[Plugin] Volet Velux IO-Homecontrol
franis
Re: [Plugin] - Volet Velux IO-Homecontrol
Message par franis »
J'ai souvent des problèmes de connexion. Domoticz ne se connecte plus à connexoon.
Avez vous deja eu ça ?
voici mon log
2021-01-04 18:42:00.727 Status: Domoticz V2020.2 (c)2012-2020 GizMoCuz
2021-01-04 18:42:00.728 Status: Build Hash: b63341bc0, Date: 2020-04-26 13:47:55
2021-01-04 18:42:00.728 Status: Startup Path: /home/pi/domoticz/
2021-01-04 18:42:00.844 Status: PluginSystem: Started, Python version '3.7.3'.
2021-01-04 18:42:00.853 Status: WebServer(HTTP) started on address: :: with port 8080
2021-01-04 18:42:00.858 Status: WebServer(SSL) started on address: :: with port 443
2021-01-04 18:42:00.861 Status: TCPServer: shared server started...
2021-01-04 18:42:00.861 Status: RxQueue: queue worker started...
2021-01-04 18:42:02.862 Status: Darksky: Started...
2021-01-04 18:42:02.862 Status: (Connexoon) Started.
2021-01-04 18:42:02.863 Status: EventSystem: reset all events...
2021-01-04 18:42:02.864 Status: EventSystem: reset all device statuses...
2021-01-04 18:42:02.873 Status: NotificationSystem: thread started...
2021-01-04 18:42:03.009 Status: Python EventSystem: Initalizing event module.
2021-01-04 18:42:03.009 Status: EventSystem: Started
2021-01-04 18:42:03.010 Status: EventSystem: Queue thread started...
2021-01-04 18:42:03.251 Status: PluginSystem: Entering work loop.
2021-01-04 18:42:03.418 Status: (Connexoon) Entering work loop.
2021-01-04 18:42:03.418 Status: (Connexoon) Initialized version 2.0.2, author 'nonolk'
2021-01-04 18:42:03.421 Status: (Connexoon) Starting Tahoma blind plugin
2021-01-04 18:42:03.730 Status: (Connexoon) Tahoma auth succeed
2021-01-04 18:42:03.784 Status: (Connexoon) Tahoma listener registred
2021-01-04 18:42:03.784 Status: (Connexoon) Check setup status at statup
2021-01-04 18:42:03.863 Status: MQTT: Connecting to localhost:1883
2021-01-04 18:42:04.065 Status: MQTT: connected to: localhost:1883
2021-01-04 18:42:04.265 Status: MQTT: Subscribed
2021-01-04 18:42:08.934 Status: Incoming connection from: 192.168.1.101
2021-01-04 18:43:43.695 (Connexoon) 6f 76 65 72 6b 69 7a 0d 0a 53 74 72 69 63 74 2d 54 72 61 6e overkiz..Strict-Tran
2021-01-04 18:43:43.695 (Connexoon) 73 70 6f 72 74 2d 53 65 63 75 72 69 74 79 3a 20 6d 61 78 2d sport-Security:.max-
2021-01-04 18:43:43.695 (Connexoon) 61 67 65 3d 33 31 35 33 36 30 30 30 3b 20 69 6e 63 6c 75 64 age=31536000;.includ
2021-01-04 18:43:43.695 (Connexoon) 65 53 75 62 44 6f 6d 61 69 6e 73 0d 0a 43 6f 6e 74 65 6e 74 eSubDomains..Content
2021-01-04 18:43:43.695 (Connexoon) 2d 54 79 70 65 3a 20 61 70 70 6c 69 63 61 74 69 6f 6e 2f 6a -Type:.application/j
2021-01-04 18:43:43.695 (Connexoon) 73 6f 6e 3b 63 68 61 72 73 65 74 3d 55 54 46 2d 38 0d 0a 4b son;charset=UTF-8..K
2021-01-04 18:43:43.695 (Connexoon) 65 65 70 2d 41 6c 69 76 65 3a 20 74 69 6d 65 6f 75 74 3d 35 eep-Alive:.timeout=5
2021-01-04 18:43:43.695 (Connexoon) 2c 20 6d 61 78 3d 35 30 0d 0a 43 6f 6e 6e 65 63 74 69 6f 6e ,.max=50..Connection
2021-01-04 18:43:43.695 (Connexoon) 3a 20 4b 65 65 70 2d 41 6c 69 76 65 0d 0a 54 72 61 6e 73 66 :.Keep-Alive..Transf
2021-01-04 18:43:43.695 (Connexoon) 65 72 2d 45 6e 63 6f 64 69 6e 67 3a 20 63 68 75 6e 6b 65 64 er-Encoding:.chunked
2021-01-04 18:43:43.695 (Connexoon) 0d 0a 0d 0a 32 0d 0a 5b 5d 0d 0a .. .. .. .. .. .. .. .. .. ....2..[]..
2021-01-04 18:43:43.696 (Connexoon) Processing 'ReadEvent' message
2021-01-04 18:43:43.696 (Connexoon) Received 5 bytes of data
2021-01-04 18:43:43.696 (Connexoon) 30 0d 0a 0d 0a .. .. .. .. .. .. .. .. .. .. .. .. .. .. .. 0....
2021-01-04 18:43:43.696 (Connexoon) Pushing 'onMessageCallback' on to queue
2021-01-04 18:43:43.696 (Connexoon) Processing 'onMessageCallback' message
2021-01-04 18:43:43.696 (Connexoon) Calling message handler 'onMessage'.
2021-01-04 18:43:43.696 (Connexoon) []
2021-01-04 18:43:48.695 (Connexoon) Queued asynchronous secure read aborted.
2021-01-04 18:43:48.695 (Connexoon) Pushing 'DisconnectedEvent' on to queue
2021-01-04 18:43:48.707 (Connexoon) Processing 'DisconnectedEvent' message
2021-01-04 18:43:48.707 (Connexoon) Disconnect event received for 'tahomalink.com:443'.
2021-01-04 18:43:48.708 (Connexoon) Pushing 'onDisconnectCallback' on to queue
2021-01-04 18:43:48.708 (Connexoon) Processing 'onDisconnectCallback' message
2021-01-04 18:43:48.708 (Connexoon) Calling message handler 'onDisconnect'.
2021-01-04 18:43:53.447 (Connexoon) Pushing 'onHeartbeatCallback' on to queue
2021-01-04 18:43:53.468 (Connexoon) Processing 'onHeartbeatCallback' message
2021-01-04 18:43:53.468 (Connexoon) Calling message handler 'onHeartbeat'.
2021-01-04 18:43:53.468 (Connexoon) Pushing 'ConnectDirective' on to queue
2021-01-04 18:43:53.468 (Connexoon) Processing 'ConnectDirective' message
2021-01-04 18:43:53.468 (Connexoon) Transport set to: 'TCP/IP', tahomalink.com:443.
2021-01-04 18:43:53.502 (Connexoon) Connect directive received, action initiated successfully.
2021-01-04 18:43:53.779 (Connexoon) Pushing 'onConnectCallback' on to queue
2021-01-04 18:43:53.803 (Connexoon) Processing 'onConnectCallback' message
2021-01-04 18:43:53.803 (Connexoon) Calling message handler 'onConnect'.
2021-01-04 18:43:53.803 (Connexoon) Pushing 'WriteDirective' on to queue
2021-01-04 18:43:53.803 (Connexoon) Processing 'WriteDirective' message
2021-01-04 18:43:53.803 (Connexoon) Sending 449 bytes of data
2021-01-04 18:43:53.803 (Connexoon) 50 4f 53 54 20 2f 65 6e 64 75 73 65 72 2d 6d 6f 62 69 6c 65 POST./enduser-mobile
2021-01-04 18:43:53.803 (Connexoon) 2d 77 65 62 2f 65 6e 64 75 73 65 72 41 50 49 2f 65 76 65 6e -web/enduserAPI/even
2021-01-04 18:43:53.803 (Connexoon) 74 73 2f 63 65 37 64 64 63 65 39 2d 61 63 31 30 2d 33 65 30 ts/ce7ddce9-ac10-3e0
2021-01-04 18:43:53.803 (Connexoon) 31 2d 31 32 35 34 2d 31 36 39 61 39 34 31 63 64 37 66 62 2f 1-1254-169a941cd7fb/
2021-01-04 18:43:53.803 (Connexoon) 66 65 74 63 68 20 48 54 54 50 2f 31 2e 31 0d 0a 41 75 74 68 fetch.HTTP/1.1..Auth
2021-01-04 18:43:53.804 (Connexoon) 6f 72 69 7a 61 74 69 6f 6e 3a 20 42 61 73 69 63 20 5a 6e 4a orization:.Basic.ZnJ
2021-01-04 18:43:53.804 (Connexoon) 68 62 6d 4e 70 63 79 35 6a 62 32 35 78 64 57 56 7a 51 47 64 hbmNpcy5jb25xdWVzQGd
2021-01-04 18:43:53.804 (Connexoon) 74 59 57 6c 73 4c 6d 4e 76 62 54 70 6d 63 6d 46 75 59 32 6c tYWlsLmNvbTpmcmFuY2l
2021-01-04 18:43:53.804 (Connexoon) 7a 4d 44 63 3d 0d 0a 55 73 65 72 2d 41 67 65 6e 74 3a 20 44 zMDc=..User-Agent:.D
2021-01-04 18:43:53.804 (Connexoon) 6f 6d 6f 74 69 63 7a 2f 31 2e 30 0d 0a 48 6f 73 74 3a 20 74 omoticz/1.0..Host:.t
2021-01-04 18:43:53.804 (Connexoon) 61 68 6f 6d 61 6c 69 6e 6b 2e 63 6f 6d 0d 0a 43 6f 6e 6e 65 ahomalink.com..Conne
2021-01-04 18:43:53.804 (Connexoon) 63 74 69 6f 6e 3a 20 6b 65 65 70 2d 61 6c 69 76 65 0d 0a 41 ction:.keep-alive..A
2021-01-04 18:43:53.804 (Connexoon) 63 63 65 70 74 2d 45 6e 63 6f 64 69 6e 67 3a 20 67 7a 69 70 ccept-Encoding:.gzip
2021-01-04 18:43:53.804 (Connexoon) 2c 20 64 65 66 6c 61 74 65 0d 0a 41 63 63 65 70 74 3a 20 2a ,.deflate..Accept:.*
2021-01-04 18:43:53.804 (Connexoon) 2f 2a 0d 0a 43 6f 6e 74 65 6e 74 2d 54 79 70 65 3a 20 61 70 /*..Content-Type:.ap
2021-01-04 18:43:53.804 (Connexoon) 70 6c 69 63 61 74 69 6f 6e 2f 6a 73 6f 6e 0d 0a 43 6f 6f 6b plication/json..Cook
2021-01-04 18:43:53.805 (Connexoon) 69 65 3a 20 4a 53 45 53 53 49 4f 4e 49 44 3d 33 42 39 42 45 ie:.JSESSIONID=3B9BE
2021-01-04 18:43:53.805 (Connexoon) 34 33 45 42 32 32 36 41 39 37 32 35 33 42 35 42 38 44 35 43 43EB226A97253B5B8D5C
2021-01-04 18:43:53.805 (Connexoon) 30 34 46 35 41 41 43 3b 20 50 61 74 68 3d 2f 65 6e 64 75 73 04F5AAC;.Path=/endus
2021-01-04 18:43:53.805 (Connexoon) 65 72 2d 6d 6f 62 69 6c 65 2d 77 65 62 3b 20 53 65 63 75 72 er-mobile-web;.Secur
2021-01-04 18:43:53.805 (Connexoon) 65 3b 20 48 74 74 70 4f 6e 6c 79 3b 20 53 61 6d 65 53 69 74 e;.HttpOnly;.SameSit
2021-01-04 18:43:53.805 (Connexoon) 65 3d 4e 6f 6e 65 0d 0a 43 6f 6e 74 65 6e 74 2d 4c 65 6e 67 e=None..Content-Leng
2021-01-04 18:43:53.805 (Connexoon) 74 68 3a 20 30 0d 0a 0d 0a .. .. .. .. .. .. .. .. .. .. .. th:.0....
2021-01-04 18:43:53.861 (Connexoon) Pushing 'ReadEvent' on to queue
2021-01-04 18:43:53.905 (Connexoon) Processing 'ReadEvent' message
2021-01-04 18:43:53.906 (Connexoon) Received 271 bytes of data
2021-01-04 18:43:53.906 (Connexoon) 48 54 54 50 2f 31 2e 31 20 32 30 30 20 0d 0a 44 61 74 65 3a HTTP/1.1.200...Date:
2021-01-04 18:43:53.906 (Connexoon) 20 4d 6f 6e 2c 20 30 34 20 4a 61 6e 20 32 30 32 31 20 31 37 .Mon,.04.Jan.2021.17
2021-01-04 18:43:53.906 (Connexoon) 3a 34 33 3a 35 33 20 47 4d 54 0d 0a 53 65 72 76 65 72 3a 20 :43:53.GMT..Server:.
2021-01-04 18:43:53.906 (Connexoon) 6f 76 65 72 6b 69 7a 0d 0a 53 74 72 69 63 74 2d 54 72 61 6e overkiz..Strict-Tran
2021-01-04 18:43:53.906 (Connexoon) 73 70 6f 72 74 2d 53 65 63 75 72 69 74 79 3a 20 6d 61 78 2d sport-Security:.max-
2021-01-04 18:43:53.906 (Connexoon) 61 67 65 3d 33 31 35 33 36 30 30 30 3b 20 69 6e 63 6c 75 64 age=31536000;.includ
2021-01-04 18:43:53.906 (Connexoon) 65 53 75 62 44 6f 6d 61 69 6e 73 0d 0a 43 6f 6e 74 65 6e 74 eSubDomains..Content
2021-01-04 18:43:53.906 (Connexoon) 2d 54 79 70 65 3a 20 61 70 70 6c 69 63 61 74 69 6f 6e 2f 6a -Type:.application/j
2021-01-04 18:43:53.906 (Connexoon) 73 6f 6e 3b 63 68 61 72 73 65 74 3d 55 54 46 2d 38 0d 0a 4b son;charset=UTF-8..K
2021-01-04 18:43:53.906 (Connexoon) 65 65 70 2d 41 6c 69 76 65 3a 20 74 69 6d 65 6f 75 74 3d 35 eep-Alive:.timeout=5
2021-01-04 18:43:53.906 (Connexoon) 2c 20 6d 61 78 3d 35 30 0d 0a 43 6f 6e 6e 65 63 74 69 6f 6e ,.max=50..Connection
2021-01-04 18:43:53.906 (Connexoon) 3a 20 4b 65 65 70 2d 41 6c 69 76 65 0d 0a 54 72 61 6e 73 66 :.Keep-Alive..Transf
2021-01-04 18:43:53.906 (Connexoon) 65 72 2d 45 6e 63 6f 64 69 6e 67 3a 20 63 68 75 6e 6b 65 64 er-Encoding:.chunked
2021-01-04 18:43:53.906 (Connexoon) 0d 0a 0d 0a 32 0d 0a 5b 5d 0d 0a .. .. .. .. .. .. .. .. .. ....2..[]..
2021-01-04 18:43:53.907 (Connexoon) Processing 'ReadEvent' message
2021-01-04 18:43:53.907 (Connexoon) Received 5 bytes of data
2021-01-04 18:43:53.907 (Connexoon) 30 0d 0a 0d 0a .. .. .. .. .. .. .. .. .. .. .. .. .. .. .. 0....
2021-01-04 18:43:53.907 (Connexoon) Pushing 'onMessageCallback' on to queue
2021-01-04 18:43:53.907 (Connexoon) Processing 'onMessageCallback' message
2021-01-04 18:43:53.907 (Connexoon) Calling message handler 'onMessage'.
2021-01-04 18:43:53.907 (Connexoon) []
2021-01-04 18:43:56.462 (Connexoon) Pushing 'DisconnectDirective' on to queue
2021-01-04 18:43:56.462 (Connexoon) Processing 'DisconnectDirective' message
2021-01-04 18:43:56.462 (Connexoon) Disconnect directive received for 'tahomalink.com:443'.
2021-01-04 18:43:56.462 (Connexoon) Handling TCP disconnect, socket (tahomalink.com:443) is connected
2021-01-04 18:43:56.463 (Connexoon) Pushing 'DisconnectedEvent' on to queue
2021-01-04 18:43:56.513 (Connexoon) Processing 'DisconnectedEvent' message
2021-01-04 18:43:56.513 (Connexoon) Disconnect event received for 'tahomalink.com:443'.
2021-01-04 18:43:56.514 (Connexoon) Pushing 'onDisconnectCallback' on to queue
2021-01-04 18:43:56.514 (Connexoon) Pushing 'onStopCallback' on to queue
2021-01-04 18:43:56.514 (Connexoon) Processing 'onDisconnectCallback' message
2021-01-04 18:43:56.514 (Connexoon) Calling message handler 'onDisconnect'.
2021-01-04 18:43:56.514 (Connexoon) Processing 'onStopCallback' message
2021-01-04 18:43:56.514 (Connexoon) Calling message handler 'onStop'.
2021-01-04 18:43:56.514 (Connexoon) Deallocating connection object 'Secure Connection' (tahomalink.com:443).
2021-01-04 18:43:56.462 Status: (Connexoon) Stop directive received.
2021-01-04 18:43:56.462 Status: (Connexoon) Exiting work loop.
2021-01-04 18:43:56.562 Status: (Connexoon) Stopping threads.
2021-01-04 18:43:56.562 Status: (Connexoon) Stopped.
2021-01-04 18:43:56.562 Status: (Connexoon) Started.
2021-01-04 18:43:56.744 Status: (Connexoon) Entering work loop.
2021-01-04 18:43:56.744 Status: (Connexoon) Initialized version 2.0.2, author 'nonolk'
2021-01-04 18:43:56.748 Status: (Connexoon) Starting Tahoma blind plugin
2021-01-04 18:43:56.903 Error: (Connexoon) Tahoma error must reconnect
2021-01-04 18:43:56.903 Error: (Connexoon) Too much connexions must wait
2021-01-04 18:44:06.775 Status: (Connexoon) Too much connections waiting before authenticating again
2021-01-04 18:44:16.796 Status: (Connexoon) Too much connections waiting before authenticating again
2021-01-04 18:44:26.766 Status: (Connexoon) Too much connections waiting before authenticating again
2021-01-04 18:44:36.786 Status: (Connexoon) Too much connections waiting before authenticating again
2021-01-04 18:44:46.757 Status: (Connexoon) Too much connections waiting before authenticating again
2021-01-04 18:44:56.776 Status: (Connexoon) Too much connections waiting before authenticating again
2021-01-04 18:45:06.798 Status: (Connexoon) Too much connections waiting before authenticating again
2021-01-04 18:45:16.769 Status: (Connexoon) Too much connections waiting before authenticating again
2021-01-04 18:45:26.790 Status: (Connexoon) Too much connections waiting before authenticating again
2021-01-04 18:45:36.809 Status: (Connexoon) Too much connections waiting before authenticating again
2021-01-04 18:45:46.778 Status: (Connexoon) Too much connections waiting before authenticating again
2021-01-04 18:45:56.797 Status: (Connexoon) Too much connections waiting before authenticating again
2021-01-04 18:46:06.817 Status: (Connexoon) Too much connections waiting before authenticating again
2021-01-04 18:46:16.787 Status: (Connexoon) Too much connections waiting before authenticating again
2021-01-04 18:46:26.806 Status: (Connexoon) Too much connections waiting before authenticating again
2021-01-04 18:46:36.777 Status: (Connexoon) Too much connections waiting before authenticating again
2021-01-04 18:46:46.798 Status: (Connexoon) Too much connections waiting before authenticating again
2021-01-04 18:46:56.819 Status: (Connexoon) Too much connections waiting before authenticating again
© 2012-2021 Domoticz | WWW: Domoticz.com
Dernière modification par Keros le 04 janv. 2021, 19:32, modifié 1 fois.
Raison : Merci de mettre les log sous les balises code afin de réduire leur place sur la page.
nonolk
Message par nonolk »
@franis
IL semblerai que tu ai trop de connections à ton compte "somfy" utilses tu d'autres outils ? Comme homebridge etc....
Somfy authorise un certains nombre d'authentification et bloque l'accès pendant un certain temps une fois ce nombre atteinds (environ 15 minutes).
@tous je me suis séparé de ma connexoon pour passer sur un kfl200 (mare de dépendre du cloud), donc je ne peu plus dévlopper de nouvelles fonctionalitées. Le code du plugin restera disponible et je peu eventuellement corriger des bugs (seulement si les logs et informations fournies sont suffisants)
ben33880
Message par ben33880 »
Salut, le klf200 tu le geres comment avec domoticz ?
nonolk
@ben33880 comme ça: viewtopic.php?f=15&t=10628
madpatrick
Message par madpatrick »
Hey,
Malheureusement, je ne parle pas français, mais c'est pourquoi j'ai traduit mon texte avec google translate.
J'avais déjà publié un problème sur le github, mais je n'ai malheureusement pas pu trouver les problèmes avec Nonolk.
Maintenant, je continue à voir un problème récurrent.
Si j'utilise les écrans vers le haut ou vers le bas, cela fonctionne très bien.
Dès que je déplace les écrans et appuie sur le bouton STOP, j'obtiens une erreur et le plugin ne fonctionne plus.
Le bouton STOP n'est pas visible dans Domoticz, mais il est visible dans Dashticz.
C'est probablement le problème, mais ensuite la question: la fonction STOP fonctionne-t-elle et est-ce également possible dans Domoticz?
Error in domtoicz.log
2021-05-04 12:02:25.175 Error: (Somfy Tahoma) 'onCommand' failed 'KeyError'.
2021-05-04 12:02:25.175 Error: (Somfy Tahoma) ----> Line 287 in '/var/domoticz/plugins/domoticz_tahoma_blind/plugin.py', function onCommand
2021-05-04 12:02:25.175 Error: (Somfy Tahoma) ----> Line 231 in '/var/domoticz/plugins/domoticz_tahoma_blind/plugin.py', function onCommand
2021-05-04 12:02:29.938 Error: (Somfy Tahoma) Tahoma error must reconnect
J'espère que mon histoire est lisible en français ;-)
ben33880
nonolk a écrit : 10 févr. 2021, 22:07 @ben33880 comme ça: viewtopic.php?f=15&t=10628
cricri
Re: [Plugin] Volet Velux IO-Homecontrol
Message par cricri »
bonjour,
merci pour le plugin, qui me parait intéressant.
Mon installation comporte 5 volets battants et 1 store terrasse.
Lorsque j'installe le matériel avec ton plugin, je n'ai que le dispositif store terrasse qui apparait.
J'ai essayé de modifier le plugin en ajoutant dans la liste des devices class: (device["uiClass"] == "SwingShutter") sans succès. je pense que le nom que j'ai donné "SwingShutter" ne convient pas. Comment retrouver le nom de UI class utilisé par les volets battants ?
Encore merci pour ce plugin.
cricri
Je me répond à moi même, j'ai trouvé le UI CLASS pour les volets battants qui est: "SwingingShutter" j'ai également rajouté le UI CLASS "Light" au pluging de nonolk.
Voilà si ça peux aidé.
madpatrick
Étant donné que le plugin de Nonolk ne fonctionnait pas à 100 % et nécessitait parfois un redémarrage, JanJaap a un peu réécrit le plugin.
Le problème vient surtout du site Somfy avec un retour qui bloque le script de temps en temps.
Votre ajout peut également aider d'autres utilisateurs dans cette version.
Si vous souhaitez partager la modification, nous pouvons l'ajouter ou si vous le souhaitez, l'ajouter au script
Le lien vers la version modifiée : https://github.com/MadPatrick/somfy
Une fois de plus, les crédits pour les bases reviennent à Nonolk.
cricri
Oui, je vous laisse le soin de l'ajouter, merci.
