MyDomoAtHome - ImperiHome
maddmadd
Re: MyDomoAtHome - ImperiHome
Message par maddmadd »
J'essaie d'installer de Mydomoathome sur un raspberry 3B en parallèle avec Domoticz j'ai un problème lors de l'installation de Mydomoathome, il me met des erreurs,
je respecte la procédure mais probleme
voici les lignes:
sudo apt-get install MyDomoAtHome
Reading package lists... Done
Building dependency tree
Reading state information... Done
Note, selecting 'mydomoathome' instead of 'MyDomoAtHome'
The following NEW packages will be installed:
mydomoathome
0 upgraded, 1 newly installed, 0 to remove and 12 not upgraded.
Need to get 0 B/6,231 kB of archives.
After this operation, 35.7 MB of additional disk space will be used.
(Reading database ... 35748 files and directories currently installed.)
Preparing to unpack .../mydomoathome_0.2.36_all.deb ...
/var/lib/dpkg/tmp.ci/preinst: line 4: npm: command not found
dpkg: error processing archive /var/cache/apt/archives/mydomoathome_0.2.36_all.d eb (--unpack):
subprocess new pre-installation script returned error exit status 127
Errors were encountered while processing:
/var/cache/apt/archives/mydomoathome_0.2.36_all.deb
E: Sub-process /usr/bin/dpkg returned an error code (1)
voici la version raspbian que j ai:
PRETTY_NAME="Raspbian GNU/Linux 9 (stretch)"
NAME="Raspbian GNU/Linux"
VERSION_ID="9"
VERSION="9 (stretch)"
ID=raspbian
ID_LIKE=debian
HOME_URL="http://www.raspbian.org/"
SUPPORT_URL="http://www.raspbian.org/RaspbianForums"
BUG_REPORT_URL="http://www.raspbian.org/RaspbianBugs"
si vous avez une idee
Merci d avance
Maddmadd
waynekramer
Message par waynekramer »
Ca fait des semaines que je tente d'installer MDAH et je n'arrive pas à dépasser cette étape. J'ai le message d'erreur suivant :
Préparation du dépaquetage de .../mydomoathome_0.2.36_all.deb ...
/usr/local/bin/npm: 2: exec: /usr/local/bin/node: not found
dpkg: erreur de traitement de l'archive /var/cache/apt/archives/mydomoathome_0.2.36_all.deb (--unpack) :
le sous-processus nouveau script pre-installation a retourné une erreur de sortie d'état 127
Des erreurs ont été rencontrées pendant l'exécution :
Je ne comprends pas ce qui bloque. Est-ce que quelqu'un a déjà eu cette erreur ou sait comment la résoudre ?
Merci pour votre aide
WK
vulbas
Message par vulbas »
tu as bien suivi ce tuto ?
https://github.com/empierre/MyDomoAtHome
waynekramer
Je te remercie pour ta réponse.
J'ai bien suivi ce tuto.
J'ai finalement trouvé la solution. Il y avait un problème de npm...
J'ai réussi à la réinstaller après quelques longues tentatives.
vulbas
hello,
depuis ce matin impossible d'acceder à imperihome :(
quand je tape "monip:3002" j'arrive bien sur la page MyDomoAtHome, mais quand je fais monip:3002/devices j'ai droit à un La connexion a échoué
j'avoue que ça commence à me soulé tous ces problemes en ce moment.
j'avais une version stable beta et je me demande encore pourquoi j'ai fais une mise à jour lol
vulbas
j'ai testé une installation toute fraiche de domoticz et le probleme est toujours present, dois y avoir un truc dans les dernieres mises à jour qui bloque :(
j'avais fait cette video sur mon domoticz que j'utilise au quotidien
https://www.youtube.com/watch?v=IP7n1B8yLOU
christophe2836
Message par christophe2836 »
vulbas a écrit :j'ai testé une installation toute fraiche de domoticz et le probleme est toujours present, dois y avoir un truc dans les dernieres mises à jour qui bloque :(
Je suis en dernière bêta de domoticz pour synology et aucun soucis avec ImperiHome.
vulbas
aaarrrggghhhhhhh,
merci de ta reponse
je ne vois pas d'ou viens le probleme ...... quelqu'un d'autre avec le pi aurait la derniere beta pour me dire si ça fonctionne ?
vraiment je ne vois pas...... juste le 3002 c'est ok mais pour les devices il ne veut pas, ça me rends dingue, je trouve pas :?
ayant testé sur un autre pi3 en installation toute neuve, le probleme est le meme. en ayant directement installé la derniere beta. ça doit venir d'autre chose donc, mais de quoi ?
je seche complet
christophe2836
vulbas a écrit :aaarrrggghhhhhhh,
merci de ta reponse
je seche complet
Version MyDomoAtHome : 0.2.36
vulbas
oui oui c'est bien celle que j'ai.
je viens de rebrancher mon pi2, install propre de domoticz avec la version stable v3.8153 ça fonctionne
je passe en beta v3.9501 et ça ne fonctionne plus. c'est donc bien un probleme dans la beta ....... et le probleme c'est qu'il me faut la beta
