[Tuto] Esp Easy + Nextion + DomoticZ
Jeff
Re: TUTO Esp Easy + Nextion + Domoticz
Message par Jeff »
@dokho
Comme d'habitude ;) : configesp
Jeff
Message par Jeff »
J'ai enfin trouver comment compiler des versions customs :D ; avec plugin choisi, le nom de la version build et tous les paramètres déja renseignés : Nom, unité, ip static, ip controller...
Je peux à la demande, si j'ai le temps, compiler une version sur mesure avec les paramètres ci dessous. Toutes les options sont paramétrables...
#ifndef ESPEASY_CUSTOM_H
#define ESPEASY_CUSTOM_H
#include <Arduino.h>
    To modify the stock configuration without changing the EspEasy.ino file :
    1) rename this file to "Custom.h" (It is ignored by Git)
    2) define your own settings below
    3) define USE_CUSTOM_H as a build flags. ie : export PLATFORMIO_BUILD_FLAGS="'-DUSE_CUSTOM_H'"
   Your Own Default Settings
    You can basically ovveride ALL macro defined in ESPEasy.ino.
    Don't forget to first #undef each existing #define that you add below.
    But since this Custom.h is included before other defines are made, you don't have to undef a lot of defines.
    Here are some examples:
#ifdef BUILD_GIT
# undef BUILD_GIT
#endif // ifdef BUILD_GIT
#define BUILD_GIT           "My Build: "  __DATE__ " "  __TIME__
#define DEFAULT_NAME        "MyEspEasyDevice"                        // Enter your device friendly name
#define UNIT                0                                        // Unit Number
#define DEFAULT_DELAY       60                                       // Sleep Delay in seconds
// --- Wifi AP Mode (when your Wifi Network is not reachable) ----------------------------------------
#define DEFAULT_AP_IP       192, 168, 4, 1                           // Enter IP address (comma separated) for AP (config) mode
#define DEFAULT_AP_SUBNET   255, 255, 255, 0                         // Enter IP address (comma separated) for AP (config) mode
#define DEFAULT_AP_KEY      "configesp"                              // Enter network WPA key for AP (config) mode
// --- Wifi Client Mode -----------------------------------------------------------------------------
#define DEFAULT_SSID                         "MyHomeSSID"            // Enter your network SSID
#define DEFAULT_KEY                          "MySuperSecretPassword" // Enter your network WPA key
#define DEFAULT_SSID2                        ""                      // Enter your fallback network SSID
#define DEFAULT_KEY2                         ""                      // Enter your fallback network WPA key
#define DEFAULT_WIFI_INCLUDE_HIDDEN_SSID     false                   // Allow to connect to hidden SSID APs
#define DEFAULT_USE_STATIC_IP                false                   // (true|false) enabled or disabled static IP
#define DEFAULT_IP                           "192.168.0.50"          // Enter your IP address
#define DEFAULT_DNS                          "192.168.0.1"           // Enter your DNS
#define DEFAULT_GW                           "192.168.0.1"           // Enter your Gateway
#define DEFAULT_SUBNET                       "255.255.255.0"         // Enter your Subnet
#define DEFAULT_IPRANGE_LOW                  "0.0.0.0"               // Allowed IP range to access webserver
#define DEFAULT_IPRANGE_HIGH                 "255.255.255.255"       // Allowed IP range to access webserver
#define DEFAULT_IP_BLOCK_LEVEL               1                       // 0: ALL_ALLOWED  1: LOCAL_SUBNET_ALLOWED  2:
// ONLY_IP_RANGE_ALLOWED
#define DEFAULT_ADMIN_USERNAME               "admin"
#define DEFAULT_ADMIN_PASS                   ""
#define DEFAULT_WIFI_CONNECTION_TIMEOUT      10000 // minimum timeout in ms for WiFi to be connected.
#define DEFAULT_WIFI_FORCE_BG_MODE           false // when set, only allow to connect in 802.11B or G mode (not N)
#define DEFAULT_WIFI_RESTART_WIFI_CONN_LOST  false // Perform wifi off and on when connection was lost.
#define DEFAULT_ECO_MODE                     false // When set, make idle calls between executing tasks.
#define DEFAULT_WIFI_NONE_SLEEP              false // When set, the wifi will be set to no longer sleep (more power
// used and need reboot to reset mode)
#define DEFAULT_GRATUITOUS_ARP               false // When set, the node will send periodical gratuitous ARP
                                                   // packets to announce itself.
#define DEFAULT_TOLERANT_LAST_ARG_PARSE      false // When set, the last argument of some commands will be parsed to the end of the line
                                                   // See: https://github.com/letscontrolit/ESPEasy/issues/2724
#define DEFAULT_SEND_TO_HTTP_ACK             false // Wait for ack with SendToHttp command.
#define DEFAULT_AP_DONT_FORCE_SETUP          false // Allow optional usage of Sensor without WIFI avaiable // When set you can use the Sensor in AP-Mode without beeing forced to /setup
#define DEFAULT_DONT_ALLOW_START_AP          false // Usually the AP will be started when no WiFi is defined, or the defined one cannot be found. This flag may prevent it.
// --- Default Controller ------------------------------------------------------------------------------
#define DEFAULT_CONTROLLER   false                                          // true or false enabled or disabled, set 1st controller
        // defaults
#define DEFAULT_CONTROLLER_ENABLED true                                     // Enable default controller by default
#define DEFAULT_CONTROLLER_USER    ""                                       // Default controller user
#define DEFAULT_CONTROLLER_PASS    ""                                       // Default controller Password
// using a default template, you also need to set a DEFAULT PROTOCOL to a suitable MQTT protocol !
#define DEFAULT_PUB         "sensors/espeasy/%sysname%/%tskname%/%valname%" // Enter your pub
#define DEFAULT_SUB         "sensors/espeasy/%sysname%/#"                   // Enter your sub
#define DEFAULT_SERVER      "192.168.0.8"                                   // Enter your Server IP address
#define DEFAULT_SERVER_HOST ""                                              // Server hostname
#define DEFAULT_SERVER_USEDNS false                                         // true: Use hostname.  false: use IP
#define DEFAULT_USE_EXTD_CONTROLLER_CREDENTIALS   false                     // true: Allow longer user credentials for controllers
#define DEFAULT_PORT        8080                                            // Enter your Server port value
#define DEFAULT_PROTOCOL    0                                               // Protocol used for controller communications
        //   0 = Stand-alone (no controller set)
        //   1 = Domoticz HTTP
        //   2 = Domoticz MQTT
        //   3 = Nodo Telnet
        //   4 = ThingSpeak
        //   5 = Home Assistant (openHAB) MQTT
        //   6 = PiDome MQTT
        //   7 = EmonCMS
        //   8 = Generic HTTP
        //   9 = FHEM HTTP
#define DEFAULT_PIN_I2C_SDA                     4
#define DEFAULT_PIN_I2C_SCL                     5
#define DEFAULT_I2C_CLOCK_SPEED                 400000            // Use 100 kHz if working with old I2C chips
#define USE_I2C_DEVICE_SCAN                     true
#define DEFAULT_SPI                             0                 //0=disabled 1=enabled and for ESP32 there is option 2 =HSPI
#define DEFAULT_PIN_STATUS_LED                  (-1)
#define DEFAULT_PIN_STATUS_LED_INVERSED         true
#define DEFAULT_PIN_RESET_BUTTON                (-1)
#define DEFAULT_USE_RULES                       false             // (true|false) Enable Rules?
#define DEFAULT_RULES_OLDENGINE                 true
#define DEFAULT_MQTT_RETAIN                     false             // (true|false) Retain MQTT messages?
#define DEFAULT_MQTT_DELAY                      100               // Time in milliseconds to retain MQTT messages
#define DEFAULT_MQTT_LWT_TOPIC                  ""                // Default lwt topic
#define DEFAULT_MQTT_LWT_CONNECT_MESSAGE        "Connected"       // Default lwt message
#define DEFAULT_MQTT_LWT_DISCONNECT_MESSAGE     "Connection Lost" // Default lwt message
#define DEFAULT_MQTT_USE_UNITNAME_AS_CLIENTID   0
#define DEFAULT_USE_NTP                         false             // (true|false) Use NTP Server
#define DEFAULT_NTP_HOST                        ""                // NTP Server Hostname
#define DEFAULT_TIME_ZONE                       0                 // Time Offset (in minutes)
#define DEFAULT_USE_DST                         false             // (true|false) Use Daily Time Saving
#define DEFAULT_LATITUDE                        0.0f              // Default Latitude
#define DEFAULT_LONGITUDE                       0.0f              // Default Longitude
#define DEFAULT_SYSLOG_IP                       ""                // Syslog IP Address
#define DEFAULT_SYSLOG_LEVEL                    0                 // Syslog Log Level
#define DEFAULT_SERIAL_LOG_LEVEL                LOG_LEVEL_INFO    // Serial Log Level
#define DEFAULT_WEB_LOG_LEVEL                   LOG_LEVEL_INFO    // Web Log Level
#define DEFAULT_SD_LOG_LEVEL                    0                 // SD Card Log Level
#define DEFAULT_USE_SD_LOG                      false             // (true|false) Enable Logging to the SD card
#define DEFAULT_USE_SERIAL                      true              // (true|false) Enable Logging to the Serial Port
#define DEFAULT_SERIAL_BAUD                     115200            // Serial Port Baud Rate
#define DEFAULT_SYSLOG_FACILITY                 0                 // kern
#define DEFAULT_SYNC_UDP_PORT                   0                 // Used for ESPEasy p2p. (IANA registered port: 8266)
#define BUILD_NO_DEBUG
// Special SSID/key setup only to be used in custom builds.
// Deployment SSID will be used only when the configured SSIDs are not reachable and/or no credentials are set.
// This to make deployment of large number of nodes easier
#define CUSTOM_DEPLOYMENT_SSID                  ""                // Enter SSID not shown in UI, to be used on custom builds to ease deployment
#define CUSTOM_DEPLOYMENT_KEY                   ""                // Enter key not shown in UI, to be used on custom builds to ease deployment
#define CUSTOM_SUPPORT_SSID                     ""                // Enter SSID not shown in UI, to be used on custom builds to ease support
#define CUSTOM_SUPPORT_KEY                      ""                // Enter key not shown in UI, to be used on custom builds to ease support
// Emergency fallback SSID will only be attempted in the first 10 minutes after reboot.
// When found, the unit will connect to it and depending on the built in flag, it will either just connect to it, or clear set credentials.
// Use case: User connects to a public AP which does need to agree on an agreement page for the rules of conduct (e.g. open APs)
// This is seen as a valid connection, so the unit will not reconnect to another node and thus becomes inaccessible.
#define CUSTOM_EMERGENCY_FALLBACK_SSID          ""                // Enter SSID not shown in UI, to be used to regain access to the node
#define CUSTOM_EMERGENCY_FALLBACK_KEY           ""                // Enter key not shown in UI, to be used to regain access to the node
#define CUSTOM_EMERGENCY_FALLBACK_RESET_CREDENTIALS  false
#define CUSTOM_EMERGENCY_FALLBACK_START_AP           false
#define CUSTOM_EMERGENCY_FALLBACK_ALLOW_MINUTES_UPTIME 10
#define USES_SSDP
#define USE_EXT_RTC                // Support for external RTC clock modules like PCF8563/PCF8523/DS3231/DS1307
// #define USE_SETTINGS_ARCHIVE
// #define FEATURE_I2CMULTIPLEXER
// #define USE_TRIGONOMETRIC_FUNCTIONS_RULES
   Defining web interface
#define MENU_INDEX_MAIN_VISIBLE          true
#define MENU_INDEX_CONFIG_VISIBLE        false
#define MENU_INDEX_CONTROLLERS_VISIBLE   false
#define MENU_INDEX_HARDWARE_VISIBLE      false
#define MENU_INDEX_DEVICES_VISIBLE       false
#define MENU_INDEX_RULES_VISIBLE         false
#define MENU_INDEX_NOTIFICATIONS_VISIBLE false
#define MENU_INDEX_TOOLS_VISIBLE         false
#define MAIN_PAGE_SHOW_SYSINFO_BUTTON    true
#define MAIN_PAGE_SHOW_WiFi_SETUP_BUTTON true
#define MAIN_PAGE_SHOW_BASIC_INFO_NOT_LOGGED_IN false
#define MAIN_PAGE_SHOW_NODE_LIST_BUILD   true
#define MAIN_PAGE_SHOW_NODE_LIST_TYPE    true
#define SETUP_PAGE_SHOW_CONFIG_BUTTON    true
//#define WEBPAGE_TEMPLATE_HIDE_HELP_BUTTON
   CSS / template
#define WEBPAGE_TEMPLATE_DEFAULT_HEADER "<header class='headermenu'><h1>ESP Easy Mega: {{title}}</h1><BR>"
#define WEBPAGE_TEMPLATE_DEFAULT_FOOTER "<footer><br><h6>Powered by <a href='http://www.letscontrolit.com' style='font-size: 15px; text-decoration: none'>Let's Control It</a> community</h6></footer></body></html>"
#define WEBPAGE_TEMPLATE_AP_HEADER      "<body><header class='apheader'><h1>Welcome to ESP Easy Mega AP</h1>"
// Embed Custom CSS in Custom.h:
#define WEBSERVER_EMBED_CUSTOM_CSS
static const char DATA_ESPEASY_DEFAULT_MIN_CSS[] PROGMEM = {
,0};
   Special settings  (rendering settings incompatible with other builds)
// #define USE_NON_STANDARD_24_TASKS
   Your Own selection of plugins and controllers
#define CONTROLLER_SET_NONE
#define NOTIFIER_SET_NONE
#define PLUGIN_SET_NONE
 ###########     Plugins
// #define USE_SERVO
// #define USES_P001   // Switch
// #define USES_P002   // ADC
// #define USES_P003   // Pulse
// #define USES_P004   // Dallas
// #define USES_P005   // DHT
// #define USES_P006   // BMP085
// #define USES_P007   // PCF8591
// #define USES_P008   // RFID
// #define USES_P009   // MCP
// #define USES_P010   // BH1750
// #define USES_P011   // PME
// #define USES_P012   // LCD
// #define USES_P013   // HCSR04
// #define USES_P014   // SI7021
// #define USES_P015   // TSL2561
// #define USES_P017   // PN532
// #define USES_P018   // Dust
// #define USES_P019   // PCF8574
// #define USES_P020   // Ser2Net
// #define USES_P021   // Level
// #define USES_P022   // PCA9685
// #define USES_P023   // OLED
// #define USES_P024   // MLX90614
// #define USES_P025   // ADS1115
// #define USES_P026   // SysInfo
// #define USES_P027   // INA219
// #define USES_P028   // BME280
// #define USES_P029   // Output
// #define USES_P031   // SHT1X
// #define USES_P032   // MS5611
// #define USES_P033   // Dummy
// #define USES_P034   // DHT12
// #define USES_P036   // FrameOLED
// #define USES_P037   // MQTTImport
// #define USES_P038   // NeoPixel
// #define USES_P039   // Environment - Thermocouple
// #define USES_P040   // RFID - ID12LA/RDM6300
// #define USES_P041   // NeoClock
// #define USES_P042   // Candle
// #define USES_P043   // ClkOutput
// #define USES_P044   // P1WifiGateway
// #define USES_P045   // MPU6050
// #define USES_P046   // VentusW266
// #define USES_P047   // I2C_soil_misture
// #define USES_P048   // Motoshield_v2
// #define USES_P049   // MHZ19
// #define USES_P050   // TCS34725 RGB Color Sensor with IR filter and White LED
// #define USES_P051   // AM2320
// #define USES_P052   // SenseAir
// #define USES_P053   // PMSx003
// #define USES_P054   // DMX512
// #define USES_P055   // Chiming
// #define USES_P056   // SDS011-Dust
// #define USES_P057   // HT16K33_LED
// #define USES_P058   // HT16K33_KeyPad
// #define USES_P059   // Encoder
// #define USES_P060   // MCP3221
// #define USES_P061   // Keypad
// #define USES_P062   // MPR121_KeyPad
// #define USES_P063   // TTP229_KeyPad
// #define USES_P064   // APDS9960 Gesture
// #define USES_P065   // DRF0299
// #define USES_P066   // VEML6040
// #define USES_P067   // HX711_Load_Cell
// #define USES_P068   // SHT3x
// #define USES_P069   // LM75A
// #define USES_P070   // NeoPixel_Clock
// #define USES_P071   // Kamstrup401
// #define USES_P072   // HDC1080
// #define USES_P073   // 7DG
// #define USES_P074   // TSL2561
// #define USES_P075   // Nextion
// #define USES_P076   // HWL8012   in POW r1
// #define USES_P077   // CSE7766   in POW R2
// #define USES_P078   // Eastron Modbus Energy meters
// #define USES_P079   // Wemos Motoshield
// #define USES_P080   // iButton Sensor  DS1990A
// #define USES_P081   // Cron
// #define USES_P082   // GPS
// #define USES_P083   // SGP30
// #define USES_P084   // VEML6070
// #define USES_P085   // AcuDC24x
// #define USES_P086   // Receiving values according Homie convention. Works together with C014 Homie controller
// #define USES_P087   // Serial Proxy
// #define USES_P088   // HeatpumpIR
// #define USES_P089   // Ping
// #define USES_P090   // CCS811
// #define USES_P091   // SerSwitch
// #define USES_P092   // DLbus
// #define USES_P093   // MitsubishiHP
// #define USES_P094   // CULReader
// #define USES_P095   // ILI9341
// #define USES_P096   // eInk
// #define USES_P097   // ESP32Touch
// #define USES_P098   //
// #define USES_P099   // XPT2046 touchscreen
// #define USES_P100   // DS2423 counter
// #define USES_P101   // WakeOnLan
// #define USES_P102   // PZEM004Tv3
// #define USES_P103   // Atlas Scientific EZO Sensors (pH, ORP, EZO, DO)
// #define USES_P104   // MAX7219 dotmatrix
// #define USES_P105   // AHT10/20/21
// #define USES_P106   // BME680
// #define USES_P107   // Si1145
// #define USES_P109   // ThermoOLED
// #define USES_P110   // VL53L0X Time of Flight sensor
// #define USES_P111   // RF522 RFID reader
// #define USES_P112   // AS7265x
// #define USES_P113   // VL53L1X ToF
// #define USES_P114   // VEML6075
// #define USES_P115   // MAX1704x
// #define USES_P119   // ITG3205 Gyro
// #define USES_P120   // ADXL345 Acceleration / Gravity
// Special plugins needing IR library
// #define USES_P016   // IR
// #define P016_SEND_IR_TO_CONTROLLER false //IF true then the JSON replay solution is transmited back to the condroller.
// #define USES_P035   // IRTX
// #define P016_P035_Extended_AC // The following define is needed for extended decoding of A/C Messages and or using standardised
                                 //common arguments for controlling all deeply supported A/C units
// #define P016_P035_USE_RAW_RAW2 //Use the RAW and RAW2 encodings, disabling it saves 3.7Kb
// #define USES_P088   // Heatpump IR
// #define USES_P108   // DDS238-x ZN Modbus energy meters
 ###########     Controllers
// #define USES_C001   // Domoticz HTTP
// #define USES_C002   // Domoticz MQTT
// #define USES_C003   // Nodo telnet
// #define USES_C004   // ThingSpeak
// #define USES_C005   // Home Assistant (openHAB) MQTT
// #define USES_C006   // PiDome MQTT
// #define USES_C007   // Emoncms
// #define USES_C008   // Generic HTTP
// #define USES_C009   // FHEM HTTP
// #define USES_C010   // Generic UDP
// #define USES_C011   // Generic HTTP Advanced
// #define USES_C012   // Blynk HTTP
// #define USES_C013   // ESPEasy P2P network
// #define USES_C014   // homie 3 & 4dev MQTT
// #define USES_C015   // Blynk
// #define USES_C016   // Cache controller
// #define USES_C017   // Zabbix
// #define USES_C018   // TTN/RN2483
 ###########     Notifiers
// #define USES_N001   // Email
// #define USES_N002   // Buzzer
#endif // ESPEASY_CUSTOM_H
dokho
Message par dokho »
Nice !
A la limite, si t'as un peu de temps, je veux bien un petit tuto pour apprendre à compiler mes propres versions
Tu compiles avec quoi comme outil ?
Jeff
Message par Jeff »
Compilation de son propre firmware avec le choix des plugins et la configuration complète des paramètres
Je compile avec vscode, tout est ici pour l'installer
https://projetsdiy.fr/debuter-platformi ... ows-linux/
Il faut aussi installer git et python, voir cet vidéo.
https://www.youtube.com/watch?v=ArqwMcYSMsU
Après je download la dernière version de espeasy ici :
https://github.com/letscontrolit/ESPEasy/releases
Menu "Assets" en bas de la version après les modifs, prendre version ESPEasy_ESP82xx_mega-20211105.zip
Je dézippe, j'ajoute le dossier à l'espace de travail : Fichier => Ajouter un dossier à l'espace de travail
Après icone sur la barre de gauche : double onglet, ca donne ceci
Dans le dossier "src" du projet, tu trouves le fichier custom-sample.h, tu le dupliques et le renomme en custom.h, décommente la ligne #ifdef USE_CUSTOM_H dans le fichier "ESPEasy_common.h"
Tu remplis tous les champs que tu souhaites dans le fichier custom.h; voci mon fichier sans mes codes wifi ;)
Custom.zip
(5.93 Kio) Téléchargé 153 fois
Tu modifies le plugin nextion à 20 lignes : _P075_Nextion.ino
#define P75_Nlines 20
Dans la barre bleu en bas, tu choisis ta plateforme : "custom_ESP8266_4M1M", voir mon image au dessus et tu compiles : icone "V" build. En espérant que tu n'ai pas d'erreur (jaune sans importantce) , rouge erreur.
Tu retrouves ton fichier "bin" dans le dossier : ESPEasy-mega-20211105\build_output\bin
Tu peux uploader dans la foulée dans ton espeasy : icone ->
Bon courage
Dernière modification par Jeff le 06 déc. 2021, 23:05, modifié 2 fois.
dokho
Message par dokho »
@Jeff
Je pense que j'ai un soucis de branchement au niveau de TX et RX: les infos MQTT arrivent bien jusqu'à ESPEasy mais ne sont pas transmises à l'écran.
Dans la config du plugin nextion je suis bien en: "HW Serial0 Swap ..."
J'ai bien connecté le RX/TX de l'écran à ces gpio (j'ai essayé aussi en inversant) mais rien n'arrive à l'écran.
Tu aurais une idée ?
Jeff
Message par Jeff »
Dans le tuto de la 1ere page, tu as le schéma de branchement et la config du plugin nextion . A vérifier.
Tu peux essayer d'envoyer une commande direct au nextion en http.
Tu as réussi à compiler ton firwmare avec le tuto que j'ai posté ? c'est bien d'avoir un retour :roll:
dokho
Message par dokho »
J'ai bien essayé en suivant les branchements indiqués sur la première page mais sans succès.
Ce que je ne comprends pas c'est que dans ta copie d'écran c'est bien noté D7 et D8, alors que d'après ton schéma c'est connecté sur D7 et D5.
Je n'ai pas encore eu/pris le temps de tester la compilation, je te ferais un retour quand ça sera fait ;)
Jeff
Message par Jeff »
Effectivement le schéma n'est pas à jour, c'est la version de l'ancien firmware.
Bleu = D7
Jaune = D8
Et la compilation ??
dokho
Message par dokho »
Bon et bien je dois avoir un pb ailleurs car même sur D7/D8 ça ne fonctionne pas.
Pour la compilation, comme je te disais dans mon précédent message je n'ai pas encore eu/pris le temps d'essayer: les journées sont trop courtes
Je te tiendrais au courant.
Jeff
Message par Jeff »
J'avais pas vu pour la compilation dans ton post précédent.
Met un screenshot de ta config plugin nextion et mqtt, je vais regarder. Ils sont bien activé ?
Essaye d'envoyer une commande
http://xxx.xxx.xxx.xxx/control?cmd=NEXTION,heure.txt="01:12"
NEXTION : nom de ton device nextion dans le plugin
heure.txt : nom d'un champ texte nommé : heure
A adapter à ta config.
