[Tuto] Aspirateur Xiaomi V1 choisir la pièce a aspirer
Johann
Re: Aspirateur Xiaomi V1 choisir la pièce a aspirer
Message par Johann »
axel2906 a écrit : 05 févr. 2019, 21:57
Johann a écrit : 05 févr. 2019, 21:17
axel2906 a écrit : 03 févr. 2019, 12:28
ah ben chez moi en tout cas cela fonctionne avec zoned-clean :roll: ;)
Ha bizarre moi j'ai ça :shock:
Commands:
  carpet_mode       Query or set the carpet mode.
  cleaning_history  Query the cleaning history.
  configure_wifi    Configure the wifi settings.
  consumables       Return consumables status.
  discover          Search for robots in the network.
  dnd               Query and adjust do-not-disturb mode.
  fanspeed          Query and adjust the fan speed.
  find              Find the robot.
  goto              Go to specific target.
  home              Return home.
  info              Return device information.
  install_sound     Install a sound.
  manual            Control the robot manually.
  map               Return the map token.
  pause             Pause cleaning.
  raw_command       Run a raw command.
  reset_consumable  Reset consumable state.
  serial_number     Query serial number.
  sound             Query and change sound settings.
  spot              Start spot cleaning.
  start             Start cleaning.
  status            Returns the state information.
  stop              Stop cleaning.
  timer             List and modify existing timers.
  timezone          Query or set the timezone.
  update_firmware   Update device firmware.
  update_status     Return update state and progress.
  zoned_clean       Clean zone.
Est-ce que tu peux me donner les requêtes que tu utilises pour google home stp, car je galère avec ifft :lol:
tu as quelle version de mirobo ? chez moi c'est la 0.4.4
pi@raspberrypi:~ $ mirobo --version
mirobo, version 0.4.4
pi@raspberrypi:~ $ mirobo --help
Usage: mirobo [OPTIONS] COMMAND [ARGS]...
  A tool to command Xiaomi Vacuum robot.
Options:
  --ip TEXT
  --token TEXT
  -d, --debug
  --id-file FILE
  --version       Show the version and exit.
  --help          Show this message and exit.
Commands:
  carpet-mode       Query or set the carpet mode.
  cleaning-history  Query the cleaning history.
  configure-wifi    Configure the wifi settings.
  home              Return home.
  install-sound     Install a sound.
  raw-command       Run a raw command.
  reset-consumable  Reset consumable state.
  serial-number     Query serial number.
  stop              Stop cleaning.
  update-firmware   Update device firmware.
  update-status     Return update state and progress.
  zoned-clean       Clean zone.
sinon pour ifttt pas de soucis !
If : google assistant
than : webhook
voila un exemple :
http://tonipdomoticz:7070/json.htm?type ... n_password
pour la partie "username" et "password" j'utilise ce site pour encoder les 2
https://codebeautify.org/base64-encode
en gros le "Set%20Level" reste toujours le meme
le "level=XX" est le numero du niveau du sélecteur (ici dans mon exemple c'est le 10 donc "Bureau")
pour le moment j'ai fais pour chaque piece une requete. Il doit avoir un moyen pour faire une seule requete en IFTT pour toutes les pièces mais j'ai pas encore planché dessus
J'ai pourtant la même version. :shock:
Merci pour les commandes iftt, je vais essayer ça
foudepc83
Message par foudepc83 »
axel2906 a écrit : 05 févr. 2019, 16:45
foudepc83 a écrit : 05 févr. 2019, 15:11 Bonjour,
Bravo pour ce tutoriel.
l'application Floleval ne fonctionne pas , je ne peux même pas récupérer le statue, j'ai un message d'erreur.
Avez vous une idée ?
dans les paramètres, as-tu bien mis sur le bon servuer ? (j'ai eu le coup la 1ere fois)
Oui,
J'ai essayé avec Bluestack , cela fonctionne mais je n'ai pas réussi a faite un copier coller. J'ai déja tenté de reinstaller l'application mais rien
axel2906
Message par axel2906 »
foudepc83 a écrit : 06 févr. 2019, 17:36
Oui,
dans bluestack, va dans historique de Flolevac choisi la dernier historique où il a aspiré completement. selectionne la zone que tu veux nettoyer. Ensuite reste appuyer sur "nettoyage" et il devrait avoir "copié dans le presse-papiers". Ensuite sur ton pc tu ouvre notepad par exemple et tu fais coller
Wolfen38
Message par Wolfen38 »
J'ai un soucis avec flolevac.... ca ne trouve pas mon aspi.
Est ce qu'il se sert des info sur les serveurs de xiaomi ou ceux du tel ?
Car j'ai 2 mihome d'installer sur mon tel, un 1er normalement, en serveur chine car toute ma domotique dessus. Et un autre en passant par parallel space celui la sous serveur singapore pour controler l'aspi.
Ca peut venir de c le problème ?
axel2906
Wolfen38 a écrit : 16 févr. 2019, 17:41 J'ai un soucis avec flolevac.... ca ne trouve pas mon aspi.
logiquement dans les parametres de flolevac tu peux choisir le serveur.
Wolfen38
Re: RE: Re: Aspirateur Xiaomi V1 choisir la pièce a aspirer
Oui j'ai essayé singapore car mon aspi est dessus mais il le trouve pas et sur serveur Chine comme ma domotique rien non plus
axel2906
Wolfen38 a écrit : 21 févr. 2019, 17:28
ce que tu peux encore essayer, tu vas dans les parametres de FloleVac et là tu as "Effacer toutes les donnée". Il va quitter l'app et quand tu l'ouvres a nouveau essaie de te connecter avec ton compte xiaomi en choisissant le bon serveur (singapoure dans ton cas)
Wolfen38
Pas mieux.
Et tu sais comment fonctionne la méthode manuelle ? Ca demande un DID, c'est quoi ?
axel2906
Wolfen38 a écrit : 27 févr. 2019, 12:30 Pas mieux.
le DID est l'ID du robot en lui meme. Pour l'obtenir il faut d'abord rooter le robot et te connecter dessus puis aller dans le fichier /mnt/default/device.conf pour avoir son ID
sinon essaie en passant via BlueStacks et tu installes Flolevac la dessus pour voir si cela aide
axel2906
axel2906 a écrit : 27 févr. 2019, 12:56
on peut retrouver l'ID pour ca il faut que tu installes npm
sudo apt-get install npm
ensuite faut installer miio
sudo npm install -g miio
dès que c'est fait suffit de taper
miio discover
et tu auras un truc dans le style :
et la ensuite tu peux tenter avec Flolevac la config manuelle
