53.966 zigate: (zigate) ZiGate plugin started!
2021-08-16 15:03:53.969 zigate: (zigate) load PluginConf
2021-08-16 15:03:53.972 zigate: (zigate) /home/pi/domoticz/plugins/Domoticz-Zigate/Conf/PluginConf-02.json timestamp is 1629117778.1899998
2021-08-16 15:03:53.972 zigate: (zigate) Dz PluginConf is older than Json Dz: 0 Json: 1629117778.1899998
2021-08-16 15:03:53.973 zigate: (zigate) PluginConf Loaded from Dz: 0 from Json: 10
2021-08-16 15:03:53.975 zigate: (zigate) Starting LoggingManagement thread
2021-08-16 15:03:53.975 zigate: (zigate) start_logging_thread
2021-08-16 15:03:53.975 zigate: (zigate) logging_thread - listening
2021-08-16 15:03:53.048 Status: Python EventSystem: Initalizing event module.
2021-08-16 15:03:53.049 Status: EventSystem: Started
2021-08-16 15:03:53.049 Status: EventSystem: Queue thread started...
2021-08-16 15:03:53.956 Status: zigate: (zigate) Initialized version 5.1, author 'zaraki673 pipiche38'
2021-08-16 15:03:53.974 Status: zigate: (zigate) channel set to 11
2021-08-16 15:03:53.974 Status: zigate: (zigate) filename set to /home/pi/domoticz/plugins/Domoticz-Zigate/Conf/PluginConf-02.json
2021-08-16 15:03:53.974 Status: zigate: (zigate) pluginHome set to /home/pi/domoticz/plugins/Domoticz-Zigate/
2021-08-16 15:03:53.974 Status: zigate: (zigate) homedirectory set to /home/pi/domoticz/plugins/Domoticz-Zigate/
2021-08-16 15:03:53.974 Status: zigate: (zigate) pluginData set to /home/pi/domoticz/plugins/Domoticz-Zigate/Data/
2021-08-16 15:03:53.974 Status: zigate: (zigate) pluginConfig set to /home/pi/domoticz/plugins/Domoticz-Zigate/Conf/
2021-08-16 15:03:53.974 Status: zigate: (zigate) pluginOTAFirmware set to /home/pi/domoticz/plugins/Domoticz-Zigate/OTAFirmware/
2021-08-16 15:03:53.974 Status: zigate: (zigate) pluginReports set to /home/pi/domoticz/plugins/Domoticz-Zigate/Reports/
2021-08-16 15:03:53.974 Status: zigate: (zigate) pluginWWW set to /home/pi/domoticz/plugins/Domoticz-Zigate/www/
2021-08-16 15:03:53.974 Status: zigate: (zigate) pluginLogs set to /home/pi/domoticz/plugins/Domoticz-Zigate/Logs/
2021-08-16 15:03:53.982 Status: zigate: (zigate) Zigate plugin stable5-5.1.006 started
2021-08-16 15:03:54.002 zigate: (zigate) Plugin Database: DeviceList-2.txt
2021-08-16 15:03:54.011 Status: zigate: (zigate) DeviceConf loaded
2021-08-16 15:03:54.462 Status: zigate: (zigate) load ListOfDevice
2021-08-16 15:03:54.555 Status: zigate: (zigate) Connection Name: Zigate, Transport: Serial, Address: /dev/ttyUSB0
2021-08-16 15:03:54.555 Status: zigate: (zigate) 2 Entries loaded from /home/pi/domoticz/plugins/Domoticz-Zigate/Data/DeviceList-2.txt
2021-08-16 15:03:54.556 Status: zigate: (zigate) Transport mode: V2-USB
2021-08-16 15:03:55.065 zigate: (zigate) Connection open: Serial<id=0x6b0a4390, open=True>(port='/dev/ttyUSB0', baudrate=115200, bytesize=8, parity='N', stopbits=1, timeout=None, xonxoff=False, rtscts=True, dsrdtr=False)
2021-08-16 15:03:55.061 Status: zigate: (zigate) ZigateTransport: Serial Connection open: Serial<id=0x6b0a4390, open=True>(port='/dev/ttyUSB0', baudrate=115200, bytesize=8, parity='N', stopbits=1, timeout=None, xonxoff=False, rtscts=True, dsrdtr=False)
2021-08-16 15:03:55.064 Status: zigate: (zigate) ZigateTransport: writer_thread Thread start.
2021-08-16 15:03:55.065 Status: zigate: (zigate) ZigateTransport: thread_processing_and_sending Thread start.
2021-08-16 15:03:59.117 Status: zigate: (zigate) ==> Transport Mode switch to full mode
2021-08-16 15:03:59.134 Status: zigate: (zigate) ZiGate+ (V2)
2021-08-16 15:03:59.134 Status: zigate: (zigate) Installer Version Number: 031f
2021-08-16 15:04:09.151 Status: zigate: (zigate) Zigate addresses ieee: 00158d00050072de , short addr: 0000
2021-08-16 15:04:09.151 Status: zigate: (zigate) Network state UP, PANID: 9e0e extPANID: 0x639f611937baa0a8 Channel: 11
2021-08-16 15:04:14.063 Status: zigate: (zigate) Request Disabling Accepting new Hardware
2021-08-16 15:04:14.704 Status: zigate: (zigate) Accepting new Hardware: Disable (Off)
2021-08-16 15:04:14.910 Status: zigate: (zigate) Number of devices recently active in Zigate = 1
2021-08-16 15:04:14.910 Status: zigate: (zigate) [00] DevID: 00 Network addr: 61e3 IEEE: 00124b0022e9785a LQI: 255 power: 00 Model: TH01 ( temp )
2021-08-16 15:04:19.079 zigate: (zigate) Switch Blue Led On
2021-08-16 15:04:19.080 Status: zigate: (zigate) Zigate set to Certification : CE
2021-08-16 15:04:19.096 Status: zigate: (zigate) Start Web Server connection
2021-08-16 15:04:19.156 Status: zigate: (zigate) Web backend for Web User Interface started on port: 9440
2021-08-16 15:04:19.157 Status: zigate: (zigate) Plugin with Zigate+, firmware 031f correctly initialized
2021-08-16 15:14:04.253 Status: Incoming connection from: 192.168.0.104
2021-08-16 15:24:12.798 zigate: (zigate) Decode8024: Status: 01
2021-08-16 15:24:12.801 zigate: (zigate) Decode8006 - MsgData: 01
2021-08-16 15:24:12.759 Status: zigate: (zigate) ZiGate PDM loaded
2021-08-16 15:24:12.800 Status: zigate: (zigate) Start Network - Formed new network
2021-08-16 15:24:12.801 Status: zigate: (zigate) Zigate details IEEE: 00158d00050072de, NetworkID: 0000, Channel: 11, Status: 01: Success
2021-08-16 15:24:12.801 Status: zigate: (zigate) Non 'Factory new' Restart status: RUNNING
2021-08-16 15:24:24.508 zigate: (zigate) Start Network statusSuccess
2021-08-16 15:24:24.063 Status: zigate: (zigate) ZigateConf setting Channel(s) to: 11
2021-08-16 15:24:24.064 Status: zigate: (zigate) setChannel - Channel set to : 00000800
2021-08-16 15:24:24.065 Status: zigate: (zigate) Force ZiGate to Normal mode
2021-08-16 15:24:24.067 Status: zigate: (zigate) Start network
2021-08-16 15:24:24.068 Status: zigate: (zigate) Set Zigate as a TimeServer
2021-08-16 15:24:25.351 Status: zigate: (zigate) Zigate addresses ieee: 00158d00050072de , short addr: 0000
2021-08-16 15:24:25.351 Status: zigate: (zigate) Network state UP, PANID: 9e0e extPANID: 0x639f611937baa0a8 Channel: 11
2021-08-16 15:24:41.567 Status: zigate: (zigate) Request Accepting new Hardware for ever
2021-08-16 15:24:41.821 Status: zigate: (zigate) Accepting new Hardware: Enable (On)
2021-08-16 15:24:54.386 zigate: (zigate) ReadAttributeRequest_0000 - Key: 61e3 , Scope: True
2021-08-16 15:25:04.636 zigate: (zigate) UpdateDevice - (zigate - TH01_Temp+Hum) 0:0.0;67.7;1
2021-08-16 15:25:04.642 zigate: (zigate) UpdateDevice - (zigate - TH01_Hum) 67.7:1
2021-08-16 15:25:11.432 Status: zigate: (zigate) Request Disabling Accepting new Hardware
2021-08-16 15:25:11.683 Status: zigate: (zigate) Accepting new Hardware: Disable (Off)
a priori ce serait la sonde qui n'envoi pas .... je n'avais pas encore poster le colis de la passerelle que j'avais acheté en premier ... du coup je le rouvre et re installe tout ...
sceenshot de mon tel ...
et en plus c'est pas le même niveau d'humidité avec la même sonde ... par contre sur le tel çà evolue si je soufle dessus !!
- 6.jpg (17.89 Kio) Consulté 1375 fois
