Error: (ZiGate) processConfigureReporting - not status for that device ffff !!!
LaurentSan
Message par LaurentSan »
Je tente de configurer des équipements Xiaomi sur un raspberry/domoticz et obtiens les messages comme celui du sujet. Quelqu'un peut il m'aiguiller ?
Voici la log.
Merci !
2019-05-30 22:47:09.137 Status: Domoticz V4.10717 (c)2012-2019 GizMoCuz
2019-05-30 22:47:09.142 Status: Build Hash: b38b49e5, Date: 2019-05-09 13:04:08
2019-05-30 22:47:09.143 Status: Startup Path: /home/pi/domoticz/
2019-05-30 22:47:10.195 Active notification Subsystems: gcm, http (2/13)
2019-05-30 22:47:10.232 Starting shared server on: :::6144
2019-05-30 22:47:10.154 Status: PluginSystem: Started, Python version '3.5.3'.
2019-05-30 22:47:10.201 Status: WebServer(HTTP) started on address: :: with port 8080
2019-05-30 22:47:10.220 Status: WebServer(SSL) started on address: :: with port 443
2019-05-30 22:47:10.235 Status: TCPServer: shared server started...
2019-05-30 22:47:10.236 Status: RxQueue: queue worker started...
2019-05-30 22:47:12.245 Status: EventSystem: reset all events...
2019-05-30 22:47:12.247 Status: EventSystem: reset all device statuses...
2019-05-30 22:47:12.435 Status: PluginSystem: Entering work loop.
2019-05-30 22:47:12.874 Status: Python EventSystem: Initalizing event module.
2019-05-30 22:47:12.877 Status: EventSystem: Queue thread started...
2019-05-30 22:47:12.877 Status: EventSystem: Started
2019-05-30 22:47:24.433 Status: Incoming Domoticz connection from: 192.168.0.51
2019-05-30 22:48:11.897 Status: (ZiGate) Started.
2019-05-30 22:48:16.053 (ZiGate) Debug: 0
2019-05-30 22:48:16.301 (ZiGate) Configure Permit To Join
2019-05-30 22:48:16.301 (ZiGate) Request discovery mode for 254 seconds
2019-05-30 22:48:16.043 Status: (ZiGate) Initialized version 4.3.0, author 'zaraki673 pipiche38'
2019-05-30 22:48:16.044 Status: (ZiGate) Entering work loop.
2019-05-30 22:48:16.052 Status: (ZiGate) Zigate plugin 4.3.0 started
2019-05-30 22:48:16.053 Status: (ZiGate) Python Version - 3.5.3 (default, Sep 27 2018, 17:25:39)
2019-05-30 22:48:16.053 [GCC 6.3.0 20170516]
2019-05-30 22:48:16.053 Status: (ZiGate) Switching Heartbeat to 5 s interval
2019-05-30 22:48:16.053 Status: (ZiGate) DomoticzVersion: 4.10717
2019-05-30 22:48:16.054 Status: (ZiGate) DomoticzHash: b38b49e5
2019-05-30 22:48:16.054 Status: (ZiGate) DomoticzBuildTime: 2019-05-09 13:04:08
2019-05-30 22:48:16.186 Status: (ZiGate) Opening DomoticzDB in raw
2019-05-30 22:48:16.189 Status: (ZiGate) load PluginConf
2019-05-30 22:48:16.191 Status: (ZiGate) PluginConf: /home/pi/domoticz/plugins/Domoticz-Zigate/Conf/PluginConf.txt
2019-05-30 22:48:16.195 Status: (ZiGate) -vibrationAqarasensitivity: medium
2019-05-30 22:48:16.195 Status: (ZiGate) -enablegroupmanagement: 0
2019-05-30 22:48:16.196 Status: (ZiGate) -resetMotiondelay: 30
2019-05-30 22:48:16.196 Status: (ZiGate) -logFORMAT: 0
2019-05-30 22:48:16.196 Status: (ZiGate) -logLQI: 0
2019-05-30 22:48:16.197 Status: (ZiGate) -channel: ['11', '15', '19', '20', '25', '26']
2019-05-30 22:48:16.218 Status: (ZiGate) Plugin Database: DeviceList-2.txt
2019-05-30 22:48:16.289 Status: (ZiGate) DeviceConf loaded
2019-05-30 22:48:16.289 Status: (ZiGate) load ListOfDevice
2019-05-30 22:48:16.291 Status: (ZiGate) Connection Name: Zigate, Transport: Serial, Address: /dev/ttyUSB0
2019-05-30 22:48:16.413 Status: (ZiGate) Major Version Num: 0003
2019-05-30 22:48:16.414 Status: (ZiGate) Installer Version Number: 030f
2019-05-30 22:48:16.627 Status: (ZiGate) Permit Join: Off
2019-05-30 22:48:16.752 Status: (ZiGate) Zigate addresses ieee: 00158d0001ee02c2 , short addr: ffff
2019-05-30 22:48:16.752 Status: (ZiGate) Network state UP, PANID: 05c6 extPANID: 0x0000000000000000 Channel: 11
2019-05-30 22:48:16.869 Status: (ZiGate) Number of devices recently active in Zigate = 0
2019-05-30 22:48:26.094 Status: (ZiGate) Plugin with Zigate firmware 030f correctly initialized
2019-05-30 22:49:21.077 Error: (ZiGate) processConfigureReporting - not status for that device ffff !!!
2019-05-30 22:49:28.036 Status: EventSystem: reset all device statuses...
2019-05-30 22:49:31.145 Status: EventSystem: reset all device statuses...
2019-05-30 22:50:21.129 Error: (ZiGate) processConfigureReporting - not status for that device ffff !!!
2019-05-30 22:51:21.137 Error: (ZiGate) processConfigureReporting - not status for that device ffff !!!
2019-05-30 22:52:21.128 Error: (ZiGate) processConfigureReporting - not status for that device ffff !!!
2019-05-30 22:53:21.145 Error: (ZiGate) processConfigureReporting - not status for that device ffff !!!
2019-05-30 22:54:21.153 Error: (ZiGate) processConfigureReporting - not status for that device ffff !!!
pipiche
Re: Error: (ZiGate) processConfigureReporting - not status for that device ffff !!!
Message par pipiche »
A priori il semble que la Zigate soit mal initialisée.
Peux-tu relancer le plugin en mettant le flag ErasePDM à True cela va effacer la Zigate - mais a priori tu n'as encore pu ajouter aucun device -
LaurentSan
Bonjour Pipiche,
Je suis allé dans le menu d'administration de Domoticz et ai passé le flag "Erase Persistent Data ( !!! full devices setup need !!! )" à True comme suggéré et mes équipements Xiaomi ont été reconnus.
Bref, ça fonctionne maintenant :D
Ce flag est désormais repassé à False.
Merci !
pipiche
[résolu] Re: Error: (ZiGate) processConfigureReporting - not status for that device ffff !!!
LaurentSan a écrit : 31 mai 2019, 16:10 Bonjour Pipiche,
Merci !
Super. Oui, laisse le flag à False, car il efface l'ensemble des données sur la Zigate .....
Amuses-toi bien ;-)
Wiki ici
chat sur Keybase.io
Tonio16
Message par Tonio16 »
Bonsoir
J'ai reçu des détecteurs d'ouverture de porte aqara. Ce seront mes premiers devices pour ma Zitate et je suis donc novice complet en Zigbee.
Ce soir, j'essaye d'apairer un des détecteurs d'ouverture mais j'ai beau faire, appuyer trois secondes, avoir le Clignotement, aucun nouveau device dans Domoticz.
Je vois rien dans le log. Mais lequel est le mode le plus pertinent ici?
Comment comprendre la source du problème?
Antoine
Ps: short adresse à 0000
pipiche
Prenons les choses par le commencement
(1) Il faut mettre la Zigate en mode appairage. Dans le menu Hardware où tu as ajouté le plugin Zigate et configuré la Zigate.
Screenshot 2019-06-04 at 20.04.09.png (30.93 Kio) Consulté 5268 fois
en mettant le paramètre: Permit join time on start à 255 ( la zigate passe en mode appairage permanent)
(2) Tu relances la Zigate en faisant simplement 'Update' dans ce menu
==> La LED Bleu de la Zigate devrait se mettre à clignoter ce qui te permet de confirmer qu'elle est bien en mode Appairage
(3) Une fois le plugin lancé
- Tu appuies effectivement sur le bouton d'appairage jusqu'a ce que la Led se mette à clignoter, l'appairage devrait se faire
Si il n'y a pas d'appairage il faudrait:
- quel est le type de Zigate que tu utilises ?
- quelle version du plugin utilises-tu
- Mettre les Logs Domoticz (dans lequels sont les logs du plugin Zigate)
Dernière modification par vil1driver le 04 juin 2019, 21:26, modifié 1 fois.
Raison : Réponse directe, citation inutile
Wiki ici
chat sur Keybase.io
Tonio16
Bonsoir
La zigate, USB, clignote bien et le plugin est la dernière version. J'ai deux devices qui on été créé avec l'installation du plugin. J'ai aussi essayé un détecteur de vibration.
Voilà ce que j'ai au démarrage.
 2019-06-04 21:06:08.851 (Zigate) Debug: 4
2019-06-04 21:06:08.851 (Zigate) Debug logging mask set to: PLUGIN
2019-06-04 21:06:08.941 (Zigate) Heartbeat interval set to: 5.
2019-06-04 21:06:08.944 (Zigate) Configure Permit To Join
2019-06-04 21:06:08.944 (Zigate) Request discovery mode for 255 seconds
2019-06-04 21:06:08.326 Status: (Zigate) Stop directive received.
2019-06-04 21:06:08.326 Status: (Zigate) Exiting work loop.
2019-06-04 21:06:08.448 Status: (Zigate) onStop called
2019-06-04 21:06:08.451 Status: (Zigate) Statistics on message
2019-06-04 21:06:08.452 Status: (Zigate) Sent:
2019-06-04 21:06:08.452 Status: (Zigate) TX commands : 7
2019-06-04 21:06:08.452 Status: (Zigate) Max Load (Queue) : 4
2019-06-04 21:06:08.452 Status: (Zigate) TX failed : 0 (0.0%)
2019-06-04 21:06:08.452 Status: (Zigate) TX timeout : 0 (0.0%)
2019-06-04 21:06:08.452 Status: (Zigate) TX data timeout : 0 (0.0%)
2019-06-04 21:06:08.452 Status: (Zigate) TX reTransmit : 0 (0.0%)
2019-06-04 21:06:08.452 Status: (Zigate) Received:
2019-06-04 21:06:08.452 Status: (Zigate) RX frame : 13
2019-06-04 21:06:08.452 Status: (Zigate) RX crc errors : 0 (0.0%)
2019-06-04 21:06:08.452 Status: (Zigate) RX lentgh errors : 0 (0.0%)
2019-06-04 21:06:08.452 Status: (Zigate) RX clusters : 0
2019-06-04 21:06:08.452 Status: (Zigate) RX clusters KO : 0
2019-06-04 21:06:08.452 Status: (Zigate) Operating time : 0 Hours 10 Mins 8 Secs
2019-06-04 21:06:08.626 Status: (Zigate) Stopping threads.
2019-06-04 21:06:08.626 Status: (Zigate) Stopped.
2019-06-04 21:06:08.627 Status: (Zigate) Started.
2019-06-04 21:06:08.843 Status: (Zigate) Entering work loop.
2019-06-04 21:06:08.845 Status: (Zigate) Initialized version 4.3.0, author 'zaraki673 pipiche38'
2019-06-04 21:06:08.851 Status: (Zigate) Zigate plugin 4.3.0 started
2019-06-04 21:06:08.852 Status: (Zigate) Python Version - 3.5.3 (default, Sep 27 2018, 17:25:39)
2019-06-04 21:06:08.852 Status: (Zigate) Switching Heartbeat to 5 s interval
2019-06-04 21:06:08.852 Status: (Zigate) DomoticzVersion: 4.10717
2019-06-04 21:06:08.852 Status: (Zigate) DomoticzHash: b38b49e5
2019-06-04 21:06:08.852 Status: (Zigate) DomoticzBuildTime: 2019-05-09 13:04:08
2019-06-04 21:06:08.866 Status: (Zigate) Opening DomoticzDB in raw
2019-06-04 21:06:08.867 Status: (Zigate) load PluginConf
2019-06-04 21:06:08.867 Status: (Zigate) PluginConf: /home/pi/domoticz/plugins/Domoticz-Zigate/Conf/PluginConf.txt
2019-06-04 21:06:08.869 Status: (Zigate) -vibrationAqarasensitivity: medium
2019-06-04 21:06:08.869 Status: (Zigate) -enablegroupmanagement: 0
2019-06-04 21:06:08.869 Status: (Zigate) -resetMotiondelay: 30
2019-06-04 21:06:08.869 Status: (Zigate) -logFORMAT: 0
2019-06-04 21:06:08.869 Status: (Zigate) -logLQI: 0
2019-06-04 21:06:08.869 Status: (Zigate) -channel: ['11', '15', '19', '20', '25', '26']
2019-06-04 21:06:08.888 Status: (Zigate) Plugin Database: DeviceList-19.txt
2019-06-04 21:06:08.925 Status: (Zigate) DeviceConf loaded
2019-06-04 21:06:08.926 Status: (Zigate) load ListOfDevice
2019-06-04 21:06:08.941 Status: (Zigate) Entries loaded from /home/pi/domoticz/plugins/Domoticz-Zigate/Data/DeviceList-19.txt : 0
2019-06-04 21:06:08.941 Status: (Zigate) Connection Name: Zigate, Transport: Serial, Address: /dev/ttyUSB-Zigate
2019-06-04 21:06:09.046 Status: (Zigate) Major Version Num: 0003
2019-06-04 21:06:09.046 Status: (Zigate) Installer Version Number: 030f
2019-06-04 21:06:09.248 Status: (Zigate) Zigate in Permit Join: On
2019-06-04 21:06:09.371 Status: (Zigate) Zigate addresses ieee: 00158d0001ecae7b , short addr: 0000
2019-06-04 21:06:09.371 Status: (Zigate) Network state UP, PANID: f2d0 extPANID: 0xe16b58b74f2d47c3 Channel: 11
2019-06-04 21:06:09.474 Status: (Zigate) Number of devices recently active in Zigate = 0
2019-06-04 21:06:18.883 Status: (Zigate) Plugin with Zigate firmware 030f correctly initialized
Après avoir tenté l'apairage, rien de plus dans les logs.
Est-ce que des versions des Aqara ne sont pas compatibles ?
Antoine
Dernière modification par vil1driver le 04 juin 2019, 21:27, modifié 1 fois.
pipiche
En règle générale les Aqaras sont compatibles, peux-tu me donner le modèle et éventuellement le lien au tu l'as acheté.
Si c'est une zigate USB, as-tu un système Windows à portée de main ?
Si c'est le cas tu peux mettre la Zigate et utiliser l'outil ZGUI pour (1) Tester la Zigate (2) voir si l'appairage fonctionne et si la Zigate reçoit bien des messages
Tu trouveras des ifnos ici: https://zigate.fr/helpdesk_category/zigate-usb/
Wiki ici
chat sur Keybase.io
Tonio16
Ok, je fais cela dès que je peux.
Antoine
Dernière modification par vil1driver le 04 juin 2019, 22:25, modifié 1 fois.
Tonio16
Bonsoir
Sous windows cela marche.
19:02:20.761 <- 01 80 48 00 0A 14 00 15 8D 00 03 3A 77 00 00 00 03
19:02:22.991 <- 01 00 4D 00 0C 30 4D 6A 00 15 8D 00 03 3A 77 00 80 00 03
19:02:23.261 <- 01 00 4D 00 0C A3 4D 6A 00 15 8D 00 03 3A 77 00 80 93 03
19:02:23.527 <- 01 87 01 00 03 85 00 00 00 03
19:02:23.673 <- 01 81 02 00 23 25 00 4D 6A 01 00 00 00 05 00 42 00 16 6C 75 6D 69 2E 73 65 6E 73 6F 72 5F 6D 61 67 6E 65 74 2E 61 71 32 90 03
19:02:24.271 <- 01 81 02 00 0E 18 00 4D 6A 01 00 00 00 01 00 20 00 01 03 90 03
19:02:24.596 <- 01 81 02 00 2A E5 01 4D 6A 01 00 00 FF 01 00 42 00 1D 01 21 EF 0B 03 28 27 04 21 A8 01 05 21 50 00 06 24 01 00 00 00 00 0A 21 00 00 64 10 01 87 03
