Plugins DeConz et ZigBee2MQTT
frtoto
Message par frtoto »
voici le log lorsque je demande sur Dz le passage de 'Off' à 'Heat'
2024-02-07 13:24:38.989 Status: User: xxx (IP: 10.0.0.151) initiated a switch command (1629/Conbee - Thermostat 159/Set Level)
2024-02-07 13:24:39.024 Conbee: onCommand called for Unit 186: Parameter 'Set Level', Level: 10, Hue:
2024-02-07 13:24:39.024 Conbee: Send Command /api/5D1CDE8B01/sensors/159/config with {} (0 in buffer)
2024-02-07 13:24:39.024 Conbee: Making Request: http://10.0.0.112:80/api/5D1CDE8B01/sensors/159/config with params {}
2024-02-07 13:24:39.075 Conbee: Request Return:
2024-02-07 13:24:39.726 Conbee: onMessage called
2024-02-07 13:24:39.726 Conbee: ### WebSocket Data : {'e': 'changed', 'id': '159', 'r': 'sensors', 'state': {'lastupdated': '2024-02-07T12:24:39.679', 'temperature': 1750, 'valve': 0}, 't': 'event', 'uniqueid': 'a4:c1:38:53:57:a4:3e:2f-01-ef00'}
2024-02-07 13:24:39.728 Conbee: ### Update device (Conbee - Thermostat 159) : {'nValue': 0, 'sValue': '17.5'}, IGNORED , no changes !
2024-02-07 13:24:39.778 Conbee: onMessage called
2024-02-07 13:24:39.778 Conbee: ### WebSocket Data : {'e': 'changed', 'id': '159', 'r': 'sensors', 'state': {'lastupdated': '2024-02-07T12:24:39.737', 'temperature': 1750, 'valve': 0}, 't': 'event', 'uniqueid': 'a4:c1:38:53:57:a4:3e:2f-01-ef00'}
2024-02-07 13:24:39.780 Conbee: ### Update device (Conbee - Thermostat 159) : {'nValue': 0, 'sValue': '17.5'}, IGNORED , no changes !
2024-02-07 13:24:39.831 Conbee: onMessage called
2024-02-07 13:24:39.831 Conbee: ### WebSocket Data : {'e': 'changed', 'id': '159', 'r': 'sensors', 'state': {'lastupdated': '2024-02-07T12:24:39.793', 'temperature': 1750, 'valve': 0}, 't': 'event', 'uniqueid': 'a4:c1:38:53:57:a4:3e:2f-01-ef00'}
2024-02-07 13:24:39.833 Conbee: ### Update device (Conbee - Thermostat 159) : {'nValue': 0, 'sValue': '17.5'}, IGNORED , no changes !
2024-02-07 13:24:39.884 Conbee: onMessage called
2024-02-07 13:24:39.884 Conbee: ### WebSocket Data : {'e': 'changed', 'id': '159', 'r': 'sensors', 'state': {'lastupdated': '2024-02-07T12:24:39.857', 'temperature': 1750, 'valve': 0}, 't': 'event', 'uniqueid': 'a4:c1:38:53:57:a4:3e:2f-01-ef00'}
2024-02-07 13:24:39.887 Conbee: ### Update device (Conbee - Thermostat 159) : {'nValue': 0, 'sValue': '17.5'}, IGNORED , no changes !
2024-02-07 13:24:39.937 Conbee: onMessage called
2024-02-07 13:24:39.937 Conbee: ### WebSocket Data : {'e': 'changed', 'id': '159', 'r': 'sensors', 'state': {'lastupdated': '2024-02-07T12:24:39.915', 'temperature': 1750, 'valve': 0}, 't': 'event', 'uniqueid': 'a4:c1:38:53:57:a4:3e:2f-01-ef00'}
2024-02-07 13:24:39.940 Conbee: ### Update device (Conbee - Thermostat 159) : {'nValue': 0, 'sValue': '17.5'}, IGNORED , no changes !
2024-02-07 13:24:39.990 Conbee: onMessage called
2024-02-07 13:24:39.991 Conbee: ### WebSocket Data : {'e': 'changed', 'id': '159', 'r': 'sensors', 'state': {'lastupdated': '2024-02-07T12:24:39.971', 'temperature': 1750, 'valve': 0}, 't': 'event', 'uniqueid': 'a4:c1:38:53:57:a4:3e:2f-01-ef00'}
2024-02-07 13:24:39.993 Conbee: ### Update device (Conbee - Thermostat 159) : {'nValue': 0, 'sValue': '17.5'}, IGNORED , no changes !
2024-02-07 13:24:40.043 Conbee: onMessage called
2024-02-07 13:24:40.044 Conbee: ### WebSocket Data : {'e': 'changed', 'id': '159', 'r': 'sensors', 'state': {'lastupdated': '2024-02-07T12:24:40.024', 'temperature': 1750, 'valve': 0}, 't': 'event', 'uniqueid': 'a4:c1:38:53:57:a4:3e:2f-01-ef00'}
2024-02-07 13:24:40.046 Conbee: ### Update device (Conbee - Thermostat 159) : {'nValue': 0, 'sValue': '17.5'}, IGNORED , no changes !
2024-02-07 13:24:40.147 Conbee: onMessage called
2024-02-07 13:24:40.147 Conbee: ### WebSocket Data : {'e': 'changed', 'id': '159', 'r': 'sensors', 'state': {'lastupdated': '2024-02-07T12:24:40.094', 'temperature': 1750, 'valve': 0}, 't': 'event', 'uniqueid': 'a4:c1:38:53:57:a4:3e:2f-01-ef00'}
2024-02-07 13:24:40.150 Conbee: ### Update device (Conbee - Thermostat 159) : {'nValue': 0, 'sValue': '17.5'}, IGNORED , no changes !
2024-02-07 13:24:40.203 Conbee: onMessage called
2024-02-07 13:24:40.203 Conbee: ### WebSocket Data : {'e': 'changed', 'id': '159', 'r': 'sensors', 'state': {'lastupdated': '2024-02-07T12:24:40.166', 'temperature': 1750, 'valve': 0}, 't': 'event', 'uniqueid': 'a4:c1:38:53:57:a4:3e:2f-01-ef00'}
2024-02-07 13:24:40.206 Conbee: ### Update device (Conbee - Thermostat 159) : {'nValue': 0, 'sValue': '17.5'}, IGNORED , no changes !
2024-02-07 13:24:40.256 Conbee: onMessage called
2024-02-07 13:24:40.257 Conbee: ### WebSocket Data : {'e': 'changed', 'id': '159', 'r': 'sensors', 'state': {'lastupdated': '2024-02-07T12:24:40.221', 'temperature': 1750, 'valve': 0}, 't': 'event', 'uniqueid': 'a4:c1:38:53:57:a4:3e:2f-01-ef00'}
2024-02-07 13:24:40.259 Conbee: ### Update device (Conbee - Thermostat 159) : {'nValue': 0, 'sValue': '17.5'}, IGNORED , no changes !
2024-02-07 13:24:40.310 Conbee: onMessage called
2024-02-07 13:24:40.310 Conbee: ### WebSocket Data : {'e': 'changed', 'id': '159', 'r': 'sensors', 'state': {'lastupdated': '2024-02-07T12:24:40.274', 'temperature': 1750, 'valve': 0}, 't': 'event', 'uniqueid': 'a4:c1:38:53:57:a4:3e:2f-01-ef00'}
2024-02-07 13:24:40.312 Conbee: ### Update device (Conbee - Thermostat 159) : {'nValue': 0, 'sValue': '17.5'}, IGNORED , no changes !
2024-02-07 13:24:40.362 Conbee: onMessage called
2024-02-07 13:24:40.362 Conbee: ### WebSocket Data : {'e': 'changed', 'id': '159', 'r': 'sensors', 'state': {'lastupdated': '2024-02-07T12:24:40.330', 'temperature': 1750, 'valve': 0}, 't': 'event', 'uniqueid': 'a4:c1:38:53:57:a4:3e:2f-01-ef00'}
2024-02-07 13:24:40.364 Conbee: ### Update device (Conbee - Thermostat 159) : {'nValue': 0, 'sValue': '17.5'}, IGNORED , no changes !
2024-02-07 13:24:40.414 Conbee: onMessage called
2024-02-07 13:24:40.415 Conbee: ### WebSocket Data : {'e': 'changed', 'id': '159', 'r': 'sensors', 'state': {'lastupdated': '2024-02-07T12:24:40.383', 'temperature': 1750, 'valve': 0}, 't': 'event', 'uniqueid': 'a4:c1:38:53:57:a4:3e:2f-01-ef00'}
2024-02-07 13:24:40.416 Conbee: ### Update device (Conbee - Thermostat 159) : {'nValue': 0, 'sValue': '17.5'}, IGNORED , no changes !
2024-02-07 13:24:40.467 Conbee: onMessage called
2024-02-07 13:24:40.467 Conbee: ### WebSocket Data : {'e': 'changed', 'id': '159', 'r': 'sensors', 'state': {'lastupdated': '2024-02-07T12:24:40.436', 'temperature': 1750, 'valve': 0}, 't': 'event', 'uniqueid': 'a4:c1:38:53:57:a4:3e:2f-01-ef00'}
2024-02-07 13:24:40.469 Conbee: ### Update device (Conbee - Thermostat 159) : {'nValue': 0, 'sValue': '17.5'}, IGNORED , no changes !
2024-02-07 13:24:40.519 Conbee: onMessage called
2024-02-07 13:24:40.519 Conbee: ### WebSocket Data : {'e': 'changed', 'id': '159', 'r': 'sensors', 'state': {'lastupdated': '2024-02-07T12:24:40.489', 'temperature': 1750, 'valve': 0}, 't': 'event', 'uniqueid': 'a4:c1:38:53:57:a4:3e:2f-01-ef00'}
2024-02-07 13:24:40.521 Conbee: ### Update device (Conbee - Thermostat 159) : {'nValue': 0, 'sValue': '17.5'}, IGNORED , no changes !
2024-02-07 13:24:40.571 Conbee: onMessage called
2024-02-07 13:24:40.571 Conbee: ### WebSocket Data : {'e': 'changed', 'id': '159', 'r': 'sensors', 'state': {'lastupdated': '2024-02-07T12:24:40.545', 'temperature': 1750, 'valve': 0}, 't': 'event', 'uniqueid': 'a4:c1:38:53:57:a4:3e:2f-01-ef00'}
2024-02-07 13:24:40.572 Conbee: ### Update device (Conbee - Thermostat 159) : {'nValue': 0, 'sValue': '17.5'}, IGNORED , no changes !
2024-02-07 13:24:40.622 Conbee: onMessage called
2024-02-07 13:24:40.623 Conbee: ### WebSocket Data : {'e': 'changed', 'id': '159', 'r': 'sensors', 'state': {'lastupdated': '2024-02-07T12:24:40.603', 'temperature': 1750, 'valve': 0}, 't': 'event', 'uniqueid': 'a4:c1:38:53:57:a4:3e:2f-01-ef00'}
2024-02-07 13:24:40.624 Conbee: ### Update device (Conbee - Thermostat 159) : {'nValue': 0, 'sValue': '17.5'}, IGNORED , no changes !
2024-02-07 13:24:40.726 Conbee: onMessage called
2024-02-07 13:24:40.726 Conbee: ### WebSocket Data : {'e': 'changed', 'id': '159', 'r': 'sensors', 'state': {'lastupdated': '2024-02-07T12:24:40.694', 'temperature': 1750, 'valve': 0}, 't': 'event', 'uniqueid': 'a4:c1:38:53:57:a4:3e:2f-01-ef00'}
2024-02-07 13:24:40.727 Conbee: ### Update device (Conbee - Thermostat 159) : {'nValue': 0, 'sValue': '17.5'}, IGNORED , no changes !
2024-02-07 13:24:40.777 Conbee: onMessage called
2024-02-07 13:24:40.777 Conbee: ### WebSocket Data : {'e': 'changed', 'id': '159', 'r': 'sensors', 'state': {'lastupdated': '2024-02-07T12:24:40.753', 'temperature': 1750, 'valve': 0}, 't': 'event', 'uniqueid': 'a4:c1:38:53:57:a4:3e:2f-01-ef00'}
2024-02-07 13:24:40.779 Conbee: ### Update device (Conbee - Thermostat 159) : {'nValue': 0, 'sValue': '17.5'}, IGNORED , no changes !
2024-02-07 13:24:40.829 Conbee: onMessage called
2024-02-07 13:24:40.829 Conbee: ### WebSocket Data : {'e': 'changed', 'id': '159', 'r': 'sensors', 'state': {'lastupdated': '2024-02-07T12:24:40.806', 'temperature': 1750, 'valve': 0}, 't': 'event', 'uniqueid': 'a4:c1:38:53:57:a4:3e:2f-01-ef00'}
2024-02-07 13:24:40.830 Conbee: ### Update device (Conbee - Thermostat 159) : {'nValue': 0, 'sValue': '17.5'}, IGNORED , no changes !
2024-02-07 13:24:40.880 Conbee: onMessage called
2024-02-07 13:24:40.881 Conbee: ### WebSocket Data : {'e': 'changed', 'id': '159', 'r': 'sensors', 'state': {'lastupdated': '2024-02-07T12:24:40.858', 'temperature': 1750, 'valve': 0}, 't': 'event', 'uniqueid': 'a4:c1:38:53:57:a4:3e:2f-01-ef00'}
2024-02-07 13:24:40.882 Conbee: ### Update device (Conbee - Thermostat 159) : {'nValue': 0, 'sValue': '17.5'}, IGNORED , no changes !
2024-02-07 13:24:40.982 Conbee: onMessage called
2024-02-07 13:24:40.982 Conbee: ### WebSocket Data : {'e': 'changed', 'id': '159', 'r': 'sensors', 'state': {'lastupdated': '2024-02-07T12:24:40.931', 'temperature': 1750, 'valve': 0}, 't': 'event', 'uniqueid': 'a4:c1:38:53:57:a4:3e:2f-01-ef00'}
2024-02-07 13:24:40.983 Conbee: ### Update device (Conbee - Thermostat 159) : {'nValue': 0, 'sValue': '17.5'}, IGNORED , no changes !
2024-02-07 13:24:41.034 Conbee: onMessage called
2024-02-07 13:24:41.034 Conbee: ### WebSocket Data : {'e': 'changed', 'id': '159', 'r': 'sensors', 'state': {'lastupdated': '2024-02-07T12:24:40.984', 'temperature': 1750, 'valve': 0}, 't': 'event', 'uniqueid': 'a4:c1:38:53:57:a4:3e:2f-01-ef00'}
2024-02-07 13:24:41.035 Conbee: ### Update device (Conbee - Thermostat 159) : {'nValue': 0, 'sValue': '17.5'}, IGNORED , no changes !
2024-02-07 13:24:41.085 Conbee: onMessage called
2024-02-07 13:24:41.085 Conbee: ### WebSocket Data : {'e': 'changed', 'id': '159', 'r': 'sensors', 'state': {'lastupdated': '2024-02-07T12:24:41.039', 'temperature': 1750, 'valve': 0}, 't': 'event', 'uniqueid': 'a4:c1:38:53:57:a4:3e:2f-01-ef00'}
2024-02-07 13:24:41.087 Conbee: ### Update device (Conbee - Thermostat 159) : {'nValue': 0, 'sValue': '17.5'}, IGNORED , no changes !
2024-02-07 13:24:41.137 Conbee: onMessage called
2024-02-07 13:24:41.137 Conbee: ### WebSocket Data : {'e': 'changed', 'id': '159', 'r': 'sensors', 'state': {'lastupdated': '2024-02-07T12:24:41.093', 'temperature': 1750, 'valve': 0}, 't': 'event', 'uniqueid': 'a4:c1:38:53:57:a4:3e:2f-01-ef00'}
2024-02-07 13:24:41.138 Conbee: ### Update device (Conbee - Thermostat 159) : {'nValue': 0, 'sValue': '17.5'}, IGNORED , no changes !
et quand je passe de 'Off' à 'Heat' directement sur le thermostat :
2024-02-07 13:30:29.264 Conbee: onMessage called
2024-02-07 13:30:29.264 Conbee: ### WebSocket Data : {'attr': {'id': '127', 'lastannounced': None, 'lastseen': '2024-02-07T12:30Z', 'manufacturername': '_TZ3000_typdpbpg', 'mode': 1, 'modelid': 'TS011F', 'name': 'Consumption 127', 'swversion': '1.0.13', 'type': 'ZHAConsumption', 'uniqueid': 'a4:c1:38:c4:2e:d3:b4:bc-01-0702'}, 'e': 'changed', 'id': '127', 'r': 'sensors', 't': 'event', 'uniqueid': 'a4:c1:38:c4:2e:d3:b4:bc-01-0702'}
2024-02-07 13:30:29.315 Conbee: onMessage called
2024-02-07 13:30:29.315 Conbee: ### WebSocket Data : {'config': {'heatsetpoint': 2200, 'locked': False, 'mode': 'heat', 'on': True, 'preset': 'manual', 'reachable': True}, 'e': 'changed', 'id': '159', 'r': 'sensors', 't': 'event', 'uniqueid': 'a4:c1:38:53:57:a4:3e:2f-01-ef00'}
2024-02-07 13:30:29.317 Conbee: ### Update device (Conbee - Thermostat 159) : {'nValue': 0, 'sValue': '22.0'}, IGNORED , no changes !
2024-02-07 13:30:29.318 Conbee: ### Update device (Conbee - Thermostat 159) : {'nValue': 10, 'sValue': '10'}
2024-02-07 13:30:29.342 Conbee: ### Update device (Conbee - Thermostat 159) : {'nValue': 30, 'sValue': '30'}
2024-02-07 13:30:29.366 Conbee: ### Update device (Conbee - Thermostat 159) : {'nValue': 0, 'sValue': '18.0'}, IGNORED , no changes !
2024-02-07 13:30:29.517 Conbee: onMessage called
2024-02-07 13:30:29.517 Conbee: ### WebSocket Data : {'e': 'changed', 'id': '159', 'r': 'sensors', 'state': {'lastupdated': '2024-02-07T12:30:29.485', 'temperature': 1800, 'valve': 0}, 't': 'event', 'uniqueid': 'a4:c1:38:53:57:a4:3e:2f-01-ef00'}
2024-02-07 13:30:29.519 Conbee: ### Update device (Conbee - Thermostat 159) : {'nValue': 0, 'sValue': '18.0'}, IGNORED , no changes !
2024-02-07 13:30:29.570 Conbee: onMessage called
2024-02-07 13:30:29.570 Conbee: ### WebSocket Data : {'e': 'changed', 'id': '159', 'r': 'sensors', 'state': {'lastupdated': '2024-02-07T12:30:29.561', 'temperature': 1800, 'valve': 0}, 't': 'event', 'uniqueid': 'a4:c1:38:53:57:a4:3e:2f-01-ef00'}
2024-02-07 13:30:29.571 Conbee: ### Update device (Conbee - Thermostat 159) : {'nValue': 0, 'sValue': '18.0'}, IGNORED , no changes !
2024-02-07 13:30:29.674 Conbee: onMessage called
2024-02-07 13:30:29.675 Conbee: ### WebSocket Data : {'e': 'changed', 'id': '159', 'r': 'sensors', 'state': {'lastupdated': '2024-02-07T12:30:29.629', 'temperature': 1800, 'valve': 0}, 't': 'event', 'uniqueid': 'a4:c1:38:53:57:a4:3e:2f-01-ef00'}
2024-02-07 13:30:29.677 Conbee: ### Update device (Conbee - Thermostat 159) : {'nValue': 0, 'sValue': '18.0'}, IGNORED , no changes !
2024-02-07 13:30:29.728 Conbee: onMessage called
2024-02-07 13:30:29.728 Conbee: ### WebSocket Data : {'e': 'changed', 'id': '159', 'r': 'sensors', 'state': {'lastupdated': '2024-02-07T12:30:29.685', 'temperature': 1800, 'valve': 0}, 't': 'event', 'uniqueid': 'a4:c1:38:53:57:a4:3e:2f-01-ef00'}
2024-02-07 13:30:29.730 Conbee: ### Update device (Conbee - Thermostat 159) : {'nValue': 0, 'sValue': '18.0'}, IGNORED , no changes !
2024-02-07 13:30:29.780 Conbee: onMessage called
2024-02-07 13:30:29.780 Conbee: ### WebSocket Data : {'e': 'changed', 'id': '159', 'r': 'sensors', 'state': {'lastupdated': '2024-02-07T12:30:29.739', 'temperature': 1800, 'valve': 0}, 't': 'event', 'uniqueid': 'a4:c1:38:53:57:a4:3e:2f-01-ef00'}
2024-02-07 13:30:29.781 Conbee: ### Update device (Conbee - Thermostat 159) : {'nValue': 0, 'sValue': '18.0'}, IGNORED , no changes !
2024-02-07 13:30:29.832 Conbee: onMessage called
2024-02-07 13:30:29.832 Conbee: ### WebSocket Data : {'e': 'changed', 'id': '159', 'r': 'sensors', 'state': {'lastupdated': '2024-02-07T12:30:29.795', 'temperature': 1800, 'valve': 0}, 't': 'event', 'uniqueid': 'a4:c1:38:53:57:a4:3e:2f-01-ef00'}
2024-02-07 13:30:29.834 Conbee: ### Update device (Conbee - Thermostat 159) : {'nValue': 0, 'sValue': '18.0'}, IGNORED , no changes !
2024-02-07 13:30:29.884 Conbee: onMessage called
2024-02-07 13:30:29.884 Conbee: ### WebSocket Data : {'e': 'changed', 'id': '159', 'r': 'sensors', 'state': {'lastupdated': '2024-02-07T12:30:29.848', 'temperature': 1800, 'valve': 0}, 't': 'event', 'uniqueid': 'a4:c1:38:53:57:a4:3e:2f-01-ef00'}
2024-02-07 13:30:29.886 Conbee: ### Update device (Conbee - Thermostat 159) : {'nValue': 0, 'sValue': '18.0'}, IGNORED , no changes !
2024-02-07 13:30:29.936 Conbee: onMessage called
2024-02-07 13:30:29.936 Conbee: ### WebSocket Data : {'e': 'changed', 'id': '159', 'r': 'sensors', 'state': {'lastupdated': '2024-02-07T12:30:29.907', 'temperature': 1800, 'valve': 0}, 't': 'event', 'uniqueid': 'a4:c1:38:53:57:a4:3e:2f-01-ef00'}
2024-02-07 13:30:29.938 Conbee: ### Update device (Conbee - Thermostat 159) : {'nValue': 0, 'sValue': '18.0'}, IGNORED , no changes !
2024-02-07 13:30:29.988 Conbee: onMessage called
2024-02-07 13:30:29.989 Conbee: ### WebSocket Data : {'e': 'changed', 'id': '159', 'r': 'sensors', 'state': {'lastupdated': '2024-02-07T12:30:29.963', 'temperature': 1800, 'valve': 0}, 't': 'event', 'uniqueid': 'a4:c1:38:53:57:a4:3e:2f-01-ef00'}
2024-02-07 13:30:29.990 Conbee: ### Update device (Conbee - Thermostat 159) : {'nValue': 0, 'sValue': '18.0'}, IGNORED , no changes !
2024-02-07 13:30:30.091 Conbee: onMessage called
2024-02-07 13:30:30.091 Conbee: ### WebSocket Data : {'e': 'changed', 'id': '159', 'r': 'sensors', 'state': {'lastupdated': '2024-02-07T12:30:30.035', 'temperature': 1800, 'valve': 0}, 't': 'event', 'uniqueid': 'a4:c1:38:53:57:a4:3e:2f-01-ef00'}
2024-02-07 13:30:30.092 Conbee: ### Update device (Conbee - Thermostat 159) : {'nValue': 0, 'sValue': '18.0'}, IGNORED , no changes !
2024-02-07 13:30:30.143 Conbee: onMessage called
2024-02-07 13:30:30.143 Conbee: ### WebSocket Data : {'e': 'changed', 'id': '159', 'r': 'sensors', 'state': {'lastupdated': '2024-02-07T12:30:30.089', 'temperature': 1800, 'valve': 0}, 't': 'event', 'uniqueid': 'a4:c1:38:53:57:a4:3e:2f-01-ef00'}
2024-02-07 13:30:30.145 Conbee: ### Update device (Conbee - Thermostat 159) : {'nValue': 0, 'sValue': '18.0'}, IGNORED , no changes !
2024-02-07 13:30:30.195 Conbee: onMessage called
2024-02-07 13:30:30.195 Conbee: ### WebSocket Data : {'attr': {'id': '23', 'lastannounced': None, 'lastseen': '2024-02-07T12:30Z', 'manufacturername': '_TZ3000_typdpbpg', 'modelid': 'TS011F', 'name': 'prise_cuisine', 'swversion': '1.0.13', 'type': 'On/Off plug-in unit', 'uniqueid': 'a4:c1:38:02:56:bb:23:52-01'}, 'e': 'changed', 'id': '23', 'r': 'lights', 't': 'event', 'uniqueid': 'a4:c1:38:02:56:bb:23:52-01'}
2024-02-07 13:30:30.245 Conbee: onMessage called
2024-02-07 13:30:30.246 Conbee: ### WebSocket Data : {'e': 'changed', 'id': '124', 'r': 'sensors', 'state': {'current': 0, 'lastupdated': '2024-02-07T12:30:30.163', 'power': 0, 'voltage': 230}, 't': 'event', 'uniqueid': 'a4:c1:38:02:56:bb:23:52-01-0b04'}
2024-02-07 13:30:30.247 Conbee: ### Update device (instant_prise_cuisine) : {'nValue': 0, 'sValue': '0'}, IGNORED , no changes !
2024-02-07 13:30:30.247 Conbee: onMessage called
2024-02-07 13:30:30.248 Conbee: ### WebSocket Data : {'e': 'changed', 'id': '159', 'r': 'sensors', 'state': {'lastupdated': '2024-02-07T12:30:30.213', 'temperature': 1800, 'valve': 0}, 't': 'event', 'uniqueid': 'a4:c1:38:53:57:a4:3e:2f-01-ef00'}
2024-02-07 13:30:30.249 Conbee: ### Update device (Conbee - Thermostat 159) : {'nValue': 0, 'sValue': '18.0'}, IGNORED , no changes !
2024-02-07 13:30:30.299 Conbee: onMessage called
2024-02-07 13:30:30.300 Conbee: ### WebSocket Data : {'e': 'changed', 'id': '159', 'r': 'sensors', 'state': {'lastupdated': '2024-02-07T12:30:30.272', 'temperature': 1800, 'valve': 0}, 't': 'event', 'uniqueid': 'a4:c1:38:53:57:a4:3e:2f-01-ef00'}
2024-02-07 13:30:30.302 Conbee: ### Update device (Conbee - Thermostat 159) : {'nValue': 0, 'sValue': '18.0'}, IGNORED , no changes !
2024-02-07 13:30:30.352 Conbee: onMessage called
2024-02-07 13:30:30.352 Conbee: ### WebSocket Data : {'e': 'changed', 'id': '159', 'r': 'sensors', 'state': {'lastupdated': '2024-02-07T12:30:30.326', 'temperature': 1800, 'valve': 0}, 't': 'event', 'uniqueid': 'a4:c1:38:53:57:a4:3e:2f-01-ef00'}
2024-02-07 13:30:30.354 Conbee: ### Update device (Conbee - Thermostat 159) : {'nValue': 0, 'sValue': '18.0'}, IGNORED , no changes !
2024-02-07 13:30:30.404 Conbee: onMessage called
2024-02-07 13:30:30.405 Conbee: ### WebSocket Data : {'e': 'changed', 'id': '159', 'r': 'sensors', 'state': {'lastupdated': '2024-02-07T12:30:30.379', 'temperature': 1800, 'valve': 0}, 't': 'event', 'uniqueid': 'a4:c1:38:53:57:a4:3e:2f-01-ef00'}
2024-02-07 13:30:30.406 Conbee: ### Update device (Conbee - Thermostat 159) : {'nValue': 0, 'sValue': '18.0'}, IGNORED , no changes !
2024-02-07 13:30:30.456 Conbee: onMessage called
2024-02-07 13:30:30.457 Conbee: ### WebSocket Data : {'e': 'changed', 'id': '159', 'r': 'sensors', 'state': {'lastupdated': '2024-02-07T12:30:30.431', 'temperature': 1800, 'valve': 0}, 't': 'event', 'uniqueid': 'a4:c1:38:53:57:a4:3e:2f-01-ef00'}
2024-02-07 13:30:30.459 Conbee: ### Update device (Conbee - Thermostat 159) : {'nValue': 0, 'sValue': '18.0'}, IGNORED , no changes !
2024-02-07 13:30:30.509 Conbee: onMessage called
2024-02-07 13:30:30.509 Conbee: ### WebSocket Data : {'e': 'changed', 'id': '159', 'r': 'sensors', 'state': {'lastupdated': '2024-02-07T12:30:30.483', 'temperature': 1800, 'valve': 0}, 't': 'event', 'uniqueid': 'a4:c1:38:53:57:a4:3e:2f-01-ef00'}
2024-02-07 13:30:30.510 Conbee: ### Update device (Conbee - Thermostat 159) : {'nValue': 0, 'sValue': '18.0'}, IGNORED , no changes !
2024-02-07 13:30:30.561 Conbee: onMessage called
2024-02-07 13:30:30.561 Conbee: ### WebSocket Data : {'e': 'changed', 'id': '159', 'r': 'sensors', 'state': {'lastupdated': '2024-02-07T12:30:30.536', 'temperature': 1800, 'valve': 0}, 't': 'event', 'uniqueid': 'a4:c1:38:53:57:a4:3e:2f-01-ef00'}
2024-02-07 13:30:30.563 Conbee: ### Update device (Conbee - Thermostat 159) : {'nValue': 0, 'sValue': '18.0'}, IGNORED , no changes !
2024-02-07 13:30:30.663 Conbee: onMessage called
2024-02-07 13:30:30.665 Conbee: ### WebSocket Data : {'e': 'changed', 'id': '159', 'r': 'sensors', 'state': {'lastupdated': '2024-02-07T12:30:30.616', 'temperature': 1800, 'valve': 0}, 't': 'event', 'uniqueid': 'a4:c1:38:53:57:a4:3e:2f-01-ef00'}
2024-02-07 13:30:30.667 Conbee: ### Update device (Conbee - Thermostat 159) : {'nValue': 0, 'sValue': '18.0'}, IGNORED , no changes !
2024-02-07 13:30:30.717 Conbee: onMessage called
2024-02-07 13:30:30.718 Conbee: ### WebSocket Data : {'e': 'changed', 'id': '159', 'r': 'sensors', 'state': {'lastupdated': '2024-02-07T12:30:30.675', 'temperature': 1800, 'valve': 0}, 't': 'event', 'uniqueid': 'a4:c1:38:53:57:a4:3e:2f-01-ef00'}
2024-02-07 13:30:30.719 Conbee: ### Update device (Conbee - Thermostat 159) : {'nValue': 0, 'sValue': '18.0'}, IGNORED , no changes !
2024-02-07 13:30:30.819 Conbee: onMessage called
2024-02-07 13:30:30.820 Conbee: ### WebSocket Data : {'e': 'changed', 'id': '159', 'r': 'sensors', 'state': {'lastupdated': '2024-02-07T12:30:30.728', 'temperature': 1800, 'valve': 0}, 't': 'event', 'uniqueid': 'a4:c1:38:53:57:a4:3e:2f-01-ef00'}
2024-02-07 13:30:30.821 Conbee: ### Update device (Conbee - Thermostat 159) : {'nValue': 0, 'sValue': '18.0'}, IGNORED , no changes !
2024-02-07 13:30:30.822 Conbee: onMessage called
2024-02-07 13:30:30.822 Conbee: ### WebSocket Data : {'e': 'changed', 'id': '159', 'r': 'sensors', 'state': {'lastupdated': '2024-02-07T12:30:30.783', 'temperature': 1800, 'valve': 0}, 't': 'event', 'uniqueid': 'a4:c1:38:53:57:a4:3e:2f-01-ef00'}
2024-02-07 13:30:30.824 Conbee: ### Update device (Conbee - Thermostat 159) : {'nValue': 0, 'sValue': '18.0'}, IGNORED , no changes !
2024-02-07 13:30:30.874 Conbee: onMessage called
2024-02-07 13:30:30.874 Conbee: ### WebSocket Data : {'e': 'changed', 'id': '159', 'r': 'sensors', 'state': {'lastupdated': '2024-02-07T12:30:30.833', 'temperature': 1800, 'valve': 0}, 't': 'event', 'uniqueid': 'a4:c1:38:53:57:a4:3e:2f-01-ef00'}
2024-02-07 13:30:30.876 Conbee: ### Update device (Conbee - Thermostat 159) : {'nValue': 0, 'sValue': '18.0'}, IGNORED , no changes !
2024-02-07 13:30:30.926 Conbee: onMessage called
2024-02-07 13:30:30.926 Conbee: ### WebSocket Data : {'e': 'changed', 'id': '159', 'r': 'sensors', 'state': {'lastupdated': '2024-02-07T12:30:30.885', 'temperature': 1800, 'valve': 0}, 't': 'event', 'uniqueid': 'a4:c1:38:53:57:a4:3e:2f-01-ef00'}
2024-02-07 13:30:30.928 Conbee: ### Update device (Conbee - Thermostat 159) : {'nValue': 0, 'sValue': '18.0'}, IGNORED , no changes !
2024-02-07 13:30:31.028 Conbee: onMessage called
2024-02-07 13:30:31.029 Conbee: ### WebSocket Data : {'e': 'changed', 'id': '159', 'r': 'sensors', 'state': {'lastupdated': '2024-02-07T12:30:30.983', 'temperature': 1800, 'valve': 0}, 't': 'event', 'uniqueid': 'a4:c1:38:53:57:a4:3e:2f-01-ef00'}
2024-02-07 13:30:31.030 Conbee: ### Update device (Conbee - Thermostat 159) : {'nValue': 0, 'sValue': '18.0'}, IGNORED , no changes !
2024-02-07 13:30:31.030 Conbee: onMessage called
2024-02-07 13:30:31.031 Conbee: ### WebSocket Data : {'attr': {'id': '9', 'lastannounced': None, 'lastseen': '2024-02-07T12:30Z', 'manufacturername': '_TZ3000_typdpbpg', 'modelid': 'TS011F', 'name': 'Prise SDB haut', 'swversion': '1.0.13', 'type': 'On/Off plug-in unit', 'uniqueid': 'a4:c1:38:5d:4a:07:3a:f7-01'}, 'e': 'changed', 'id': '9', 'r': 'lights', 't': 'event', 'uniqueid': 'a4:c1:38:5d:4a:07:3a:f7-01'}
2024-02-07 13:30:31.031 Conbee: onMessage called
2024-02-07 13:30:31.031 Conbee: ### WebSocket Data : {'attr': {'id': '134', 'lastannounced': None, 'lastseen': '2024-02-07T12:30Z', 'manufacturername': '_TZ3000_typdpbpg', 'mode': 1, 'modelid': 'TS011F', 'name': 'Power 134', 'swversion': '1.0.13', 'type': 'ZHAPower', 'uniqueid': 'a4:c1:38:5d:4a:07:3a:f7-01-0b04'}, 'e': 'changed', 'id': '134', 'r': 'sensors', 't': 'event', 'uniqueid': 'a4:c1:38:5d:4a:07:3a:f7-01-0b04'}
2024-02-07 13:30:31.031 Conbee: ### WebSocket Data : {'e': 'changed', 'id': '134', 'r': 'sensors', 'state': {'current': 0, 'lastupdated': '2024-02-07T12:30:31.003', 'power': 0, 'voltage': 230}, 't': 'event', 'uniqueid': 'a4:c1:38:5d:4a:07:3a:f7-01-0b04'}
2024-02-07 13:30:31.033 Conbee: ### Update device (Conbee - Power 134) : {'nValue': 0, 'sValue': '0'}, IGNORED , no changes !
2024-02-07 13:30:31.033 Conbee: ### WebSocket Data : {'attr': {'id': '133', 'lastannounced': None, 'lastseen': '2024-02-07T12:30Z', 'manufacturername': '_TZ3000_typdpbpg', 'mode': 1, 'modelid': 'TS011F', 'name': 'Consumption 133', 'swversion': '1.0.13', 'type': 'ZHAConsumption', 'uniqueid': 'a4:c1:38:5d:4a:07:3a:f7-01-0702'}, 'e': 'changed', 'id': '133', 'r': 'sensors', 't': 'event', 'uniqueid': 'a4:c1:38:5d:4a:07:3a:f7-01-0702'}
Pour le NAS, j'ai désactivé "surveillance station" (j'ai une caméra pour surveiller mes impressions 3d) et l'activité des disques a nettement diminuée !
Edit : sinon j'ai besoin d'un autre thermostat, en as-tu un à me conseiller qui fonctionne de façon plus fiable sur la conbee II ? Merci !
Dz 2025.11_16729 - Conbee II
Thorgal
Message par Thorgal »
Alors je vais pas pouvoir t'en conseiller sur tuya, non pas que ce ne soit pas de la qualité, mais qu'il est impossible de savoir ce que tu vas avoir. Dans la même commande au meme fournisseur, tu peux en commander 3, identique visuellement, mais tous different avec un fonctionnement different.
Par contre, dans les marques classiques bosch/danfoss/elko/ally la y a pas de suprises, tu sais ce que tu vas avoir.
Mais celle que tu as n'as pas l'air si mauvaise, d'apres les logs le probleme vient du plugin, pas la vanne.
Pour le "mode" qui ne marche plus, je sais pas ce qui s' est passé, mais si tu teste le code sur la beta ca devrait refonctionner
Dans le repertoire du plugin
git pull
git checkout beta
git pull
Par contre la, je me souvient plus
10 C'est le mode
22 la temperature
18 le setpoint.
Mais le 30 ?????
Edit:
Ha oui le preset.
frtoto
C'est bon ça fonctionne, merci !
Thorgal
Ben du coup si tout est bon pour toi, je balance le DDF sur deconz, et fais une MAJ sur le plugin aussi car la c'est plutot handicapant.
Juste si tu peux me confirmer le DDF fonctionnel
  "schema": "devcap1.schema.json",
  "manufacturername": ["_TZE200_ztvwu4nk", "_TZE204_5toc8efa", "_TZE200_5toc8efa", "_TZE200_ye5jkfsb", "_TZE204_aoclfnxz", "_TZE200_u9bfwha0"],
  "modelid": ["TS0601", "TS0601", "TS0601", "TS0601", "TS0601", "TS0601"],
  "vendor": "Tuya",
  "product": "Moes TRVs",
  "sleeper": false,
  "status": "Gold",
  "subdevices": [
      "type": "$TYPE_THERMOSTAT",
      "restapi": "/sensors",
      "uuid": [
        "$address.ext",
        "0x01",
        "0xef00"
      "meta": {
        "values": {
          "config/mode": {"off": 0, "heat": 1}
      "items": [
          "name": "attr/id"
          "name": "attr/lastannounced"
          "name": "attr/lastseen"
          "name": "attr/manufacturername"
          "name": "attr/modelid"
          "name": "attr/name"
          "name": "attr/swversion",
          "refresh.interval": 86400,
          "parse": {"fn": "zcl", "ep": 1, "cl": "0x0000", "at": "0x0001", "script": "tuya_swversion.js"},
          "read": {"fn": "zcl", "ep": 1, "cl": "0x0000", "at": "0x0001"}
          "name": "attr/type"
          "name": "attr/uniqueid"
          "name": "config/heatsetpoint",
          "parse": {"fn": "tuya", "dpid": 16, "eval": "Item.val = Attr.val * 100;"},
          "write": {"fn": "tuya", "dpid": 16, "dt": "0x2b", "eval": "Item.val / 100;"},
          "read": {"fn": "tuya"}
          "name": "config/locked",
          "parse": {"fn": "tuya", "dpid": 40, "eval": "Item.val = Attr.val;"},
          "write": {"fn": "tuya", "dpid": 40, "dt": "0x10", "eval": "Item.val;"},
          "read": {"fn": "none"}
          "name": "config/on"
          "name": "config/reachable"
          "name": "config/mode",
          "values": [
              ["off", 0], ["heat", 1]
          "parse": {"fn": "tuya", "dpid": 1, "eval": "if (Attr.val == 0) { Item.val = 'off' } else { Item.val = 'heat' }"},
          "write": {"fn": "tuya", "dpid": 1, "dt": "0x10", "eval": "if (Item.val == 'off') { false } else { true }"},
          "name": "config/preset",
          "parse": {"fn": "tuya", "dpid": 2, "script": "tuya_trv_preset.js"},
          "write": {"fn": "tuya", "dpid": 2, "dt": "0x30", "script": "tuya_trv_preset_set.js"},
          "name": "state/lastupdated"
          "name": "state/temperature",
          "parse": {"fn": "tuya", "dpid": 24, "eval": "Item.val = Attr.val * 10;"},
          "name": "state/valve",
          "parse": {"fn": "tuya", "dpid": 36, "eval": "Item.val = Attr.val > 5;"},
y avait juste le heatpoint a corriger ?
frtoto
Oui c'est tout bon, la seule correction était le heatpoint
frtoto
1er problème :
depuis quelques jours la plupart de mes devices sont très lents à répondre (parfois plusieurs dizaines de secondes) alors que je n'ai rien changé à part mettre à jour le plugin mais pas sûr que cela ai un rapport.
Lors du démarrage de DZ j'ai cette erreur qui apparait :
2024-02-17 09:22:16.739 Error: Conbee: Process request took to long: 1.4293513298034668 s
2024-02-17 09:22:16.740 Error: Conbee: Process request took to long: 1.5548970699310303 s
2024-02-17 09:22:16.741 Error: Conbee: Process request took to long: 1.6530945301055908 s
mais uniquement au démarrage, plus après
ma clé conbee II est sur un rasp différent de Dz, j'ai redémarré les 2 rasp, passé le WIFI du rasp conbee sur un autre réseau (de 2.4 à 5 Ghz) mais rien n'y fait
2ème Problème :
Un détecteur de présence xiaomi est reconnu comme routeur ! alors qu'il est comme les autres sur batterie, il y a un moyen de changer cela ?
Merci !
edit : pour le second pb c'est en fait une prise xiaomi qui est identifiée comme "lumi.sensor.motion_aq2", elle ne me sert pas franchement, je la vire
Thorgal
Ce ne serais pas un probleme reseau ? Sinon regardes l'occupation du processeur, il doit y en avoir un qui "tourne trop" ( Ca devrait etre autour de 5% si tu n'as que deconz).
Ce message d'erreur est une securité, ca veut dire que domoticz a fait une requete a deconz, et qu'il a mit plus de 1s pour repondre, en local c'est pas normal.
Tu peux essayer avec phoscon, vu qu'il est sur la meme machine que deconz. Si tu as toujours les 10s de decalage, ca doit venir de ce PI, sinon de celui avec Domoticz.
Tu as quelle conbee ? et quelle version de deconz ? La derniere version de deconz accelere beaucoup de chose, mais tu aurais eu ce probleme depuis le debut.
frtoto
les ping sont bons (<1ms pour Dz en Ethernet et 1ms pour DeConz en Wifi)
les taux d'occupations aussi respectivement 2% et 6%
Clé Conbee 2, avant dernier firmware et derniere version de DeConz
Thorgal
Lol, pas de bol, tout a l'air bon ...
Et la seule chose que tu es fait, c'est mettre a jour le plugin domoticz ?
Tu as regardé si tu avais les memes lags via phoscon que via domoticz ?
frtoto
Le problème pour les tests c'est que lorsque l'on a activé plusieurs fois un device il n'y a plus vraiment de latence puis ça revient au bout d'un temps indéterminé : cela peut bien fonctionner pendant plusieurs heures comme redysfonctionner au bout de 30 secondes...
peut-être que j'abuse sur le nombre de device ?
Sans titre.jpg (217.7 Kio) Consulté 984 fois
Dernière modification par frtoto le 18 févr. 2024, 08:55, modifié 1 fois.
