Le plugin ZigBeeForDomoticZ et Wireguard
Jihem
Message par Jihem »
Bonjour à tous
De retour sur ce forum pour signaler que je rencontre un problème avec le VPN Wireguard.
Lorsque que celui-ci est actif, le plugin Zigbeefordomoticz ne démarre pas, la page web (127.0.0.1:9440) ne s'ouvre pas.
Domoticz affiche l'erreur: Error: zigbee hardware (2) thread seems to have ended unexpectedly
Si je désactive Wireguard, tout rentre dans l'ordre après un 'reboot'
les Logs de Domoticz
 2024-04-03 19:54:01.285 Status: Domoticz V2023.2 (c)2012-2023 GizMoCuz
2024-04-03 19:54:01.285 Status: Build Hash: 19efd039c, Date: 2023-07-21 17:23:44
2024-04-03 19:54:01.285 Status: Startup Path: /home/pi/domoticz/
2024-04-03 19:54:01.619 Status: PluginSystem: Started, Python version '3.9.2', 2 plugin definitions loaded.
2024-04-03 19:54:01.638 Status: WebServer(HTTP) started on address: :: with port 8080
2024-04-03 19:54:01.654 Status: WebServer(SSL) started on address: :: with port 443
2024-04-03 19:54:01.662 Status: TCPServer: shared server started...
2024-04-03 19:54:01.662 Status: RxQueue: queue worker started...
2024-04-03 19:54:03.663 zigbee: Worker thread started.
2024-04-03 19:54:03.663 Status: zigbee: Entering work loop.
2024-04-03 19:54:03.663 Status: zigbee: Started.
2024-04-03 19:54:03.663 Status: NotificationSystem: thread started...
2024-04-03 19:54:03.665 Status: EventSystem: reset all events...
2024-04-03 19:54:03.666 Status: EventSystem: reset all device statuses...
2024-04-03 19:54:03.866 Status: RF-Link: Using serial port: /dev/ttyACM0
2024-04-03 19:54:03.899 Status: Python EventSystem: Initializing event module.
2024-04-03 19:54:03.899 Status: EventSystem: Started
2024-04-03 19:54:03.900 Status: EventSystem: Queue thread started...
2024-04-03 19:54:03.902 Status: PluginSystem: 1 plugins started.
2024-04-03 19:54:04.785 Status: RF-Link: Controller Initialized!...
2024-04-03 19:54:05.022 Status: RF-Link: RFLink Detected, Version: 1.1 Revision: 41 Build: 3
2024-04-03 19:54:05.401 Status: zigbee: Initialized version 7.1, author 'pipiche38'
2024-04-03 19:54:05.421 Status: zigbee: Zigbee for Domoticz plugin starting
2024-04-03 19:54:05.421 Status: zigbee: Z4D plugin requires python3 3.8 or above and you are running 3.9
2024-04-03 19:54:05.421 Status: zigbee: Checking Python modules /home/pi/domoticz/plugins/Domoticz-Zigbee/requirements.txt
2024-04-03 19:54:06.245 zigbee: load PluginConf
2024-04-03 19:54:06.247 zigbee: Loading PluginConf - from Domoticz sqlite Db
2024-04-03 19:54:06.247 zigbee: /home/pi/domoticz/plugins/Domoticz-Zigbee/Conf/PluginConf-02.json timestamp is 1702982423.910328
2024-04-03 19:54:06.247 zigbee: Dz PluginConf is older than Json Dz: 0 Json: 1702982423.910328
2024-04-03 19:54:06.250 zigbee: Installing plugin custom page /home/pi/domoticz/www/templates/zigbee.html
2024-04-03 19:54:06.251 zigbee: Starting LoggingManagement thread
2024-04-03 19:54:06.252 zigbee: start_logging_thread
2024-04-03 19:54:06.253 zigbee: logging_thread - listening
2024-04-03 19:54:06.249 Status: zigbee: PluginAnalytics set to 1
2024-04-03 19:54:06.249 Status: zigbee: LegrandCompatibilityMode set to 1
2024-04-03 19:54:06.249 Status: zigbee: channel set to 11
2024-04-03 19:54:06.249 Status: zigbee: filename set to /home/pi/domoticz/plugins/Domoticz-Zigbee/Conf/PluginConf-02.json
2024-04-03 19:54:06.249 Status: zigbee: pluginHome set to /home/pi/domoticz/plugins/Domoticz-Zigbee
2024-04-03 19:54:06.249 Status: zigbee: homedirectory set to /home/pi/domoticz/plugins/Domoticz-Zigbee
2024-04-03 19:54:06.249 Status: zigbee: pluginData set to /home/pi/domoticz/plugins/Domoticz-Zigbee/Data
2024-04-03 19:54:06.249 Status: zigbee: pluginConfig set to /home/pi/domoticz/plugins/Domoticz-Zigbee/Conf
2024-04-03 19:54:06.249 Status: zigbee: pluginOTAFirmware set to /home/pi/domoticz/plugins/Domoticz-Zigbee/OTAFirmware
2024-04-03 19:54:06.249 Status: zigbee: pluginReports set to /home/pi/domoticz/plugins/Domoticz-Zigbee/Reports
2024-04-03 19:54:06.249 Status: zigbee: pluginWWW set to /home/pi/domoticz/plugins/Domoticz-Zigbee/www
2024-04-03 19:54:06.249 Status: zigbee: pluginLogs set to /home/pi/domoticz/plugins/Domoticz-Zigbee/Logs
2024-04-03 19:54:06.249 Status: zigbee: Input set to 1
2024-04-03 19:54:06.249 Status: zigbee: ZclClusters set to 1
2024-04-03 19:54:06.249 Status: zigbee: Legrand set to 1
2024-04-03 19:54:06.250 Status: zigbee: zclDecoder set to 1
2024-04-03 19:54:06.250 Status: zigbee: expJsonDatabase set to 0
2024-04-03 19:54:06.253 Status: zigbee: Please watch plugin log into /home/pi/domoticz/plugins/Domoticz-Zigbee/Logs/PluginZigbee_02.log
2024-04-03 19:54:06.267 Status: zigbee: Zigbee for Domoticz (z4d) plugin stable7-7.1.007 started
2024-04-03 19:54:06.272 Status: [web:8080] Incoming connection from: 127.0.0.1
2024-04-03 19:54:06.288 Status: zigbee: Loading ZCL Cluster definitions
2024-04-03 19:54:06.292 Status: zigbee: - ZCL Cluster 0000 - (V1) Basic loaded
2024-04-03 19:54:06.294 Status: zigbee: - ZCL Cluster 0001 - (V1) Power loaded
2024-04-03 19:54:06.295 Status: zigbee: - ZCL Cluster 0002 - (V1) Device Temperature Configuration loaded
2024-04-03 19:54:06.296 Status: zigbee: - ZCL Cluster 0003 - (V1) Identify loaded
2024-04-03 19:54:06.297 Status: zigbee: - ZCL Cluster 0004 - (V1) Groups loaded
2024-04-03 19:54:06.298 Status: zigbee: - ZCL Cluster 0005 - (V1) Scenes loaded
2024-04-03 19:54:06.299 Status: zigbee: - ZCL Cluster 0006 - (V1) On/Off loaded
2024-04-03 19:54:06.300 Status: zigbee: - ZCL Cluster 0007 - (V1) On/Off Switch Configuration loaded
2024-04-03 19:54:06.301 Status: zigbee: - ZCL Cluster 0008 - (V1) Level loaded
2024-04-03 19:54:06.302 Status: zigbee: - ZCL Cluster 0009 - (V1) Alarms loaded
2024-04-03 19:54:06.303 Status: zigbee: - ZCL Cluster 000a - (V1) Time loaded
2024-04-03 19:54:06.303 Status: zigbee: - ZCL Cluster 000d - (V1) Analog Output loaded
2024-04-03 19:54:06.305 Status: zigbee: - ZCL Cluster 000f - (V1) Binary Input loaded
2024-04-03 19:54:06.306 Status: zigbee: - ZCL Cluster 0013 - (V1) Multistate Output loaded
2024-04-03 19:54:06.308 Status: zigbee: - ZCL Cluster 0019 - (V1) OTA Upgrade loaded
2024-04-03 19:54:06.309 Status: zigbee: - ZCL Cluster 0020 - (V1) Poll Control loaded
2024-04-03 19:54:06.311 Status: zigbee: - ZCL Cluster 0102 - (V1) Window Covering loaded
2024-04-03 19:54:06.312 Status: zigbee: - ZCL Cluster 0202 - (V1) Fan Control loaded
2024-04-03 19:54:06.314 Status: zigbee: - ZCL Cluster 0204 - (V1) Thermostat User Interface Configuration loaded
2024-04-03 19:54:06.316 Status: zigbee: - ZCL Cluster 0300 - (V1) Color Control loaded
2024-04-03 19:54:06.317 Status: zigbee: - ZCL Cluster 0301 - (V1) Ballast Configuration loaded
2024-04-03 19:54:06.318 Status: zigbee: - ZCL Cluster 0400 - (V1) Illuminance Level Sensing loaded
2024-04-03 19:54:06.319 Status: zigbee: - ZCL Cluster 0402 - (V1) Temperature Measurement loaded
2024-04-03 19:54:06.321 Status: zigbee: - ZCL Cluster 0403 - (V1) Pressure Measurement loaded
2024-04-03 19:54:06.322 Status: zigbee: - ZCL Cluster 0405 - (V1) Relative Humidity Measurement loaded
2024-04-03 19:54:06.324 Status: zigbee: - ZCL Cluster 0406 - (V1) Occupancy Sensing loaded
2024-04-03 19:54:06.329 Status: zigbee: - ZCL Cluster 0700 - (V1) Price loaded
2024-04-03 19:54:06.331 Status: zigbee: - ZCL Cluster 0702 - (V1) Metering (Smart Energy) loaded
2024-04-03 19:54:06.333 Status: zigbee: - ZCL Cluster 0b01 - (V1) Meter Identification loaded
2024-04-03 19:54:06.336 Status: zigbee: - ZCL Cluster 0b04 - (V1) Electrical Measurement loaded
2024-04-03 19:54:06.338 Status: zigbee: - ZCL Cluster 0b05 - (V1) Diagnostics loaded
2024-04-03 19:54:06.339 Status: zigbee: - ZCL Cluster e000 - (V1) Tuya E000 Private Cluster loaded
2024-04-03 19:54:06.340 Status: zigbee: - ZCL Cluster e001 - (V1) Tuya E001 Private Cluster loaded
2024-04-03 19:54:06.342 Status: zigbee: - ZCL Cluster e002 - (V1) Tuya E002 Private Cluster loaded
2024-04-03 19:54:06.343 Status: zigbee: - ZCL Cluster fcc0 - (V1) LUMI Private Cluster loaded
2024-04-03 19:54:06.345 Status: zigbee: - ZCL Cluster ff66 - (V1) Lixee Zlinky private cluster loaded
2024-04-03 19:54:06.349 Status: zigbee: DeviceConf loaded - 16 confs loaded
2024-04-03 19:54:06.354 Status: zigbee: Local-Device conf loaded - 19 confs loaded
2024-04-03 19:54:06.949 Status: zigbee: 574 Certified devices loaded from z4d repository.
2024-04-03 19:54:06.954 Status: zigbee: load ListOfDevice
2024-04-03 19:54:08.310 Status: zigbee: 40 Entries loaded from /home/pi/domoticz/plugins/Domoticz-Zigbee/Data/DeviceList-2.txt
2024-04-03 19:54:08.502 Status: zigbee: Transport mode: PI
2024-04-03 19:54:08.730 Status: zigbee: Python version: ['3.9.2 (default, Mar 12 2021, 04:06:34) ', '[GCC 10.2.1 20210110]'] dist info: {'id': 'raspbian', 'version': '11', 'version_parts': {'major': '11', 'minor': '', 'build_number': ''}, 'like': 'debian', 'codename': 'bullseye'} linux_distribution: ['raspbian', '11', 'bullseye'] system: Linux machine: aarch64 platform: Linux-6.1.21-v8+-aarch64-with-glibc2.31 uname: uname_result(system='Linux', node='raspberrypi', release='6.1.21-v8+', version='#1642 SMP PREEMPT Mon Apr 3 17:24:16 BST 2023', machine='aarch64') version: #1642 SMP PREEMPT Mon Apr 3 17:24:16 BST 2023 mac_ver: ('', ('', '', ''), '')
2024-04-03 19:54:09.353 Status: zigbee: ZigateTransport: Serial Connection open: Serial<id=0xe9726e68, open=True>(port='/dev/ttyS0', baudrate=115200, bytesize=8, parity='N', stopbits=1, timeout=None, xonxoff=False, rtscts=False, dsrdtr=False)
2024-04-03 19:54:09.357 Status: zigbee: ZigateTransport: writer_thread Thread start.
2024-04-03 19:54:09.357 Status: zigbee: ZigateTransport: thread_processing_and_sending Thread start.
2024-04-03 19:54:09.358 Status: zigbee: Start Web Server connection
2024-04-03 19:54:09.381 Status: zigbee: Web backend for Web User Interface started on port: 9440
2024-04-03 19:54:09.382 Status: zigbee: Plugin looks to upgrade the Certified Device package
2024-04-03 19:55:11.993 Error: zigbee hardware (2) thread seems to have ended unexpectedly
2024-04-03 19:55:49.952 zigbee: UpdateDevice - (zigbee - Connected outlet_Power-000474000014f5d9-01) 5.0:5
2024-04-03 19:55:49.957 zigbee: UpdateDevice - (zigbee - Connected outlet_Meter-000474000014f5d9-01) 0:5.0;192.3446
[b][i]2024-04-03 19:55:54.002 Error: zigbee hardware (2) thread seems to have ended unexpectedly[/i][/b]
Avez-vous déjà rencontré ce problème?
Merci d'avance
Hard:Raspberry Pi4 + SSD Arduino Tablette murale Archos
Soft: Domoticz WireGuard vpn Homebridge Tradfri Ikea
Devices:[/colore]Rfxtrx433 DI-O Chacon Sonoff touch Anémomètre, pluviometre, sondes Orégon, capteurs humidité Miflora, téléinfo
pipiche
Re: Le plugin ZigBeeForDomoticZ et Wireguard
Message par pipiche »
est-ce que :
l'accès à l'API domoticz depuis localhost/127.0.0.1 est possible ?
peut-on avoir les logs du plugin ? ca serait plus pertinent
Wiki ici
chat sur Keybase.io
Jihem
Message par Jihem »
Bonjour Pipiche
Je pense que le problème vient de Wireguard.
J'utilise le client VPN de Wireguard, le serveur étant sur une boxe à l’extérieur; or quand il est activé, il n'y a plus d’accès internet et il semblerait que le plugin ai besoin d'un accès internet pour se lancer:
INFO    :b'Looking in indexes: https://pypi.org/simple, https://www.piwheels.org/simple'
En effet si je lance Domoticz avec Wireguard activé, le plugin plante.
Par contre si j'active Wireguard après le lancement de Domoticz tout fonctionne normalement.
Cet accès à internet est il indispensable?
Est-ce qu'il serait possible de télécharger ces fichiers pour les stocker dans le répertoire du plugin et de modifier la commande:
'Looking in indexes: http://home/pi/domoticz/plugin/Domoticz-Zigbee/simple,
Merci de ton aide
les logs du plugin avec Wireguard activé:
Wir-pb1.7z
(6.93 Kio) Téléchargé 70 fois
pipiche
si tu veux configurer le plugin sans accès Internet,
tu peux essayer de mettre le paramètre suivant
"internetAccess": 0
dans le fichier de configuration du plugin ( repertoire
Conf/PluginConf-xx.json
Attention à bien utiliser la syntax JSON
[EDIT], je pense par contre que cela ne va que éviter le check de la version du plugin. Après il y a un check au départ sur la version de la base des objets certifiés, ca risque d'etre compliqué ici, je verrais pour faire quelque chose sur la branche wip-develop
Wiki ici
chat sur Keybase.io
Jihem
Message par Jihem »
Merci Pipiche
Finalement j'ai contourné le problème en lançant Wireguard après Domoticz.
Modération
Si le sujet est terminé, merci de bien vouloir modifier le premier message de cette discussion pour indiquer [Résolu] dans le titre du sujet. Comment faire ? Voir le sujet [A lire avant de poster] Guide pour bien formuler une demande.
