Attaque réseau ?
Re: Attaque réseau ?
Mais il sort d'oú ce "'vi /etc/fail2ban/filter.d/domoticz.conf\n' failed! " ?
C'est la dernière ligne d'erreur de retour de la commande sudo /etc/init.d/fail2ban restart
Ok je pense avoir compris.
viewtopic.php?f=13&t=946&start=10
Dans mon tuto je dis de faire :
vi /etc/fail2ban/filter.d/domoticz.conf et je mets le texte après.
Je parie que tu as tout sélectionné et que tu as collé ma ligne vi /etc/fail2ban/filter.d/domoticz.conf dans ton fichier /etc/fail2ban/filter.d/domoticz.conf .
Tu peux vérifier stp ?
J'y avais pensé et voici le message d'erreur de la même commande avec cette ligne en moins
[....] Restarting authentication failure monitor: fail2banTraceback (most recent call last):
File "/usr/bin/fail2ban-client", line 404, in <module>
if client.start(sys.argv):
File "/usr/bin/fail2ban-client", line 373, in start
return self.__processCommand(args)
File "/usr/bin/fail2ban-client", line 183, in __processCommand
ret = self.__readConfig()
File "/usr/bin/fail2ban-client", line 378, in __readConfig
ret = self.__configurator.getOptions()
File "/usr/share/fail2ban/client/configurator.py", line 68, in getOptions
return self.__jails.getOptions(jail)
File "/usr/share/fail2ban/client/jailsreader.py", line 67, in getOptions
ret = jail.getOptions()
File "/usr/share/fail2ban/client/jailreader.py", line 78, in getOptions
ret = self.__filter.read()
File "/usr/share/fail2ban/client/filterreader.py", line 56, in read
return ConfigReader.read(self, "filter.d/" + self.__file)
File "/usr/share/fail2ban/client/configreader.py", line 62, in read
SafeConfigParserWithIncludes.read(self, [bConf, bLocal])
File "/usr/share/fail2ban/client/configparserinc.py", line 108, in read
fileNamesFull += SafeConfigParserWithIncludes.getIncludes(filename)
File "/usr/share/fail2ban/client/configparserinc.py", line 79, in getIncludes
parser.read(resource)
File "/usr/lib/python2.7/ConfigParser.py", line 305, in read
self._read(fp, filename)
File "/usr/lib/python2.7/ConfigParser.py", line 512, in _read
raise MissingSectionHeaderError(fpname, lineno, line)
ConfigParser.MissingSectionHeaderError: File contains no section headers.
file: /etc/fail2ban/filter.d/domoticz.conf, line: 3
' # Fail2Ban configuration file for domoticz\n'
failed!
failed!
Bizarre. Encore un \n , tu peux vérifier tes fichiers de config à coups de vi ?
Tu peux les poster ici ?
ça vient. Je rame avec vi
Bsr
Fais voir file: /etc/fail2ban/filter.d/domoticz.conf,
la ligne 1 sera interresante
Objectif : WAF > 1
Objectif : WAF > 1
C'est bon je n'ai plus de message d'erreur. Il fallait utiliser vi et pas nano.
Je continu le tuto et je posterai le résultat.
Merci pour le coup de main.
tt
tt
patrice
Il y avait effectivement il y avait un problème avec la ligne 1 qu'il fallait commenter #.
J'en reste là car tous les log s'inscrivent sur la carte sd et j'ai pas envie de prendre de risque. Je verrais quand je passerai domoticz sur ssd.
jackslayter
j'ai fail2ban qui plante avec la "config" domoticz (viewtopic.php?f=13&t=946&start=10#p8203) pourtant j'ai re vérifié c'est exactement la même config, j'ai essayer d'enlever mes autres config (https et ssh) rien ne change , un log plus verbeur, rien , fail2ban ne veut même pas se lancer
