Re: Attaque réseau ?
Publié : 13 avr. 2016, 16:09
Ah oui j'avais oublié ce détail. Il faut faire les modifs dans jail.local et non dans jail.conf.
J'ai corrigé dans mon tuto page 2, merci.
Reprenez le contrôle de votre domotique
https://easydomoticz.com/forum/
2016-09-26 16:48:19.725 Incoming connection from: 122.228.215.3
2016-09-26 16:48:19.726 Error: Webserver: File '/script': No such file or directory (2)
Sep 26 06:25:44 raspberrypi CRON[23877]: pam_unix(cron:session): session closed for user root
Sep 26 06:26:04 raspberrypi sshd[5770]: Received disconnect from 119.249.54.88: 11: [preauth]
Sep 26 06:26:53 raspberrypi sshd[5782]: Received disconnect from 119.249.54.75: 11: [preauth]
Sep 26 06:41:15 raspberrypi sshd[5930]: Received disconnect from 221.194.47.224: 11: [preauth]
Sep 26 06:53:41 raspberrypi sshd[6058]: Did not receive identification string from 163.172.197.79
Sep 26 07:17:01 raspberrypi CRON[6293]: pam_unix(cron:session): session opened for user root by (uid=0)
Sep 26 07:17:01 raspberrypi CRON[6293]: pam_unix(cron:session): session closed for user root
Sep 26 07:49:31 raspberrypi sshd[6658]: Did not receive identification string from 212.129.21.142
Sep 26 07:49:31 raspberrypi sshd[6659]: reverse mapping checking getaddrinfo for 212-129-21-142.rev.poneytelecom.eu [212.129.21.142] failed - POSSIBLE BREAK-IN ATTEMPT!
Sep 26 07:49:31 raspberrypi sshd[6659]: pam_unix(sshd:auth): authentication failure; logname= uid=0 euid=0 tty=ssh ruser= rhost=212.129.21.142 user=root
Sep 26 07:49:33 raspberrypi sshd[6659]: Failed password for root from 212.129.21.142 port 61164 ssh2
Sep 26 07:49:33 raspberrypi sshd[6659]: error: Received disconnect from 212.129.21.142: 3: com.jcraft.jsch.JSchException: Auth fail [preauth]
Sep 26 07:49:33 raspberrypi sshd[6665]: reverse mapping checking getaddrinfo for 212-129-21-142.rev.poneytelecom.eu [212.129.21.142] failed - POSSIBLE BREAK-IN ATTEMPT!
Sep 26 07:49:33 raspberrypi sshd[6665]: Invalid user test from 212.129.21.142
Sep 26 07:49:33 raspberrypi sshd[6665]: input_userauth_request: invalid user test [preauth]
Sep 26 07:49:33 raspberrypi sshd[6665]: pam_unix(sshd:auth): check pass; user unknown
Sep 26 07:49:33 raspberrypi sshd[6665]: pam_unix(sshd:auth): authentication failure; logname= uid=0 euid=0 tty=ssh ruser= rhost=212.129.21.142
Sep 26 07:49:35 raspberrypi sshd[6665]: Failed password for invalid user test from 212.129.21.142 port 61537 ssh2
Sep 26 07:49:35 raspberrypi sshd[6665]: error: Received disconnect from 212.129.21.142: 3: com.jcraft.jsch.JSchException: Auth fail [preauth]
Sep 26 07:49:35 raspberrypi sshd[6671]: reverse mapping checking getaddrinfo for 212-129-21-142.rev.poneytelecom.eu [212.129.21.142] failed - POSSIBLE BREAK-IN ATTEMPT!
Sep 26 07:49:35 raspberrypi sshd[6671]: Invalid user admin from 212.129.21.142
Sep 26 07:49:35 raspberrypi sshd[6671]: input_userauth_request: invalid user admin [preauth]
Sep 26 07:49:35 raspberrypi sshd[6671]: pam_unix(sshd:auth): check pass; user unknown
Sep 26 07:49:35 raspberrypi sshd[6671]: pam_unix(sshd:auth): authentication failure; logname= uid=0 euid=0 tty=ssh ruser= rhost=212.129.21.142
Sep 26 07:49:38 raspberrypi sshd[6671]: Failed password for invalid user admin from 212.129.21.142 port 61687 ssh2
Sep 26 07:49:38 raspberrypi sshd[6671]: error: Received disconnect from 212.129.21.142: 3: com.jcraft.jsch.JSchException: Auth fail [preauth]
Sep 26 07:49:38 raspberrypi sshd[6678]: reverse mapping checking getaddrinfo for 212-129-21-142.rev.poneytelecom.eu [212.129.21.142] failed - POSSIBLE BREAK-IN ATTEMPT!
Sep 26 07:49:38 raspberrypi sshd[6678]: pam_unix(sshd:auth): authentication failure; logname= uid=0 euid=0 tty=ssh ruser= rhost=212.129.21.142 user=root
Sep 26 07:49:40 raspberrypi sshd[6678]: Failed password for root from 212.129.21.142 port 62070 ssh2
Sep 26 07:49:40 raspberrypi sshd[6678]: error: Received disconnect from 212.129.21.142: 3: com.jcraft.jsch.JSchException: Auth fail [preauth]
Sep 26 07:49:41 raspberrypi sshd[6684]: reverse mapping checking getaddrinfo for 212-129-21-142.rev.poneytelecom.eu [212.129.21.142] failed - POSSIBLE BREAK-IN ATTEMPT!
Sep 26 07:49:41 raspberrypi sshd[6684]: Invalid user guest from 212.129.21.142
Sep 26 07:49:41 raspberrypi sshd[6684]: input_userauth_request: invalid user guest [preauth]
Sep 26 07:49:41 raspberrypi sshd[6684]: pam_unix(sshd:auth): check pass; user unknown
Sep 26 07:49:41 raspberrypi sshd[6684]: pam_unix(sshd:auth): authentication failure; logname= uid=0 euid=0 tty=ssh ruser= rhost=212.129.21.142
Sep 26 07:49:42 raspberrypi sshd[6684]: Failed password for invalid user guest from 212.129.21.142 port 62234 ssh2
Sep 26 07:49:42 raspberrypi sshd[6684]: error: Received disconnect from 212.129.21.142: 3: com.jcraft.jsch.JSchException: Auth fail [preauth]
Sep 26 07:49:43 raspberrypi sshd[6694]: reverse mapping checking getaddrinfo for 212-129-21-142.rev.poneytelecom.eu [212.129.21.142] failed - POSSIBLE BREAK-IN ATTEMPT!
Sep 26 07:49:43 raspberrypi sshd[6694]: Invalid user ubnt from 212.129.21.142
Sep 26 07:49:43 raspberrypi sshd[6694]: input_userauth_request: invalid user ubnt [preauth]
Sep 26 07:49:43 raspberrypi sshd[6694]: pam_unix(sshd:auth): check pass; user unknown
Sep 26 07:49:43 raspberrypi sshd[6694]: pam_unix(sshd:auth): authentication failure; logname= uid=0 euid=0 tty=ssh ruser= rhost=212.129.21.142
Sep 26 07:49:44 raspberrypi sshd[6694]: Failed password for invalid user ubnt from 212.129.21.142 port 62370 ssh2
Sep 26 07:49:44 raspberrypi sshd[6694]: error: Received disconnect from 212.129.21.142: 3: com.jcraft.jsch.JSchException: Auth fail [preauth]
Sep 26 07:49:45 raspberrypi sshd[6704]: reverse mapping checking getaddrinfo for 212-129-21-142.rev.poneytelecom.eu [212.129.21.142] failed - POSSIBLE BREAK-IN ATTEMPT!
Sep 26 07:49:45 raspberrypi sshd[6704]: Invalid user support from 212.129.21.142
Sep 26 07:49:45 raspberrypi sshd[6704]: input_userauth_request: invalid user support [preauth]
Sep 26 07:49:45 raspberrypi sshd[6704]: pam_unix(sshd:auth): check pass; user unknown
Sep 26 07:49:45 raspberrypi sshd[6704]: pam_unix(sshd:auth): authentication failure; logname= uid=0 euid=0 tty=ssh ruser= rhost=212.129.21.142
Sep 26 07:49:46 raspberrypi sshd[6704]: Failed password for invalid user support from 212.129.21.142 port 62766 ssh2
Sep 26 07:49:46 raspberrypi sshd[6704]: error: Received disconnect from 212.129.21.142: 3: com.jcraft.jsch.JSchException: Auth fail [preauth]
Sep 26 07:49:47 raspberrypi sshd[6710]: reverse mapping checking getaddrinfo for 212-129-21-142.rev.poneytelecom.eu [212.129.21.142] failed - POSSIBLE BREAK-IN ATTEMPT!
Sep 26 07:49:47 raspberrypi sshd[6710]: Invalid user test from 212.129.21.142
Sep 26 07:49:47 raspberrypi sshd[6710]: input_userauth_request: invalid user test [preauth]
Sep 26 07:49:47 raspberrypi sshd[6710]: pam_unix(sshd:auth): check pass; user unknown
Sep 26 07:49:47 raspberrypi sshd[6710]: pam_unix(sshd:auth): authentication failure; logname= uid=0 euid=0 tty=ssh ruser= rhost=212.129.21.142
Sep 26 07:49:49 raspberrypi sshd[6710]: Failed password for invalid user test from 212.129.21.142 port 62898 ssh2
Sep 26 07:49:49 raspberrypi sshd[6710]: error: Received disconnect from 212.129.21.142: 3: com.jcraft.jsch.JSchException: Auth fail [preauth]
Sep 26 07:49:49 raspberrypi sshd[6716]: reverse mapping checking getaddrinfo for 212-129-21-142.rev.poneytelecom.eu [212.129.21.142] failed - POSSIBLE BREAK-IN ATTEMPT!
Sep 26 07:49:50 raspberrypi sshd[6716]: pam_unix(sshd:auth): authentication failure; logname= uid=0 euid=0 tty=ssh ruser= rhost=212.129.21.142 user=pi
Sep 26 07:49:52 raspberrypi sshd[6716]: Failed password for pi from 212.129.21.142 port 63305 ssh2
Sep 26 07:49:52 raspberrypi sshd[6716]: error: Received disconnect from 212.129.21.142: 3: com.jcraft.jsch.JSchException: Auth fail [preauth]
Sep 26 07:49:52 raspberrypi sshd[6722]: reverse mapping checking getaddrinfo for 212-129-21-142.rev.poneytelecom.eu [212.129.21.142] failed - POSSIBLE BREAK-IN ATTEMPT!
Sep 26 07:49:52 raspberrypi sshd[6722]: Invalid user admin from 212.129.21.142
Sep 26 07:49:52 raspberrypi sshd[6722]: input_userauth_request: invalid user admin [preauth]
Sep 26 07:49:52 raspberrypi sshd[6722]: pam_unix(sshd:auth): check pass; user unknown
Sep 26 07:49:52 raspberrypi sshd[6722]: pam_unix(sshd:auth): authentication failure; logname= uid=0 euid=0 tty=ssh ruser= rhost=212.129.21.142
Sep 26 07:49:53 raspberrypi sshd[6722]: Failed password for invalid user admin from 212.129.21.142 port 63442 ssh2
Sep 26 07:49:53 raspberrypi sshd[6722]: error: Received disconnect from 212.129.21.142: 3: com.jcraft.jsch.JSchException: Auth fail [preauth]
Sep 26 07:49:54 raspberrypi sshd[6728]: reverse mapping checking getaddrinfo for 212-129-21-142.rev.poneytelecom.eu [212.129.21.142] failed - POSSIBLE BREAK-IN ATTEMPT!
Sep 26 07:49:54 raspberrypi sshd[6728]: Invalid user user from 212.129.21.142
Sep 26 07:49:54 raspberrypi sshd[6728]: input_userauth_request: invalid user user [preauth]
Sep 26 07:49:54 raspberrypi sshd[6728]: pam_unix(sshd:auth): check pass; user unknown
Sep 26 07:49:54 raspberrypi sshd[6728]: pam_unix(sshd:auth): authentication failure; logname= uid=0 euid=0 tty=ssh ruser= rhost=212.129.21.142
Sep 26 07:49:56 raspberrypi sshd[6728]: Failed password for invalid user user from 212.129.21.142 port 63819 ssh2
Sep 26 07:49:56 raspberrypi sshd[6728]: error: Received disconnect from 212.129.21.142: 3: com.jcraft.jsch.JSchException: Auth fail [preauth]
Sep 26 07:49:56 raspberrypi sshd[6734]: reverse mapping checking getaddrinfo for 212-129-21-142.rev.poneytelecom.eu [212.129.21.142] failed - POSSIBLE BREAK-IN ATTEMPT!
Sep 26 07:49:56 raspberrypi sshd[6734]: Invalid user ftpuser from 212.129.21.142
Sep 26 07:49:56 raspberrypi sshd[6734]: input_userauth_request: invalid user ftpuser [preauth]
Sep 26 07:49:56 raspberrypi sshd[6734]: pam_unix(sshd:auth): check pass; user unknown
Sep 26 07:49:56 raspberrypi sshd[6734]: pam_unix(sshd:auth): authentication failure; logname= uid=0 euid=0 tty=ssh ruser= rhost=212.129.21.142
Sep 26 07:49:58 raspberrypi sshd[6734]: Failed password for invalid user ftpuser from 212.129.21.142 port 63844 ssh2
Sep 26 07:49:58 raspberrypi sshd[6734]: error: Received disconnect from 212.129.21.142: 3: com.jcraft.jsch.JSchException: Auth fail [preauth]
Sep 26 07:49:58 raspberrypi sshd[6740]: reverse mapping checking getaddrinfo for 212-129-21-142.rev.poneytelecom.eu [212.129.21.142] failed - POSSIBLE BREAK-IN ATTEMPT!
Sep 26 07:49:58 raspberrypi sshd[6740]: Invalid user PlcmSpIp from 212.129.21.142
Sep 26 07:49:58 raspberrypi sshd[6740]: input_userauth_request: invalid user PlcmSpIp [preauth]
Sep 26 07:49:58 raspberrypi sshd[6740]: pam_unix(sshd:auth): check pass; user unknown
Sep 26 07:49:58 raspberrypi sshd[6740]: pam_unix(sshd:auth): authentication failure; logname= uid=0 euid=0 tty=ssh ruser= rhost=212.129.21.142
Sep 26 07:50:00 raspberrypi sshd[6740]: Failed password for invalid user PlcmSpIp from 212.129.21.142 port 64386 ssh2
Sep 26 07:50:00 raspberrypi sshd[6740]: error: Received disconnect from 212.129.21.142: 3: com.jcraft.jsch.JSchException: Auth fail [preauth]
Sep 26 07:50:00 raspberrypi sshd[6746]: reverse mapping checking getaddrinfo for 212-129-21-142.rev.poneytelecom.eu [212.129.21.142] failed - POSSIBLE BREAK-IN ATTEMPT!
Sep 26 07:50:00 raspberrypi sshd[6746]: Invalid user admin from 212.129.21.142
Sep 26 07:50:00 raspberrypi sshd[6746]: input_userauth_request: invalid user admin [preauth]
Sep 26 07:50:00 raspberrypi sshd[6746]: pam_unix(sshd:auth): check pass; user unknown
Sep 26 07:50:00 raspberrypi sshd[6746]: pam_unix(sshd:auth): authentication failure; logname= uid=0 euid=0 tty=ssh ruser= rhost=212.129.21.142
Sep 26 07:50:03 raspberrypi sshd[6746]: Failed password for invalid user admin from 212.129.21.142 port 64408 ssh2
Sep 26 07:50:03 raspberrypi sshd[6746]: error: Received disconnect from 212.129.21.142: 3: com.jcraft.jsch.JSchException: Auth fail [preauth]
Sep 26 07:50:03 raspberrypi sshd[6752]: reverse mapping checking getaddrinfo for 212-129-21-142.rev.poneytelecom.eu [212.129.21.142] failed - POSSIBLE BREAK-IN ATTEMPT!
Sep 26 07:50:03 raspberrypi sshd[6752]: Invalid user nagios from 212.129.21.142
Sep 26 07:50:03 raspberrypi sshd[6752]: input_userauth_request: invalid user nagios [preauth]
Sep 26 07:50:03 raspberrypi sshd[6752]: pam_unix(sshd:auth): check pass; user unknown
Sep 26 07:50:03 raspberrypi sshd[6752]: pam_unix(sshd:auth): authentication failure; logname= uid=0 euid=0 tty=ssh ruser= rhost=212.129.21.142
Sep 26 07:50:05 raspberrypi sshd[6752]: Failed password for invalid user nagios from 212.129.21.142 port 64560 ssh2
Sep 26 07:50:05 raspberrypi sshd[6752]: error: Received disconnect from 212.129.21.142: 3: com.jcraft.jsch.JSchException: Auth fail [preauth]
Sep 26 07:50:06 raspberrypi sshd[6758]: reverse mapping checking getaddrinfo for 212-129-21-142.rev.poneytelecom.eu [212.129.21.142] failed - POSSIBLE BREAK-IN ATTEMPT!
Sep 26 07:50:06 raspberrypi sshd[6758]: Invalid user adam from 212.129.21.142
Sep 26 07:50:06 raspberrypi sshd[6758]: input_userauth_request: invalid user adam [preauth]
Sep 26 07:50:06 raspberrypi sshd[6758]: pam_unix(sshd:auth): check pass; user unknown
Sep 26 07:50:06 raspberrypi sshd[6758]: pam_unix(sshd:auth): authentication failure; logname= uid=0 euid=0 tty=ssh ruser= rhost=212.129.21.142
Sep 26 07:50:08 raspberrypi sshd[6758]: Failed password for invalid user adam from 212.129.21.142 port 64975 ssh2
Sep 26 07:50:08 raspberrypi sshd[6758]: error: Received disconnect from 212.129.21.142: 3: com.jcraft.jsch.JSchException: Auth fail [preauth]
Sep 26 07:50:08 raspberrypi sshd[6764]: reverse mapping checking getaddrinfo for 212-129-21-142.rev.poneytelecom.eu [212.129.21.142] failed - POSSIBLE BREAK-IN ATTEMPT!
Sep 26 07:50:08 raspberrypi sshd[6764]: pam_unix(sshd:auth): authentication failure; logname= uid=0 euid=0 tty=ssh ruser= rhost=212.129.21.142 user=root
Sep 26 07:50:10 raspberrypi sshd[6764]: Failed password for root from 212.129.21.142 port 65124 ssh2
Sep 26 07:50:10 raspberrypi sshd[6764]: error: Received disconnect from 212.129.21.142: 3: com.jcraft.jsch.JSchException: Auth fail [preauth]
Sep 26 08:17:01 raspberrypi CRON[7045]: pam_unix(cron:session): session opened for user root by (uid=0)
Sep 26 08:17:01 raspberrypi CRON[7045]: pam_unix(cron:session): session closed for user root
Sep 26 08:47:02 raspberrypi sshd[7371]: Received disconnect from 121.18.238.114: 11: [preauth]
Sep 26 08:47:08 raspberrypi sshd[7374]: Received disconnect from 119.249.54.75: 11: [preauth]
Sep 26 09:00:03 raspberrypi sshd[7507]: Received disconnect from 121.18.238.98: 11: [preauth]
Sep 26 09:10:05 raspberrypi sshd[7611]: Received disconnect from 221.194.47.249: 11: [preauth]
Sep 26 09:17:01 raspberrypi CRON[7683]: pam_unix(cron:session): session opened for user root by (uid=0)
Sep 26 09:17:01 raspberrypi CRON[7683]: pam_unix(cron:session): session closed for user root
Sep 26 10:17:01 raspberrypi CRON[8312]: pam_unix(cron:session): session opened for user root by (uid=0)
Sep 26 10:17:01 raspberrypi CRON[8312]: pam_unix(cron:session): session closed for user root
Sep 26 10:21:15 raspberrypi sshd[8375]: Received disconnect from 119.249.54.66: 11: [preauth]
Sep 26 10:21:56 raspberrypi sshd[8387]: Received disconnect from 119.249.54.88: 11: [preauth]
Sep 26 10:39:20 raspberrypi sshd[8560]: Received disconnect from 121.18.238.104: 11: [preauth]
Sep 26 10:50:02 raspberrypi sshd[8673]: Received disconnect from 221.194.47.249: 11: [preauth]
Sep 26 10:54:13 raspberrypi sshd[8716]: Received disconnect from 117.169.85.170: 11: Bye Bye [preauth]
Sep 26 11:17:01 raspberrypi CRON[8952]: pam_unix(cron:session): session opened for user root by (uid=0)
Sep 26 11:17:01 raspberrypi CRON[8952]: pam_unix(cron:session): session closed for user root
Sep 26 11:19:53 raspberrypi sshd[8999]: Did not receive identification string from 213.165.89.84
Sep 26 11:27:05 raspberrypi sshd[9077]: Did not receive identification string from 163.172.197.79
Sep 26 12:00:28 raspberrypi sshd[9412]: Received disconnect from 119.249.54.66: 11: [preauth]
Sep 26 12:00:40 raspberrypi sshd[9421]: Received disconnect from 221.194.47.229: 11: [preauth]
Sep 26 12:17:01 raspberrypi CRON[9591]: pam_unix(cron:session): session opened for user root by (uid=0)
Sep 26 12:17:01 raspberrypi CRON[9591]: pam_unix(cron:session): session closed for user root
Sep 26 13:09:50 raspberrypi sshd[10148]: Did not receive identification string from 113.108.21.16
Sep 26 13:17:01 raspberrypi CRON[10220]: pam_unix(cron:session): session opened for user root by (uid=0)
Sep 26 13:17:01 raspberrypi CRON[10220]: pam_unix(cron:session): session closed for user root
Sep 26 13:18:44 raspberrypi sshd[10265]: Received disconnect from 121.18.238.109: 11: [preauth]
Sep 26 13:20:42 raspberrypi sshd[10287]: pam_unix(sshd:auth): authentication failure; logname= uid=0 euid=0 tty=ssh ruser= rhost=89-97-55-33.ip16.fastwebnet.it user=root
Sep 26 13:20:44 raspberrypi sshd[10287]: Failed password for root from 89.97.55.33 port 39866 ssh2
Sep 26 13:20:46 raspberrypi sshd[10287]: Failed password for root from 89.97.55.33 port 39866 ssh2
Sep 26 13:20:46 raspberrypi sshd[10287]: Received disconnect from 89.97.55.33: 11: disconnected by user [preauth]
Sep 26 13:20:46 raspberrypi sshd[10287]: PAM 1 more authentication failure; logname= uid=0 euid=0 tty=ssh ruser= rhost=89-97-55-33.ip16.fastwebnet.it user=root
Sep 26 13:36:56 raspberrypi sshd[10456]: Received disconnect from 221.194.47.249: 11: [preauth]
Sep 26 13:41:22 raspberrypi sshd[10505]: fatal: Unable to negotiate a key exchange method [preauth]
Sep 26 14:17:01 raspberrypi CRON[10866]: pam_unix(cron:session): session opened for user root by (uid=0)
Sep 26 14:17:01 raspberrypi CRON[10866]: pam_unix(cron:session): session closed for user root
Sep 26 15:06:09 raspberrypi sshd[11388]: Received disconnect from 221.194.47.229: 11: [preauth]
Sep 26 15:12:18 raspberrypi sshd[11456]: Received disconnect from 119.249.54.75: 11: [preauth]
Sep 26 15:17:01 raspberrypi CRON[11503]: pam_unix(cron:session): session opened for user root by (uid=0)
Sep 26 15:17:02 raspberrypi CRON[11503]: pam_unix(cron:session): session closed for user root
Sep 26 15:25:50 raspberrypi sshd[11617]: Received disconnect from 121.18.238.109: 11: [preauth]
Sep 26 15:41:20 raspberrypi sshd[11776]: Received disconnect from 221.194.47.249: 11: [preauth]
Sep 26 16:06:51 raspberrypi sudo: root : TTY=unknown ; PWD=/home/pi/domoticz ; USER=root ; COMMAND=/usr/sbin/service domoticz.sh stop
Sep 26 16:06:51 raspberrypi sudo: pam_unix(sudo:session): session opened for user root by (uid=0)
Sep 26 16:07:22 raspberrypi sudo: pam_unix(sudo:session): session closed for user root
Sep 26 16:07:37 raspberrypi sudo: root : TTY=unknown ; PWD=/home/pi/domoticz ; USER=root ; COMMAND=/usr/sbin/service domoticz.sh start
Sep 26 16:07:37 raspberrypi sudo: pam_unix(sudo:session): session opened for user root by (uid=0)
Sep 26 16:07:37 raspberrypi sudo: pam_unix(sudo:session): session closed for user root
Sep 26 16:17:01 raspberrypi CRON[12264]: pam_unix(cron:session): session opened for user root by (uid=0)
Sep 26 16:17:01 raspberrypi CRON[12264]: pam_unix(cron:session): session closed for user root
Sep 26 17:00:16 raspberrypi sshd[12725]: pam_unix(sshd:auth): authentication failure; logname= uid=0 euid=0 tty=ssh ruser= rhost=polo-pc.home user=pi
Sep 26 17:00:18 raspberrypi sshd[12725]: Failed password for pi from 192.168.1.27 port 51973 ssh2
Sep 26 17:00:24 raspberrypi sshd[12725]: Accepted password for pi from 192.168.1.27 port 51973 ssh2
Sep 26 17:00:24 raspberrypi sshd[12725]: pam_unix(sshd:session): session opened for user pi by (uid=0)
Sep 26 17:00:24 raspberrypi sshd[12725]: lastlog_openseek: Couldn't stat /var/log/lastlog: No such file or directory
Sep 26 17:00:36 raspberrypi sudo: pi : TTY=pts/0 ; PWD=/home/pi ; USER=root ; COMMAND=/usr/bin/nano /tmp/domoticz.txt
Sep 26 17:00:36 raspberrypi sudo: pam_unix(sudo:session): session opened for user root by pi(uid=0)
Sep 26 17:00:42 raspberrypi sudo: pam_unix(sudo:session): session closed for user root
Sep 26 17:01:14 raspberrypi sudo: pi : TTY=pts/0 ; PWD=/home/pi ; USER=root ; COMMAND=/usr/bin/nano /var/log/domoticz.log
Sep 26 17:01:14 raspberrypi sudo: pam_unix(sudo:session): session opened for user root by pi(uid=0)
Sep 26 17:01:17 raspberrypi sudo: pam_unix(sudo:session): session closed for user root
Sep 26 17:01:37 raspberrypi sudo: pi : TTY=pts/0 ; PWD=/home/pi ; USER=root ; COMMAND=/usr/bin/nano /etc/fail2ban/
Sep 26 17:01:37 raspberrypi sudo: pam_unix(sudo:session): session opened for user root by pi(uid=0)
Sep 26 17:01:57 raspberrypi sudo: pam_unix(sudo:session): session closed for user root
Sep 26 17:05:16 raspberrypi sudo: pi : TTY=pts/0 ; PWD=/home/pi ; USER=root ; COMMAND=/usr/bin/nano /etc/fail2ban/jail.local
Sep 26 17:05:16 raspberrypi sudo: pam_unix(sudo:session): session opened for user root by pi(uid=0)
Sep 26 17:06:27 raspberrypi sshd[12725]: pam_unix(sshd:session): session closed for user pi
Sep 26 17:06:27 raspberrypi sudo: pam_unix(sudo:session): session closed for user root
Sep 26 17:06:39 raspberrypi sshd[12904]: Accepted password for pi from 192.168.1.27 port 52051 ssh2
Sep 26 17:06:39 raspberrypi sshd[12904]: pam_unix(sshd:session): session opened for user pi by (uid=0)
Sep 26 17:06:39 raspberrypi sshd[12904]: lastlog_openseek: Couldn't stat /var/log/lastlog: No such file or directory
Sep 26 17:06:47 raspberrypi sudo: pi : TTY=pts/0 ; PWD=/home/pi ; USER=root ; COMMAND=/usr/bin/nano var/log/auth.log
Sep 26 17:06:47 raspberrypi sudo: pam_unix(sudo:session): session opened for user root by pi(uid=0)
Sep 26 17:06:59 raspberrypi sudo: pam_unix(sudo:session): session closed for user root
Sep 26 17:12:09 raspberrypi sshd[13028]: pam_unix(sshd:auth): authentication failure; logname= uid=0 euid=0 tty=ssh ruser= rhost=polo-pc.home user=pi
Sep 26 17:12:11 raspberrypi sshd[13028]: Failed password for pi from 192.168.1.27 port 52113 ssh2
Sep 26 17:12:18 raspberrypi sshd[13028]: Accepted password for pi from 192.168.1.27 port 52113 ssh2
Sep 26 17:12:18 raspberrypi sshd[13028]: pam_unix(sshd:session): session opened for user pi by (uid=0)
DAEMON_ARGS="$DAEMON_ARGS -log /var/log//domoticz.log"Code : Tout sélectionner
sudo /etc/init.d/domoticz.sh restart
