Pour celui ci c'est plus compliqué en effet
- Capture d’écran 2021-12-21 185908.png (11.41 Kio) Consulté 2512 fois
Dans ce cas: sur l'appareil (le thermostat) je bascule de Manuel a Programation. Dans les logs du device on voit Program/auto/program/auto.....
Voici les logs correspondants
2021-12-21 19:01:01.462 Deconz Plugins: (Deconz Plugins) onMessage called
2021-12-21 19:01:01.463 Deconz Plugins: (Deconz Plugins) ### WebSocket Data : {'config': {'heatsetpoint': 2000, 'locked': False, 'mode': 'heat', 'offset': 0, 'on': False, 'preset': 'auto', 'reachable': True, 'schedule': {}, 'schedule_on': False, 'setvalve': False}, 'e': 'changed', 'id': '11', 'r': 'sensors', 't': 'event', 'uniqueid': '90:35:ea:ff:fe:6e:e7:70-01-0201'}
2021-12-21 19:01:01.465 Deconz Plugins: (Deconz Plugins) ### Update device (Reglage) : {'nValue': 0, 'sValue': '20.0'}, IGNORED , no changes !
2021-12-21 19:01:01.465 Deconz Plugins: (Deconz Plugins) ### Update device (Deconz Plugins - Thermostat 11) : {'nValue': 0, 'sValue': '10'}, IGNORED , no changes !
2021-12-21 19:01:01.465 Deconz Plugins: (Deconz Plugins) ### Update device (Deconz Plugins - Thermostat 11) : {'nValue': 20, 'sValue': '20'}
2021-12-21 19:01:01.485 Deconz Plugins: (Deconz Plugins) ### Update device (T° Salon) : {'nValue': 0, 'sValue': '19.5'}, IGNORED , no changes !
2021-12-21 19:01:01.535 Deconz Plugins: (Deconz Plugins) onMessage called
2021-12-21 19:01:01.536 Deconz Plugins: (Deconz Plugins) ### WebSocket Data : {'config': {'heatsetpoint': 2000, 'locked': False, 'mode': 'heat', 'offset': 0, 'on': False, 'preset': 'program', 'reachable': True, 'schedule': {}, 'schedule_on': False, 'setvalve': False}, 'e': 'changed', 'id': '11', 'r': 'sensors', 't': 'event', 'uniqueid': '90:35:ea:ff:fe:6e:e7:70-01-0201'}
2021-12-21 19:01:01.537 Deconz Plugins: (Deconz Plugins) ### Update device (Reglage) : {'nValue': 0, 'sValue': '20.0'}, IGNORED , no changes !
2021-12-21 19:01:01.537 Deconz Plugins: (Deconz Plugins) ### Update device (Deconz Plugins - Thermostat 11) : {'nValue': 0, 'sValue': '10'}, IGNORED , no changes !
2021-12-21 19:01:01.538 Deconz Plugins: (Deconz Plugins) ### Update device (Deconz Plugins - Thermostat 11) : {'nValue': 80, 'sValue': '80'}
2021-12-21 19:01:01.550 Deconz Plugins: (Deconz Plugins) ### Update device (T° Salon) : {'nValue': 0, 'sValue': '19.5'}, IGNORED , no changes !
2021-12-21 19:01:04.406 Deconz Plugins: (Deconz Plugins) onMessage called
2021-12-21 19:01:04.407 Deconz Plugins: (Deconz Plugins) ### WebSocket Data : {'config': {'heatsetpoint': 2300, 'locked': False, 'mode': 'heat', 'offset': 0, 'on': False, 'preset': 'program', 'reachable': True, 'schedule': {}, 'schedule_on': False, 'setvalve': False}, 'e': 'changed', 'id': '11', 'r': 'sensors', 't': 'event', 'uniqueid': '90:35:ea:ff:fe:6e:e7:70-01-0201'}
2021-12-21 19:01:04.408 Deconz Plugins: (Deconz Plugins) ### Update device (Reglage) : {'nValue': 0, 'sValue': '23.0'}
2021-12-21 19:01:04.424 Deconz Plugins: (Deconz Plugins) ### Update device (Deconz Plugins - Thermostat 11) : {'nValue': 0, 'sValue': '10'}, IGNORED , no changes !
2021-12-21 19:01:04.424 Deconz Plugins: (Deconz Plugins) ### Update device (Deconz Plugins - Thermostat 11) : {'nValue': 80, 'sValue': '80'}
2021-12-21 19:01:04.440 Deconz Plugins: (Deconz Plugins) ### Update device (T° Salon) : {'nValue': 0, 'sValue': '19.5'}, IGNORED , no changes !
2021-12-21 19:01:04.440 Deconz Plugins: (Deconz Plugins) onMessage called
2021-12-21 19:01:04.441 Deconz Plugins: (Deconz Plugins) ### WebSocket Data : {'e': 'changed', 'id': '11', 'r': 'sensors', 'state': {'lastupdated': '2021-12-21T18:01:04.398', 'on': False, 'temperature': 1950}, 't': 'event', 'uniqueid': '90:35:ea:ff:fe:6e:e7:70-01-0201'}
2021-12-21 19:01:04.442 Deconz Plugins: (Deconz Plugins) ### Update device (T° Salon) : {'nValue': 0, 'sValue': '19.5'}, IGNORED , no changes !
2021-12-21 19:01:05.093 Deconz Plugins: (Deconz Plugins) onHeartbeat called
2021-12-21 19:01:05.995 Deconz Plugins: (Deconz Plugins) onMessage called
2021-12-21 19:01:05.996 Deconz Plugins: (Deconz Plugins) ### WebSocket Data : {'attr': {'id': '1', 'lastannounced': None, 'lastseen': '2021-12-21T18:01Z', 'manufacturername': 'dresden elektronik', 'modelid': 'ConBee II', 'name': 'Configuration tool 1', 'swversion': '0x26660700', 'type': 'Configuration tool', 'uniqueid': '00:21:2e:ff:ff:07:b7:8b-01'}, 'e': 'changed', 'id': '1', 'r': 'lights', 't': 'event', 'uniqueid': '00:21:2e:ff:ff:07:b7:8b-01'}
2021-12-21 19:01:05.996 Deconz Plugins: (Deconz Plugins) Banned/Ignored device > 1 (lights)
2021-12-21 19:01:06.147 Deconz Plugins: (Deconz Plugins) onMessage called
2021-12-21 19:01:06.147 Deconz Plugins: (Deconz Plugins) ### WebSocket Data : {'config': {'heatsetpoint': 2300, 'locked': False, 'mode': 'heat', 'offset': 0, 'on': False, 'preset': 'auto', 'reachable': True, 'schedule': {}, 'schedule_on': False, 'setvalve': False}, 'e': 'changed', 'id': '11', 'r': 'sensors', 't': 'event', 'uniqueid': '90:35:ea:ff:fe:6e:e7:70-01-0201'}
2021-12-21 19:01:06.148 Deconz Plugins: (Deconz Plugins) ### Update device (Reglage) : {'nValue': 0, 'sValue': '23.0'}, IGNORED , no changes !
2021-12-21 19:01:06.148 Deconz Plugins: (Deconz Plugins) ### Update device (Deconz Plugins - Thermostat 11) : {'nValue': 0, 'sValue': '10'}, IGNORED , no changes !
2021-12-21 19:01:06.148 Deconz Plugins: (Deconz Plugins) ### Update device (Deconz Plugins - Thermostat 11) : {'nValue': 20, 'sValue': '20'}
2021-12-21 19:01:06.173 Deconz Plugins: (Deconz Plugins) ### Update device (T° Salon) : {'nValue': 0, 'sValue': '19.5'}, IGNORED , no changes !
2021-12-21 19:01:06.173 Deconz Plugins: (Deconz Plugins) onMessage called
2021-12-21 19:01:06.173 Deconz Plugins: (Deconz Plugins) ### WebSocket Data : {'config': {'heatsetpoint': 2300, 'locked': False, 'mode': 'heat', 'offset': 0, 'on': False, 'preset': 'program', 'reachable': True, 'schedule': {}, 'schedule_on': False, 'setvalve': False}, 'e': 'changed', 'id': '11', 'r': 'sensors', 't': 'event', 'uniqueid': '90:35:ea:ff:fe:6e:e7:70-01-0201'}
2021-12-21 19:01:06.174 Deconz Plugins: (Deconz Plugins) ### Update device (Reglage) : {'nValue': 0, 'sValue': '23.0'}, IGNORED , no changes !
2021-12-21 19:01:06.175 Deconz Plugins: (Deconz Plugins) ### Update device (Deconz Plugins - Thermostat 11) : {'nValue': 0, 'sValue': '10'}, IGNORED , no changes !
2021-12-21 19:01:06.175 Deconz Plugins: (Deconz Plugins) ### Update device (Deconz Plugins - Thermostat 11) : {'nValue': 80, 'sValue': '80'}
2021-12-21 19:01:06.191 Deconz Plugins: (Deconz Plugins) ### Update device (T° Salon) : {'nValue': 0, 'sValue': '19.5'}, IGNORED , no changes !
2021-12-21 19:01:08.799 Deconz Plugins: (Deconz Plugins) onMessage called
2021-12-21 19:01:08.800 Deconz Plugins: (Deconz Plugins) ### WebSocket Data : {'config': {'heatsetpoint': 2300, 'locked': False, 'mode': 'heat', 'offset': 0, 'on': False, 'preset': 'auto', 'reachable': True, 'schedule': {}, 'schedule_on': False, 'setvalve': False}, 'e': 'changed', 'id': '11', 'r': 'sensors', 't': 'event', 'uniqueid': '90:35:ea:ff:fe:6e:e7:70-01-0201'}
2021-12-21 19:01:08.802 Deconz Plugins: (Deconz Plugins) ### Update device (Reglage) : {'nValue': 0, 'sValue': '23.0'}, IGNORED , no changes !
2021-12-21 19:01:08.803 Deconz Plugins: (Deconz Plugins) ### Update device (Deconz Plugins - Thermostat 11) : {'nValue': 0, 'sValue': '10'}, IGNORED , no changes !
2021-12-21 19:01:08.803 Deconz Plugins: (Deconz Plugins) ### Update device (Deconz Plugins - Thermostat 11) : {'nValue': 20, 'sValue': '20'}
2021-12-21 19:01:08.829 Deconz Plugins: (Deconz Plugins) ### Update device (T° Salon) : {'nValue': 0, 'sValue': '19.5'}, IGNORED , no changes !
2021-12-21 19:01:08.830 Deconz Plugins: (Deconz Plugins) onMessage called
2021-12-21 19:01:08.831 Deconz Plugins: (Deconz Plugins) ### WebSocket Data : {'config': {'heatsetpoint': 2300, 'locked': False, 'mode': 'heat', 'offset': 0, 'on': False, 'preset': 'program', 'reachable': True, 'schedule': {}, 'schedule_on': False, 'setvalve': False}, 'e': 'changed', 'id': '11', 'r': 'sensors', 't': 'event', 'uniqueid': '90:35:ea:ff:fe:6e:e7:70-01-0201'}
2021-12-21 19:01:08.832 Deconz Plugins: (Deconz Plugins) ### Update device (Reglage) : {'nValue': 0, 'sValue': '23.0'}, IGNORED , no changes !
2021-12-21 19:01:08.833 Deconz Plugins: (Deconz Plugins) ### Update device (Deconz Plugins - Thermostat 11) : {'nValue': 0, 'sValue': '10'}, IGNORED , no changes !
2021-12-21 19:01:08.833 Deconz Plugins: (Deconz Plugins) ### Update device (Deconz Plugins - Thermostat 11) : {'nValue': 80, 'sValue': '80'}
2021-12-21 19:01:08.855 Deconz Plugins: (Deconz Plugins) ### Update device (T° Salon) : {'nValue': 0, 'sValue': '19.5'}, IGNORED , no changes !
2021-12-21 19:01:12.363 Deconz Plugins: (Deconz Plugins) onMessage called
2021-12-21 19:01:12.364 Deconz Plugins: (Deconz Plugins) ### WebSocket Data : {'config': {'heatsetpoint': 2300, 'locked': False, 'mode': 'heat', 'offset': 0, 'on': False, 'preset': 'auto', 'reachable': True, 'schedule': {}, 'schedule_on': False, 'setvalve': False}, 'e': 'changed', 'id': '11', 'r': 'sensors', 't': 'event', 'uniqueid': '90:35:ea:ff:fe:6e:e7:70-01-0201'}
2021-12-21 19:01:12.365 Deconz Plugins: (Deconz Plugins) ### Update device (Reglage) : {'nValue': 0, 'sValue': '23.0'}, IGNORED , no changes !
2021-12-21 19:01:12.365 Deconz Plugins: (Deconz Plugins) ### Update device (Deconz Plugins - Thermostat 11) : {'nValue': 0, 'sValue': '10'}, IGNORED , no changes !
2021-12-21 19:01:12.366 Deconz Plugins: (Deconz Plugins) ### Update device (Deconz Plugins - Thermostat 11) : {'nValue': 20, 'sValue': '20'}
2021-12-21 19:01:12.388 Deconz Plugins: (Deconz Plugins) ### Update device (T° Salon) : {'nValue': 0, 'sValue': '19.5'}, IGNORED , no changes !
2021-12-21 19:01:12.388 Deconz Plugins: (Deconz Plugins) onMessage called
2021-12-21 19:01:12.388 Deconz Plugins: (Deconz Plugins) ### WebSocket Data : {'config': {'heatsetpoint': 2300, 'locked': False, 'mode': 'heat', 'offset': 0, 'on': False, 'preset': 'program', 'reachable': True, 'schedule': {}, 'schedule_on': False, 'setvalve': False}, 'e': 'changed', 'id': '11', 'r': 'sensors', 't': 'event', 'uniqueid': '90:35:ea:ff:fe:6e:e7:70-01-0201'}
2021-12-21 19:01:12.389 Deconz Plugins: (Deconz Plugins) ### Update device (Reglage) : {'nValue': 0, 'sValue': '23.0'}, IGNORED , no changes !
2021-12-21 19:01:12.389 Deconz Plugins: (Deconz Plugins) ### Update device (Deconz Plugins - Thermostat 11) : {'nValue': 0, 'sValue': '10'}, IGNORED , no changes !
2021-12-21 19:01:12.389 Deconz Plugins: (Deconz Plugins) ### Update device (Deconz Plugins - Thermostat 11) : {'nValue': 80, 'sValue': '80'}
2021-12-21 19:01:12.405 Deconz Plugins: (Deconz Plugins) ### Update device (T° Salon) : {'nValue': 0, 'sValue': '19.5'}, IGNORED , no changes !
2021-12-21 19:01:14.313 Deconz Plugins: (Deconz Plugins) onMessage called
2021-12-21 19:01:14.316 Deconz Plugins: (Deconz Plugins) ### WebSocket Data : {'config': {'heatsetpoint': 2000, 'locked': False, 'mode': 'heat', 'offset': 0, 'on': False, 'preset': 'program', 'reachable': True, 'schedule': {}, 'schedule_on': False, 'setvalve': False}, 'e': 'changed', 'id': '11', 'r': 'sensors', 't': 'event', 'uniqueid': '90:35:ea:ff:fe:6e:e7:70-01-0201'}
2021-12-21 19:01:14.317 Deconz Plugins: (Deconz Plugins) ### Update device (Reglage) : {'nValue': 0, 'sValue': '20.0'}
2021-12-21 19:01:14.341 Deconz Plugins: (Deconz Plugins) ### Update device (Deconz Plugins - Thermostat 11) : {'nValue': 0, 'sValue': '10'}, IGNORED , no changes !
2021-12-21 19:01:14.342 Deconz Plugins: (Deconz Plugins) ### Update device (Deconz Plugins - Thermostat 11) : {'nValue': 80, 'sValue': '80'}
2021-12-21 19:01:14.362 Deconz Plugins: (Deconz Plugins) ### Update device (T° Salon) : {'nValue': 0, 'sValue': '19.5'}, IGNORED , no changes !
2021-12-21 19:01:14.362 Deconz Plugins: (Deconz Plugins) onMessage called
2021-12-21 19:01:14.363 Deconz Plugins: (Deconz Plugins) ### WebSocket Data : {'e': 'changed', 'id': '11', 'r': 'sensors', 'state': {'lastupdated': '2021-12-21T18:01:14.303', 'on': False, 'temperature': 1950}, 't': 'event', 'uniqueid': '90:35:ea:ff:fe:6e:e7:70-01-0201'}
2021-12-21 19:01:14.364 Deconz Plugins: (Deconz Plugins) ### Update device (T° Salon) : {'nValue': 0, 'sValue': '19.5'}, IGNORED , no changes !
2021-12-21 19:01:15.072 Deconz Plugins: (Deconz Plugins) onHeartbeat called
Dans ce cas: Sur le device (celui de ce post), je clique sur Manuel/ program. Le 2 premiers essais il me semble qu il a basculé le thermostat,
PUis plus rien
2021-12-21 19:03:29.708 Status: User: Admin (IP: 192.168.0.2) initiated a switch command (24/Deconz Plugins - Thermostat 11/Set Level)
2021-12-21 19:03:37.854 Status: User: Admin (IP: 192.168.0.2) initiated a switch command (24/Deconz Plugins - Thermostat 11/Set Level)
2021-12-21 19:03:44.758 Status: User: Admin (IP: 192.168.0.2) initiated a switch command (24/Deconz Plugins - Thermostat 11/Set Level)
2021-12-21 19:03:53.665 Status: User: Admin (IP: 192.168.0.2) initiated a switch command (24/Deconz Plugins - Thermostat 11/Set Level)
2021-12-21 19:03:58.398 Deconz Plugins: (Deconz Plugins) Classic Data : [{'error': {'address': '/sensors/11/config/preset', 'description': 'Could not set attribute', 'type': 608}}]
2021-12-21 19:03:58.364 Status: User: Admin (IP: 192.168.0.2) initiated a switch command (24/Deconz Plugins - Thermostat 11/Set Level)
2021-12-21 19:03:58.398 Error: Deconz Plugins: (Deconz Plugins) deCONZ error :{'error': {'address': '/sensors/11/config/preset', 'description': 'Could not set attribute', 'type': 608}}
2021-12-21 19:04:02.305 Deconz Plugins: (Deconz Plugins) onCommand called for Unit 15: Parameter 'Set Level', Level: 80, Hue:
2021-12-21 19:04:02.306 Deconz Plugins: (Deconz Plugins) Send Command /api/91BCD782C8/sensors/11/config with {'preset': 'program'} (0 in buffer)
2021-12-21 19:04:02.306 Deconz Plugins: (Deconz Plugins) Making Request: http://127.0.0.1:80/api/91BCD782C8/sensors/11/config with params {'preset': 'program'}
2021-12-21 19:04:02.320 Deconz Plugins: (Deconz Plugins) Request Return: [{"success":{"/sensors/11/config/preset":"program"}}]
2021-12-21 19:04:02.320 Deconz Plugins: (Deconz Plugins) Classic Data : [{'success': {'/sensors/11/config/preset': 'program'}}]
2021-12-21 19:04:02.370 Deconz Plugins: (Deconz Plugins) onMessage called
2021-12-21 19:04:02.371 Deconz Plugins: (Deconz Plugins) ### WebSocket Data : {'config': {'heatsetpoint': 2000, 'locked': False, 'mode': 'heat', 'offset': 0, 'on': False, 'preset': 'program', 'reachable': True, 'schedule': {}, 'schedule_on': False, 'setvalve': False}, 'e': 'changed', 'id': '11', 'r': 'sensors', 't': 'event', 'uniqueid': '90:35:ea:ff:fe:6e:e7:70-01-0201'}
2021-12-21 19:04:02.371 Deconz Plugins: (Deconz Plugins) ### Update device (Reglage) : {'nValue': 0, 'sValue': '20.0'}, IGNORED , no changes !
2021-12-21 19:04:02.372 Deconz Plugins: (Deconz Plugins) ### Update device (Deconz Plugins - Thermostat 11) : {'nValue': 0, 'sValue': '10'}, IGNORED , no changes !
2021-12-21 19:04:02.372 Deconz Plugins: (Deconz Plugins) ### Update device (Deconz Plugins - Thermostat 11) : {'nValue': 80, 'sValue': '80'}
2021-12-21 19:04:02.392 Deconz Plugins: (Deconz Plugins) ### Update device (T° Salon) : {'nValue': 0, 'sValue': '20.0'}, IGNORED , no changes !
2021-12-21 19:04:02.265 Status: User: Admin (IP: 192.168.0.2) initiated a switch command (24/Deconz Plugins - Thermostat 11/Set Level)
2021-12-21 19:04:05.097 Deconz Plugins: (Deconz Plugins) onHeartbeat called
2021-12-21 19:04:08.153 Deconz Plugins: (Deconz Plugins) onCommand called for Unit 15: Parameter 'Set Level', Level: 20, Hue:
2021-12-21 19:04:08.154 Deconz Plugins: (Deconz Plugins) Send Command /api/91BCD782C8/sensors/11/config with {'preset': 'auto'} (0 in buffer)
2021-12-21 19:04:08.154 Deconz Plugins: (Deconz Plugins) Making Request: http://127.0.0.1:80/api/91BCD782C8/sensors/11/config with params {'preset': 'auto'}
2021-12-21 19:04:08.171 Deconz Plugins: (Deconz Plugins) Request Return: [{"success":{"/sensors/11/config/preset":"auto"}}]
2021-12-21 19:04:08.172 Deconz Plugins: (Deconz Plugins) Classic Data : [{'success': {'/sensors/11/config/preset': 'auto'}}]
2021-12-21 19:04:08.222 Deconz Plugins: (Deconz Plugins) onMessage called
2021-12-21 19:04:08.223 Deconz Plugins: (Deconz Plugins) ### WebSocket Data : {'config': {'heatsetpoint': 2000, 'locked': False, 'mode': 'heat', 'offset': 0, 'on': False, 'preset': 'auto', 'reachable': True, 'schedule': {}, 'schedule_on': False, 'setvalve': False}, 'e': 'changed', 'id': '11', 'r': 'sensors', 't': 'event', 'uniqueid': '90:35:ea:ff:fe:6e:e7:70-01-0201'}
2021-12-21 19:04:08.224 Deconz Plugins: (Deconz Plugins) ### Update device (Reglage) : {'nValue': 0, 'sValue': '20.0'}, IGNORED , no changes !
2021-12-21 19:04:08.225 Deconz Plugins: (Deconz Plugins) ### Update device (Deconz Plugins - Thermostat 11) : {'nValue': 0, 'sValue': '10'}, IGNORED , no changes !
2021-12-21 19:04:08.225 Deconz Plugins: (Deconz Plugins) ### Update device (Deconz Plugins - Thermostat 11) : {'nValue': 20, 'sValue': '20'}
2021-12-21 19:04:08.248 Deconz Plugins: (Deconz Plugins) ### Update device (T° Salon) : {'nValue': 0, 'sValue': '20.0'}, IGNORED , no changes !
2021-12-21 19:04:08.128 Status: User: Admin (IP: 192.168.0.2) initiated a switch command (24/Deconz Plugins - Thermostat 11/Set Level)
2021-12-21 19:04:10.402 Deconz Plugins: (Deconz Plugins) onMessage called
2021-12-21 19:04:10.404 Deconz Plugins: (Deconz Plugins) ### WebSocket Data : {'attr': {'id': '11', 'lastannounced': '2021-12-20T18:06:58Z', 'lastseen': '2021-12-21T18:04Z', 'manufacturername': '_TZE200_aoclfnxz', 'modelid': 'TS0601', 'name': 'Thermostat 11', 'productid': 'Tuya_THD BTH-002 Thermostat', 'swversion': None, 'type': 'ZHAThermostat', 'uniqueid': '90:35:ea:ff:fe:6e:e7:70-01-0201'}, 'e': 'changed', 'id': '11', 'r': 'sensors', 't': 'event', 'uniqueid': '90:35:ea:ff:fe:6e:e7:70-01-0201'}
2021-12-21 19:04:10.855 Deconz Plugins: (Deconz Plugins) onMessage called
2021-12-21 19:04:10.855 Deconz Plugins: (Deconz Plugins) ### WebSocket Data : {'config': {'heatsetpoint': 2300, 'locked': False, 'mode': 'heat', 'offset': 0, 'on': False, 'preset': 'auto', 'reachable': True, 'schedule': {}, 'schedule_on': False, 'setvalve': False}, 'e': 'changed', 'id': '11', 'r': 'sensors', 't': 'event', 'uniqueid': '90:35:ea:ff:fe:6e:e7:70-01-0201'}
2021-12-21 19:04:10.856 Deconz Plugins: (Deconz Plugins) ### Update device (Reglage) : {'nValue': 0, 'sValue': '23.0'}
2021-12-21 19:04:10.868 Deconz Plugins: (Deconz Plugins) ### Update device (Deconz Plugins - Thermostat 11) : {'nValue': 0, 'sValue': '10'}, IGNORED , no changes !
2021-12-21 19:04:10.868 Deconz Plugins: (Deconz Plugins) ### Update device (Deconz Plugins - Thermostat 11) : {'nValue': 20, 'sValue': '20'}
2021-12-21 19:04:10.879 Deconz Plugins: (Deconz Plugins) ### Update device (T° Salon) : {'nValue': 0, 'sValue': '20.0'}, IGNORED , no changes !
2021-12-21 19:04:10.879 Deconz Plugins: (Deconz Plugins) onMessage called
2021-12-21 19:04:10.880 Deconz Plugins: (Deconz Plugins) ### WebSocket Data : {'e': 'changed', 'id': '11', 'r': 'sensors', 'state': {'lastupdated': '2021-12-21T18:04:10.841', 'on': False, 'temperature': 2000}, 't': 'event', 'uniqueid': '90:35:ea:ff:fe:6e:e7:70-01-0201'}
2021-12-21 19:04:10.880 Deconz Plugins: (Deconz Plugins) ### Update device (T° Salon) : {'nValue': 0, 'sValue': '20.0'}, IGNORED , no changes !
2021-12-21 19:04:12.835 Deconz Plugins: (Deconz Plugins) onCommand called for Unit 15: Parameter 'Set Level', Level: 80, Hue:
2021-12-21 19:04:12.835 Deconz Plugins: (Deconz Plugins) Send Command /api/91BCD782C8/sensors/11/config with {'preset': 'program'} (0 in buffer)
2021-12-21 19:04:12.835 Deconz Plugins: (Deconz Plugins) Making Request: http://127.0.0.1:80/api/91BCD782C8/sensors/11/config with params {'preset': 'program'}
2021-12-21 19:04:12.858 Deconz Plugins: (Deconz Plugins) Request Return: [{"success":{"/sensors/11/config/preset":"program"}}]
2021-12-21 19:04:12.859 Deconz Plugins: (Deconz Plugins) Classic Data : [{'success': {'/sensors/11/config/preset': 'program'}}]
2021-12-21 19:04:12.909 Deconz Plugins: (Deconz Plugins) onMessage called
2021-12-21 19:04:12.910 Deconz Plugins: (Deconz Plugins) ### WebSocket Data : {'config': {'heatsetpoint': 2300, 'locked': False, 'mode': 'heat', 'offset': 0, 'on': False, 'preset': 'program', 'reachable': True, 'schedule': {}, 'schedule_on': False, 'setvalve': False}, 'e': 'changed', 'id': '11', 'r': 'sensors', 't': 'event', 'uniqueid': '90:35:ea:ff:fe:6e:e7:70-01-0201'}
2021-12-21 19:04:12.911 Deconz Plugins: (Deconz Plugins) ### Update device (Reglage) : {'nValue': 0, 'sValue': '23.0'}, IGNORED , no changes !
2021-12-21 19:04:12.911 Deconz Plugins: (Deconz Plugins) ### Update device (Deconz Plugins - Thermostat 11) : {'nValue': 0, 'sValue': '10'}, IGNORED , no changes !
2021-12-21 19:04:12.911 Deconz Plugins: (Deconz Plugins) ### Update device (Deconz Plugins - Thermostat 11) : {'nValue': 80, 'sValue': '80'}
2021-12-21 19:04:12.932 Deconz Plugins: (Deconz Plugins) ### Update device (T° Salon) : {'nValue': 0, 'sValue': '20.0'}, IGNORED , no changes !
2021-12-21 19:04:12.793 Status: User: Admin (IP: 192.168.0.2) initiated a switch command (24/Deconz Plugins - Thermostat 11/Set Level)
2021-12-21 19:04:13.132 Deconz Plugins: (Deconz Plugins) onMessage called
2021-12-21 19:04:13.133 Deconz Plugins: (Deconz Plugins) ### WebSocket Data : {'config': {'heatsetpoint': 2300, 'locked': False, 'mode': 'heat', 'offset': 0, 'on': False, 'preset': 'auto', 'reachable': True, 'schedule': {}, 'schedule_on': False, 'setvalve': False}, 'e': 'changed', 'id': '11', 'r': 'sensors', 't': 'event', 'uniqueid': '90:35:ea:ff:fe:6e:e7:70-01-0201'}
2021-12-21 19:04:13.134 Deconz Plugins: (Deconz Plugins) ### Update device (Reglage) : {'nValue': 0, 'sValue': '23.0'}, IGNORED , no changes !
2021-12-21 19:04:13.135 Deconz Plugins: (Deconz Plugins) ### Update device (Deconz Plugins - Thermostat 11) : {'nValue': 0, 'sValue': '10'}, IGNORED , no changes !
2021-12-21 19:04:13.135 Deconz Plugins: (Deconz Plugins) ### Update device (Deconz Plugins - Thermostat 11) : {'nValue': 20, 'sValue': '20'}
2021-12-21 19:04:13.152 Deconz Plugins: (Deconz Plugins) ### Update device (T° Salon) : {'nValue': 0, 'sValue': '20.0'}, IGNORED , no changes !
2021-12-21 19:04:15.056 Deconz Plugins: (Deconz Plugins) onHeartbeat called
2021-12-21 19:04:15.056 Deconz Plugins: (Deconz Plugins) onMessage called
2021-12-21 19:04:15.057 Deconz Plugins: (Deconz Plugins) ### WebSocket Data : {'attr': {'id': '1', 'lastannounced': None, 'lastseen': '2021-12-21T18:04Z', 'manufacturername': 'dresden elektronik', 'modelid': 'ConBee II', 'name': 'Configuration tool 1', 'swversion': '0x26660700', 'type': 'Configuration tool', 'uniqueid': '00:21:2e:ff:ff:07:b7:8b-01'}, 'e': 'changed', 'id': '1', 'r': 'lights', 't': 'event', 'uniqueid': '00:21:2e:ff:ff:07:b7:8b-01'}
2021-12-21 19:04:15.057 Deconz Plugins: (Deconz Plugins) Banned/Ignored device > 1 (lights)
2021-12-21 19:04:15.809 Deconz Plugins: (Deconz Plugins) onMessage called
2021-12-21 19:04:15.809 Deconz Plugins: (Deconz Plugins) ### WebSocket Data : {'config': {'heatsetpoint': 2000, 'locked': False, 'mode': 'heat', 'offset': 0, 'on': False, 'preset': 'auto', 'reachable': True, 'schedule': {}, 'schedule_on': False, 'setvalve': False}, 'e': 'changed', 'id': '11', 'r': 'sensors', 't': 'event', 'uniqueid': '90:35:ea:ff:fe:6e:e7:70-01-0201'}
2021-12-21 19:04:15.810 Deconz Plugins: (Deconz Plugins) ### Update device (Reglage) : {'nValue': 0, 'sValue': '20.0'}
2021-12-21 19:04:15.829 Deconz Plugins: (Deconz Plugins) ### Update device (Deconz Plugins - Thermostat 11) : {'nValue': 0, 'sValue': '10'}, IGNORED , no changes !
2021-12-21 19:04:15.829 Deconz Plugins: (Deconz Plugins) ### Update device (Deconz Plugins - Thermostat 11) : {'nValue': 20, 'sValue': '20'}
2021-12-21 19:04:15.850 Deconz Plugins: (Deconz Plugins) ### Update device (T° Salon) : {'nValue': 0, 'sValue': '20.0'}, IGNORED , no changes !
2021-12-21 19:04:15.851 Deconz Plugins: (Deconz Plugins) onMessage called
2021-12-21 19:04:15.851 Deconz Plugins: (Deconz Plugins) ### WebSocket Data : {'e': 'changed', 'id': '11', 'r': 'sensors', 'state': {'lastupdated': '2021-12-21T18:04:15.780', 'on': False, 'temperature': 2000}, 't': 'event', 'uniqueid': '90:35:ea:ff:fe:6e:e7:70-01-0201'}
2021-12-21 19:04:15.852 Deconz Plugins: (Deconz Plugins) ### Update device (T° Salon) : {'nValue': 0, 'sValue': '20.0'}, IGNORED , no changes !
2021-12-21 19:04:19.509 Deconz Plugins: (Deconz Plugins) onCommand called for Unit 15: Parameter 'Set Level', Level: 80, Hue:
2021-12-21 19:04:19.509 Deconz Plugins: (Deconz Plugins) Send Command /api/91BCD782C8/sensors/11/config with {'preset': 'program'} (0 in buffer)
2021-12-21 19:04:19.510 Deconz Plugins: (Deconz Plugins) Making Request: http://127.0.0.1:80/api/91BCD782C8/sensors/11/config with params {'preset': 'program'}
2021-12-21 19:04:19.524 Deconz Plugins: (Deconz Plugins) Request Return: [{"success":{"/sensors/11/config/preset":"program"}}]
2021-12-21 19:04:19.524 Deconz Plugins: (Deconz Plugins) Classic Data : [{'success': {'/sensors/11/config/preset': 'program'}}]
2021-12-21 19:04:19.525 Deconz Plugins: (Deconz Plugins) onMessage called
2021-12-21 19:04:19.525 Deconz Plugins: (Deconz Plugins) ### WebSocket Data : {'config': {'heatsetpoint': 2000, 'locked': False, 'mode': 'heat', 'offset': 0, 'on': False, 'preset': 'program', 'reachable': True, 'schedule': {}, 'schedule_on': False, 'setvalve': False}, 'e': 'changed', 'id': '11', 'r': 'sensors', 't': 'event', 'uniqueid': '90:35:ea:ff:fe:6e:e7:70-01-0201'}
2021-12-21 19:04:19.526 Deconz Plugins: (Deconz Plugins) ### Update device (Reglage) : {'nValue': 0, 'sValue': '20.0'}, IGNORED , no changes !
2021-12-21 19:04:19.526 Deconz Plugins: (Deconz Plugins) ### Update device (Deconz Plugins - Thermostat 11) : {'nValue': 0, 'sValue': '10'}, IGNORED , no changes !
2021-12-21 19:04:19.526 Deconz Plugins: (Deconz Plugins) ### Update device (Deconz Plugins - Thermostat 11) : {'nValue': 80, 'sValue': '80'}
2021-12-21 19:04:19.550 Deconz Plugins: (Deconz Plugins) ### Update device (T° Salon) : {'nValue': 0, 'sValue': '20.0'}, IGNORED , no changes !
2021-12-21 19:04:19.601 Deconz Plugins: (Deconz Plugins) onMessage called
2021-12-21 19:04:19.602 Deconz Plugins: (Deconz Plugins) ### WebSocket Data : {'config': {'heatsetpoint': 2000, 'locked': False, 'mode': 'heat', 'offset': 0, 'on': False, 'preset': 'auto', 'reachable': True, 'schedule': {}, 'schedule_on': False, 'setvalve': False}, 'e': 'changed', 'id': '11', 'r': 'sensors', 't': 'event', 'uniqueid': '90:35:ea:ff:fe:6e:e7:70-01-0201'}
2021-12-21 19:04:19.604 Deconz Plugins: (Deconz Plugins) ### Update device (Reglage) : {'nValue': 0, 'sValue': '20.0'}, IGNORED , no changes !
2021-12-21 19:04:19.605 Deconz Plugins: (Deconz Plugins) ### Update device (Deconz Plugins - Thermostat 11) : {'nValue': 0, 'sValue': '10'}, IGNORED , no changes !
2021-12-21 19:04:19.605 Deconz Plugins: (Deconz Plugins) ### Update device (Deconz Plugins - Thermostat 11) : {'nValue': 20, 'sValue': '20'}
2021-12-21 19:04:19.636 Deconz Plugins: (Deconz Plugins) ### Update device (T° Salon) : {'nValue': 0, 'sValue': '20.0'}, IGNORED , no changes !
2021-12-21 19:04:19.470 Status: User: Admin (IP: 192.168.0.2) initiated a switch command (24/Deconz Plugins - Thermostat 11/Set Level)
2021-12-21 19:04:24.497 Deconz Plugins: (Deconz Plugins) onCommand called for Unit 15: Parameter 'Set Level', Level: 80, Hue:
2021-12-21 19:04:24.497 Deconz Plugins: (Deconz Plugins) Send Command /api/91BCD782C8/sensors/11/config with {'preset': 'program'} (0 in buffer)
2021-12-21 19:04:24.497 Deconz Plugins: (Deconz Plugins) Making Request: http://127.0.0.1:80/api/91BCD782C8/sensors/11/config with params {'preset': 'program'}
2021-12-21 19:04:24.520 Deconz Plugins: (Deconz Plugins) Request Return: [{"success":{"/sensors/11/config/preset":"program"}}]
2021-12-21 19:04:24.520 Deconz Plugins: (Deconz Plugins) Classic Data : [{'success': {'/sensors/11/config/preset': 'program'}}]
2021-12-21 19:04:24.570 Deconz Plugins: (Deconz Plugins) onMessage called
2021-12-21 19:04:24.571 Deconz Plugins: (Deconz Plugins) ### WebSocket Data : {'config': {'heatsetpoint': 2000, 'locked': False, 'mode': 'heat', 'offset': 0, 'on': False, 'preset': 'program', 'reachable': True, 'schedule': {}, 'schedule_on': False, 'setvalve': False}, 'e': 'changed', 'id': '11', 'r': 'sensors', 't': 'event', 'uniqueid': '90:35:ea:ff:fe:6e:e7:70-01-0201'}
2021-12-21 19:04:24.572 Deconz Plugins: (Deconz Plugins) ### Update device (Reglage) : {'nValue': 0, 'sValue': '20.0'}, IGNORED , no changes !
2021-12-21 19:04:24.573 Deconz Plugins: (Deconz Plugins) ### Update device (Deconz Plugins - Thermostat 11) : {'nValue': 0, 'sValue': '10'}, IGNORED , no changes !
2021-12-21 19:04:24.573 Deconz Plugins: (Deconz Plugins) ### Update device (Deconz Plugins - Thermostat 11) : {'nValue': 80, 'sValue': '80'}
2021-12-21 19:04:24.600 Deconz Plugins: (Deconz Plugins) ### Update device (T° Salon) : {'nValue': 0, 'sValue': '20.0'}, IGNORED , no changes !
2021-12-21 19:04:24.495 Status: User: Admin (IP: 192.168.0.2) initiated a switch command (24/Deconz Plugins - Thermostat 11/Set Level)
2021-12-21 19:04:25.051 Deconz Plugins: (Deconz Plugins) onHeartbeat called
2021-12-21 19:04:25.653 Deconz Plugins: (Deconz Plugins) onMessage called
2021-12-21 19:04:25.654 Deconz Plugins: (Deconz Plugins) ### WebSocket Data : {'config': {'heatsetpoint': 2000, 'locked': False, 'mode': 'heat', 'offset': 0, 'on': False, 'preset': 'auto', 'reachable': True, 'schedule': {}, 'schedule_on': False, 'setvalve': False}, 'e': 'changed', 'id': '11', 'r': 'sensors', 't': 'event', 'uniqueid': '90:35:ea:ff:fe:6e:e7:70-01-0201'}
2021-12-21 19:04:25.655 Deconz Plugins: (Deconz Plugins) ### Update device (Reglage) : {'nValue': 0, 'sValue': '20.0'}, IGNORED , no changes !
2021-12-21 19:04:25.656 Deconz Plugins: (Deconz Plugins) ### Update device (Deconz Plugins - Thermostat 11) : {'nValue': 0, 'sValue': '10'}, IGNORED , no changes !
2021-12-21 19:04:25.656 Deconz Plugins: (Deconz Plugins) ### Update device (Deconz Plugins - Thermostat 11) : {'nValue': 20, 'sValue': '20'}
2021-12-21 19:04:25.679 Deconz Plugins: (Deconz Plugins) ### Update device (T° Salon) : {'nValue': 0, 'sValue': '20.0'}, IGNORED , no changes !
© 2012-2021 Domoticz | WWW: Domoticz.com
