MyDomoAtHome - ImperiHome
manuloup
Re: MyDomoAtHome - ImperiHome
Message par manuloup »
Lol. Mea culpa.
La suite :
pi@raspberrypi /usr/bin $ sudo apt-get install MyDomoAtHome
Reading package lists... Done
Building dependency tree
Reading state information... Done
The following packages were automatically installed and are no longer required:
  libboost-dev libboost1.49-dev libc-ares2 libv8-3.14.5
Use 'apt-get autoremove' to remove them.
The following NEW packages will be installed:
  MyDomoAtHome
0 upgraded, 1 newly installed, 0 to remove and 20 not upgraded.
Need to get 0 B/123 kB of archives.
After this operation, 369 kB of additional disk space will be used.
(Reading database ... 102067 files and directories currently installed.)
Unpacking mydomoathome (from .../MyDomoAtHome_0.0.47_all.deb) ...
npm ERR! Error: No compatible version found: prettyjson@'^1.1.2'
npm ERR! Valid install targets:
npm ERR! ["0.0.1","0.1.0","0.1.1","0.1.2","0.1.3","0.1.4","0.2.0","0.2.1","0.3.0","0.3.1","0.4.0","0.5.0","0.6.0","0.7.0","0.7.1","0.8.0","0.8.1","0.9.0","0.10.0","0.11.0","0.11.1","0.12.0","0.12.1","0.13.0","1.0.0","1.1.0","1.1.1","1.1.2","1.1.3"]
npm ERR!     at installTargetsError (/usr/local/lib/node_modules/npm/lib/cache.js:685:10)
npm ERR!     at /usr/local/lib/node_modules/npm/lib/cache.js:607:10
npm ERR!     at saved (/usr/local/lib/node_modules/npm/node_modules/npm-registry-client/lib/get.js:138:7)
npm ERR!     at FSReqWrap.oncomplete (fs.js:82:15)
npm ERR! If you need help, you may report this log at:
npm ERR!     <http://github.com/isaacs/npm/issues>
npm ERR! or email it to:
npm ERR!     <npm-@googlegroups.com>
npm ERR! System Linux 4.1.19+
npm ERR! command "/usr/bin/node" "/usr/local/bin/npm" "install" "-g" "forever"
npm ERR! cwd /
npm ERR! node -v v4.2.2
npm ERR! npm -v 1.2.15
npm ERR!
npm ERR! Additional logging details can be found in:
npm ERR!     /npm-debug.log
npm ERR! not ok code 0
dpkg: error processing /var/cache/apt/archives/MyDomoAtHome_0.0.47_all.deb (--unpack):
 subprocess new pre-installation script returned error exit status 1
Errors were encountered while processing:
E: Sub-process /usr/bin/dpkg returned an error code (1)
manuloup
Bon, même opération pour npm, je relance.
manuloup
Bon ben voilà, ça marche :)
Comment voit-on la version de MyDomoAtHome installée ?
J'imagine qu'on le met à jour via APT ?
Merci Emmanuel
Manu
epierre
Message par epierre »
manuloup a écrit :Bon ben voilà, ça marche :)
Merci Emmanuel
Manu
bon doc a lettre a jour ☺️
mise a jour par apt, tu as device virtuel avec la version dans IH
zigbee zwave nrf24l rfx
denisb88
Message par denisb88 »
Pendant l'install (qui n'est pas encore fini d'ailleurs) j'ai eu ce message
npm WARN optional dep failed, continuing fsevents@1.0.9
C'est grave docteur ?
PI 2-Aeon Stick-RFXCom : sondes RFX-10 détec.fumées-2 détec.ouverture-7 caméras-NetAtmo+3 modules+Anémo+Pluvio-2 prises Greenwave-1 prise Wemo-3 détec.inondation-1 Parrot Flower-1 détecteur UV-1 hub Harmony-prises RFX- 4 Squeezebox-XPENology+Plex
epierre
denisb88 a écrit :Pendant l'install (qui n'est pas encore fini d'ailleurs) j'ai eu ce message
non mais je ne sais pas le cacher
denisb88
Bon je l'ai installé mais problème, avec cette version pendant l'installation, Domoticz a freezé, je l'ai relancé mais toujours en initialisation.
Du coup j'ai relancé le raspberry et là monit ne demarre plus, j'ai ce message
Job for monit.service failed. See 'systemctl status monit.service' and 'journalctl -xn' for details.
La commande donne ceci
monit.service - LSB: service and resource monitoring daemon
Loaded: loaded (/etc/init.d/monit)
Active: failed (Result: exit-code) since Sun 2016-03-27 17:07:46 CEST; 11min ago
Process: 2091 ExecStart=/etc/init.d/monit start (code=exited, status=1/FAILURE)
Alors qu'avant il n'y avait aucun problème
epierre
si tu avais mis mdah dedans retires le, c'est un pb de conf ici, il n'utilise pas nodejs
manuloup
Ça fonctionne impec de mon côté, merci Emmanuel.
J'ai même les bonnes valeurs qui apparaissent pour les devices du RPI, alors que ça apparaissait mal avant.
denisb88
epierre a écrit :si tu avais mis mdah dedans retires le, c'est un pb de conf ici, il n'utilise pas nodejs
Merci mais c'est quoi mdah (je débute)
J'ai réussi à lancer monit avec
sudo /etc/init.d/monit stop
sudo /etc/init.d/monit start
