aie,
cette fois ci je n'ai plus acces à la page MDAH
pi@raspberrypi:~ $ curl http://192.168.1.225:3002/devices
curl: (7) Failed to connect to 192.168.1.225 port 3002: Connexion refusée
pi@raspberrypi:~ $
pi@raspberrypi:~ $ node --version
v4.2.2
pi@raspberrypi:~ $ npm --version
2.15.12
pi@raspberrypi:~ $ sudo service mydomoathome status
● mydomoathome.service - MDAH ISS Rest interface for Domoticz to Imperihome
Loaded: loaded (/etc/systemd/system/mydomoathome.service; enabled; vendor pre
Active: active (running) since Thu 2018-05-31 20:26:15 CEST; 7min ago
Process: 3424 ExecStartPre=/bin/chmod 755 /run/mydomoathome (code=exited, stat
Process: 3421 ExecStartPre=/bin/chown www-data:www-data /etc/mydomoathome/conf
Process: 3418 ExecStartPre=/bin/chown www-data:www-data /run/mydomoathome (cod
Process: 3415 ExecStartPre=/bin/mkdir -p /run/mydomoathome (code=exited, statu
Main PID: 3427 (mydomoathome)
CGroup: /system.slice/mydomoathome.service
├─3427 /bin/bash /usr/share/mydomoathome/bin/mydomoathome
├─3428 node /usr/local/bin/forever --minUptime 5000 --spinSleepTime 2
└─4580 /usr/bin/node /usr/share/mydomoathome/app/mdah.js
mai 31 20:33:35 raspberrypi MDAH[3427]: at Module.require (module.js:366:17)
mai 31 20:33:35 raspberrypi MDAH[3427]: at require (module.js:385:17)
mai 31 20:33:35 raspberrypi MDAH[3427]: at Object.<anonymous> (/usr/share/my
mai 31 20:33:35 raspberrypi MDAH[3427]: at Module._compile (module.js:435:26
mai 31 20:33:35 raspberrypi MDAH[3427]: at Object.Module._extensions..js (mo
mai 31 20:33:35 raspberrypi MDAH[3427]: at Module.load (module.js:356:32)
mai 31 20:33:35 raspberrypi MDAH[3427]: at Function.Module._load (module.js:
mai 31 20:33:35 raspberrypi MDAH[3427]: at Function.Module.runMain (module.j
mai 31 20:33:35 raspberrypi MDAH[3427]: error: Forever detected script exited wi
mai 31 20:33:38 raspberrypi MDAH[3427]: error: Script restart attempt #102
lines 1-23...skipping...
Loaded: loaded (/etc/systemd/system/mydomoathome.service; enabled; vendor preset: enabled)
Process: 3424 ExecStartPre=/bin/chmod 755 /run/mydomoathome (code=exited, status=0/SUCCESS)
Process: 3421 ExecStartPre=/bin/chown www-data:www-data /etc/mydomoathome/config.json (code=exited, status=0/SUCCESS)
Process: 3418 ExecStartPre=/bin/chown www-data:www-data /run/mydomoathome (code=exited, status=0/SUCCESS)
Process: 3415 ExecStartPre=/bin/mkdir -p /run/mydomoathome (code=exited, status=0/SUCCESS)
├─3428 node /usr/local/bin/forever --minUptime 5000 --spinSleepTime 2000 --max-old-space-size=128 -a -l /var/log/mydomoathome/mdah.log /usr/share/mydomoathome/app/mdah.js
mai 31 20:33:35 raspberrypi MDAH[3427]: at Object.<anonymous> (/usr/share/mydomoathome/app/mdah.js:38:16)
mai 31 20:33:35 raspberrypi MDAH[3427]: at Module._compile (module.js:435:26)
mai 31 20:33:35 raspberrypi MDAH[3427]: at Object.Module._extensions..js (module.js:442:10)
mai 31 20:33:35 raspberrypi MDAH[3427]: at Function.Module._load (module.js:311:12)
mai 31 20:33:35 raspberrypi MDAH[3427]: at Function.Module.runMain (module.js:467:10)
mai 31 20:33:35 raspberrypi MDAH[3427]: error: Forever detected script exited with code: 1
mai 31 20:33:38 raspberrypi MDAH[3427]: error: Script restart attempt #102[/code]
