j'essaie d'adapter un script python ecrit pour Jeedom dans Domoticz, dont voici le code
le script tourne bien il récupère les valeurs mais rien ne rentre dans la base domoticz...Une idée? (J 'ai un doute sur le paramétrage de l'url de push vers domoticz)
#!/usr/bin/env python3
# -*- coding: utf-8 -*-
# __author__ = "Jordan Martin"
# __licence__ = "Apache License 2.0"
import serial
import logging
import subprocess
import requests
logging.basicConfig(level=logging.INFO, format='%(asctime)s %(message)s')
# Port serial
stty_port = '/dev/ttyUSB0'
# URL de push vers Jeedom --->Domoticz
base_url = 'http://192.168.1.38:8080/json.htm?type=command¶m=udevice&idx=9&nvalue=0&svalue=value{}'
# Clé à récupéré et id de l'info dans Jeedom
measure_keys = ['EAIT','SINSTI']
def main():
logging.info('Starting...')
# Reconfigure le port serial pour eviter
# l'erreur: termios.error: (22, 'Invalid argument')
logging.info('Reconfigure stty %s' % stty_port)
subprocess.call(['stty', '-F', stty_port, 'iexten'])
with serial.Serial(port=stty_port, baudrate=9600, parity=serial.PARITY_EVEN, stopbits=serial.STOPBITS_ONE,
bytesize=serial.SEVENBITS, timeout=1) as ser:
logging.info('Reading on %s' % stty_port)
while True:
line = ser.readline()
arr = line.decode('ascii').split('\t')
if len(arr) != 3:
continue
send_measure(arr)
def send_measure(arr):
key = arr[0]
if key not in measure_keys:
return False
if not verify_checksum(arr):
logging.warn('checksum failure for %s' % key)
return False
value = int(arr[1])
# cmd_id = measure_keys.get(key)
url = base_url.format(value)
logging.info('%s => %s' % (key, value))
x = requests.get(url);
print (x.status_code)
return True
def verify_checksum(arr):
tag = arr[0]
data = arr[1]
checksum = arr[2].replace('\r\n', '')
checked_data = [ord(c) for c in (tag + '\t' + data + '\t')]
computed_sum = (sum(checked_data) & 0x3F) + 0x20
return checksum == chr(computed_sum)
if __name__ == '__main__':
main()
