problème de quoi ? hardware ou software ?
Publié : 03 mai 2016, 22:59
par kelly97129
je me présente quand même
Newbee
Gateway MySensors 2.0 bétâ serial sur Raspi jeedom 2.26
j'ai des soucis de Gateway et noeuds
*Passerelle usb amplifié" cf viewtopic.php?f=20&t=1528
Noeud temp hum sur pile DHT 22 cf http://forum.mysensors.org/topic/486/my ... ery-sensor
 * DESCRIPTION
 * This sketch provides an example how to implement a humidity/temperature
 * sensor using DHT11/DHT-22
 * http://www.mysensors.org/build/humidity
// Enable debug prints
#define MY_DEBUG
#define MY_NODE_ID 2
// Enable and select radio type attached
#define MY_RADIO_NRF24
//#define MY_RADIO_RFM69
#include <SPI.h>
#include <MySensor.h>
#include <DHT.h>
#define VBAT_PER_BITS 0.003363075  // Calculated volts per bit from the used battery montoring voltage divider.   Internal_ref=1.1V, res=10bit=2^10-1=1023, Eg for 3V (2AA): Vin/Vb=R1/(R1+R2)=470e3/(1e6+470e3),  Vlim=Vb/Vin*1.1=3.44V, Volts per bit = Vlim/1023= 0.003363075
#define VMIN 1.9  // Battery monitor lower level. Vmin_radio=1.9V
#define VMAX 3.3  //  " " " high level. Vmin<Vmax<=3.44
int BATTERY_SENSE_PIN = A0;  // select the input pin for the battery sense point
#define CHILD_ID_HUM 0
#define CHILD_ID_TEMP 1
#define HUMIDITY_SENSOR_DIGITAL_PIN 3
unsigned long SLEEP_TIME = 30000; // Sleep time between reads (in milliseconds)
DHT dht;
float lastTemp;
float lastHum;
boolean metric = true;
int batteryPcnt = 0;
int batLoop = 0;
int batArray[3];
MyMessage msgHum(CHILD_ID_HUM, V_HUM);
MyMessage msgTemp(CHILD_ID_TEMP, V_TEMP);
void setup()
  // use the 1.1 V internal reference
  analogReference(INTERNAL);
  delay(500); // Allow time for radio if power used as reset <<<<<<<<<<<<<< Experimented with good result
  dht.setup(HUMIDITY_SENSOR_DIGITAL_PIN);
  metric = getConfig().isMetric;
void presentation()
  // Send the Sketch Version Information to the Gateway
  sendSketchInfo("A_CUISINE", "1.0");
  // Register all sensors to gw (they will be created as child devices)
  present(CHILD_ID_HUM, S_HUM);
  present(CHILD_ID_TEMP, S_TEMP);
void loop()
  int sensorValue = analogRead(BATTERY_SENSE_PIN);    // Battery monitoring reading
delay(1000);
  delay(dht.getMinimumSamplingPeriod());
  // Fetch temperatures from DHT sensor
  float temperature = dht.getTemperature();
  if (isnan(temperature)) {
      Serial.println("Failed reading temperature from DHT");
  } else if (temperature != lastTemp) {
    lastTemp = temperature;
    if (!metric) {
      temperature = dht.toFahrenheit(temperature);
    send(msgTemp.set(temperature, 1));
    #ifdef MY_DEBUG
    Serial.print("Temp: ");
    Serial.println(temperature);
    #endif
 delay(1000);
  // Fetch humidity from DHT sensor
  float humidity = dht.getHumidity();
  if (isnan(humidity)) {
      Serial.println("Failed reading humidity from DHT");
  } else if (humidity != lastHum) {
      lastHum = humidity;
      send(msgHum.set(humidity, 1));
      #ifdef MY_DEBUG
      Serial.print("Hum: ");
      Serial.println(humidity);
      #endif
  delay(1000);
  float Vbat  = sensorValue * VBAT_PER_BITS;
   int batteryPcnt = static_cast<int>(((Vbat-VMIN)/(VMAX-VMIN))*100.);
 Serial.print("Battery percent: "); Serial.print(batteryPcnt); Serial.println(" %");
   batArray[batLoop] = batteryPcnt;
   if (batLoop > 2) {
     batteryPcnt = (batArray[0] + batArray[1] + batArray[2] + batArray[3]);
     batteryPcnt = batteryPcnt / 4;
    Serial.print("Battery percent (Avg (4):) "); Serial.print(batteryPcnt); Serial.println(" %");
       sendBatteryLevel(batteryPcnt);
       batLoop = 0;
     batLoop = batLoop + 1;
  sleep(SLEEP_TIME); //sleep a bit
et voici le log que la Gateway reçoit
0;255;3;0;9;Starting gateway (RNNGA-, 2.0.0-beta)
0;255;3;0;9;Radio init successful.
0;255;3;0;14;Gateway startup complete.
0;255;3;0;9;Init complete, id=0, parent=0, distance=0
0;255;3;0;9;read: 2-2-0 s=255,c=3,t=15,pt=0,l=2,sg=0:
0;255;3;0;9;send: 0-0-2-2 s=255,c=3,t=15,pt=0,l=2,sg=0,st=fail:
0;255;3;0;9;read: 2-2-0 s=255,c=0,t=17,pt=0,l=10,sg=0:2.0.0-beta
2;255;0;0;17;2.0.0-beta
0;255;3;0;9;read: 2-2-0 s=255,c=3,t=6,pt=1,l=1,sg=0:0
2;255;3;0;6;0
0;255;3;0;9;read: 2-2-0 s=255,c=3,t=11,pt=0,l=9,sg=0:A_CUISINE
2;255;3;0;11;A_CUISINE
0;255;3;0;9;read: 2-2-0 s=255,c=3,t=12,pt=0,l=3,sg=0:1.0
2;255;3;0;12;1.0
0;255;3;0;9;read: 2-2-0 s=0,c=0,t=7,pt=0,l=0,sg=0:
2;0;0;0;7;
0;255;3;0;9;read: 2-2-0 s=1,c=0,t=6,pt=0,l=0,sg=0:
2;1;0;0;6;
Pouvez-vous me donner un coup de P..d;
Non !! Désolé coup de main.
Re: problème de quoi ? hardware ou software ?
Publié : 03 mai 2016, 23:20
par deennoo
Bah euh nous c'est pas jeedom, mais bon.
Et sur le forum officiel mysensors ?
Publié : 04 mai 2016, 06:11
par kelly97129
deennoo a écrit :Bah euh nous c'est pas jeedom, mais bon.
Certes je sais...
Mais le problème ne vient pas de Jeedom mais de MySensors.
Je présentait mon système je le même problème de non reconnaissance d'inclusion des noeuds sur Domoticz.
La Gateway me retourne aussi des st:fail:
Est-ce que mon sketch est bon ? Que me manque t'il ou j'ai fais une erreur ?
Publié : 04 mai 2016, 10:09
quel intérêt as tu d'utiliser la version beta ?
commence par utiliser la version stable et ainsi valider ton sketch avant de jouer avec les version en cours de dev et donc potentiellement bugée
Publié : 05 mai 2016, 20:10
par kelly97129
vil1driver a écrit :Salut,
Cela me fait exactement la même chose avec la version stable que ce soit 1.5.3 ou 1.5.4 même la version sur le site MySensors le sketch sur la page du Gateway serial
