Sketch relais et temperature (dallas)
Publié : 30 mars 2016, 10:48
par jule1986
Je vous propose un sketch de temperature ( a base de dallas) et relais.
Il n'est surement pas parfait :? mais il fonctionne.
/**Sketch pour 1 sonde de temperature dallas(broche3) et 2 relais(broche 4 et 5)
#include <MySensor.h>
#include <SPI.h>
#include <OneWire.h>
#define RELAY_1  4  // Arduino Digital I/O pin number for first relay (second on pin+1 etc)
#define NUMBER_OF_RELAYS 2 // Total number of attached relays
#define RELAY_ON 0  // GPIO value to write to turn on attached relay
#define RELAY_OFF 1 // GPIO value to write to turn off attached relay
#define ONE_WIRE_BUS 3 // Pin where dallase sensor is connected
#define MAX_ATTACHED_DS18B20 1
OneWire oneWire(ONE_WIRE_BUS); // Setup a oneWire instance to communicate with any OneWire devices (not just Maxim/Dallas temperature ICs)
DallasTemperature sensors(&oneWire); // Pass the oneWire reference to Dallas Temperature.
MySensor gw;
float lastTemperature[MAX_ATTACHED_DS18B20];
int numSensors=0;
boolean receivedConfig = false;
boolean metric = true;
// Initialize temperature message
MyMessage msg(0,V_TEMP);
void setup()
  // Startup up the OneWire library
  sensors.begin();
  // Startup and initialize MySensors library. Set callback for incoming messages.
  gw.begin(incomingMessage, AUTO, true);
  // Send the sketch version information to the gateway and Controller
  gw.sendSketchInfo("Relay & Dallas", "1.0");
  // Fetch relay status
  for (int i=0; i<MAX_ATTACHED_DS18B20; i++) {
     gw.present(i, S_TEMP);
  for (int sensor=1, pin=RELAY_1; sensor<=NUMBER_OF_RELAYS;sensor++, pin++) {
    // Register all sensors to gw (they will be created as child devices)
    gw.present(sensor, S_LIGHT);
    // Then set relay pins in output mode
    pinMode(pin, OUTPUT);
    // Set relay to last known state (using eeprom storage)
    digitalWrite(pin, gw.loadState(sensor)?RELAY_ON:RELAY_OFF);
void loop()
  // Alway process incoming messages whenever possible
  gw.process();
  // Fetch temperatures from Dallas sensors
  sensors.requestTemperatures();
  // Read temperatures and send them to controller
    // Fetch and round temperature to one decimal
    float temperature = static_cast<float>(static_cast<int>((gw.getConfig().isMetric?sensors.getTempCByIndex(i):sensors.getTempFByIndex(i)) * 10.)) / 10.;
    // Only send data if temperature has changed more then 1 degC and no error
    if (int(lastTemperature[i]) != int(temperature) && temperature != -127.00 && temperature != 85.00) { //added integer
      // Send in the new temperature
      gw.send(msg.setSensor(i).set(temperature,1));
      // Save new temperatures for next compare
      lastTemperature[i]=temperature;
void incomingMessage(const MyMessage &message) {
  // We only expect one type of message from controller. But we better check anyway.
  if (message.type==V_LIGHT) {
     // Change relay state
     digitalWrite(message.sensor-1+RELAY_1, message.getBool()?RELAY_ON:RELAY_OFF);
     // Store state in eeprom
     gw.saveState(message.sensor, message.getBool());
     // Write some debug info
     Serial.print("Incoming change for sensor:");
     Serial.print(message.sensor);
     Serial.print(", New status: ");
     Serial.println(message.getBool());
Re: Sketch relais et temperature (dallas)
Publié : 05 avr. 2016, 17:38
par jamon66
Merci beaucoup, je vais tester !!
