[Tuto] Consomation d'eau ajout simple dans DomoticZ
Re: [TUTO] Consomation d'eau ajout dans domoticz - SDEI
Merci je vais tester de suite!!!
Bon toujours pas mieux... toujours cette foutue erreur arithmetic.
J'ai donc repris mon fichier 2015-08.dat modifié manuellement pour voir ce que ca donne.
Ca bloque a l'etape 4.... J'ai ceci:
- PART 4 Update the db
File size is NOT zero -> DB update needed
Stoping Domoticz !
Domoticz stopped
Update DB START
Update Values
Error: near line 1: attempt to write a readonly database
Error: near line 2: attempt to write a readonly database
Error: near line 3: attempt to write a readonly database
Error: near line 4: attempt to write a readonly database
Error: near line 5: attempt to write a readonly database
Error: near line 6: attempt to write a readonly database
Error: near line 7: attempt to write a readonly database
Update Status
Update DB END
Starting Domoticz !
2015-08-11 20:03:46.034 Domoticz V2.2713 (c)2012-2015 GizMoCuz
2015-08-11 20:03:46.035 System: Raspberry Pi
2015-08-11 20:03:46.037 Startup Path: /home/pi/domoticz/
domoticz: Domoticz is starting up....
EDIT: Bon ce soucis est réglé, probleme de droit sur le fichier DB mais le compteur est toujours a zero.....
Requetes sql obtenues:
- PART 3 Generate SQL
DELETE FROM `Meter_Calendar` WHERE devicerowid=68 and date = '2015-08-01'; INSERT INTO `Meter_Calendar` VALUES ('68', (100*18 5), '468.902', '2015-08-01' );
DELETE FROM `Meter_Calendar` WHERE devicerowid=68 and date = '2015-08-02'; INSERT INTO `Meter_Calendar` VALUES ('68', (100*34 4), '469.246', '2015-08-02' );
DELETE FROM `Meter_Calendar` WHERE devicerowid=68 and date = '2015-08-03'; INSERT INTO `Meter_Calendar` VALUES ('68', (100*44 5), '469.691', '2015-08-03' );
DELETE FROM `Meter_Calendar` WHERE devicerowid=68 and date = '2015-08-04'; INSERT INTO `Meter_Calendar` VALUES ('68', (100*58 1), '470.271', '2015-08-04' );
DELETE FROM `Meter_Calendar` WHERE devicerowid=68 and date = '2015-08-05'; INSERT INTO `Meter_Calendar` VALUES ('68', (100*43 3), '470.704', '2015-08-05' );
DELETE FROM `Meter_Calendar` WHERE devicerowid=68 and date = '2015-08-06'; INSERT INTO `Meter_Calendar` VALUES ('68', (100*50 8), '471.212', '2015-08-06' );
DELETE FROM `Meter_Calendar` WHERE devicerowid=68 and date = '2015-08-07'; INSERT INTO `Meter_Calendar` VALUES ('68', (100*41 6), '471.628', '2015-08-07' );
update DeviceStatus set lastupdate = '2015-08-07 22:22:38' where id = 68;
Heu le saut de ligne entre 18 et 5 est pas normal. Tu es sur qu'il est bien en format unix?
Si tu veux utiliser ton fichier .dat il faut enlever le 100 * dans la requette. Le reste semble ok.
Si te veux juste tester le requete tu peux faire:
sqlite3 /home/pi/doloticz/doloticz.db
Puis tu tapes ta requeete sql...
Tu as aussi sqlite3browther que est plus convivial pour pc. Il te suffit juste a recupere ta db sur ton pc (voa sauvegarde par ex)... Ca te permetra de debuger tes requettes sql.
Raspberry B+ & PI2 / Domoticz / RFXtrx433E / multiple homemade devices
My blog/tutos for domoticz / electronics stuff : domotique.web2diz.net
Re: [compteur d'eau ajout dans domoticz - SDEI
Bon après un reboot de tout le "tointoin"....j'obtiens ceci....
Ceci avec mon fichier modifié
Et dans Domoicz....
root@raspberrypi:/home/pi# /home/pi/SDEI/updateConsoEau.sh
/home/pi/SDEI/updateConsoEau.sh[18]: [: argument expected
- PART 1 Get the data from SDEI for 2015-08
/home/pi/SDEI/2015-08.dat generated
rm: impossible de supprimer « /home/pi/SDEI/cookiefile »: Aucun fichier ou dossier de ce type
- PART 2 Update .dat file
/home/pi/SDEI/2015-08.dat Updated
DELETE FROM `Meter_Calendar` WHERE devicerowid=69 and date = '2015-08-01'; INSERT INTO `Meter_Calendar` VALUES ('69', (100*185), '468.902', '2015-08-01' );
DELETE FROM `Meter_Calendar` WHERE devicerowid=69 and date = '2015-08-02'; INSERT INTO `Meter_Calendar` VALUES ('69', (100*344), '469.246', '2015-08-02' );
DELETE FROM `Meter_Calendar` WHERE devicerowid=69 and date = '2015-08-03'; INSERT INTO `Meter_Calendar` VALUES ('69', (100*445), '469.691', '2015-08-03' );
DELETE FROM `Meter_Calendar` WHERE devicerowid=69 and date = '2015-08-04'; INSERT INTO `Meter_Calendar` VALUES ('69', (100*581), '470.271', '2015-08-04' );
DELETE FROM `Meter_Calendar` WHERE devicerowid=69 and date = '2015-08-05'; INSERT INTO `Meter_Calendar` VALUES ('69', (100*433), '470.704', '2015-08-05' );
DELETE FROM `Meter_Calendar` WHERE devicerowid=69 and date = '2015-08-06'; INSERT INTO `Meter_Calendar` VALUES ('69', (100*508), '471.212', '2015-08-06' );
DELETE FROM `Meter_Calendar` WHERE devicerowid=69 and date = '2015-08-07'; INSERT INTO `Meter_Calendar` VALUES ('69', (100*416), '471.628', '2015-08-07' );
update DeviceStatus set lastupdate = '2015-08-07 00:02:20' where id = 69;
Stoping Domoticz !
Domoticz stopped
Update DB START
Update Values
Update Status
Update DB END
Starting Domoticz !
2015-08-12 00:02:25.600 Domoticz V2.2713 (c)2012-2015 GizMoCuz
2015-08-12 00:02:25.601 System: Raspberry Pi
2015-08-12 00:02:25.602 Startup Path: /home/pi/domoticz/
Domoticz started
### END ###
Et dans Domoicz....
- Pièces jointes
- compteur.png (166.66 Kio) Consulté 8768 fois
Enfin j'espere...
Cool !
Je pense que tu devrair yrnymter un update...
sudo apt-get update
sudo apt-get upgrade
sudo apt-get update
J'ai fait mise à jour comme demandé , mais en faisant tourné normalement toujours cette erreur aritmethic 0.185.
J'ai un peu bidouillé le code en ajoutant ceci:
Dans la partie : PART 2 set the file to be usable apres la ligne 76
Du coup mon 0.185 se transforme en 0185 et plus d'erreur arithmetic.....
Mais se serait trop facile.....car dans mon fichier .dat au lieu d'obtenir ceci:
J'obtiens cela:
Probleme de mise en forme sous forme de tableau....et la date déconne....
En fait faudrait que je puisse adapter ma formule juste sur la deuxieme colonne.....je cherche je cherche mais suis qu'un pauvre débutant alors pas évident...
sed -e 's/0./0/g' file3 > file4Du coup mon 0.185 se transforme en 0185 et plus d'erreur arithmetic.....
01/08/2015,185,468.902
02/08/2015,344,469.246
03/08/2015,445,469.691
04/08/2015,581,470.271
05/08/2015,433,470.704
06/08/2015,508,471.212
07/08/2015,416,471.628Code : Tout sélectionner
[[0/0/205,0185,468.90],[0/0/205,0344,469.246],[0/0/205,0445,469.691],[0/0/205,0581,470271],[0/0/205,0433,47070],[0/0/205,050,471.212],[0/0/205,0416,471.628],[0/0/205,04,472.08],[0/0/205,0314,472.3$En fait faudrait que je puisse adapter ma formule juste sur la deuxieme colonne.....je cherche je cherche mais suis qu'un pauvre débutant alors pas évident...
oui en modifiant les sed tu devrais arriver a tes fins !
pour t'aider tu peux supprimer la ligne :
qui supprime les fichier intermédiaires
Pour travailler que sur val (premiere valeur du fichier apres mise ne format ) tu peux remplacer :
par :
ca va pas marcher si tu consomme plus de 1m3... mais ce reste pas trop mal .. .
sed -e 's/\\//g' $export_file > file1 # supprime les "\" et les remplace par rien
sed -e 's/\],\[/\n/g' file1 > file2 # supprime les "],[" et remplace par des saut de ligne
sed -e 's/\[\[/\n/g' file2 > file3 # supprime les "[[" et remplace par des saut de ligne
sed -e 's/\"//g' file3 |grep -v ",0,0" |grep -e '^$' -v |grep -v ERR > $export_file
# supprime les " , les ",0,0"
# supprime les lignes d'erreur si il y en a (ex : pbl de connection)Code : Tout sélectionner
rm file1 file2 file3 Pour travailler que sur val (premiere valeur du fichier apres mise ne format ) tu peux remplacer :
val1=$(( $val * 100))Code : Tout sélectionner
val1=`echo $val | sed -e 's/0\.//g'`Raspberry B+ & PI2 / Domoticz / RFXtrx433E / multiple homemade devices
Merci!!
Je lance mes test!!!
EDIT:
Bon pour l'instant rien de neuf...choux blanc toujours la meme erreur arthmetic......
Dans le fichier .dat il faut que j'arrive a supprimer "0." par "0" et après ca roulera mieux....
EDIT:
