[{"datetime":"2023-04-16","datetimeEpoch":1681596000,"tempmax":13.9,"tempmin":7.1,"temp":11.6,"feelslikemax":13.9,"feelslikemin":6.1,"feelslike":11.4,"dew":4.6,"humidity":62.8,"precip":0.0,"precipprob":0.0,"precipcover":0.0,"preciptype":null,"snow":0.0,"snowdepth":0.0,"windgust":34.6,"windspeed":19.8,"winddir":7.6,"pressure":1025.0,"cloudcover":83.8,"visibility":24.1,"solarradiation":368.7,"solarenergy":13.4,"uvindex":7.0,"severerisk":10.0,"sunrise":"06:59:55","sunriseEpoch":1681621195,"sunset":"20:43:23","sunsetEpoch":1681670603,"moonphase":0.87,"conditions":"Partially cloudy","description":"Becoming cloudy in the afternoon.","icon":"partly-cloudy-day","stations":null,"source":"fcst"}],"stations":{"AU951":{"distance":18969.0,"latitude":48.599,"longitude":2.064,"useCount":0,"id":"AU951","name":"F5POE Forges-les-bains FR","quality":0,"contribution":0.0},"LFPO":{"distance":35385.0,"latitude":48.73,"longitude":2.4,"useCount":0,"id":"LFPO","name":"LFPO","quality":49,"contribution":0.0},"LFPN":{"distance":34043.0,"latitude":48.75,"longitude":2.12,"useCount":0,"id":"LFPN","name":"LFPN","quality":50,"contribution":0.0}},"currentConditions":{"datetime":"14:35:00","datetimeEpoch":1681648500,"temp":15.0,"feelslike":15.0,"humidity":46.5,"dew":3.6,"precip":0.0,"precipprob":0.0,"snow":0.0,"snowdepth":0.0,"preciptype":null,"windgust":null,"windspeed":24.1,"winddir":355.0,"pressure":1025.0,"visibility":10.0,"cloudcover":88.0,"solarradiation":745.0,"solarenergy":2.7,"uvindex":7.0,"conditions":"Partially cloudy","icon":"partly-cloudy-day","stations":["AU951","LFPO","LFPN"],"source":"obs","sunrise":"06:59:55","sunriseEpoch":1681621195,"sunset":"20:43:23","sunsetEpoch":1681670603,"moonphase":0.87}}
[DzVents] Données Météo Weather Visual Crossing
Re: [DzVents] Données Météo Weather Visual Crossing
Dans ma requete JSON j'ai bien l'air de tour récupérer oui c'est pour ca que je pige pas pourquoi via le script ca ne passe pas :
Je n'arrive pas à lire ton Json. Enregistre-le sous un fichier .json et ajoute-le à ton message (onglet fichier joint en dessous de la zonne de rédaction).
Tu n'as pas d'erreurs dans les logs de DomoticZ ?
Pour info, le PR intégrant nativement Visual Crossing a été intégré ce matin en béta, avec d'autres corrections mineures... Et OZW est toujours là pour ceux qui se refusent toujours à passer à ZwajeJS.
Probable que les build soient déjà dispo, je devrais faire la MAJ demain si j'ai un peu de temps.
Voici le fichier (ca correspond a la requete test d'exemple que tu as mis dans ton post) que j'ai custom avec ma KEY API et ma ville.
Au niveau de mes logs j'ai cette erreur qui correspond au Barometre et qui persiste, j'ai testé plusieurs types de widgets de type Barometre au cas ou mais ca ne change rien :
Merci pour ton aide car la je galère2023-04-17 11:40:06.232 Error: dzVents: Error: (2.5.3) -- weather.visualcrossing v1.1: There is no device with that name or id: Barometre
2023-04-17 11:40:06.232 Error: dzVents: Error: (2.5.3) -- weather.visualcrossing v1.1: An error occurred when calling event handler weathervisualcrossing
2023-04-17 11:40:06.232 Error: dzVents: Error: (2.5.3) -- weather.visualcrossing v1.1: ...moticz/scripts/dzVents/scripts/weathervisualcrossing.lua:52: attempt to index a nil value
- Pièces jointes
requete.json- (1.91 Kio) Téléchargé 186 fois
Tu n'aurais pas deux widgets avec le même nom ?
Tu pourrais lancer cette adresse IP_domoticz:Port/json.htm?type=devices&rid=IDX dans ton navigateur en mettant l'adresse de DomoticZ et le numéro Idx de ton widget barometre et nous mettre le Json en pièce jointe.
Mets-nous également ton script en entier stp.
Voila
Et voici la derniere erreur quand je recréer un widget barometre (j'en ai bien que 1 seul avec ce nom) :
--[[ --[[ ~/home/pi/domoticz/scripts/dzVents/scripts/weathervisualcrossing.lua
author : gso
: modifié pour weathervisualcrossing par BernardC
MAJ : 11/04/2023
création : 24/03/2023
Principe :
lien pour inscription à weather visual crossing:
https://www.visualcrossing.com/sign-up
lien pour récupérer la clé:
https://www.visualcrossing.com/account
requête type pour remplacer DarkSky API pour La localitée "Le Mans" dans Sarthe
https://weather.visualcrossing.com/VisualCrossingWebServices/rest/services/timeline/Le%20Mans/today?unitGroup=metric&include=fcst%2Ccurrent&key=<votre cle API>&options=nonulls&contentType=json
local scriptName = 'weather.visualcrossing'
local scriptVersion = '1.1'
-- les 2 variables à renseigner
-- suivant utilisateur
local Localite = 'morigny%20champigny'
local apiKey = 'ma clé'
--local uri = 'https://weather.visualcrossing.com/VisualCrossingWebServices/rest/services/timeline/'..Localite..'?unitGroup=metric&include=events%2Cdays%2Ccurrent%2Chours%2Calerts&key='..apiKey..'&contentType=json'
local uri = 'https://weather.visualcrossing.com/VisualCrossingWebServices/rest/services/timeline/'..Localite..'/today?unitGroup=metric&include=fcst%2Ccurrent&key='..apiKey..'&options=nonulls&contentType=json'
local prefix = 'WVC'
local StMeteo = { -- devices idx (à modifier en conséquence), fonction de maj donnée devices domoticz
-- {idx = 0, cde = function (dz, idx, v) dz.devices(idx).updateTempHum(v.currentConditions.temp, v.currentConditions.humidity, dz.HUM_COMPUTE) end },
-- Dew Point (°C) point rosée
-- {idx = 0, cde = function (dz, idx, v) dz.devices(idx).updateTemperature(v.currentConditions.dew) end },
-- Pression amosphérique
--{idx = 0, cde = function (dz, idx, v) dz.devices(idx).updatePressure(v.currentConditions.pressure) end },
--THB Barometre
{idx = 'Barometre', cde = function (dz, idx, v)
local precipprobr= v.currentConditions.precipprob -- probability of precipitation for tomorrow
local clouds = v.currentConditions.cloudcover
local baro = dz.BARO_NOINFO
if v.currentConditions.precipprob >= 0.3 then baro = dz.BARO_RAIN
elseif clouds >= 75 then baro = dz.BARO_CLOUDY
elseif clouds >= 25 then baro = dz.BARO_PARTLYCLOUDY -- et pas BARO_PARTLY_CLOUDY comme dans wiki ??
else baro = dz.BARO_SUNNY
dz.devices(idx).updateTempHumBaro(v.currentConditions.temp,v.currentConditions.humidity,dz.HUM_COMPUTE,v.currentConditions.pressure,baro)
end },
-- UV
{idx = 'UV', cde = function (dz, idx, v) dz.devices(idx).updateUV(v.currentConditions.uvindex) end },
-- Couverture nuageuse
{idx = 'Couverture nuageuse', cde = function (dz, idx, v) dz.devices(idx).updatePercentage(v.currentConditions.cloudcover) end },
-- Visibilité en (km)
{idx = 'Visibilite', cde = function (dz, idx, v) dz.devices(idx).updateVisibility(v.currentConditions.visibility) end },
-- Pluie MAJ le 11/04/2023
{idx = 'Pluie', cde = function (dz, idx, v)
if v.currentConditions.precip == nil then v.currentConditions.precip = 0 end
if v.days[1].precip == nil then v.v.days[1].precip = 0 end
--(hauteur en mm * 100 par heure, le compteur est total en mm)
dz.devices(idx).updateRain(v.currentConditions.precip*100, v.days[1].precip)
end },
-- Vent en m/s MAJ le 11/04/2023
{idx = 'Vent', cde = function (dz, idx, v)
if v.currentConditions.windgust == nil then v.currentConditions.windsgust = v.days[1].windgust end
degrees = v.currentConditions.winddir
local quadrants = {"NNE","NE","ENE","E","ESE","SE","SSE","S","SSW","SW","WSW","W","WNW","NW","NNW"}
local quad = 'N'
if degrees <= 348.75 and degrees > 11.25 then quad = quadrants[tonumber(math.floor((degrees - 11.25) / 22.5)+1)] end
dz.devices(idx).updateWind(degrees, quad, v.currentConditions.windspeed/3.6, v.currentConditions.windgust/3.6, v.currentConditions.temp, v.currentConditions.feelslike)
-- bearing(°), direction(N S NNW..), speed(m/s), gust(m/s), temperature(°C), chill(°C)
-- vitesse vent/3,6 pour adapter l'affichage, les données reçu sont en Km/H
end },
--[[ -- devices à modifier pour l'ajout
-- Snow
{idx = 'Neige', cde = function (dz, idx, v)
if v.current.snow ~= nil then dz.devices(idx).updateRain(v.current.snow['1h']*100, v.daily[1].snow)
elseif v.daily[1] ~= nil then dz.devices(idx).updateRain(0, v.daily[1].snow)
else dz.devices(idx).updateRain(0, 0) end
end }, --rate in mm * 100 per hour, counter is total in mm)
-- Meteo
{idx = Meteo, cde = function (dz, idx, v)
local txt = v.current.weather[1].description..' ('..v.current.weather[1].main..' - '..v.current.weather[1].id..')'
dz.devices(idx).updateText(txt)
end },
-- Moon
{idx = 'Lune', cde = function (dz, idx, v)
-- local dt = os.date("%a %d %b à %X", v.daily[1].dt) -- UTC
local moonrise = os.date("%Hh%M", v.daily[1].moonrise) -- UTC
local moonset = os.date("%Hh%M", v.daily[1].moonset) -- UTC
local p = v.daily[1].moon_phase*100 -- 0 and 1 are 'new moon', 0.25 is 'first quarter moon', 0.5 is 'full moon' and 0.75 is 'last quarter moon'.
if p==0 or p==100 then phase = "Nouvelle Lune ?"
elseif p<25 then phase = "Premier Croissant ?"
elseif p==25 then phase = "Premier Quartier ?"
elseif p<50 then phase = "Gibeuse Croissante ?"
elseif p==50 then phase = "Pleine Lune ?"
elseif p<75 then phase = "Gibeuse Décroissante ?"
elseif p==75 then phase = "Dernier Quartier ?"
elseif p<100 then phase = "Dernier Croissant ?"
-- luminosity
p = 2*p
if p>100 then p = 200-p end
local txt = "Lever à "..moonrise.."\nCoucher à "..moonset.."\nPhase : "..phase.." ("..p.."%)"
end },
-- Moon Phase (%)
{idx = 'Lune phase', cde = function (dz, idx, v)
dz.devices(idx).updatePercentage(v.daily[1].moon_phase*100)
end },
-- Alerts
--,"alerts":[{"sender_name":"METEO-FRANCE","event":"Moderate thunderstorm warning","start":1680321640,"end":1680386400,"description":"Moderate damages may occur, especially in vulnerable or in exposed areas and to people who carry out weather-related activities.","tags":["Thunderstorm"]}]}
{idx = 'Alerte', cde = function (dz, idx, v)
if v.alerts ~= nil then
local txt = ''
for k, alert in ipairs(v.alerts) do
local from = os.date("%a %d %b à %X", alert['start'])
local to = os.date("%a %d %b à %X", alert['end'])
txt = txt..k..'. '..alert.event.."\n"
txt = txt..' du '..from.."\n"
txt = txt..' au '..to.."\n"
txt = txt..alert.description.."\n"
-- txt = txt..alert.sender_name -- Meteo France
txt = txt..' tags : '..table.concat(alert.tags, ', ')..'\n\n'
-- updateAlertSensor(level, text): Function. Level can be domoticz.ALERTLEVEL_GREY, ALERTLEVEL_GREEN, ALERTLEVEL_YELLOW, ALERTLEVEL_ORANGE, ALERTLEVEL_RED. Supports command options.
dz.devices(idx).updateAlertSensor(dz.ALERTLEVEL_RED, txt)
dz.notify('Alerte Météo', txt, dz.PRIORITY_HIGH) -- notify(subject, message, priority, sound) domoticz.PRIORITY_LOW, PRIORITY_MODERATE, PRIORITY_NORMAL, PRIORITY_HIGH, PRIORITY_EMERGENCY
dz.devices(idx).updateAlertSensor(dz.ALERTLEVEL_GREEN, "Pas d'alerte")
end },
-- LOOP
return {
active = true, -- false,
on = {
timer = { "every 5 minutes" },
httpResponses = { "OWMcallback" }, -- correspond au caractère générique de rappel
logging = {
level = domoticz.LOG_ERROR, domoticz.LOG_INFO, --, domoticz.LOG_DEBUG, domoticz.LOG_MODULE_EXEC_INFO
marker = '-- '..scriptName..' v'..scriptVersion
-- LOOP
execute = function(dz, triggerItem)
local function errorMessage(message,notify) -- Ajouter une entrée au journal et notifier à tous les sous-systèmes
dz.log(message, dz.LOG_ERROR)
if notify then
-- dz.notify(message) -- notify(subject, message, priority, sound): Fonction. Envoi d’une notification (Prowl). La priorité sera choisie entre domoticz.PRIORITY_LOW, PRIORITY_MODERATE, PRIORITY_NORMAL, PRIORITY_HIGH, PRIORITY_EMERGENCY
-- MAIN
if triggerItem.isTimer then
local url = uri
dz.openURL({
url = url,
method = "GET",
callback= 'OWMcallback'
}).afterSec(1)
if triggerItem.isHTTPResponse then
if triggerItem.ok and triggerItem.isJSON then
local resultsTable = triggerItem.json
print('reception de weathervisualcrossing')
if resultsTable ~= nil and resultsTable.currentConditions ~= nil then
for k, d in ipairs(StMeteo) do
if d['idx'] ~= 0 then --0
d.cde(dz, d['idx'], resultsTable)
errorMessage("Probleme avec la reponse de weathervisualcrossing", false)
end --execute
2023-04-17 12:40:05.627 Error: dzVents: Error: (2.5.3) -- weather.visualcrossing v1.1: Method updateTempHumBaro is not available for device "Barometre" (deviceType=Temp + Humidity, deviceSubType=THGN122/123/132, THGR122/228/238/268). If you believe this is not correct, please report.
2023-04-17 12:40:05.637 Error: dzVents: Error: (2.5.3) -- weather.visualcrossing v1.1: An error occurred when calling event handler weathervisualcrossing
2023-04-17 12:40:05.637 Error: dzVents: Error: (2.5.3) -- weather.visualcrossing v1.1: ...moticz/scripts/dzVents/scripts/weathervisualcrossing.lua:79: attempt to perform arithmetic on a nil value (field 'windgust')- Pièces jointes
barometre.json- (1.38 Kio) Téléchargé 196 fois
Ton widget est de type Temp + Hum. Il faut un Temp + Hum + Bar. Supprime-le et recréer-le.
Remet nous le Json.
Relance le script.
Mets nous les log
Remet nous le Json.
Relance le script.
Mets nous les log
Voila avec le widget temp+hum+baro
2023-04-17 13:20:06.565 Error: dzVents: Error: (2.5.3) -- weather.visualcrossing v1.1: No status provided. Temperature + humidity not set
2023-04-17 13:20:06.574 Error: dzVents: Error: (2.5.3) -- weather.visualcrossing v1.1: An error occurred when calling event handler weathervisualcrossing
2023-04-17 13:20:06.574 Error: dzVents: Error: (2.5.3) -- weather.visualcrossing v1.1: ...moticz/scripts/dzVents/scripts/weathervisualcrossing.lua:79: attempt to perform arithmetic on a nil value (field 'windgust')- Pièces jointes
Barometre2.json- (1.45 Kio) Téléchargé 183 fois
Un temp hum baro a besoin de 5 valeurs
/json.htm?type=command¶m=udevice&idx=IDX&nvalue=0&svalue=TEMP;HUM;HUM_STAT;BAR;BAR_FORVersion: 2023.1 sur VM Synology, docker Zwave Js UI (Z-stick GEN5, Fibaro...), Zigbeefordomoticz. Nextion RGB Led Screen
Il y aurait bien les 5 Jeff :
Je pense que le problème est maintenant sur un autre Widget. Il faut que je teste le script.
dz.devices(idx).updateTempHumBaro(v.currentConditions.temp,v.currentConditions.humidity,dz.HUM_COMPUTE,v.currentConditions.pressure,baro)Comment bien utiliser le forum : Poser une question, Mettre un script, un fichier, une image ou des logs
