Page 2 sur 2
Re: Mise à jour du Kernel plus de 1-wire...snif
Publié : 22 oct. 2015, 11:30
par beuz33
Est ce que quelqu'un ayant fait la mise a jour kernel aurait le meme fichier config.txt a partagé svp.
Publié : 22 oct. 2015, 22:13
par patrice
Bonsoir
Voici celui que j'ai
# For more options and information see
# http://www.raspberrypi.org/documentation/configuration/config-txt.md
# Some settings may impact device functionality. See link above for details
# uncomment if you get no picture on HDMI for a default "safe" mode
#hdmi_safe=1
# uncomment this if your display has a black border of unused pixels visible
# and your display can output without overscan
#disable_overscan=1
# uncomment the following to adjust overscan. Use positive numbers if console
# goes off screen, and negative if there is too much border
#overscan_left=16
#overscan_right=16
#overscan_top=16
#overscan_bottom=16
# uncomment to force a console size. By default it will be display's size minus
# overscan.
#framebuffer_width=1280
#framebuffer_height=720
# uncomment if hdmi display is not detected and composite is being output
#hdmi_force_hotplug=1
# uncomment to force a specific HDMI mode (this will force VGA)
#hdmi_group=1
#hdmi_mode=1
# uncomment to force a HDMI mode rather than DVI. This can make audio work in
# DMT (computer monitor) modes
#hdmi_drive=2
# uncomment to increase signal to HDMI, if you have interference, blanking, or
# no display
#config_hdmi_boost=4
# uncomment for composite PAL
#sdtv_mode=2
#uncomment to overclock the arm. 700 MHz is the default.
#arm_freq=800
dtparam=spi=on
dtparam=i2c1=on
dtparam=i2c_arm=on
dtoverlay=w1-gpio
gpu_mem=16
Publié : 27 févr. 2024, 00:28
par lolo6112
Je sais que ce fil est très vieux mais comme je pense que certaines personnes trouveront bien le moyen de le lire alors j'interviens.
PRUDENCE EST MERE DE SURETE !!!
La manip "sudo rpi-update" est du ressort de ceux qui maitrisent parfaitement Linux et savent faire un downgrade.
Et surtout, comme de bien entendu avec ce genre de tests, font une sauvegarde complète de la carte SD. Au cas où !
Je fonctionne avec Domoticz depuis 2016, j'y ai une multitude de devices, volets roulants, lumières, sondes diverses et variées, tout type de protocoles . La téléinfo qui remonte en filaire du compteur, au RdC le PI est lui au 2ème . Je précise car j'ai lu des anneries parlant de 1m de câble ou d'autres galejades du genre. EDF donne comme indication 70m de câble dans ses docs. Je ne pense pas que les ingés de chez EDF soient des imbéciles. Et tests sur 8 ans à l'appui cela fonctionne avec un bus qui traverse le RDC et ensuite 2 niveaux, plus un retour au 2ème vers le tableau au plafond soit +/- 25m :D
Alors si, un problème récent, ma téléinfo n'a plus fonctionnée dans Domoticz, elle remontait historiquement en OWL180 (protocole Oregon) par du RF433MHz. En fait j'ai découvert que le nano utilisé pour ça me brulait les émetteurs 433, j'en ai cramé 3. Je n'ai pas cherché plus avant le truc a 8 ans. J'ai modifié le tout en raccordant la téléinfo sur le Rapsberry direct et ça fonctionne, trois fils de plus sur le PI. Cela étant, après 8 ans cette modif ne m'a rien coutée, j'utilise le même optocoupleur un CP817 avec un diode de redressement supplémentaire en entrée pour avoir du vrai DC vs de l'AC mitigé sur la téléinfo. Mais les résultats sont là et montrent que de bidouiller les versions cela n'apporte souvent que des bugs et des soucis, pas toujours la fiabiilité.
Pour mon compte je travaille sur (Au cas où des "news geeks" voudraient rigoler et dirent il n'a rien compris :mrgreen: ) :
- 1 Raspberry PI 2 modèle B, 1 GHz de RAM en 32bits. Jusqu'à preuve du contraire, à part que pour les PC Debian à complétement abandonné la version 32bits depuis Bookworm, je ne vois pas ce qui coince. On parle de Raspberry au pire vous achetez un PI 4 ou un 5 à 100€ et plus, et vous serez en 64bits. Mais franchement il y a vraiment besoin de 64bits pour récupérer des sondes ??? Et 100€ sur le site officiel ça pique très fort je trouve, non ? Je parle d'un PI tout équipé avec une alim. et sa p'tite boite qui va bien et encore j'ai pas compté un câble µHDMI/HDMI, moi mes écrans n'ont pas de µHDMI ;
- Version Linux : Linux raspberry 4.19.58-v7+ #1245 SMP Fri Jul 12 17:25:51 BST 2019 armv77l GNU/Linux. Ce qui sous entend un noyau 4.19.58, une version debian Buster. Si vous êtes curieux faites un "sudo cat /ect/apt/sources.list.d/raspi.list, vous apercevrez à l'écran le dépôt avec quelle version de debian est basé votre raspberry. C'est là qu'il faut changer pour passer à Bulleyes Debian 11 ou dernièrement Bookwoem Debian 12 et ensuite un sudo update suivi d'un sudo upgrade. Clairement les nouvelles versions de Linux ou de son noyau sont là pour les derniers matériels en date, nouveaus Laptops, miniPC, nouvelle version de bluetooth, nouvelle barette RAM, et j'en passe. Moi sur un raspberry 2 modèle B je ne vois pas ce qu'un nouveau noyau ou version va m'apporter, à part des dysfonctionnements avec du matos qui marche très bien lui ! ;
- Domoticz Version 4.10717 depuis 2019, RAS ça tourne et même plutôt bien. J'ai testé la version 2024 sur un autre Raspberry que j'ai, même modèle 2 type B, la 2024 ne m'a pas reconnue correctement tous mes devices, depuis le temps je dois en avoir plus de 70. Et pour tout couronner lorsque j'ai dit à Domoticz la nouvelle "téléinfo" remplace l'ancien "compteur multiple", pour ne pas perdre l'historique, ça a ramé pendant des lustres, j'ai du relancer Domoticz au bout d'un moment "statut exited" en SSL et mon ancien compteur n'avait pas disparu. Il a fini par le faire en refaisant la manip, manque de bol plantage de la database sur le compteur heure creuse après ! Résultat j'en ai eu marre je suis repassé sur ma vieille carte SD de 8 ans et j'ai rapatrié ma sauveagrde de ma db, et là ça a roulé tip top.
J'avais déjà eu des problèmes lors de la mise à jour en 2019, j'avais du recréer beaucoup de devices et j'avais perdu de l'historique bien entendu. Du coup "chat échaudé craignant l'eau froide", je n'ai pas insisté !
Alors tests réalisés à l'appui, les nouveaux firmwares, noyaux Linux, etc ne risquent que de vous apporter de gros soucis trop souvent. On ne change pas une équipe qui gagne, faites donc attention.
Au dernières nouvelles d'ailleurs, car je n'affirme rien sans avoir testé/regardé, le "sudo rpi-update" va vous coller un noyau Linux 6.1.XX. C'est celui que j'ai sur une distro dérivée de Debian sur un miniPC CPU AMD Ryzen 5 5600H, 16G° de RAM, disque NVME 500G° et disque SATA3 SSD de 1 T°, un p'tit jouet qui booste comme un dingue. Parle-t-on vraiment des mêmes besoins ?
Donc voilà, c'était long, mais franchement si vous passez par là et que vous lisez l'ensemble au moins vous saurez que doucement c'est plus prudent.
Domoticz marche très bien sur un vieux PI 2 en 32bits, et ça marche longtemps en plus je l'ai testé pour vous :o
Amusez-vous mais ne jetez pas l'argent par les fenêtres ça ne sert à rien, à part pour les frimeurs.
Et surtout mefiez-vous des "new geeks" qui participent activement aux nouvelles versions, y compris pour Linux.
Ils ont deux leitmotiv, "ils ne se trompent jamais !" et "Au pire, s'ils se trompent, ils mentent plutôt que de l'avouer..."
Je sais, je suis un vieux briscard, mais bon je programme en open source depuis les années 2014, je suis sous Linus depuis, pfffft, mais j'ai aussi des softs qui ne fonctionnent que sous Windows, donc dual boot tout le temps.
Et mes 8 ans de Domoticz c'est du vécu :lol:
Bon courage à tous
