[Tuto] Charger ESPEasy dans votre ESP8266
Re: [Tuto] Charger ESPEasy dans votre ESP8266
@doume, peux tu nous mettre une photo de ta wemos stp ?
ci-joint image du site d'achat
NodeMCU Lua ESP8266 ESP-12 WeMos D1 Mini WIFI Développement Board Module TE441
Features:
D1 mini, it is a mini NodeMcu Lua WiFi board based on ESP-8266EX.
11 digital input/output pins, all pins have interrupt/pwm/I2C/one-wire.
ESP8266 has I/O Pin.
No need to download restting.
A great set of tools to develop ESP8266.
Specifications:
supported(except D0)
1 analog input(3.3V max input)
A Micro USB connection
Dimension: 25.6mm x 34.2mm
How to get started in Arduino:
Setup driver:
Before you use miniD1 boards, you need setup CH340g driver.
Python:
On Windows you need install Python 2.7.10.
On Linux & MAC OSX, you don't need install it, comes preinstalled with OS.
Installing Hardware package:
There is two ways to install hardware package, Boards Manager or GIT
Installing with Boards Manager:
Starting with 1.6.4, Arduino allows installation of third-party platform packages using Boards Manager. We have packages available for Windows, Mac OS, and Linux (32 and 64 bit).
1.Install Arduino 1.6.7 from the Arduino website.
2.Start Arduino and open Preferences window.
3.Enter http://arduino.esp8266.com/stable/packa ... index.json into Additional Boards Manager URLs field. You can add multiple URLs, separating them with commas.
4.Open Tools→Board:xxx→Boards Manager and install esp8266 by ESP8266
Community (and don't forget to select your ESP8266 board from Tools > Board menu after installation).
Installing with GIT (Recommend):
We recommend using GIT to install Hardware package,you can always get the latest version of it.
Package includes:
1x Mini NodeMCU Lua Wifi Wireless Module
Features:
Specifications:
Setup driver:
Python:
Package includes:
- Pièces jointes
- TE441-E-10-4.jpg (593.6 Kio) Consulté 9103 fois
Dernière modification par Doume le 28 janv. 2017, 22:36, modifié 1 fois.
Tu as recu la meme ou celle-ci ?
J'ai rajouté les specs avec mes photos
C'est bien celle de ma photo que j'ai reçue.
J'en ai d'autres en commande, dont une décrite comme le modèle D1 mini Pro (avec prise d'antenne externe), telle que tu l'as affichée.
Je pense que la source de mes problèmes, c'est le circuit USB-Serial dont elle est équipée ( CH341 ) : Pas trouvé de drivers vraiment capables de le gérer !
Ces drivers ne semblent pas capables de gérer la parité, or la carte la génère , et du coup le PC et la carte ne savent pas se parler !
La mini pro est super mais attention debut janvier sa memoire n'etait pas gerer que 4mo sur le 16 dispo.
Tes pilotes : http://www.wch.cn/download/CH341SER_ZIP.html
J'essaierai ce 'nouveau' pilote demain, là je suis cuit !
J'avoue que je pratique pas trop le Chinois, mais on verra !
Le plus important c'est "download" le reste c'est du classique,
Dézipper puis installer
Bon, ben les drivers pointés hier soir ne donnent rien de plus...
Hier, j'ai contacté le vendeur de cette Wemos : Voici leur réponse :
Faut reconnaitre que leur réaction est irréprochable : Et Paypal vient de me notifier que le remboursement avait été initié !
Maintenant, me reste à attendre les 3 exemplaires arrivant de Chine, et voir si j'aurai plus de chance.
Merci pour les tentatives d'aide.
Dear customer,
Warm greetings from Welsky Technologies and thank you very much for choosing our item.
From your description, our team think there might be something wrong with that unit.
Please be reassured, we will issue you the refund with no need to return the item. Is that acceptable to you?
Sorry for the inconvenience and looking forward to hearing from you.
With best regards,
Welsky Technology Limited
Julie
Customer Service
J'ai reçu depuis 3 modules (qui fonctionnent) :
- Le 1er est un module 'Pro', équipé de 16 MB de flash : son FTDI est un CP2104
- Les 2 suivants sont des D1 mini : L'un a un FTDI de type HL-340, l'autre un CH-341, et pourtant, même provenance , même expéditeur, même référence !
Ca semble être une loterie !
Je viens d'uploader esp easy dans un esp-01 mais impossible de voir le réseau wifi.
J'ai lu au mieux les réponses sur ce post, j'ai bien essayé d'uploader un sketch sur la carte, sans problème, je renvoi le firmware esp easy mais rien à faire. Testé sur deux cartes.
si quelqu'un avait une piste ...
Cordialement.
Cordialement.
