Depuis la mise a jour mes devices SHelly ne répondent plus.
J'ai essaye de redémarrer le service, je vois bien dans le log que le switch a été executé :
2021-04-24 07:13:54.113 Status: User: Admin (IP: 192.168.1.249) initiated a switch command (133/Hall de Nuit/On)
2021-04-24 07:14:04.066 Shelly MQTT: (Shelly MQTT) Heartbeating...
2021-04-24 07:14:04.066 Shelly MQTT: (Shelly MQTT) MqttClient::ping
2021-04-24 07:14:04.066 Shelly MQTT: (Shelly MQTT) Sending 2 bytes of data
2021-04-24 07:14:04.066 Shelly MQTT: (Shelly MQTT) c0 00 .. .. .. .. .. .. .. .. .. .. .. .. .. .. .. .. .. .. �
2021-04-24 07:14:04.116 Shelly MQTT: (Shelly MQTT) Received 2 bytes of data
2021-04-24 07:14:04.116 Shelly MQTT: (Shelly MQTT) d0 00 .. .. .. .. .. .. .. .. .. .. .. .. .. .. .. .. .. .. Ю
2021-04-24 07:14:14.088 Shelly MQTT: (Shelly MQTT) Heartbeating...
2021-04-24 07:14:14.088 Shelly MQTT: (Shelly MQTT) MqttClient::ping
2021-04-24 07:14:14.088 Shelly MQTT: (Shelly MQTT) Sending 2 bytes of data
2021-04-24 07:14:14.088 Shelly MQTT: (Shelly MQTT) c0 00 .. .. .. .. .. .. .. .. .. .. .. .. .. .. .. .. .. .. �
2021-04-24 07:14:14.138 Shelly MQTT: (Shelly MQTT) Received 2 bytes of data
2021-04-24 07:14:14.139 Shelly MQTT: (Shelly MQTT) d0 00 .. .. .. .. .. .. .. .. .. .. .. .. .. .. .. .. .. .. Ю
2021-04-24 07:14:24.059 Shelly MQTT: (Shelly MQTT) Heartbeating...
2021-04-24 07:14:24.059 Shelly MQTT: (Shelly MQTT) MqttClient::ping
2021-04-24 07:14:24.059 Shelly MQTT: (Shelly MQTT) Sending 2 bytes of data
2021-04-24 07:14:24.059 Shelly MQTT: (Shelly MQTT) c0 00 .. .. .. .. .. .. .. .. .. .. .. .. .. .. .. .. .. .. �
2021-04-24 07:14:24.109 Shelly MQTT: (Shelly MQTT) Received 2 bytes of data
2021-04-24 07:14:24.110 Shelly MQTT: (Shelly MQTT) d0 00 .. .. .. .. .. .. .. .. .. .. .. .. .. .. .. .. .. .. Ю
2021-04-24 07:14:28.711 Shelly MQTT: (Shelly MQTT) Command: On (0) Color:
2021-04-24 07:14:28.711 Shelly MQTT: (Shelly MQTT) shellies/shellyswitch25-68C63AF9B0F7/relay/0/command on
2021-04-24 07:14:28.711 Shelly MQTT: (Shelly MQTT) MqttClient::publish shellies/shellyswitch25-68C63AF9B0F7/relay/0/command (on)
2021-04-24 07:14:28.711 Shelly MQTT: (Shelly MQTT) Sending 58 bytes of data
2021-04-24 07:14:28.711 Shelly MQTT: (Shelly MQTT) 30 38 00 34 73 68 65 6c 6c 69 65 73 2f 73 68 65 6c 6c 79 73 08.4shellies/shellys
2021-04-24 07:14:28.711 Shelly MQTT: (Shelly MQTT) 77 69 74 63 68 32 35 2d 36 38 43 36 33 41 46 39 42 30 46 37 witch25-68C63AF9B0F7
2021-04-24 07:14:28.711 Shelly MQTT: (Shelly MQTT) 2f 72 65 6c 61 79 2f 30 2f 63 6f 6d 6d 61 6e 64 6f 6e .. .. /relay/0/commandon
2021-04-24 07:14:28.761 Shelly MQTT: (Shelly MQTT) Received 58 bytes of data
2021-04-24 07:14:28.761 Shelly MQTT: (Shelly MQTT) 30 38 00 34 73 68 65 6c 6c 69 65 73 2f 73 68 65 6c 6c 79 73 08.4shellies/shellys
2021-04-24 07:14:28.761 Shelly MQTT: (Shelly MQTT) 77 69 74 63 68 32 35 2d 36 38 43 36 33 41 46 39 42 30 46 37 witch25-68C63AF9B0F7
2021-04-24 07:14:28.761 Shelly MQTT: (Shelly MQTT) 2f 72 65 6c 61 79 2f 30 2f 63 6f 6d 6d 61 6e 64 6f 6e .. .. /relay/0/commandon
2021-04-24 07:14:28.761 Shelly MQTT: (Shelly MQTT) MQTT message: shellies/shellyswitch25-68C63AF9B0F7/relay/0/command onles shelly travaillent avec mqtt et le plug in shelly
Une idée ou piste de recherche ?
