ça ne passe pas chez moi, il doit me manquer un truc.
1/ dans domoticz: j'ai bien mis basic-auth, je suis en https (http désactivé), j'avais bien un user pour imperihome
1er test ok:
curl -s -k "https://userpourmdah:pwdmdah@192.168.1.xxx/json.htm?type=devices&filter=all&used=true&order=Name"| grep '"Name"'| wc -l2/ ensuite pour MDAH: upgrade vers 2.41 ok, dans le config.json, j'ai ça:
"app_name": "MyDomoAtHome",
"auth": {"username": "userimperihome", "password": "motdepasseimperihome"},
"tempmode": "C",
"https" : true,
"key" : "/etc/mydomoathome/key.pem",
"cert": "/etc/mydomoathome/key-cert.pem",
"domoticz": {
"ssl": true,
"host": "192.168.1.xxx",
"port": "443",
"path": "/",
"auth": {"username": "userpourmdah", "password": "pwdmdah"}
"port": 3002,
"passcode": ""
}Code : Tout sélectionner
curl -s -k "https://userimperihome:motdepasseimperihome@192.168.1.xxx:3002/devices"Code : Tout sélectionner
{"devices":[{"id":"S00","name":"Unable to connect to Domoticz","type":"DevGenericSensor","room":"Utility","params":[{"key":"Value","value":"https://userimperihome:motdepasseimperihome@192.168.1.xxx:443/json.htm"}]},{"id":"S01","name":"Please add this gateway in Setup/settings/Local Networks","type":"DevGenericSensor","room":"Utility"}]}
