Re: plantage DZ
Publié : 28 août 2021, 18:56
/etc/init.d/domoticz.sh est bien celui qui est censé démarrer domoticz.
Reprenez le contrôle de votre domotique
https://easydomoticz.com/forum/
pi@raspberrypi:~ $ less /tmp/domoticz.txt
2021-08-29 00:25:10.162 Status: Domoticz V2021.1 (build 13482) (c)2012-2021 GizMoCuz
2021-08-29 00:25:10.162 Status: Build Hash: e8eb6e363, Date: 2021-08-24 17:14:18
2021-08-29 00:25:10.163 Status: Startup Path: /home/pi/domoticz/
2021-08-29 00:25:11.285 Sunrise: 07:04:00 SunSet: 20:40:00
2021-08-29 00:25:11.285 Day length: 13:35:00 Sun at south: 13:52:00
2021-08-29 00:25:11.285 Civil twilight start: 06:31:00 Civil twilight end: 21:12:00
2021-08-29 00:25:11.285 Nautical twilight start: 05:51:00 Nautical twilight end: 21:53:00
2021-08-29 00:25:11.285 Astronomical twilight start: 05:07:00 Astronomical twilight end: 22:37:00
2021-08-29 00:25:12.127 Status: PluginSystem: Started, Python version '3.7.3'.
2021-08-29 00:25:12.168 Active notification Subsystems: email, pushbullet (2/13)
2021-08-29 00:25:12.209 Status: WebServer(HTTP) started on address: :: with port 8080
2021-08-29 00:25:12.337 Status: WebServer(SSL) started on address: :: with port 443
2021-08-29 00:25:12.351 Status: Proxymanager started.
2021-08-29 00:25:12.384 Status: Camera: settings (re)loaded
2021-08-29 00:25:12.395 Starting shared server on: :::6554
2021-08-29 00:25:12.395 Status: TCPServer: shared server started...
2021-08-29 00:25:12.401 Status: RxQueue: queue worker started...
2021-08-29 00:25:12.484 Proxy: Error, reconnecting (Connection refused)
2021-08-29 00:25:14.403 Status: EDF: Teleinfo device uses serial port: /dev/ttyUSB-EDF at 1200 bauds
2021-08-29 00:25:14.412 Status: EDF: CRC checks will be performed on incoming data
2021-08-29 00:25:14.415 Status: switch TV presence: Worker started...
2021-08-29 00:25:14.415 Status: controle batterie zwave: (controle batterie zwave) Entering work loop.
2021-08-29 00:25:14.416 controle batterie zwave hardware started.
2021-08-29 00:25:14.416 Status: controle batterie zwave: (controle batterie zwave) Started.
2021-08-29 00:25:14.417 Status: Harmony: Worker thread started...
2021-08-29 00:25:14.451 Status: hardware pi: System: Raspberry Pi
2021-08-29 00:25:14.498 Status: hardware pi: Hardware Monitor: Started (OStype Raspberry Pi Linux)
2021-08-29 00:25:14.498 Status: hue bridge: Worker started...
2021-08-29 00:25:14.498 Status: clim: ( clim) Entering work loop.
2021-08-29 00:25:14.498 clim hardware started.
2021-08-29 00:25:14.498 Status: clim: ( clim) Started.
2021-08-29 00:25:14.499 Status: NotificationSystem: thread started...
2021-08-29 00:25:14.500 Status: EventSystem: reset all events...
2021-08-29 00:25:14.521 Status: EventSystem: reset all device statuses...
2021-08-29 00:25:14.583 Status: EDF: CRC check mode set to 1
2021-08-29 00:25:14.605 Status: rflink-433: Using serial port: /dev/ttyUSB-RFX433
2021-08-29 00:25:14.859 Status: controle batterie zwave: (controle batterie zwave) Initialized version 0.5.2, author 'logread'
2021-08-29 00:25:14.907 Status: Z-wave: using config in: /home/pi/domoticz/Config/
2021-08-29 00:25:14.956 Status: PluginSystem: 2 plugins started.
2021-08-29 00:25:15.405 Status: clim: ( clim) Initialized version 3.0.0, author 'tixi'
2021-08-29 00:25:15.581 controle batterie zwave: (controle batterie zwave) Debug logging mask set to: NONE
2021-08-29 00:25:15.582 controle batterie zwave: (controle batterie zwave) Setting battery level to full if greater or equal than 75 percent
2021-08-29 00:25:15.582 controle batterie zwave: (controle batterie zwave) Setting battery level to normal if greater or equal than 50 percent
2021-08-29 00:25:15.582 controle batterie zwave: (controle batterie zwave) Setting battery level to empty if less or equal than 25 percent
2021-08-29 00:25:15.584 controle batterie zwave: (controle batterie zwave) Using polling interval of 60 minutes
2021-08-29 00:25:15.593 clim: ( clim) Debug logging mask set to: NONE
2021-08-29 00:25:15.709 Status: Z-wave: Starting...
2021-08-29 00:25:15.709 Status: Z-wave: Version: 1.6-1911-gc6a420ef
2021-08-29 00:25:16.466 hue bridge: Color Switch (Hue color lamp 1)
2021-08-29 00:25:16.546 hue bridge: Color Switch (Hue color go droit)
2021-08-29 00:25:16.609 hue bridge: Color Switch (Hue go gauche)
2021-08-29 00:25:16.638 hardware pi: Temp (Internal Temperature)
2021-08-29 00:25:16.673 hue bridge: Color Switch (Hue color spot centre)
2021-08-29 00:25:16.700 hue bridge: Color Switch (Hue color spot droit)
2021-08-29 00:25:16.721 hue bridge: Color Switch (Hue color spot gauche)
2021-08-29 00:25:16.740 hue bridge: Color Switch (Hue color lamp 2)
2021-08-29 00:25:16.741 Status: Python EventSystem: Initializing event module.
2021-08-29 00:25:16.743 Status: EventSystem: Started
2021-08-29 00:25:16.744 Status: EventSystem: Queue thread started...
2021-08-29 00:25:16.782 EDF: General/kWh (Teleinfo kWh Heures Creuses)
pi@raspberrypi:~ $ sudo service domoticz.sh status
● domoticz.service - LSB: Home Automation System
Loaded: loaded (/etc/init.d/domoticz.sh; generated)
Active: active (exited) since Sun 2021-08-29 00:25:10 CEST; 8min ago
Process: 608 ExecStart=/etc/init.d/domoticz.sh start (code=exited, status=0/SUCCESS)
Aug 29 00:24:30 raspberrypi systemd[1]: Starting LSB: Home Automation System...
Aug 29 00:25:10 raspberrypi domoticz.sh[608]: 2021-08-29 00:25:10.162 Status: Domoticz V2021.1 (build 13482) (c)2012-2021 GizMoCuz
Aug 29 00:25:10 raspberrypi domoticz.sh[608]: 2021-08-29 00:25:10.162 Status: Build Hash: e8eb6e363, Date: 2021-08-24 17:14:18
Aug 29 00:25:10 raspberrypi domoticz.sh[608]: 2021-08-29 00:25:10.163 Status: Startup Path: /home/pi/domoticz/
Aug 29 00:25:10 raspberrypi domoticz.sh[608]: domoticz: Domoticz is starting up....
Aug 29 00:25:10 raspberrypi domoticz[620]: Domoticz is starting up....
Aug 29 00:25:10 raspberrypi domoticz[624]: Domoticz running...
Aug 29 00:25:10 raspberrypi systemd[1]: Started LSB: Home Automation System.
pi@raspberrypi:~ $
