2021-01-20 17:13:42.481 (Clef USB Zwave) General/Voltage (Voltage)
2021-01-20 17:13:42.519 (Clef USB Zwave) Current (Unknown)
2021-01-20 17:13:43.503 (Clef USB Zwave) General/kWh (kWh Chevet Chambre)
2021-01-20 17:13:43.540 (Clef USB Zwave) Usage (Lampadaire Boule)
2021-01-20 17:13:43.544 (Clef USB Zwave) General/kWh (kWh Chevet Chambre)
2021-01-20 17:13:43.578 (Clef USB Zwave) General/Voltage (Voltage)
2021-01-20 17:13:43.615 (Clef USB Zwave) Current (Unknown)
2021-01-20 17:13:43.795 (Clef USB Conbee II) ### Request config
2021-01-20 17:13:43.808 Status: (Clef USB Conbee II) Firmware version : 0x26580700
2021-01-20 17:13:43.808 Status: (Clef USB Conbee II) Websocketnotifyall : True
2021-01-20 17:13:43.808 (Clef USB Conbee II) ### Request lights
2021-01-20 17:13:43.820 (Clef USB Conbee II) ### Device > 1 Name:Configuration tool 1 Type:Configuration tool Details:{'reachable': True} and []
2021-01-20 17:13:43.820 (Clef USB Conbee II) Skipping Device (Useless) : 00:21:2e:ff:ff:06:0d:c5-01
2021-01-20 17:13:43.821 (Clef USB Conbee II) ### Device > 10 Name:Prise TV Type:Smart plug Details:{'alert': 'none', 'on': False, 'reachable': True} and []
2021-01-20 17:13:43.928 (Clef USB Conbee II) ### Device > 11 Name:prise 6 Type:Smart plug Details:{'alert': 'none', 'on': True, 'reachable': True} and []
2021-01-20 17:13:43.928 (Clef USB Conbee II) ### Device > 12 Name:Lampadaire Boule Type:Smart plug Details:{'alert': 'none', 'on': False, 'reachable': True} and []
2021-01-20 17:13:43.929 (Clef USB Conbee II) ### Device > 2 Name:Camera Salon Type:Smart plug Details:{'alert': 'none', 'on': False, 'reachable': True} and []
2021-01-20 17:13:43.929 (Clef USB Conbee II) ### Device > 4 Name:Prise informatique Type:Smart plug Details:{'alert': 'none', 'on': True, 'reachable': True} and []
2021-01-20 17:13:43.930 (Clef USB Conbee II) ### Device > 8 Name:Prise Placard Type:Smart plug Details:{'alert': 'none', 'on': False, 'reachable': True} and []
2021-01-20 17:13:43.930 (Clef USB Conbee II) ### Request sensors
2021-01-20 17:13:43.951 (Clef USB Conbee II) ### Device > 10 Name:Salle_de_Bain Pression Type:ZHAPressure Details:{'lastupdated': '2021-01-20T15:49:24.535', 'pressure': 1012} and {'battery': 95, 'on': True, 'reachable': True}
2021-01-20 17:13:43.952 (Clef USB Conbee II) ### Device > 12 Name:Capteur Volet Roulant Bureau Type:ZHAOpenClose Details:{'lastupdated': '2021-01-20T15:48:41.531', 'open': False} and {'battery': 95, 'on': True, 'reachable': True, 'temperature': 1700}
2021-01-20 17:13:43.952 (Clef USB Conbee II) ### Device > 14 Name:Capteur Volet Roulant Chambre Type:ZHAOpenClose Details:{'lastupdated': '2021-01-20T15:48:41.194', 'open': False} and {'battery': 98, 'on': True, 'reachable': True, 'temperature': 1500}
2021-01-20 17:13:43.953 (Clef USB Conbee II) ### Device > 15 Name:Capteur Volet Roulant Sejour Type:ZHAOpenClose Details:{'lastupdated': '2021-01-20T15:48:42.781', 'open': False} and {'battery': 91, 'on': True, 'reachable': True, 'temperature': 1600}
2021-01-20 17:13:43.953 (Clef USB Conbee II) ### Device > 16 Name:Capteur Volet Roulant Cuisine Type:ZHAOpenClose Details:{'lastupdated': '2021-01-20T15:48:42.395', 'open': False} and {'battery': 95, 'on': True, 'reachable': True, 'temperature': 1600}
2021-01-20 17:13:43.954 (Clef USB Conbee II) ### Device > 17 Name:Bureau Temperature Type:ZHATemperature Details:{'lastupdated': '2021-01-20T15:44:01.240', 'temperature': 1546} and {'battery': 100, 'offset': 0, 'on': True, 'reachable': True}
2021-01-20 17:13:43.954 (Clef USB Conbee II) ### Device > 18 Name:Bureau Humidité Type:ZHAHumidity Details:{'humidity': 6031, 'lastupdated': '2021-01-20T15:44:01.255'} and {'battery': 100, 'offset': 0, 'on': True, 'reachable': True}
2021-01-20 17:13:43.955 (Clef USB Conbee II) ### Device > 19 Name:Bureau Pression Type:ZHAPressure Details:{'lastupdated': '2021-01-20T15:44:01.261', 'pressure': 1013} and {'battery': 100, 'on': True, 'reachable': True}
2021-01-20 17:13:43.955 (Clef USB Conbee II) ### Device > 20 Name:Entrée Temperature Type:ZHATemperature Details:{'lastupdated': '2021-01-20T15:57:13.990', 'temperature': 1662} and {'battery': 100, 'offset': 0, 'on': True, 'reachable': True}
2021-01-20 17:13:43.956 (Clef USB Conbee II) ### Device > 21 Name:Entrée Humidité Type:ZHAHumidity Details:{'humidity': 5512, 'lastupdated': '2021-01-20T15:57:13.990'} and {'battery': 100, 'offset': 0, 'on': True, 'reachable': True}
2021-01-20 17:13:43.956 (Clef USB Conbee II) ### Device > 22 Name:Entrée Pression Type:ZHAPressure Details:{'lastupdated': '2021-01-20T15:57:13.990', 'pressure': 1012} and {'battery': 100, 'on': True, 'reachable': True}
2021-01-20 17:13:43.957 (Clef USB Conbee II) ### Device > 23 Name:Chambre Temperature Type:ZHATemperature Details:{'lastupdated': '2021-01-20T15:51:46.135', 'temperature': 1680} and {'battery': 100, 'offset': 0, 'on': True, 'reachable': True}
2021-01-20 17:13:43.957 (Clef USB Conbee II) ### Device > 24 Name:Chambre Humidité Type:ZHAHumidity Details:{'humidity': 5612, 'lastupdated': '2021-01-20T15:51:46.150'} and {'battery': 100, 'offset': 0, 'on': True, 'reachable': True}
2021-01-20 17:13:43.958 (Clef USB Conbee II) ### Device > 25 Name:Chambre Pression Type:ZHAPressure Details:{'lastupdated': '2021-01-20T15:51:46.168', 'pressure': 1011} and {'battery': 100, 'on': True, 'reachable': True}
2021-01-20 17:13:43.958 (Clef USB Conbee II) ### Device > 26 Name:Capteur Fenetre Cuisine Type:ZHAOpenClose Details:{'lastupdated': '2021-01-20T15:38:04.088', 'open': False} and {'battery': 100, 'on': True, 'reachable': True, 'temperature': 2300}
2021-01-20 17:13:43.958 (Clef USB Conbee II) ### Device > 27 Name:Daylight Type:Daylight Details:{'dark': False, 'daylight': False, 'lastupdated': '2021-01-20T16:12:48.382', 'status': 180, 'sunrise': '2021-01-20T07:35:38', 'sunset': '2021-01-20T16:30:00'} and {'configured': True, 'on': True, 'sunriseoffset': 30, 'sunsetoffset': -30}
2021-01-20 17:13:43.959 Error: (Clef USB Conbee II) Device creation failed, Domoticz settings prevent accepting new devices.
2021-01-20 17:13:43.959 Status: (Clef USB Conbee II) ### Create Device 00:21:2e:ff:ff:06:0d:c5-01 > Daylight (Daylight) as Unit 24
2021-01-20 17:13:43.959 Error: (Clef USB Conbee II) Can't Update Unit > 27 (sensors) : {'nValue': 0, 'sValue': 'Off'}
2021-01-20 17:13:43.959 (Clef USB Conbee II) ### Device > 28 Name:Capteur Fenetre Bureau Type:ZHAOpenClose Details:{'lastupdated': '2021-01-20T15:53:05.675', 'open': False} and {'battery': 100, 'on': True, 'reachable': True, 'temperature': 2100}
2021-01-20 17:13:43.960 (Clef USB Conbee II) ### Device > 29 Name:Capteur Fenetre Sejour Type:ZHAOpenClose Details:{'lastupdated': '2021-01-20T15:54:10.744', 'open': False} and {'battery': 100, 'on': True, 'reachable': True, 'temperature': 1800}
2021-01-20 17:13:43.960 (Clef USB Conbee II) ### Device > 30 Name:Capteur Fenetre Chambre Type:ZHAOpenClose Details:{'lastupdated': '2021-01-20T16:02:42.515', 'open': False} and {'battery': 100, 'on': True, 'reachable': True, 'temperature': 1900}
2021-01-20 17:13:43.961 (Clef USB Conbee II) ### Device > 8 Name:Salle_de_Bain Temperature Type:ZHATemperature Details:{'lastupdated': '2021-01-20T15:49:24.517', 'temperature': 1731} and {'battery': 95, 'offset': 0, 'on': True, 'reachable': True}
2021-01-20 17:13:43.961 (Clef USB Conbee II) ### Device > 9 Name:Salle_de_Bain Humidité Type:ZHAHumidity Details:{'humidity': 5304, 'lastupdated': '2021-01-20T15:49:24.529'} and {'battery': 95, 'offset': 0, 'on': True, 'reachable': True}
2021-01-20 17:13:43.962 (Clef USB Conbee II) ### Request groups
2021-01-20 17:13:43.971 Status: (Clef USB Conbee II) ### deCONZ ready
2021-01-20 17:13:43.971 Status: (Clef USB Conbee II) ### Found 6 Operators, 21 Sensors, 0 Groups, 0 Scenes and 0 others, with 0 Ignored
2021-01-20 17:13:43.971 Status: (Clef USB Conbee II) ### Device 84:2e:14:ff:fe:35:9a:f6-01-0702(Prise Placard kWh) Not in deCONZ ATM, the device is deleted or not ready.
2021-01-20 17:13:43.972 Status: (Clef USB Conbee II) ### Device 84:2e:14:ff:fe:35:9a:f6-01-0b04(Prise Placard kW) Not in deCONZ ATM, the device is deleted or not ready.
2021-01-20 17:13:43.972 Status: (Clef USB Conbee II) ### Device 58:8e:81:ff:fe:db:88:81-01-0702(Camera Salon kWh) Not in deCONZ ATM, the device is deleted or not ready.
2021-01-20 17:13:43.972 Status: (Clef USB Conbee II) ### Device 58:8e:81:ff:fe:db:88:81-01-0b04(Camera Salon kW) Not in deCONZ ATM, the device is deleted or not ready.
2021-01-20 17:13:43.972 Status: (Clef USB Conbee II) ### Device 84:2e:14:ff:fe:36:67:1d-01-0702(Prise Ordinateur Bureau kWh) Not in deCONZ ATM, the device is deleted or not ready.
2021-01-20 17:13:43.972 Status: (Clef USB Conbee II) ### Device 84:2e:14:ff:fe:36:67:1d-01-0b04(Prise Ordinateur Bureau kW) Not in deCONZ ATM, the device is deleted or not ready.
2021-01-20 17:13:43.972 Status: (Clef USB Conbee II) ### Device 58:8e:81:ff:fe:d3:90:41-01-0b04(Clef USB Conbee II - Power 27) Not in deCONZ ATM, the device is deleted or not ready.
2021-01-20 17:13:44.023 Status: (Clef USB Conbee II) Launching websocket on port 443
2021-01-20 17:13:44.073 (Clef USB Conbee II) Websocket Handshake : HTTP/1.1 101 Switching Protocols
***Upgrade: websocket
***Connection: Upgrade
***Sec-WebSocket-Accept: V0htEbn5FhIA1xfQRyG3yU1aG9c=
***Server: deconz
***Access-Control-Allow-Credentials: false
***Access-Control-Allow-Methods: GET
***Access-Control-Allow-Headers: content-type
***Access-Control-Allow-Origin: http://127.0.0.1
***Date: Wed, 20 Jan 2021 16:13:44 GMT
2021-01-20 17:13:44.592 (Clef USB Zwave) Gen
