ghost simulateur de présence copie du VERA
jbhallez
Message par jbhallez »
Bonjour, je recherche a allumer aléatoirement dès la tombé" de la nuit des ampoules et les éteindre de même à des heures aléatoire durant la nuit jusqu'a une certaine heure... je suis arriver sur cela:
https://community.getvera.com/t/vacatio ... s/177691/3
Quelqu'un peut me l'adapter pour Domoticz Merci beaucoup ! je ne sais pas si il faut le faire en Lua ou Dzventz ou un melange des deux... Je bux a cause des fonctions luup... qui n'existe pas sur Domoticz
-- This scene
-- . needs a virtual switch to know when somebody is home
-- . needs a virtual switch to enable/disable simulation when nobody is home
-- . is triggered 1 hour before sunset, at Vera startup and when virtual switch is turned ON
-- -- -- -- -- https://community.getvera.com/t/vacation-ghosts/177691/3
local at_home_virtual_switch_device = 122
local ghost_virtual_switch_device = 42
local dry_run = false
local sunset_time = os.date("*t", luup.sunset())
local sunset = sunset_time.hour * 60 + sunset_time.min
luup.log("Sunset is at " .. string.format("%02i:%02i:%02i", sunset_time.hour, sunset_time.min, sunset_time.sec))
local offset_times = 0
local ghost_rules = {
    living_room = {
        switch_devices = { 10, 11 },
        dimmer_devices = { 12 },
        dimmer_level = 33, -- 33%
        start_min = sunset - 10, start_max = sunset + 15, -- start between t-10 and t+15 minutes
        end_min = 22*60, end_max = 23*60 -- end between 10pm & 11pm
    bedside_room1 = {
        switch_devices = { 20 },
        start_min = sunset, start_max = sunset + 30, -- start between t and t+30 minutes
        end_min = 20.5*60, end_max = 21*60, -- end between 8:30pm and 9:00pm
        cycles = true,
        cycles_on_min = 30, cycles_on_max = 3 * 60, -- each cycle should leave light ON for 30 to 3 hours
        cycles_off_min = 5, cycles_off_max = 30 -- each cycle should leave light OFF for 5 to 30 minutes
    ceiling_room1 = {
        switch_devices = { 21 },
        end_min = 20.5*60, end_max = 21.5*60, -- end between 8:30pm and 9:30pm
        cycles = true,
        cycles_on_min = 30, cycles_on_max = 60, -- each cycle should leave light ON for 30 to 1 hour
        cycles_off_min = 15, cycles_off_max = 60 -- each cycle should leave light OFF for 15 to 60 minutes
    bedside_room2 = {
        switch_devices = { 28 },
        end_min = 21*60, end_max = 23*60, -- end between 9:00pm and 11:00pm
function ghostDeviceIdToName(device_id)
    return luup.devices[device_id].description .. " " .. luup.rooms[luup.devices[device_id].room_num] .. " (#" .. device_id .. ")"
function generateGhosts()
    -- Reinitialize ghost list
    if ghosts then
        terminateAllGhosts() -- terminate all current ghosts if any
    ghosts = {}
    sorted_ghosts = {}
    -- Calc ghosts start/end
    luup.log("Generating ghosts...")
    math.randomseed(os.time())
    for rule_name, rule in pairs(ghost_rules) do
        local starts = math.random(rule['start_min'] * 60, rule['start_max'] * 60) + (offset_times * 60)
        local ends = math.random(rule['end_min'] * 60, rule['end_max'] * 60) + (offset_times * 60)
        local ghost_i = 1
        local ghost_starts = starts
        local ghost_ends = ends
        while ghost_starts < ends do
            local ghost_name = rule_name .. " #" .. ghost_i
            if rule['cycles'] then
                ghost_ends = math.min(ghost_starts + math.random(rule['cycles_on_min'] * 60, rule['cycles_on_max'] * 60), ends)
            ghosts["" .. ghost_starts .. "/" .. ghost_name] = { name = ghost_name, rule_name = rule_name, starts = ghost_starts, duration = ghost_ends - ghost_starts }
                ghost_starts = ghost_ends + math.random(rule['cycles_off_min'] * 60, rule['cycles_off_max'] * 60)
            ghost_i = ghost_i + 1
    -- Sort ghosts by start time
    for ghost_id in pairs(ghosts) do
        table.insert(sorted_ghosts, ghost_id)
    table.sort(sorted_ghosts)
function wakeGhost(ghost_id)
    if (luup.variable_get("urn:upnp-org:serviceId:VSwitch1", "Status", at_home_virtual_switch_device) == "1") then
        luup.log("Not waking up ghost " .. ghost_id .. ", somebody is home")
        if (luup.variable_get("urn:upnp-org:serviceId:VSwitch1", "Status", ghost_virtual_switch_device) == "0") then
            luup.log("Not waking up ghost " .. ghost_id .. ", virtual switch has been turned OFF")
            local ghost = ghosts[ghost_id]
            if ghost then
                luup.log("Waking up ghost " .. ghost_id)
                rule = ghost_rules[ghost['rule_name']]
                if rule['switch_devices'] then
                    for i, device_id in ipairs(rule['switch_devices']) do
                        if luup.variable_get("urn:upnp-org:serviceId:SwitchPower1", "Status", device_id) == "1" then
                            luup.log("Ghost " .. ghost_id .. " is NOT switching " .. ghostDeviceIdToName(device_id) .. " ON, it's already ON!")
                            luup.log("Ghost " .. ghost_id .. " is switching " .. ghostDeviceIdToName(device_id) .. " ON")
                            if not ghost['switch_devices_to_turn_off'] then
                                ghost['switch_devices_to_turn_off'] = {}
                            table.insert(ghost['switch_devices_to_turn_off'], device_id)
                            if not dry_run then
                                luup.call_action("urn:upnp-org:serviceId:SwitchPower1", "SetTarget", { newTargetValue = "1" }, device_id)
                if rule['dimmer_devices'] then
                    for i, device_id in ipairs(rule['dimmer_devices']) do
                            local dimmer_level = rule['dimmer_level'] or 25
                            luup.log("Ghost " .. ghost_id .. " is switching " .. ghostDeviceIdToName(device_id) .. " ON to " .. dimmer_level .."%")
                            if not ghost['dimmer_devices_to_turn_off'] then
                                ghost['dimmer_devices_to_turn_off'] = {}
                            table.insert(ghost['dimmer_devices_to_turn_off'], device_id)
                            if not dry_run then
                                luup.call_action("urn:upnp-org:serviceId:Dimming1", "SetLoadLevelTarget", { newLoadlevelTarget = "" .. dimmer_level }, device_id)
                luup.log("Schedule ghost termination in " .. ghost['duration'] .. " seconds")
                luup.call_delay("terminateGhost", ghost['duration'], ghost_id)
                luup.log("Ghost " .. ghost_id .. " already killed, do nothing")
function terminateAllGhosts()
    for i, ghost_id in ipairs(sorted_ghosts) do
        terminateGhost(ghost_id)
function terminateGhost(ghost_id)
        luup.log("Not terminating ghost " .. ghost_id .. ", somebody is home")
        if ghost then
            luup.log("Terminating ghost " .. ghost_id)
            if ghost['switch_devices_to_turn_off'] then
                for i, device_id in ipairs(ghost['switch_devices_to_turn_off']) do
                    luup.log("Ghost " .. ghost_id .. " is switching " .. ghostDeviceIdToName(device_id) .. " OFF")
                    if not dry_run then
                        luup.call_action("urn:upnp-org:serviceId:SwitchPower1", "SetTarget", { newTargetValue = "0" }, device_id)
            if ghost['dimmer_devices_to_turn_off'] then
                for i, device_id in ipairs(ghost['dimmer_devices_to_turn_off']) do
                    if not dry_run then
            luup.log("Ghost " .. ghost_id .. " already terminated")
function scheduleGhosts()
    local current_time = os.date("*t", os.time())
    local seconds_from_midnight = current_time.hour * 3600 + current_time.min * 60 + current_time.sec
    luup.log("Scheduling ghosts...")
    local report = ""
    local ghosts_count = 0
    local scheduled_ghosts_count = 0
        ghosts_count = ghosts_count + 1
        local starts_in = ghost['starts'] - seconds_from_midnight
        local ends_in = starts_in + ghost['duration']
        local status = ""
        if ends_in < 60 then
            status = "skipped, too late"
        elseif starts_in < 0 then
            status = "started " .. -starts_in .. " seconds ago, run now"
            ghost['duration'] = ghost['duration'] + starts_in
            scheduled_ghosts_count = scheduled_ghosts_count + 1
            wakeGhost(ghost_id)
            status = "scheduled"
            luup.call_delay("wakeGhost", starts_in, ghost_id)
        -- report
        local start_h = math.floor(ghost['starts'] / 3600)
        local start_m = math.floor((ghost['starts'] - (start_h * 3600)) / 60)
        local start_s = ghost['starts'] - (start_h * 3600) - (start_m * 60)
        local start_str = string.format("%02i:%02i:%02i", start_h, start_m, start_s)
        local duration_h = math.floor(ghost['duration'] / 3600)
        local duration_m = math.floor((ghost['duration'] - (duration_h * 3600)) / 60)
        local duration_s = ghost['duration'] - (duration_h * 3600) - (duration_m * 60)
        local duration_str = string.format("%02i:%02i:%02i", duration_h, duration_m, duration_s)
        local ends = ghost['starts'] + ghost['duration']
        local end_h = math.floor(ends / 3600)
        local end_m = math.floor((ends - (end_h * 3600)) / 60)
        local end_s = ends - (end_h * 3600) - (end_m * 60)
        local end_str = string.format("%02i:%02i:%02i", end_h, end_m, end_s)
        local report_line = string.format("%25s %s => %s (%s): %s", ghost['name'], start_str, end_str, duration_str, status)
        luup.log(report_line)
        report = report .. report_line .. "\n"
    report_file = io.open('/tmp/ghosts.txt', 'w')
    report_file:write('Ghosts generated ' .. os.date("%x %X", os.time()) .. "\n\n")
    report_file:write(report)
if (luup.variable_get("urn:upnp-org:serviceId:VSwitch1", "Status", at_home_virtual_switch_device) == "0") then
    if (luup.variable_get("urn:upnp-org:serviceId:VSwitch1", "Status", ghost_virtual_switch_device) == "1") then
        generateGhosts()
        luup.call_delay('scheduleGhosts', 10)
        luup.log("Not generating any ghost, virtual switch is OFF")
    luup.log("Not generating any ghost, somebody is home")
Re: ghost simulateur de présence copie du VERA
Domoticz intègre cela nativement dans ses planning.
Il te suffit de choisir l'heure d'allumage et de cocher aléatoire.
Idem pour l'extinction.
Dans les paramètres, tu définis la notion aléatoire, de quelques minutes à plusieurs heures..
C'est le plus simple.
LucasC
Message par LucasC »
Sans aller aussi loin, je souhaite allumer un éclairage disons une heure après le coucher du soleil.
Je n'arrive pas à ajouter 1h à sunset.
Aurriez vous le script pour cela ?
Merci bien pour votre aide
thier
Message par thier »
pour avoir l'heure du coucher de soleil en minutes:
coucherSoleilEnMinutes = timeofday['SunsetInMinutes']
pour décaler par exemple de 10 minutes:
decalage = timeofday['SunsetInMinutes'] + 10
pour avoir l'heure en cours en minute:
heureminutes = (tonumber(os.date('%H',os.time()))*60)+tonumber(os.date('%M',os.time()))
Aprés tu compares heureminutes avec decalage pour allumer ta lampe.
Également possible par planning
denis_brasseur
Message par denis_brasseur »
vil1driver a écrit : 04 janv. 2020, 11:50 Également possible par planning
LucasC
J'avais une erreur du style " xxx[string]: 34 attempt to perform arithmectic on global xxxx" et en le refaisant en minute comme le porpose THIER cela fonctionne
Je préfère faire en code, je me dis que si mon RPI meure, je n'ai qu'a télécharger le code alors que les réglages plannings seront à refaire. Et pour ma culture perso je voulais savoir comment faire (ça peut me servir pour d'autres scripts).
Au final voila mon code, je repasse en heure juste apres le calcul pour faciliter la lecture du log
Heure_Allumage_minutes = timeofday['SunsetInMinutes'] + 10
Heure_Allumage = string.sub(os.date("!%X",60*Heure_Allumage_minutes),1,5)
print ('Heure Allumage ' ..Heure_Allumage)
if (heure = Heure_Allumage) then
Merci pour votre aide, bonne journée
