[Résolu]Blocage au démarrage.
tix63
Message par tix63 »
Je bloque depuis plusieurs jours. J'ai une erreur au démarrage.
Qui pourrait m'aider svp ?
Merci d'avance
Mon log :
2025-09-29 16:57:45.270 Status: Zigbee: Started.
2025-09-29 16:57:45.270 Status: Zigbee: Entering work loop.
2025-09-29 16:57:46.067 Status: Zigbee: Initialized version 7.1, author 'pipiche38'
2025-09-29 16:57:46.069 Status: Zigbee: Welcome to Zigbee for Domoticz (Z4D) plugin. (c)pipiche38 - 2018 - 2025
2025-09-29 16:57:46.069 Zigbee: PYTHONPATH is not set
2025-09-29 16:57:46.069 Status: Zigbee: Z4D requires python3.9 or above and you are running 3.11
2025-09-29 16:57:46.070 Status: Zigbee: Z4D is loading configuration settings
2025-09-29 16:57:46.071 Zigbee: Loading PluginConf - from Domoticz sqlite Db
2025-09-29 16:57:46.071 Zigbee: /home/tix63/domoticz/plugins/Domoticz-Zigbee/Conf/PluginConf-16.json timestamp is 1759151605.7265828
2025-09-29 16:57:46.071 Zigbee: Dz PluginConf is older than Json Dz: 0 Json: 1759151605.7265828
2025-09-29 16:57:46.072 Status: Zigbee: filename set to /home/tix63/domoticz/plugins/Domoticz-Zigbee/Conf/PluginConf-16.json
2025-09-29 16:57:46.072 Status: Zigbee: pluginHome set to /home/tix63/domoticz/plugins/Domoticz-Zigbee
2025-09-29 16:57:46.072 Status: Zigbee: homedirectory set to /home/tix63/domoticz/plugins/Domoticz-Zigbee
2025-09-29 16:57:46.073 Status: Zigbee: pluginData set to /home/tix63/domoticz/plugins/Domoticz-Zigbee/Data
2025-09-29 16:57:46.073 Status: Zigbee: pluginConfig set to /home/tix63/domoticz/plugins/Domoticz-Zigbee/Conf
2025-09-29 16:57:46.073 Status: Zigbee: pluginOTAFirmware set to /home/tix63/domoticz/plugins/Domoticz-Zigbee/OTAFirmware
2025-09-29 16:57:46.073 Status: Zigbee: pluginReports set to /home/tix63/domoticz/plugins/Domoticz-Zigbee/Reports
2025-09-29 16:57:46.073 Status: Zigbee: pluginWWW set to /home/tix63/domoticz/plugins/Domoticz-Zigbee/www
2025-09-29 16:57:46.073 Status: Zigbee: pluginLogs set to /home/tix63/domoticz/plugins/Domoticz-Zigbee/Logs
2025-09-29 16:57:46.073 Status: Zigbee: SSLCertificate set to /home/tix63/domoticz/plugins/Domoticz-Zigbee/certs/server.crt
2025-09-29 16:57:46.073 Status: Zigbee: SSLPrivateKey set to /home/tix63/domoticz/plugins/Domoticz-Zigbee/certs/server.key
2025-09-29 16:57:46.073 Status: Zigbee: expJsonDatabase set to 0
2025-09-29 16:57:46.262 Status: Zigbee: Z4D is checking the python modules requirements
2025-09-29 16:57:46.262 Status: Zigbee: Checking Python modules /home/tix63/domoticz/plugins/Domoticz-Zigbee/constraints.txt
2025-09-29 16:57:46.266 Status: Zigbee: - zigpy==0.83.0 version required 0.83.0 installed 0.83.0
2025-09-29 16:57:46.268 Status: Zigbee: - zigpy_znp==0.14.1 version required 0.14.1 installed 0.14.1
2025-09-29 16:57:46.269 Status: Zigbee: - zigpy_deconz==0.25.2 version required 0.25.2 installed 0.25.2
2025-09-29 16:57:46.271 Status: Zigbee: - bellows==0.46.0 version required 0.46.0 installed 0.46.0
2025-09-29 16:57:46.273 Status: Zigbee: - dnspython==2.7.0 version required 2.7.0 installed 2.7.0
2025-09-29 16:57:46.274 Status: Zigbee: - pyserial>=3.5 version required 3.5 installed 3.5
2025-09-29 16:57:46.276 Status: Zigbee: - charset-normalizer==2.0.11 version required 2.0.11 installed 2.0.11
2025-09-29 16:57:46.278 Status: Zigbee: - jsonschema==4.17.3 version required 4.17.3 installed 4.17.3
2025-09-29 16:57:46.280 Status: Zigbee: - cryptography<=40.0.2 version required 40.0.2 installed 38.0.4
2025-09-29 16:57:46.280 Status: Zigbee: Z4D is installing the WebUI in the domoticz custom menu
2025-09-29 16:57:46.281 Status: Zigbee: Z4D Please watch plugin logs into /home/tix63/domoticz/plugins/Domoticz-Zigbee/Logs/PluginZigbee_16.log
2025-09-29 16:57:46.283 Status: Zigbee: Z4D is initializing a connection to Domoticz Api/Json
2025-09-29 16:57:46.287 Status: Zigbee: Z4D is starting with stable7-7.1.023
2025-09-29 16:57:46.293 Status: Zigbee: Z4D loads ZCL Cluster definitions
2025-09-29 16:57:46.308 Status: Zigbee: Z4D loaded 16 configuration from legacy database.
2025-09-29 16:57:46.308 Status: Zigbee: Z4D loads 0 configuration from the local certified Db.
2025-09-29 16:57:46.426 Status: Zigbee: Z4D loads 651 certified devices from repository version [6.478]
2025-09-29 16:57:46.427 Status: Zigbee: Z4D loading plugin database
2025-09-29 16:57:46.428 Status: Zigbee: Z4D loads 0 entries from /home/tix63/domoticz/plugins/Domoticz-Zigbee/Data/DeviceList-16.txt
2025-09-29 16:57:46.430 Status: Zigbee: Z4D is starting transport Mode: 'ZigpyEZSP' Serial: '/dev/ttyUSB0' IP: '0.0.0.0 'Port: '9999'
2025-09-29 16:57:47.697 Status: Zigbee: Z4D starting EZSP
2025-09-29 16:57:47.700 Status: Zigbee: Z4D starting WebUI on port 9440
2025-09-29 16:57:47.735 Status: Zigbee: Plugin looks to upgrade the Certified Device package
2025-09-29 16:57:50.970 Status: Zigbee: ++ Started radio ezsp port: /dev/ttyUSB0 config {'device': {'path': '/dev/ttyUSB0', 'baudrate': 115200, 'flow_control': None}, 'network': {}, 'ezsp_config': {}, 'ezsp_policies': {}, 'ota': {}, 'handle_unknown_devices': True}
2025-09-29 16:57:50.971 Status: Zigbee: ++ Use of Zigpy Persistent Db
2025-09-29 16:57:52.267 Status: Zigbee: Z4D Widgets usage is at 1.2% (252 units free)
2025-09-29 16:57:52.267 Status: Zigbee: Z4D started with Domoticz legacy Framework
2025-09-29 16:58:02.174 Error: Zigbee: Error at startup
2025-09-29 16:58:02.194 Status: Zigbee: ++ Network settings
2025-09-29 16:58:02.195 Status: Zigbee: PAN ID: 0xFFFE
2025-09-29 16:58:02.196 Status: Zigbee: Extended PAN ID: ff:ff:ff:ff:ff:ff:ff:ff
2025-09-29 16:58:02.197 Status: Zigbee: Channel: 0
2025-09-29 16:58:02.197 Status: Zigbee: Channel mask: []
2025-09-29 16:58:02.198 Status: Zigbee: NWK update ID: 0
2025-09-29 16:58:02.199 Status: Zigbee: Device IEEE: ff:ff:ff:ff:ff:ff:ff:ff
2025-09-29 16:58:02.201 Status: Zigbee: Device NWK: 0xFFFE
2025-09-29 16:58:02.201 Status: Zigbee: Network key: ff:ff:ff:ff:ff:ff:ff:ff:ff:ff:ff:ff:ff:ff:ff:ff
2025-09-29 16:58:02.202 Status: Zigbee: Network key sequence: 0
2025-09-29 16:58:02.203 Status: Zigbee: Network key counter: 0
2025-09-29 16:58:02.203 Error: Zigbee: start_zigpy_task error in radio_start:
2025-09-29 16:58:02.215 Error: Zigbee: Coordinator not correctly initialized
Dernière modification par tix63 le 05 oct. 2025, 12:41, modifié 3 fois.
Syno => Rasp
RFXComm
Wiz
NetAtmo Therm + Meteo
Smart Led Messager
Re: Blocage au démarrage.
quel est le type de clef que tu utilises ? Modèle exacte ? Est-ce un chipset Texas Instruments, SiliconLabs ou autres ?
tix63
Message par tix63 »
J'utilise une clef Sonoff 3.0 USB Dongle Plus (ZBDongle-E)
J'ai donc pris "Silicon" dans la conf.
Syno => Rasp
RFXComm
Wiz
Smart Led Messager
tix63
Message par tix63 »
J'ai 2 fois la conf dans le matériel. C'est doublé. Je ne sais pas comment corriger. Est-ce que cela peut expliquer le problème ?
Zigbee for Domoticz - Doublon.png (134.53 Kio) Consulté 1238 fois
Syno => Rasp
RFXComm
Wiz
Smart Led Messager
Oui tu en as 1 de trop. Tu as du faire un add au lieu de update.
tix63
Message par tix63 »
Probablement.
Cela se corrige ?
J'ai aussi un doublon dans la liste des types de matériel
Z4D doublon.png (252.05 Kio) Consulté 1232 fois
Dernière modification par Keros le 29 sept. 2025, 19:56, modifié 1 fois.
Syno => Rasp
RFXComm
Wiz
Smart Led Messager
Tu dois avoir deux dossiers du plugin dans dossier_domoticz/Plugins.
tix63
Message par tix63 »
Je ne vois pas de doublon dans les dossiers :
tix63@raspberrypi:~/domoticz/plugins $ ls -l
total 16
drwxr-xr-x 3 tix63 tix63 4096 30 sept. 21:42 AwoxSMP
drwxr-xr-x 19 tix63 tix63 4096 29 sept. 15:08 Domoticz-Zigbee
drwxr-xr-x 2 tix63 tix63 4096 26 févr. 2025 examples
drwxr-xr-x 5 tix63 tix63 4096 21 sept. 17:13 PP-MANAGER
Je sèche
Dernière modification par Keros le 01 oct. 2025, 12:26, modifié 2 fois.
Raison : Citation supprimée. Merci de ne pas citer le messaage précédent lors d'une réponse directe.
Syno => Rasp
RFXComm
Wiz
Smart Led Messager
tix63
Message par tix63 »
tix63 a écrit : 29 sept. 2025, 17:46 J'utilise une clef Sonoff 3.0 USB Dongle Plus (ZBDongle-E)
Est-ce que j'ai faux en prenant "Silicon Labs" ?
Est-il possible de désinstaller le plugin facilement et de le réinstaller svp ?
Syno => Rasp
RFXComm
Wiz
Smart Led Messager
et PP-MANAGER il y a quoi dedans. Où sont installés les plugins quand ils sont installé via PP-MANAGER
