[LUA] Horaires de marées
Je mets à disposition de la communauté ce petit script sans prétention.
Il permet d'afficher dans un capteur text le coefficient de marées ainsi que les horaires de pleine mer et basse mer.
local scriptName = 'maree'
local scriptVersion = '2.0'
--                                        Dummy à créer :
local textDeviceIdx = 133
local port = 122
return {
	active = false,
	logging = {
		level = domoticz.LOG_DEBUG, -- Uncomment to override the dzVents global logging setting
		marker = scriptName..' '..scriptVersion
	on = {
		timer = {'every 6 hours'},
		httpResponses = {
			scriptName,
		if item.isTimer then
			local url = "http://horloge.maree.frbateaux.net/ws"..port..".js"
			domoticz.log('Requesting data from maree.fr', domoticz.LOG_DEBUG)
			domoticz.openURL({url = url, method = 'GET', callback = scriptName}).afterSec(7)
		if not item.isHTTPResponse then return end
		local response = item
		if (not response.ok) or (response.trigger ~= scriptName) then
			domoticz.log('Last http response was not what expected. Trigger: '..response.trigger, domoticz.LOG_ERROR)
			domoticz.log(response.data, domoticz.LOG_ERROR)
			return
		if response.trigger == scriptName then
			local horaires = ""
			local coeff = ""
			domoticz.log('maree data has been received', domoticz.LOG_DEBUG)
			local contents = response.data
			--domoticz.log('data : '..contents, domoticz.LOG_DEBUG)
			for _,v in ipairs(response.lines) do
				--domoticz.log(v)
				if (string.find(tostring(v),"Coef")~= nil ) then
					domoticz.log ("coeff : "..v:sub(46):gsub(";",""))
					coeff = v:sub(46):gsub(";","")
				if (string.find(tostring(v),"marégramme")~= nil ) then
					domoticz.log ("horaires : "..v:sub(48,v:find("<div")-1):gsub("<b>",""):gsub("</b>",""):gsub("<br>"," "))
					horaires = v:sub(48,v:find("<div")-1):gsub("<b>",""):gsub("</b>",""):gsub("<br>"," ")
			domoticz.devices(textDeviceIdx).updateText('Coeff '..coeff.." "..horaires)
Pour trouver le numéro de votre port favoris, il faut aller sur maree.info, taper le nom du port (ou de la ville) et cliquer dessus.
L'URL de la page ouverte sera de type : http://maree.info/122
Vous avez deviné, 122 est le numéro à mettre après "port ="
Dernière modification par Neutrino le 26 juil. 2016, 19:07, modifié 1 fois.
deennoo
Re: Horaires de marées
Message par deennoo »
Bah voilà ! Liée a une webcam sur la nord de Bisca, je saurais si j'ai le temps d'aller profité du swell !
Grincheux
Message par Grincheux »
Merci pour le partage, je vais testé.
Je le verrais bien sur la custom page de Vil1driver.
oula85
Message par oula85 »
Bien vu voisin !!! Ca peut etre utile effectivement
Stef17
Message par Stef17 »
Ce serait sympas effectivement... mais les info s'affiche ou ??? j'ai mis le script dans home/pi/domoticz/script/lua/ sous le nom script_time_marees.lua ... j'ai essayé de le lancer via un interrupteur avec dans action on : script:///home/pi/domoticz/script/lua/script_time_marees.lua comme expliqué pour les débutants sur http://easydomoticz.com/domoticz-et-scripts-les-bases/ mais y a rien qui se passe !
RaspberryPi2B+SD16GPNYclass10-RFlink firm1.1R41-domoticz 5877-6 sonde temp + une prise domotisé et 4 adaptateurs chaicon pour radiateur
deennoo
c'est ecrit dans le script :
if (time.hour % 6 ==0 and time.min == 1) then
il s'execute une fois par jour a 6h du matin
est ce que tu as cree un dumy text ? reglages>>materiels>>dummy>>cree un capteur>>text
Ici on parle de scripts en LUA le langague natif dans domoticz donc :
http://easydomoticz.com/?s=lua
Bonne Lecture
En fait il s'exécute à 00:01, 06:01, 12:01 et 18:01 ;)
Stef17
Donc si j'ai bien compris je fait ça dans la partie événement en lua que j'appelle "script_time_marees" je suppose qu'il ajouteras tout seul l'extension... mais cela ne me dis pas comment l'afficher... j'ai bien créer un dumy text qui est maintenant dans "Mesure" que j'ai appelé "Maree" et qui affiche "hello world"... mais comment le script va s'y afficher ???
Eureka... en indiquant dans le script l'idx du dumy text ??? c'est bien cela ???
textDeviceIdx = L'idx du dumy que j'ai créé
Je suis vraiment nul en script et je ne penses pas être le seul ;-) j'avais impimé dans ma tete le numero du port mais quand on débute en prog sur un truc particulier comme domoticz... on ne sait pas ce que c'est l'idx...
C'est bien ça ! ;)
En fait Domoticz propose 2 manières de stocker les scripts LUA :
- Soit via l'interface Événements, les scripts sont alors stocker dans la BDD.
- soit en mettant des fichiers texte dans le répertoire /domoticz/scripts/lua/ .
Perso, je préfère les fichiers, plus facilement copiables, modifiables, "sauvegardables"...
Stef17
Donc j'aurais pu faire en mettant le script dans /domoticz/scripts/lua/
Moi aussi je préfère en fichier brut... c'est plus dans mon esprit ;-)
Pour les sauvegardes, existe t il une façon simple sur raspberry pour copier ce genre de fichier sur partage réseau (synology) ?
