Domoticz redémarre toutes les 10'
Publié : 20 mars 2020, 09:03
J'ai constaté que Rfxcom/Domoticz redémarre toutes les 10'
Aucun message dans log/erreur
Constat toutes les 10' j'ai les infos suivantes :
Ensuite cela continue normalement.
Est-ce normal ?
Une idée ?
2020-03-20 10:50:08.396 Status: Startup Path: /home/pi/domoticz/
2020-03-20 10:50:08.518 Status: PluginSystem: Started, Python version '3.7.3'.
2020-03-20 10:50:08.529 Status: WebServer(HTTP) started on address: :: with port 80xx
2020-03-20 10:50:08.535 Status: WebServer(SSL) started on address: :: with port 443
2020-03-20 10:50:08.538 Status: Proxymanager started.
2020-03-20 10:50:08.583 Status: Camera: settings (re)loaded
2020-03-20 10:50:08.585 Status: TCPServer: shared server started...
2020-03-20 10:50:08.585 Status: RxQueue: queue worker started...
2020-03-20 10:50:08.666 Status: PROXY: Authenticate result: Invalid apikey/password combination..
2020-03-20 10:50:10.115 Status: (Exec info) interceptWH2600.py: WH2600 Interceptor 1.0.3 listening for PWS on port 80xx. Running as a CRON job...
2020-03-20 10:50:10.116 Status: Incoming connection from: 192.168.1.xxx
2020-03-20 10:50:10.162 Status: Incoming connection from: 192.168.1.xxx
2020-03-20 10:50:10.585 Status: RFXCOM: Worker started...
2020-03-20 10:50:10.586 Status: (Onduleur UPS) Started.
2020-03-20 10:50:10.586 Status: EventSystem: reset all events...
2020-03-20 10:50:10.587 Status: EventSystem: reset all device statuses...
2020-03-20 10:50:10.593 Status: Darksky: Started...
2020-03-20 10:50:10.593 Status: Wunderground: Worker started...
2020-03-20 10:50:10.825 Status: Python EventSystem: Initalizing event module.
2020-03-20 10:50:10.825 Status: EventSystem: Started
2020-03-20 10:50:10.825 Status: EventSystem: Queue thread started...
2020-03-20 10:50:10.947 Status: PluginSystem: Entering work loop.
2020-03-20 10:50:11.150 (Onduleur UPS) Debug logging mask set to: NONE
2020-03-20 10:50:11.147 Status: (Onduleur UPS) Entering work loop.
2020-03-20 10:50:11.147 Status: (Onduleur UPS) Initialized version 0.2.3, author 'logread'
2020-03-20 10:50:11.586 Status: MQTT: Connecting to localhost:1883
2020-03-20 10:50:11.589 Status: RFXCOM: Using serial port: /dev/ttyUSB0
2020-03-20 10:50:11.687 Status: MQTT: connected to: localhost:1883
2020-03-20 10:50:11.788 Status: MQTT: Subscribed
2020-03-20 10:50:12.165
2020-03-20 10:50:12.240 subtype = Interface Response
2020-03-20 10:50:12.240 Sequence nbr = 2
2020-03-20 10:50:12.240 response on cmnd = Get Status
2020-03-20 10:50:12.240 Transceiver type = 433.92MHz
2020-03-20 10:50:12.240 Firmware version = 1022
2020-03-20 10:50:12.240 Firmware type = Ext2
2020-03-20 10:50:12.240 Hardware version = 1.3
2020-03-20 10:50:12.240 Undec off
2020-03-20 10:50:12.240 X10 enabled
2020-03-20 10:50:12.240 ARC enabled
2020-03-20 10:50:12.240 AC enabled
2020-03-20 10:50:12.240 HomeEasy EU enabled
2020-03-20 10:50:12.240 Meiantech/Atlantic disabled
2020-03-20 10:50:12.240 Oregon Scientific enabled
2020-03-20 10:50:12.240 ATI/Cartelectronic disabled
2020-03-20 10:50:12.240 Visonic disabled
2020-03-20 10:50:12.240 Mertik disabled
2020-03-20 10:50:12.240 AD disabled
2020-03-20 10:50:12.240 Hideki disabled
2020-03-20 10:50:12.240 La Crosse enabled
2020-03-20 10:50:12.240 Legrand disabled
2020-03-20 10:50:12.240 MSG4Reserved5 disabled
2020-03-20 10:50:12.240 BlindsT0 disabled
2020-03-20 10:50:12.240 BlindsT1 disabled
2020-03-20 10:50:12.240 AE disabled
2020-03-20 10:50:12.240 RUBiCSON disabled
2020-03-20 10:50:12.240 FineOffset disabled
2020-03-20 10:50:12.240 Lighting4 enabled
2020-03-20 10:50:12.240 Conrad RSL disabled
2020-03-20 10:50:12.240 ByronSX disabled
2020-03-20 10:50:12.240 IMAGINTRONIX disabled
2020-03-20 10:50:12.240 KEELOQ disabled
2020-03-20 10:50:12.240 Home Confort disabled
2020-03-20 10:50:15.306 Status: Incoming connection from: 192.168.1.xxx
2020-03-20 10:50:20.400 Status: LUA: ==========================================================
2020-03-20 10:50:20.400 Status: LUA: Device_Wind_Speed :5.0 km/h
2020-03-20 10:50:20.400 Status: LUA: ==================================================2020- Est-ce normal ?
Une idée ?
