Crash domoticz - exited
jme
Message par jme »
Hier j'ai voulu installer le therme Aurora.
Lorsque j'ai redémarré le service, il s'est mis en Active exited.
J'ai un peu chipoté, réinstallé, remis des anciens backup.
Le service a fini par redémarrer.
Une fois que j'ai fais un changement dans les settings, le service a recrashé:
./domoticz
2022-01-27 10:17:49.512  Status: Domoticz V2021.1 (c)2012-2021 GizMoCuz
2022-01-27 10:17:49.512  Status: Build Hash: 8547c5b7e, Date: 2021-04-17 17:29:11
2022-01-27 10:17:49.512  Status: Startup Path: /home/administrateur/domoticz/
2022-01-27 10:17:49.625  Sunrise: 08:24:00 SunSet: 17:25:00
2022-01-27 10:17:49.625  Day length: 09:01:00 Sun at south: 12:54:00
2022-01-27 10:17:49.625  Civil twilight start: 07:48:00 Civil twilight end: 18:01:00
2022-01-27 10:17:49.625  Nautical twilight start: 07:08:00 Nautical twilight end: 18:40:00
2022-01-27 10:17:49.625  Astronomical twilight start: 06:29:00 Astronomical twilight end: 19:19:00
2022-01-27 10:17:49.734  Status: PluginSystem: Started, Python version '3.8.10'.
2022-01-27 10:17:49.819  Active notification Subsystems: email, kodi, pushsafer, telegram (4/13)
2022-01-27 10:17:49.946  Status: WebServer(HTTP) started on address: :: with port 8080
2022-01-27 10:17:50.010  Status: Notification: Temp Piscine Temperature is 3.8 degrees [< 20.0 degrees]
2022-01-27 10:17:50.010  Status: Incoming connection from: 192.168.1.38
2022-01-27 10:17:50.011  Error: WebServer(SSL) startup failed on address 0.0.0.0 with port: 443: bind: Permission denied
2022-01-27 10:17:50.011  Error: WebServer(SSL) check privileges for opening ports below 1024
2022-01-27 10:17:50.011  Status: Camera: settings (re)loaded
2022-01-27 10:17:50.012  Starting shared server on: :::6144
2022-01-27 10:17:50.012  Status: TCPServer: shared server started...
2022-01-27 10:17:50.012  Status: RxQueue: queue worker started...
2022-01-27 10:17:52.012  Status: Weather: Started...
2022-01-27 10:17:52.013  Status: Weather: Started...
2022-01-27 10:17:52.014  Status: Weather: Started...
2022-01-27 10:17:52.015  Shelly MQTT hardware started.
2022-01-27 10:17:52.015  Status: Shelly MQTT: (Shelly MQTT) Started.
2022-01-27 10:17:52.015  Status: Shelly MQTT: (Shelly MQTT) Entering work loop.
2022-01-27 10:17:52.016  Status: Kodi: Started
2022-01-27 10:17:52.016  Tuya hardware started.
2022-01-27 10:17:52.016  Status: Tuya: (Tuya) Started.
2022-01-27 10:17:52.016  Status: Tuya: (Tuya) Entering work loop.
2022-01-27 10:17:52.016  WLED hardware started.
2022-01-27 10:17:52.016  Status: WLED: (WLED) Started.
2022-01-27 10:17:52.016  Status: WLED: (WLED) Entering work loop.
2022-01-27 10:17:52.016  Sonos player hardware started.
2022-01-27 10:17:52.016  Status: Sonos player: (Sonos player) Started.
2022-01-27 10:17:52.016  Status: Sonos player: (Sonos player) Entering work loop.
2022-01-27 10:17:52.016  Hyperion hardware started.
2022-01-27 10:17:52.016  Status: Hyperion: (Hyperion) Started.
2022-01-27 10:17:52.016  Status: Hyperion: (Hyperion) Entering work loop.
2022-01-27 10:17:52.016  Tuya2 hardware started.
2022-01-27 10:17:52.017  Status: Tuya2: (Tuya2) Started.
2022-01-27 10:17:52.017  Status: Tuya2: (Tuya2) Entering work loop.
2022-01-27 10:17:52.017  Status: NotificationSystem: thread started...
2022-01-27 10:17:52.017  Status: EventSystem: reset all events...
2022-01-27 10:17:52.034  Status: dzVents: Write file: /home/administrateur/domoticz/scripts/dzVents/generated_scripts/Power_SUM.lua
2022-01-27 10:17:52.034  Status: dzVents: Write file: /home/administrateur/domoticz/scripts/dzVents/generated_scripts/PiscineV2.lua
2022-01-27 10:17:52.034  Status: EventSystem: reset all device statuses...
2022-01-27 10:17:52.123  Kodi: (OSMC) Starting thread.
2022-01-27 10:17:52.139  Status: Shelly MQTT: (Shelly MQTT) Initialized version 0.6.0
2022-01-27 10:17:52.142  Shelly MQTT: (Shelly MQTT) New hardware creation enabled
2022-01-27 10:17:52.180  Error: Sonos player: (PP-MANAGER) failed to load 'plugin.py', Python Path used was ':/usr/lib/python38.zip:/usr/lib/python3.8:/usr/lib/python3.8/lib-dynload:/usr/local/lib/python3.8/dist-packages:/usr/lib/python3/dist-packages:/usr/lib/python3.8/dist-packages'.
2022-01-27 10:17:52.180  Error: Sonos player: (Sonos player) Module Import failed, exception: 'ModuleNotFoundError'
2022-01-27 10:17:52.180  Error: Sonos player: (Sonos player) Module Import failed: ' Name: plugin'
2022-01-27 10:17:52.180  Error: Sonos player: (Sonos player) Error Line details not available.
2022-01-27 10:17:52.217  Status: PluginSystem: 6 plugins started.
2022-01-27 10:17:52.220  Status: Hyperion: (Hyperion) Initialized version 1.0.4, author 'elgringo'
2022-01-27 10:17:52.223  Kodi: Starting I/O service thread.
2022-01-27 10:17:52.742  Status: Tuya: (Tuya) Initialized version 0.1, author 'tizzen33'
2022-01-27 10:17:53.016  Status: MQTT Gateway: MQTT: Connecting to localhost:1883
2022-01-27 10:17:53.216  Status: MQTT Gateway: MQTT: connected to: localhost:1883
2022-01-27 10:17:53.416  Status: MQTT Gateway: MQTT: Subscribed
2022-01-27 10:17:55.088  Status: Python EventSystem: Initalizing event module.
2022-01-27 10:17:55.088  Status: EventSystem: Started
2022-01-27 10:17:55.088  Status: EventSystem: Queue thread started...
2022-01-27 10:17:55.265  Status: WLED: (WLED) Initialized version 0.0.1, author 'frustreermeneer'
2022-01-27 10:17:55.266  WLED: (WLED) devices existed already
2022-01-27 10:17:55.266  WLED: (WLED) Updating presets
2022-01-27 10:17:55.282  Shelly MQTT: (Shelly MQTT) Connected to MQTT Server: 127.0.0.1:1883
2022-01-27 10:17:55.454  Status: Tuya2: (Tuya2) Initialized version 1.0.0, author 'Wagner Oliveira'
2022-01-27 10:17:55.455  Tuya2: (Tuya2) TUYA plugin started
2022-01-27 10:17:55.457  Tuya2: (Tuya2) Update 0:'Off' (Tuya2 - Prise bureau) TimedOut=True
2022-01-27 10:17:55.459  Tuya2: (Tuya2) Update 0:'Off' (Tuya2 - Yaourtierre) TimedOut=True
2022-01-27 10:17:55.461  Tuya2: (Tuya2) Update 0:'Off' (Bulbe) TimedOut=True
2022-01-27 10:17:55.480  Tuya2: (Tuya2) Update 0:'Off' (Projecteur Garage) TimedOut=True
2022-01-27 10:17:55.483  Tuya2: (Tuya2) Update 0:'Off' (Le Rat) TimedOut=True
2022-01-27 10:17:55.486  Tuya2: (Tuya2) Update 0:'Off' (Spot couleur) TimedOut=True
2022-01-27 10:17:55.487  Tuya2: (Tuya2) Update 0:'Off' (Tuya Porte) TimedOut=True
2022-01-27 10:17:55.490  Tuya2: (Tuya2) Update 0:'Off' (Tuya2 - prise sonette) TimedOut=True
2022-01-27 10:17:55.492  Tuya2: (Tuya2) Update 0:'Off' (Tuya2 - Si \"porte\"Quelqu'un sonne la cloche,\"prise sonette\"Interrupteur 1:Marche) TimedOut=True
2022-01-27 10:17:55.495  Tuya2: (Tuya2) Update 0:'Off' (Palissade) TimedOut=True
2022-01-27 10:17:55.497  Tuya2: (Tuya2) Update 0:'Off' (Terasse) TimedOut=True
2022-01-27 10:17:55.501  Tuya2: (Tuya2) Update 0:'Off' (carport2) TimedOut=True
2022-01-27 10:17:55.503  Tuya2: (Tuya2) Update 0:'Off' (carport1) TimedOut=True
2022-01-27 10:17:55.505  Tuya2: (Tuya2) Update 0:'Off' (Tuya2 - thermostat de la mer) TimedOut=True
2022-01-27 10:17:55.556  Error: WLED: (WLED) No transport, write directive to 'JSONConn' ignored.
2022-01-27 10:17:56.127  Status: dzVents: Info: Handling events for: "Shelly3em Energy Total A", value: "0;5318876.1"
2022-01-27 10:17:56.128  Status: EventSystem: Script event triggered: /home/administrateur/domoticz/dzVents/runtime/dzVents.lua
2022-01-27 10:17:56.156  Status: dzVents: Info: Handling events for: "Shelly3em Energy Total B", value: "0;2280682.7"
2022-01-27 10:17:56.157  Status: dzVents: Info: Handling events for: "Shelly3em Energy Total C", value: "0;422639.6"
2022-01-27 10:17:56.158  Status: EventSystem: Script event triggered: /home/administrateur/domoticz/dzVents/runtime/dzVents.lua
2022-01-27 10:17:57.577  Tuya2: (Tuya2) Update 0:'Off' (carport2) TimedOut=False
2022-01-27 10:17:57.581  Tuya2: (Tuya2) Update 1:'On' (Projecteur Garage) TimedOut=True
2022-01-27 10:17:57.583  Tuya2: (Tuya2) Update 0:'Off' (Tuya2 - Prise bureau) TimedOut=False
2022-01-27 10:17:57.586  Tuya2: (Tuya2) Update 1:'On' (Spot couleur) TimedOut=False
2022-01-27 10:17:57.588  Tuya2: (Tuya2) Update 1:'On' (Tuya2 - thermostat de la mer) TimedOut=False
2022-01-27 10:17:57.590  Tuya2: (Tuya2) Update 1:'On' (Le Rat) TimedOut=True
2022-01-27 10:17:57.593  Tuya2: (Tuya2) Update 0:'Off' (carport1) TimedOut=False
2022-01-27 10:17:57.596  Tuya2: (Tuya2) Update 1:'On' (Bulbe) TimedOut=False
2022-01-27 10:17:57.599  Tuya2: (Tuya2) Update 0:'Off' (Palissade) TimedOut=False
2022-01-27 10:17:57.601  Tuya2: (Tuya2) Update 0:'Off' (Terasse) TimedOut=False
2022-01-27 10:18:02.755  Weather: Temp + Humidity + Baro (Chastre Temp-Hum)
2022-01-27 10:18:02.759  Weather: Wind (Chastre Wind)
2022-01-27 10:18:02.762  Weather: UV (Chastre UV)
2022-01-27 10:18:02.764  Weather: Rain (Rain)
2022-01-27 10:18:02.766  Weather: General/Visibility (Chastre Visibility)
2022-01-27 10:18:02.768  Weather: General/Custom Sensor (Ozone Sensor)
2022-01-27 10:18:02.770  Weather: General/Percentage (Cloud Cover)
2022-01-27 10:18:02.772  Weather: Temp + Humidity + Baro (THB)
2022-01-27 10:18:02.774  Weather: Wind (Unknown)
2022-01-27 10:18:02.775  Weather: UV (UV)
2022-01-27 10:18:02.777  Weather: Rain (Rain)
2022-01-27 10:18:02.779  Weather: General/Visibility (Unknown)
2022-01-27 10:18:02.780  Weather: General/Custom Sensor (Ozone Sensor)
2022-01-27 10:18:02.782  Weather: General/Percentage (Cloud Cover)
2022-01-27 10:18:02.801  Weather: Temp + Humidity + Baro (THB)
2022-01-27 10:18:02.804  Weather: Wind (Unknown)
2022-01-27 10:18:02.806  Weather: UV (UV Index)
2022-01-27 10:18:02.808  Weather: Rain (Rain)
2022-01-27 10:18:02.811  Weather: General/Visibility (Unknown)
2022-01-27 10:18:02.813  Weather: General/Custom Sensor (Ozone Sensor)
2022-01-27 10:18:02.814  Weather: General/Percentage (Cloud Cover)
PING 192.168.1.226 (192.168.1.226) 56(84) bytes of data.
--- 192.168.1.226 ping statistics ---
1 packets transmitted, 0 received, 100% packet loss, time 0ms
2022-01-27 10:18:05.329  Status: EventSystem: Script event triggered: /home/administrateur/domoticz/scripts/lua/script_time_octoprint.lua
2022-01-27 10:18:05.424  Status: LUA:  -------- Temp PiscineTemp = 3.81C,
2022-01-27 10:18:06.078  Status: LUA: Caroline:Inconnu Inconnu
2022-01-27 10:18:06.676  Status: dzVents: Info: Handling events for: "Temp Panneau solaire", value: "4.25"
2022-01-27 10:18:06.676  Status: dzVents: Info: ------ Start internal script: PiscineV2: Device: "Temp Panneau solaire (Temp Piscine)", Index: 232
2022-01-27 10:18:06.677  Status: dzVents: Info: ------ Finished PiscineV2
2022-01-27 10:18:18.588  Status: Incoming connection from: 192.168.1.79
2022-01-27 10:18:19.938  Status: dzVents: Info: Handling events for: "Shelly3em Energy Total A", value: "0;5318882.5"
2022-01-27 10:18:19.939  Status: EventSystem: Script event triggered: /home/administrateur/domoticz/dzVents/runtime/dzVents.lua
2022-01-27 10:18:19.959  Status: dzVents: Info: Handling events for: "Shelly3em Energy Total B", value: "0;2280683.7"
2022-01-27 10:18:19.960  Status: EventSystem: Script event triggered: /home/administrateur/domoticz/dzVents/runtime/dzVents.lua
2022-01-27 10:18:19.980  Status: dzVents: Info: Handling events for: "Shelly3em Energy Total C", value: "0;422639.8"
2022-01-27 10:18:19.981  Status: EventSystem: Script event triggered: /home/administrateur/domoticz/dzVents/runtime/dzVents.lua
2022-01-27 10:18:36.037  Status: dzVents: Info: Handling events for: "Temp Panneau solaire", value: "4.25"
2022-01-27 10:18:36.037  Status: dzVents: Info: ------ Start internal script: PiscineV2: Device: "Temp Panneau solaire (Temp Piscine)", Index: 232
2022-01-27 10:18:36.038  Status: dzVents: Info: ------ Finished PiscineV2
2022-01-27 10:18:41.206  Active notification Subsystems: browser, email, kodi, pushsafer, telegram (5/13)
Fatal Python error: Segmentation fault
Current thread 0x00007f6b3e7fc640 (most recent call first):
<no Python frame>
2022-01-27 10:18:41.213  Error: Domoticz(pid:33213, tid:33235('Sonos player')) received fatal signal 11 (Segmentation fault)
2022-01-27 10:18:41.213  Error: siginfo address=0x3e8000081bd, address=0x7f6b6b88ea3b
2022-01-27 10:18:42.631  Error: Thread 23 (Thread 0x7f6b3e7fc640 (LWP 33235)):
2022-01-27 10:18:42.631  Error: #0  0x00007f6b6b5f168f in __GI___wait4 (pid=33430, stat_loc=0x7f6b3e7fa9a4, options=0, usage=0x0) at ../sysdeps/unix/sysv/linux/wait4.c:30
2022-01-27 10:18:42.631  Error: #1  0x00005616ecb31077 in dumpstack_gdb(bool) ()
2022-01-27 10:18:42.631  Error: #2  0x00005616ecb3165e in signal_handler(int, siginfo_t*, void*) ()
2022-01-27 10:18:42.631  Error: #3  <signal handler called>
2022-01-27 10:18:42.631  Error: #4  raise (sig=<optimized out>) at ../sysdeps/unix/sysv/linux/raise.c:49
2022-01-27 10:18:42.631  Error: #5  <signal handler called>
2022-01-27 10:18:42.631  Error: #6  0x00007f6b6a3e7eaf in PyModule_GetDict () from /usr/lib/x86_64-linux-gnu/libpython3.8.so
2022-01-27 10:18:42.631  Error: #7  0x00005616ecef1b23 in Plugins::CPlugin::LoadSettings() ()
2022-01-27 10:18:42.631  Error: #8  0x00005616ecef991b in Plugins::CDirectiveBase::Process() ()
2022-01-27 10:18:42.631  Error: #9  0x00005616ecef9287 in Plugins::CPlugin::Do_Work() ()
2022-01-27 10:18:42.631  Error: #10 0x00005616ed26818f in execute_native_thread_routine ()
2022-01-27 10:18:42.631  Error: #11 0x00007f6b6b883590 in start_thread (arg=0x7f6b3e7fc640) at pthread_create.c:463
2022-01-27 10:18:42.631  Error: #12 0x00007f6b6b62c223 in clone () at ../sysdeps/unix/sysv/linux/x86_64/clone.S:95
Segmentation fault (core dumped)
Si quelqu'un a une piste .
Merci d'avance
Re: Crash domoticz - exited
On dirait un problème de plugin (sonos player).
Tu es sous quelle version de debian ?
jme
Message par jme »
Merci pour ta réponse:
cat /etc/os-release
NAME="Ubuntu"
VERSION="20.10 (Groovy Gorilla)"
ID=ubuntu
ID_LIKE=debian
PRETTY_NAME="Ubuntu 20.10"
VERSION_ID="20.10"
HOME_URL="https://www.ubuntu.com/"
SUPPORT_URL="https://help.ubuntu.com/"
BUG_REPORT_URL="https://bugs.launchpad.net/ubuntu/"
PRIVACY_POLICY_URL="https://www.ubuntu.com/legal/terms-and-policies/privacy-policy"
VERSION_CODENAME=groovy
UBUNTU_CODENAME=groovy
Donc le problème de vient pas de là.
Tu es sous quelle version de Python ?
Il semble que c'est ton plugin sonos qui fait planter.
Essaie de le désactiver pour voir.
jme
Message par jme »
python -V
Python 2.7.18
Chrominator
Message par Chrominator »
Ca donnera peut-être la même version sur ton système, mais pourrais-tu nous montrer la page "a propos" de l'interface graphique de ton système ?
Sur un de mes pi je n'ai pas la même version avec la commande et dans "à propos" et à mon avis c'est cette dernière qui est pertinente.
Screenshot 2022-01-31 at 18-54-34 Domoticz_dev.png (102.14 Kio) Consulté 2258 fois
RFXtrx433 USB Ver Pro1/1043
Rtl433 RTL-SDR receiver
RFLink Gateway
Zigbee SLZB-06
jme
Message par jme »
pour le moment domoticz tourne, mais des que je fais un changement il se crash.
Edit: j'ai fais l'upgarde du jour, a voir si ca continue a planter ...
Dernière modification par jme le 01 févr. 2022, 17:11, modifié 1 fois.
Modération
En hébergeant les images à l'extérieur du forum, il y a de fort risques qu'ils ne soient plus disponible dans quelque temps comme ici, ou encore . Merci d'éditer votre message et utiliser l'onglet Fichiers joints en dessous de la zone d'écriture des messages pour enregistrer les éléments sur le serveur du forum.
