Projet TBH
slybreiz
Re: Projet TBH
Message par slybreiz »
2015-12-10 22:20:05.311 LUA: <br>17.4 58 6.3 92
2015-12-10 22:20:05.311 LUA: <br>17.4;58;6.3;92
ca viendrais de la source ? du coup
#!/usr/bin/php
<?php
// Slush Coin Check
if($argc == 3) {
    $username =  $argv[1];
    $password =  $argv[2];
} else {
    die("Usage: username password\n");
// Create the temporary cookie
$cookiefile = tempnam("", "slush_");
// Get CSRF
$url = "https://mon.projet-tbh.fr/accounts/login/?next=/";
$curl = curl_init();
curl_setopt($curl, CURLOPT_URL, $url);
curl_setopt($curl, CURLOPT_COOKIEFILE, $cookiefile);
curl_setopt($curl, CURLOPT_COOKIEJAR, $cookiefile);
curl_setopt($curl, CURLOPT_RETURNTRANSFER, 1);
$data = curl_exec($curl);
curl_close($curl);
preg_match("/<input type='hidden' name='csrfmiddlewaretoken' value='(.*?)' \/>/", $data, $csrf);
// Login to Slush
$postfields = "csrfmiddlewaretoken=$csrf[1]&username=$username&password=$password";
curl_setopt($curl, CURLOPT_POST, 1);
curl_setopt($curl, CURLOPT_POSTFIELDS, $postfields);
curl_setopt($curl, CURLOPT_FOLLOWLOCATION, true);
curl_setopt($curl, CURLOPT_TIMEOUT, 20);
curl_close($curl);
// Visit earnings page
$url = "https://mon.projet-tbh.fr/confort/data-confort-instantane";
curl_close($curl);
// Capture current temperature
try{
   $temperature = json_decode($data, true);
    if(isset($temperature['temp_int']) and isset($temperature['hygro_int']) and isset($temperature['temp_ext']) and isset($temperature['hygro_ext']))$
    echo $temperature['temp_int'] . ";" . $temperature['hygro_int'] . ";" . $temperature['temp_ext'] . ";" . $temperature['hygro_ext'];
   } else {
     echo null;
} catch(Exception $e){
    echo($e);
// Clean up cookie
unlink($cookiefile);
domoticz on synology dsm 6 DS109(hack DS112j) + RXFcom433E / Archos Home connecte / 4 * HC ECR-100 / Archos TBH / sonde température Alecto WS1700 / prise chacon
Re: Projet TBH
Le script php renvoie bien les bonnes données.
La ligne avec le 'match' est bizarre, il y a plein d'espaces à un endroit où il ne doit pas y en avoir.
Essaye ça :
---recupere l'heure en minutes
time=os.time()
maintenant=tonumber(hours*60+minutes)
if(maintenant%10 ==0 )then
   local appelTBH=assert(io.popen("php /home/pi/domoticz/scripts/php/capteur_meteo_2.php LOGIN MDP"))
   local tempHygroTBH = appelTBH:read('*all')
   appelTBH:close()
   print(tempHygroTBH) -- affiche ce que nous renvoie le script PHP
   tempInt,hygroInt,tempExt,hygroExt = tempHygroTBH:match("([^;]+);([^;]+);([^;]+);([^;]+)")
   print(tempInt.." "..hygroInt.." "..tempExt.." "..hygroExt)
  --Ensuite remplissez votre commandArray avec les donnees recueillies :)
tempInt = tostring(tonumber(tempInt))
tempExt= tostring(tonumber(tempExt))
hygroInt = tostring(tonumber(hygroInt))
hygroExt= tostring(tonumber(hygroExt))
commandArray[1] = {['UpdateDevice'] = '28|0|' ..tempInt..";"..hygroInt}
commandArray[2] = {['UpdateDevice'] = '29|0|' ..tempExt..";"..hygroExt}
slybreiz
Re: Projet TBH
même soucie
2015-12-11 08:10:07.010 LUA: <br>16.9 58 5 97
2015-12-11 08:10:07.017 EventSystem: Script event triggered: /home/pi/domoticz/scripts/lua/script_time_tbhweb_meteo.lua
time=os.time()
   appelTBH:close()
Re: Projet TBH
Donc, là c'est vraiment bizarre...
Tu es sur quelle version de domoticz ?
Il serait peut être judicieux de passer en beta.
slybreiz
Re: Projet TBH
version stable V2 3530
par contre je suppose que si je passe en beta pas moyen de revenir en version normal .
slybreiz
Re: Projet TBH
Maj fait avec une petite sauvegarde avant bien sur :p
2015-12-11 18:30:05.457 LUA:
18.4 62 9.9 96
2015-12-11 18:30:05.464 EventSystem: Script event triggered: /home/pi/domoticz/scripts/lua/script_time_tbhweb_meteo.lua
Re: Projet TBH
Il y a toujours moyen de revenir sur une stable :)
Au niveau de tes widgets température, ça donne quoi ?
slybreiz
Re: Projet TBH
toujours pareil pas d'affichage des temperature / humidite.
par contre j'ai fait un script lua juste avec la température et un widget température et la ça fonctionne l'affichage est correcte
je pense que je vais séparer les différentes courbes temp ext tempint et humint humiext pour voir les valeur dans les widget et garder les widjets temp/hum pour les pont de rosé .
en attendant d'avoir des vraies sonde températures :p
Re: Projet TBH
Mèkechuikon !
Le capteur temp + humidity attend 3 valeurs !
temp;hygro;statut !!!
commandArray[1] = {['UpdateDevice'] = '28|0|' ..tempInt..";"..hygroInt..";0"}
commandArray[2] = {['UpdateDevice'] = '29|0|' ..tempExt..";"..hygroExt..";0"}
Plus d'info ici :
http://www.domoticz.com/wiki/Domoticz_A ... 2Fhumidity
slybreiz
Re: Projet TBH
effectivement cela est mieux :p
