prévisions météo, donc pas un device habituel, tu as le /json.htm?type=devices&filter=all&used=true&order=Name ?manuloup a écrit : Et sur la page météo de domoticz :
MyDomoAtHome - ImperiHome
Re: MyDomoAtHome - ImperiHome
zigbee zwave nrf24l rfx
RAINVAL=$(curl -s -i -H "Accept: application/json" "https://api.forecast.io/forecast/$API/$LAT,$LON?units=ca&exclude=currently,minutely,hourly,alerts,flags" | grep precipIntensity| cut -d, -f14 |cut -d: -f2 | cut -c 1-3)
echo "Precipitation : ${RAINVAL}"
curl --silent -s -i -H "Accept: application/json" "http://192.168.1.5:8080/json.htm?type=command¶m=udevice&idx=130&nvalue=0&svalue=0;${RAINVAL}"
non ilm me faut:
Je viens de comprendre. Voici la partie qui t'intéresse :
"AddjMulti" : 1.0,
"AddjMulti2" : 1.0,
"AddjValue" : 0.0,
"AddjValue2" : 0.0,
"BatteryLevel" : 255,
"CustomImage" : 0,
"Data" : "0;0.3",
"Description" : "",
"Favorite" : 0,
"HardwareID" : 6,
"HardwareName" : "Virtuel switch",
"HardwareType" : "Dummy (Does nothing, use for virtual switches only)",
"HardwareTypeVal" : 15,
"HaveTimeout" : false,
"ID" : "140D1",
"LastUpdate" : "2016-04-02 14:00:25",
"Name" : "Précipitations sous 24h",
"Notifications" : "false",
"PlanID" : "0",
"PlanIDs" : [ 0 ],
"Protected" : false,
"Rain" : "0.2",
"RainRate" : "0.0",
"ShowNotifications" : true,
"SignalLevel" : "-",
"SubType" : "TFA",
"Timers" : "false",
"Type" : "Rain",
"TypeImg" : "rain",
"Unit" : 1,
"Used" : 1,
"XOffset" : "0",
"YOffset" : "0",
"idx" : "130"
},Synology DS920+ avec VM Debian 12, Aeon Labs Z-Stick Gen5, Aeon Zwave et devices zwaves , Teleinfo USB, devices Zigbee, batterie Marstek Venus E, Shelly Pro 3EM...
I'm sending a new version out if you can test.
Sure, let me know when it is done.
done, version 0.1.1, please do apt-get update && apt-get upgrademanuloup a écrit :Sure, let me know when it is done.
W: Failed to fetch http://www.e-nef.com/domoticz/mdah/Release.gpg Could not connect to www.e-nef.com:80 (80.67.160.90), connection timed out
W: Some index files failed to download. They have been ignored, or old ones used instead.Synology DS920+ avec VM Debian 12, Aeon Labs Z-Stick Gen5, Aeon Zwave et devices zwaves , Teleinfo USB, devices Zigbee, batterie Marstek Venus E, Shelly Pro 3EM...
Bonjour Emmanuel,
Tu as changé de version et mon Imperihome donne toujours 0.0.47 en version installée et idem en found ?
Du coup, après voir vu les derniers échanges, j'ai lancé un update mais si je ne les avais pas lus, je n'aurai pas su qu'il y avait du changement.
Je confirme, rien de nouveau non plus de mon côté.
