Plugins DeConz et ZigBee2MQTT
frtoto
Message par frtoto »
edit : j'ai retrouvé, je vais enregistrer pendant 48h et voir
edit 2 : Cela ressemblait à ça ?(j'ai le log complet si tu veux)
2021-05-30 16:56:06.210  Météo: Temp + Humidity (temp_ext_arr)
2021-05-30 16:56:06.234  Météo: Temp + Humidity + Baro (temp_netatmo_int)
2021-05-30 16:56:06.240  Météo: Air Quality (Qualité air Salon)
2021-05-30 16:56:06.246  Météo: General/Sound Level (Bruit Salon)
2021-05-30 16:56:10.503  Conbee: (Conbee) Incomplete Json keep it for later : b'\x81~\x01[{"attr":{"id":"21","lastannounce'
2021-05-30 16:56:10.504  Conbee: (Conbee) Incomplete Json keep it for later : b'\x81~\x01[{"attr":{"id":"21","lastannounced":null,"lastseen":"2021-05-30T14:55Z","manufacturername":"dresden elektronik","modelid":"ConBee II","name":'
2021-05-30 16:56:10.504  Conbee: (Conbee) Incomplete Json keep it for later : b'\x81~\x01[{"attr":{"id":"21","lastannounced":null,"lastseen":"2021-05-30T14:55Z","manufacturername":"dresden elektronik","modelid":"ConBee II","name":"Configuration tool 21","swversion":"0x264a0700","type":"Configuration t'
2021-05-30 16:56:10.505  Conbee: (Conbee) Incomplete Json keep it for later : b'\x81~\x01V{"att'
2021-05-30 16:56:10.506  Conbee: (Conbee) Incomplete Json keep it for later : b'\x81~\x00\xa6{"e":"changed","id":"70","r":"sensors","state":{"consumption":24940,"lastupdated":"2021-05-30T14:55:32.221"},"t":"event","uniqueid":"00:15:8d:00'
2021-05-30 16:56:10.514  Conbee: (Conbee) Websocket Handshake : ":"event","uniqueid":"00:0d:6f:ff:fe:aa:be:f7-01"}
2021-05-30 16:57:00.192  Status: EventSystem: Script event triggered: vmc_cine
2021-05-30 16:57:00.200  Status: EventSystem: Script event triggered: vmc_sdb haut
2021-05-30 16:57:00.210  Status: EventSystem: Script event triggered: chauff SDB haut
Dz 2025.11_16729 - Conbee II
Thorgal
Message par Thorgal »
Yep, je veux bien, car je comprend pas du tout ce qui se passe
La c'est encore pire, j'ai l'impression que tu as recu 2 fois le meme websocket avec "att"
C'est pas possible que tu n'aie pas d'erreur du genre "Malformed JSON response, can't repair"
Et on voit pas non plus quand le code a nettoyé les infos avec un log du genre
2021-05-31 17:00:57.179 (deCONZ) ### WebSocket Data : {'state': {'power': 0, 'lastupdated': '2021-05-31T15:00:57.151'}, 'uniqueid': '00:04:74:00:00:72:06:45-01-0b04', 'id': '20', 't': 'event', 'e': 'changed', 'r': 'sensors'}
Du coup, je ne vois pas du tout ce que fais le code avec ces infos ....
PS: je suis en log "debug info only" de mon coté
frtoto
voici le log, je suis aussi en "info only"
merci
Edit : Mon firmware : 26680700
version deConz : 2.11.1-beta
Dernière modification par frtoto le 01 juin 2021, 20:35, modifié 1 fois.
Thorgal
Mais rassures moi, tu n'as aucun websockets ? aucune information qui remonte ?
Du coup je me suis penché sur ta connexion websocket
***Access-Control-Allow-Origin: http://10.0.0.1
C'est normal ca ? C'est sensé etre l'adresse IP de domoticz (http://127.0.0.1 si tout sur la meme machine)
Il y a plein de truc que je ne vois pas dans tes logs, par exemple
2021-05-31 22:23:17.422 (deCONZ) onHeartbeat called
2021-05-31 22:21:51.764 (deCONZ) onMessage called
C'est des trucs qui apparaissent avec le debug level "debug info only" dans la page hardware du plugin, tout en bas.
frtoto
L'adresse IP oui c'est normal, j'ai un rasp dédié à la Conbee IP 10.0.0.112 (comme ça elle est placée au centre de la maison) et DZ sur 10.0.0.1
Pour les info de debug je n'avais que la premiere case de cochée, je viens d'activer le debug plus bas sur la page, mais est-ce normal d'avoir autant d'info sur la page du plugin (notamment 2 fois la partie deCOnz Bridge) ?
Je refais des logs avec le 2éme debug activé et je te renvoie ça
Sans titre.jpg (304.51 Kio) Consulté 2852 fois
frtoto
Voila les logs
Dernière modification par frtoto le 03 juin 2021, 19:46, modifié 1 fois.
Thorgal
Non c'est pas trop normal, mais j pense qu'au prochain demarrage ca va disparaitre.
Sinon pour ton probleme, j'arrive a voir ce que c'est, tu recois une partie de websocket qui reinitialise ta chaine, par contre j'arrive vraiment a reproduire ca de mon coté.
Du coup j'aurais un dernier service a te demander, je viens de coder un fichier special avec les infos qui me manque.
https://github.com/Smanar/Domoticz-deCO ... 67e5245ded
Je ne sais pas comment tu as installé le plugin, mais si tu l'as fait via git
- vas dans le repertoire du plugin
cd Domoticz\plugins\Domoticz-deCONZ
- Update
git pull
- changement de branche
git checkout debug
- Update
git pull
- Redemarrage du plugin dans hardware/plugin/deconz/update
Tu vas avoir des logs en plus commencant par "data1" "data2" "data3", si tu pouvais me passer les memes logs que precedement ?
frtoto
Salut !
Log démarré à l'instant avec le plugin sur la branche debug, je t'envoie le fichier ce soir.
pour la page du plugin dans Dz cela fait longtemps que j'ai ces informations en double (même après plusieurs maj de dz)
Thorgal
Tu n'aurais pas 2 fois le plugin dans le repertoire plugin ?
J'ai deja eu cette issue, mais je me souviens plus comment la reproduire.
frtoto
Si c'est ça !
Voilà le log
Dernière modification par frtoto le 05 juin 2021, 13:54, modifié 2 fois.
