[Tuto] Utiliser Monitor
Re: custom page
Voici
"5MinuteHistoryDays" : 1,
"ActTime" : 1432204413,
"AllowWidgetOrdering" : true,
"DashboardType" : 1,
"Latitude" : "43.437882",
"Longitude" : "4.945711",
"MobileType" : 0,
"ServerTime" : "May 21 2015 12:33:33",
"Sunrise" : "06:11:00",
"Sunset" : "21:02:00",
"TempScale" : 1.0,
"TempSign" : "C",
"WindScale" : 1.0,
"WindSign" : "m/s",
"dontcachehtml" : true,
"result" : [
"BatteryLevel" : 255,
"CustomImage" : 0,
"Data" : "Open",
"Favorite" : 1,
"HardwareID" : 3,
"HardwareName" : "RFX-433-RTS",
"HaveDimmer" : false,
"HaveGroupCmd" : false,
"HaveTimeout" : false,
"ID" : "001001",
"Image" : "Light",
"IsSubDevice" : false,
"LastUpdate" : "2015-05-21 09:58:43",
"Level" : 0,
"LevelInt" : 0,
"MaxDimLevel" : 0,
"Name" : "Volet Global Maison",
"Notifications" : "false",
"PlanID" : "0",
"Protected" : false,
"ShowNotifications" : true,
"SignalLevel" : 7,
"Status" : "Open",
"StrParam1" : "",
"StrParam2" : "",
"SubType" : "RFY",
"SwitchType" : "Blinds",
"SwitchTypeVal" : 3,
"Timers" : "false",
"Type" : "RFY",
"TypeImg" : "blinds",
"Unit" : 1,
"Used" : 1,
"UsedByCamera" : false,
"XOffset" : "0",
"YOffset" : "0",
"idx" : "25"
"status" : "OK",
"title" : "Devices"
"MobileType" : 0,
"TempScale" : 1.0,
"TempSign" : "C",
"WindScale" : 1.0,
"WindSign" : "m/s",
"result" : [
"CustomImage" : 0,
"Data" : "Open",
"Favorite" : 1,
"HardwareID" : 3,
"ID" : "001001",
"Image" : "Light",
"Level" : 0,
"LevelInt" : 0,
"MaxDimLevel" : 0,
"PlanID" : "0",
"SignalLevel" : 7,
"Status" : "Open",
"StrParam1" : "",
"StrParam2" : "",
"SubType" : "RFY",
"Timers" : "false",
"Type" : "RFY",
"Unit" : 1,
"Used" : 1,
"XOffset" : "0",
"YOffset" : "0",
"idx" : "25"
"status" : "OK",
"title" : "Devices"
Re: custom page
ah oui d'accords, c'est du SOMFY,
j'ai fait l'ajout, re tente si tu veux bien
Re: custom page
Parfait!
Merci pour ce travail et ta réactivité
Christian
Christian
Re: custom page
ya pas de quoi
* Suppression des flèches de navigation (desktop)
* ajout contrôle clavier gauche/droite (desktop)
* ajout popup météo pour afficher les températures de la journée, heure par heure
* ajout icon security panel + clavier en popup
* meilleurs gestion des timeout de popup
* slide en boucle
* slide en boucle
Re: custom page
Bonsoir @vildriver
J'ai mis en place ta dernière mise à jour.
gauche/droite par flèche clavier = OK
mais pas vu les slides écrans et le pop-up météo : y-a-t-il une manip particulière à faire ?
Comment faut-il faire si on n'utilise que deux écrans sur les 3 pour ne pas voir le troisième ?
Merci d'avance et encore merci pour ce magnifique travail.
Synology DS212 + RFXTrx433 + AEon Stick S2
Oregon - Thgr122Nx / Chacon - module 1000w - détecteur de fumée 34131 / OWL -CM180 / Greenwave Multiprise
Re: custom page
Par slide en boucle, je veux dire qu'après la dernière page tu tombes sur la première et depuis la première tu peux slider vers la gauche pour tomber sur la dernière...
Avec plus de 2 pages je trouve cela plus pratique.
Pour la popup météo, il suffit en principe de cliquer sur l'icon météo.
De même pour l'alarme, si tu affiches son status, un clic dessus fera aparaitre le clavier.
Je ne me sers pas non plus de la page 3 mais elle ne me gène pas vraiment..
Pour ne pas la voir, tu peux supprimer la partie html qui permet de l'afficher (je te donnes les numéros de ligne quand je rentre).
Merci de ton retour.
Re: custom page
du coups pour supprimer la page 3,
tu édites le fichier frontpage.html et tu supprimes de la ligne 223 à la ligne 321
et puis tu passes en fin de page la valeur continuous à false
<script type="text/javascript">
var mySwipe = new Swipe(document.getElementById('slider'),{
speed: 300,
continuous: false
Dernière modification par vil1driver le 30 mai 2015, 17:19, modifié 1 fois.
Re: custom page
Merci pur la réponse rapide
C'est parfait.
Pour info.....
Je suis en train de tout porter sur Synology avec domoticz en application synology.
Custom pages marche.
Quelques problèmes encore pour faire reconnaître des interrupteurs...
Pas pu le faire avec Debian en chroot, des pb de make sur l'application domoticz......
Si quelqu'un a des compétences, je suis preneur...
C'est parfait.
Pour info.....
Re: custom page
custom page n'utilise que des requêtes JSON,
si tu as un domoticz fonctionnel, custom page fonctionnera.
mon domoticz tourne sous ubuntu server, pas eu de soucis particuliers pour l'installer.
Re: custom page
Bonjour je suis bloqué des le debut, j'avoue que je ne comprend pas vraiment mon probleme.
J'essaye deja juste de lancer la ''frontpage.html'' et je me retrouve directement avec un Domoticz Offline, j'ai bien changé l'ip dans frontpage_settings.js. Je dois activer un autre truc sur Domoticz ?
