Re: Zigate : pertes de device Xiaomi
Publié : 22 janv. 2019, 19:10
Verdict : KO
2019-01-22 19:04:43.446 Status: (ZiGate) Installer Version Number: 030f
2019-01-22 19:04:43.548 Status: (ZiGate) Decode8015 : Number of devices recently active in Zigate = 3
2019-01-22 19:04:43.548 Status: (ZiGate) Decode8015 : [00] DevID = 01 Network addr = 03d5 IEEE = 00158d0002c8f47f RSSI = 117 Power = 00 HB = 1543 found in ListOfDevices
2019-01-22 19:04:43.548 Status: (ZiGate) Decode8015 : [01] DevID = 02 Network addr = bd89 IEEE = 00158d000121c607 RSSI = 248 Power = 00 HB = 1539 found in ListOfDevices
2019-01-22 19:04:43.548 Status: (ZiGate) Decode8015 : [02] DevID = 03 Network addr = c455 IEEE = 00158d00019ff1b6 RSSI = 190 Power = 00 HB = 1531 found in ListOfDevices
2019-01-22 19:04:43.701 Status: (ZiGate) Decode8009 : Zigate addresses ieee: 00158d0001ed465c , short addr: 0000
2019-01-22 19:04:43.701 Status: (ZiGate) Decode8009 - Network state UP, PANID: 193f extPANID: 0x2507756c7d5a75b4 Channel: 11
2019-01-22 19:04:43.957 Status: (ZiGate) Permit Join is On
2019-01-22 19:05:25.508 Status: (ZiGate) [0] NEW OBJECT: 1394 Device Annouce
2019-01-22 19:05:27.373 Status: (ZiGate) [0] NEW OBJECT: 1394 Device Annouce
2019-01-22 19:05:28.335 Status: (ZiGate) [0] NEW OBJECT: 1394 (re)Starting process
2019-01-22 19:05:29.192 Status: (ZiGate) [0] NEW OBJECT: 1394 Device Annouce
2019-01-22 19:05:31.057 Status: (ZiGate) [0] NEW OBJECT: 1394 Device Annouce
2019-01-22 19:05:32.720 Status: (ZiGate) [0] NEW OBJECT: 1394 Device Annouce
2019-01-22 19:05:33.324 Status: (ZiGate) [0] NEW OBJECT: 1394 Ox8045 received Infos
2019-01-22 19:05:33.324 Status: (ZiGate) [0] NEW OBJECT: 1394 Request Simple Descriptor for Ep: 01
2019-01-22 19:05:33.325 Status: (ZiGate) [0] NEW OBJECT: 1394 Request Attributes for Cluster 0x0000
2019-01-22 19:05:33.326 Status: (ZiGate) [0] NEW OBJECT: 1394 Request Attributes for Cluster 0x0001
2019-01-22 19:05:33.438 Status: (ZiGate) [-] NEW OBJECT: 1394 Simple Descriptor EP 01
2019-01-22 19:05:33.439 Status: (ZiGate) [-] NEW OBJECT: 1394 ProfileID 0104
2019-01-22 19:05:33.439 Status: (ZiGate) [-] NEW OBJECT: 1394 ZDeviceID 0102
2019-01-22 19:05:33.439 Status: (ZiGate) [-] NEW OBJECT: 1394 Cluster IN Count: 10
2019-01-22 19:05:33.439 Status: (ZiGate) [-] NEW OBJECT: 1394 Cluster In 1: 0000
2019-01-22 19:05:33.439 Status: (ZiGate) [-] NEW OBJECT: 1394 Cluster In 2: 0004
2019-01-22 19:05:33.439 Status: (ZiGate) [-] NEW OBJECT: 1394 Cluster In 3: 0003
2019-01-22 19:05:33.439 Status: (ZiGate) [-] NEW OBJECT: 1394 Cluster In 4: 0005
2019-01-22 19:05:33.439 Status: (ZiGate) [-] NEW OBJECT: 1394 Cluster In 5: 000a
2019-01-22 19:05:33.440 Status: (ZiGate) [-] NEW OBJECT: 1394 Cluster In 6: 0102
2019-01-22 19:05:33.440 Status: (ZiGate) [-] NEW OBJECT: 1394 Cluster In 7: 000d
2019-01-22 19:05:33.440 Status: (ZiGate) [-] NEW OBJECT: 1394 Cluster In 8: 0013
2019-01-22 19:05:33.440 Status: (ZiGate) [-] NEW OBJECT: 1394 Cluster In 9: 0006
2019-01-22 19:05:33.440 Status: (ZiGate) [-] NEW OBJECT: 1394 Cluster In 10: 0001
2019-01-22 19:05:33.440 Status: (ZiGate) [-] NEW OBJECT: 1394 Cluster In 11: 0406
2019-01-22 19:05:33.440 Status: (ZiGate) [-] NEW OBJECT: 1394 Cluster In 12: 0008
2019-01-22 19:05:33.440 Status: (ZiGate) [-] NEW OBJECT: 1394 Cluster In 13: 0300
2019-01-22 19:05:33.440 Status: (ZiGate) [-] NEW OBJECT: 1394 Cluster In 14: 0403
2019-01-22 19:05:33.440 Status: (ZiGate) [-] NEW OBJECT: 1394 Cluster In 15: 0405
2019-01-22 19:05:33.440 Status: (ZiGate) [-] NEW OBJECT: 1394 Cluster In 16: 0402
2019-01-22 19:05:33.441 Status: (ZiGate) [-] NEW OBJECT: 1394 Cluster OUT Count: 0a
2019-01-22 19:05:33.441 Status: (ZiGate) [-] NEW OBJECT: 1394 Cluster Out 1: 0019
2019-01-22 19:05:33.441 Status: (ZiGate) [-] NEW OBJECT: 1394 Cluster Out 2: 000a
2019-01-22 19:05:33.441 Status: (ZiGate) [-] NEW OBJECT: 1394 Cluster Out 3: 000d
2019-01-22 19:05:33.441 Status: (ZiGate) [-] NEW OBJECT: 1394 Cluster Out 4: 0102
2019-01-22 19:05:33.441 Status: (ZiGate) [-] NEW OBJECT: 1394 Cluster Out 5: 0013
2019-01-22 19:05:33.441 Status: (ZiGate) [-] NEW OBJECT: 1394 Cluster Out 6: 0006
2019-01-22 19:05:33.441 Status: (ZiGate) [-] NEW OBJECT: 1394 Cluster Out 7: 0001
2019-01-22 19:05:33.441 Status: (ZiGate) [-] NEW OBJECT: 1394 Cluster Out 8: 0406
2019-01-22 19:05:33.441 Status: (ZiGate) [-] NEW OBJECT: 1394 Cluster Out 9: 0008
2019-01-22 19:05:33.441 Status: (ZiGate) [-] NEW OBJECT: 1394 Cluster Out 10: 0300
2019-01-22 19:05:34.047 Status: (ZiGate) Decode8048 - Leave indication, IEEE : 00158d0002c64acb Status : Success
2019-01-22 19:05:35.552 Status: (ZiGate) [0] NEW OBJECT: 3c8a Device Annouce
2019-01-22 19:05:35.553 Status: (ZiGate) NetworkID : 3c8a is replacing 1394 and is attached to IEEE : 00158d0002c64acb
2019-01-22 19:05:35.705 Status: (ZiGate) [0] NEW OBJECT: 3c8a Device Annouce
2019-01-22 19:05:36.824 (ZiGate) ZigateRead - MsgType: 8102, MsgLength: 0034, MsgCRC: fa, Data: 043c8a010000ff010042002703280f0521ef000727000000000000000008211601092100010a2100006420016520ff66219900; RSSI: b7
2019-01-22 19:05:36.825 (ZiGate) ZigateRead - MsgType 8102 - Report Individual Attribute response : 0181020034fa043c8a010000ff010042002703280f0521ef000727000000000000000008211601092100010a2100006420016520ff66219900b703
2019-01-22 19:05:36.825 (ZiGate) Decode8102 - Individual Attribute response : [3c8a:01] ClusterID: 0000 AttributeID: ff01 Status: 00 Type: 42 Size: 0027 ClusterData: >03280f0521ef000727000000000000000008211601092100010a2100006420016520ff66219900<
2019-01-22 19:05:36.825 (ZiGate) Decode8102 : Attribute Report from 3c8a SQN = 04 ClusterID = 0000 AttrID = ff01 Attribute Data = 03280f0521ef000727000000000000000008211601092100010a2100006420016520ff66219900
2019-01-22 19:05:36.825 (ZiGate) Device : 3c8a MacCapa : 8e updating SQN to 04
2019-01-22 19:05:36.826 (ZiGate) ReadCluster - 0000/ff01 Saddr: 3c8a ClusterData : 03280f0521ef000727000000000000000008211601092100010a2100006420016520ff66219900
2019-01-22 19:05:58.351 (ZiGate) ZigateEncode - Encodind data: 3c8a
2019-01-22 19:05:58.351 (ZiGate) Encode in: 3c8a / out:3c8a
2019-01-22 19:05:58.606 (ZiGate) ZigateRead - decoded data : 0180420012b391003c8a115f006400640000008e7f4001ba03 lenght : 50
2019-01-22 19:05:58.606 (ZiGate) ZigateRead - MsgType: 8042, MsgLength: 0012, MsgCRC: b3, Data: 91003c8a115f006400640000008e7f4001; RSSI: ba
2019-01-22 19:05:58.606 (ZiGate) ZigateRead - MsgType 8042 - Reception Node descriptor response : 0180420012b391003c8a115f006400640000008e7f4001ba03
2019-01-22 19:05:58.606 (ZiGate) Decode8042 - Reception Node Descriptor for : 3c8a SEQ : 91 Status : 00 manufacturer :115f mac_capability : 8e bit_field : 4001
