Domoticz et Google Home via le plugin DZGA
Re: Domoticz et Google Home via le plugin DZGA
Salut Samourai,
je ne retrouve plus la manip pour installer le certif letsencrypt dans le répertoire domoticz? je l'avais fait mais je trouve plus la manip apres réinstallation de DZGA
samourai47
Letsencrypt
https://www.domoticz.com/wiki/Native_secure_access_with_Lets_Encrypt
sudo /etc/letsencrypt/letsencrypt-auto certonly --webroot --email philippe@toto.fr -d monsite.duckdns.org -w /home/pi/domoticz/www/
sudo mv ~/domoticz/server_cert.pem ~/domoticz/server_cert.pem.org # see below about DH params why not just delete it
sudo cat /etc/letsencrypt/live/monsite.duckdns.org/privkey.pem >> ~/domoticz/server_cert.pem
sudo cat /etc/letsencrypt/live/monsite.duckdns.org/fullchain.pem >> ~/domoticz/server_cert.pem
sudo cp ~/domoticz/server_cert.pem ~/domoticz/letsencrypt_server_cert.pem
sudo /etc/init.d/domoticz.sh restart
Après redemarrage si erreur domoticz
Error: [web:443] missing SSL DH parameters from file
Add the DHparam :
sudo cat /etc/ssl/certs/dhparam.pem >> ~/domoticz/server_cert.pem
and if you get also an error like : /etc/ssl/certs/dhparam.pem: No such file or directory
cd /etc/ssl/certs
sudo openssl dhparam -out dhparam.pem 2048
Pour le renouvellement auto j'ai cree un fichier que j'ai appelé deploy-cert.sh. Pense a lui donner les droits d'excution
#!/bin/bash
sudo mv /home/pi/domoticz/server_cert.pem /home/pi/domoticz/server_cert.pem.org
sudo cat /etc/letsencrypt/live/monsite.duckdns.org/privkey.pem >> /home/pi/domoticz/server_cert.pem
sudo cat /etc/letsencrypt/live/monsite.duckdns.org/fullchain.pem >> /home/pi/domoticz/server_cert.pem
sudo cp /home/pi/domoticz/server_cert.pem /home/pi/domoticz/letsencrypt_server_cert.pem
sudo cat /etc/ssl/certs/dhparam.pem >> /home/pi/domoticz/server_cert.pem
sudo /etc/init.d/domoticz.sh restartCode : Tout sélectionner
0 23 1 * * sudo /etc/letsencrypt/certbot-auto renew --webroot -w ~/domoticz/www/ --deploy-hook ~/domoticz/scripts/deploy-cert.sh >/dev/null
Dernière modification par samourai47 le 06 déc. 2020, 23:21, modifié 1 fois.
Merci samourai,
tu m'as mis sur la bonne piste, j'ai réussi
Bonne soirée
Bonne soirée
Est cr que quelqu'un a déjà eu ce type de problème d affichage ?
Décidément...
Décidément...
- Pièces jointes
- Capture d’écran 2020-12-06 à 23.39.14.png (38.39 Kio) Consulté 4315 fois
samourai47
non pas encore....
Bizarre
Bizarre
Ca me dit rien non plus
Bon je suis desesperé...
je ne comprends absolument pas pourquoi il m'est impossible de faire fonctionner DZGA avec nginx..(et j'ai pas reussi à refaire fonctionner ngrok aussi au passage...)
J'ai reinstallé sur mon raspberry pi debian10 au moins 5 fois et toujours le meme resultat.. impossible de faire fonctionner nginx et dzga....
Voilà mes derniers messages d'erreur.;
Edit
pi@raspberrypi:~ $ python3 Domoticz-Google-Assistant/
Loading configuration...
Connecting to Domoticz on http://XXXXXXX:XXXX
Service account key is not found. Report state will be unavailable
Using SSL connection
File "/usr/lib/python3.7/runpy.py", line 193, in _run_module_as_main
"__main__", mod_spec)
File "/usr/lib/python3.7/runpy.py", line 85, in _run_code
exec(code, run_globals)
File "Domoticz-Google-Assistant/__main__.py", line 109, in <module>
startServer()
File "Domoticz-Google-Assistant/__main__.py", line 52, in startServer
secure(server)
File "Domoticz-Google-Assistant/__main__.py", line 26, in secure
server.socket = ssl.wrap_socket (server.socket, keyfile=key, certfile=cert, server_side=True, ssl_version=ssl.PROTOCOL_TLSv1_2)
File "/usr/lib/python3.7/ssl.py", line 1216, in wrap_socket
context.load_cert_chain(certfile, keyfile)
PermissionError: [Errno 13] Permission denied
Edit
startServer()
secure(server)
samourai47
Hello
Peut etre une piste?
Ensuite il parle de account key
Tu as bien recupere et colle la cle json de ton compte google?
Si tu te connecte avec nginx ca doit etre https//XXXXXXX:XXXXLoading configuration...
Oui, j'avais fait l'étape avec la cle json.. mais ca ne changeait rien.samourai47 a écrit : 13 déc. 2020, 18:28 Hello
Peut etre une piste?Si tu te connecte avec nginx ca doit etre https//XXXXXXX:XXXXLoading configuration...
Je suis sur Debian 10.. Avec une adresse duckdns suis je le seul ?
Franchement incompréhensible..
samourai47
la je suis pas assez fort...
Chez moi je me suis refait une install a zero et tout a fonctionne du premier coup
Courage.... Lol
Courage.... Lol
