Plugin Z4D avec new matériel "passerelle Zigbee SLZB 06"
Wolfen38
Re: Plugin Z4D avec new matériel "passerelle Zigbee SLZB 06"
Message par Wolfen38 »
Si tu veux dire le 1er lancement avec initialize sur true, oui, mais cette fois, apres la modif du socket, j'ai pas remis true, j'etais sur false.
Mon log de démarrage :
2025-04-16 10:13:53.541 Status: Cle-sonoff: Entering work loop.
2025-04-16 10:13:53.541 Cle-sonoff: Worker thread started.
2025-04-16 10:13:53.541 Status: Cle-sonoff: Started.
2025-04-16 10:13:55.302 Status: Cle-sonoff: Initialized version 7.1, author 'pipiche38'
2025-04-16 10:13:55.306 Status: Cle-sonoff: Welcome to Zigbee for Domoticz (Z4D) plugin.
2025-04-16 10:13:55.306 Status: Cle-sonoff: PYTHONPATH is not set
2025-04-16 10:13:55.306 Status: Cle-sonoff: Z4D requires python3.9 or above and you are running 3.9
2025-04-16 10:13:55.307 Cle-sonoff: Z4D loading PluginConf
2025-04-16 10:13:55.310 Cle-sonoff: Loading PluginConf - from Domoticz sqlite Db
2025-04-16 10:13:55.311 Cle-sonoff: /home/pi/domoticz/plugins/Domoticz-Zigate/Conf/PluginConf-43.json timestamp is 1744646830.3810997
2025-04-16 10:13:55.311 Cle-sonoff: Dz PluginConf is older than Json Dz: 0 Json: 1744646830.3810997
2025-04-16 10:13:55.315 Status: Cle-sonoff: filename set to /home/pi/domoticz/plugins/Domoticz-Zigate/Conf/PluginConf-43.json
2025-04-16 10:13:55.315 Status: Cle-sonoff: pluginHome set to /home/pi/domoticz/plugins/Domoticz-Zigate
2025-04-16 10:13:55.315 Status: Cle-sonoff: homedirectory set to /home/pi/domoticz/plugins/Domoticz-Zigate
2025-04-16 10:13:55.316 Status: Cle-sonoff: pluginData set to /home/pi/domoticz/plugins/Domoticz-Zigate/Data
2025-04-16 10:13:55.316 Status: Cle-sonoff: pluginConfig set to /home/pi/domoticz/plugins/Domoticz-Zigate/Conf
2025-04-16 10:13:55.316 Status: Cle-sonoff: pluginOTAFirmware set to /home/pi/domoticz/plugins/Domoticz-Zigate/OTAFirmware
2025-04-16 10:13:55.316 Status: Cle-sonoff: pluginReports set to /home/pi/domoticz/plugins/Domoticz-Zigate/Reports
2025-04-16 10:13:55.316 Status: Cle-sonoff: pluginWWW set to /home/pi/domoticz/plugins/Domoticz-Zigate/www
2025-04-16 10:13:55.316 Status: Cle-sonoff: pluginLogs set to /home/pi/domoticz/plugins/Domoticz-Zigate/Logs
2025-04-16 10:13:55.316 Status: Cle-sonoff: SSLCertificate set to /home/pi/domoticz/plugins/Domoticz-Zigate/certs/server.crt
2025-04-16 10:13:55.316 Status: Cle-sonoff: SSLPrivateKey set to /home/pi/domoticz/plugins/Domoticz-Zigate/certs/server.key
2025-04-16 10:13:55.317 Status: Cle-sonoff: expJsonDatabase set to 0
2025-04-16 10:13:55.405 Status: Cle-sonoff: Checking Python modules /home/pi/domoticz/plugins/Domoticz-Zigate/constraints.txt
2025-04-16 10:13:55.415 Status: Cle-sonoff: - zigpy==0.73.1 version required 0.73.1 installed 0.73.1
2025-04-16 10:13:55.423 Status: Cle-sonoff: - zigpy_znp==0.13.1 version required 0.13.1 installed 0.13.1
2025-04-16 10:13:55.430 Status: Cle-sonoff: - zigpy_deconz==0.24.1 version required 0.24.1 installed 0.24.1
2025-04-16 10:13:55.438 Status: Cle-sonoff: - bellows==0.42.5 version required 0.42.5 installed 0.42.5
2025-04-16 10:13:55.446 Status: Cle-sonoff: - dnspython==2.6.1 version required 2.6.1 installed 2.6.1
2025-04-16 10:13:55.453 Status: Cle-sonoff: - pyserial>=3.5 version required 3.5 installed 3.5
2025-04-16 10:13:55.462 Status: Cle-sonoff: - charset-normalizer==2.0.11 version required 2.0.11 installed 2.0.11
2025-04-16 10:13:55.472 Status: Cle-sonoff: - jsonschema==4.17.3 version required 4.17.3 installed 4.17.3
2025-04-16 10:13:55.483 Status: Cle-sonoff: - cryptography<=40.0.2 version required 40.0.2 installed 3.3.2
2025-04-16 10:13:55.484 Cle-sonoff: Installing plugin custom page /home/pi/domoticz/www/templates/Cle-sonoff.html
2025-04-16 10:13:55.484 Cle-sonoff: start_logging_thread
2025-04-16 10:13:55.485 Cle-sonoff: logging_thread - listening
2025-04-16 10:13:55.486 Status: Cle-sonoff: Please watch plugin log into /home/pi/domoticz/plugins/Domoticz-Zigate/Logs/PluginZigbee_43.log
2025-04-16 10:13:55.513 Status: Cle-sonoff: Z4D starting with stable7-7.1.018
2025-04-16 10:13:55.515 Status: Cle-sonoff: Z4D Multi-instances detected. Enable workaround
2025-04-16 10:13:55.524 Status: Cle-sonoff: Z4D loads ZCL Cluster definitions
2025-04-16 10:13:55.562 Status: Cle-sonoff: Z4D loaded 16 configuration from legacy database.
2025-04-16 10:13:55.564 Status: Cle-sonoff: Z4D loads 17 configuration from the local certified Db.
2025-04-16 10:13:55.892 Status: Cle-sonoff: Z4D loads 639 certified devices from repository version [6.438]
2025-04-16 10:13:55.893 Status: Cle-sonoff: Z4D loading database
2025-04-16 10:13:55.894 Status: Cle-sonoff: Z4D loads 0 entries from /home/pi/domoticz/plugins/Domoticz-Zigate/Data/DeviceList-43.txt
2025-04-16 10:13:55.899 Status: Cle-sonoff: Z4D configured to use transport mode: ZigpyZNP
2025-04-16 10:13:58.313 Status: Cle-sonoff: Z4D starting ZNP
2025-04-16 10:13:58.317 Status: Cle-sonoff: Z4D starts WebUI
2025-04-16 10:13:58.355 Status: Cle-sonoff: WebUI thread started
2025-04-16 10:13:58.382 Status: Cle-sonoff: WebUI Server started on 0.0.0.0:9460
2025-04-16 10:13:58.643 Status: Cle-sonoff: Plugin looks to upgrade the Certified Device package
2025-04-16 10:14:00.983 Status: Cle-sonoff: ++ Started radio znp port: /dev/serial1
2025-04-16 10:14:00.984 Status: Cle-sonoff: ++ Use of Zigpy Persistent Db
2025-04-16 10:14:14.395 Status: Cle-sonoff: Z4D Widgets usage is at 1.2% (252 units free)
2025-04-16 10:14:14.396 Status: Cle-sonoff: Z4D started with legacy Framework
2025-04-16 10:16:13.082 Error: Cle-sonoff: [120] I have hard time to get Coordinator Version. Most likely there is a communication issue
2025-04-16 10:16:23.112 Error: Cle-sonoff: [130] I have hard time to get Coordinator Version. Most likely there is a communication issue
2025-04-16 10:16:23.673 Status: Cle-sonoff: Stop directive received.
Wolfen38
J'ai refait avec initialize true, et pas mieux :
2025-04-16 10:38:29.985 Status: Cle-sonoff: Entering work loop.
2025-04-16 10:38:29.985 Cle-sonoff: Worker thread started.
2025-04-16 10:38:29.985 Status: Cle-sonoff: Started.
2025-04-16 10:38:31.658 Status: Cle-sonoff: Initialized version 7.1, author 'pipiche38'
2025-04-16 10:38:31.662 Status: Cle-sonoff: Welcome to Zigbee for Domoticz (Z4D) plugin.
2025-04-16 10:38:31.662 Status: Cle-sonoff: PYTHONPATH is not set
2025-04-16 10:38:31.663 Status: Cle-sonoff: Z4D requires python3.9 or above and you are running 3.9
2025-04-16 10:38:31.664 Cle-sonoff: Z4D loading PluginConf
2025-04-16 10:38:31.667 Cle-sonoff: Loading PluginConf - from Domoticz sqlite Db
2025-04-16 10:38:31.668 Cle-sonoff: /home/pi/domoticz/plugins/Domoticz-Zigate/Conf/PluginConf-43.json timestamp is 1744646830.3810997
2025-04-16 10:38:31.668 Cle-sonoff: Dz PluginConf is older than Json Dz: 0 Json: 1744646830.3810997
2025-04-16 10:38:31.671 Status: Cle-sonoff: filename set to /home/pi/domoticz/plugins/Domoticz-Zigate/Conf/PluginConf-43.json
2025-04-16 10:38:31.671 Status: Cle-sonoff: pluginHome set to /home/pi/domoticz/plugins/Domoticz-Zigate
2025-04-16 10:38:31.672 Status: Cle-sonoff: homedirectory set to /home/pi/domoticz/plugins/Domoticz-Zigate
2025-04-16 10:38:31.672 Status: Cle-sonoff: pluginData set to /home/pi/domoticz/plugins/Domoticz-Zigate/Data
2025-04-16 10:38:31.672 Status: Cle-sonoff: pluginConfig set to /home/pi/domoticz/plugins/Domoticz-Zigate/Conf
2025-04-16 10:38:31.672 Status: Cle-sonoff: pluginOTAFirmware set to /home/pi/domoticz/plugins/Domoticz-Zigate/OTAFirmware
2025-04-16 10:38:31.672 Status: Cle-sonoff: pluginReports set to /home/pi/domoticz/plugins/Domoticz-Zigate/Reports
2025-04-16 10:38:31.673 Status: Cle-sonoff: pluginWWW set to /home/pi/domoticz/plugins/Domoticz-Zigate/www
2025-04-16 10:38:31.673 Status: Cle-sonoff: pluginLogs set to /home/pi/domoticz/plugins/Domoticz-Zigate/Logs
2025-04-16 10:38:31.673 Status: Cle-sonoff: SSLCertificate set to /home/pi/domoticz/plugins/Domoticz-Zigate/certs/server.crt
2025-04-16 10:38:31.673 Status: Cle-sonoff: SSLPrivateKey set to /home/pi/domoticz/plugins/Domoticz-Zigate/certs/server.key
2025-04-16 10:38:31.674 Status: Cle-sonoff: expJsonDatabase set to 0
2025-04-16 10:38:31.766 Status: Cle-sonoff: Checking Python modules /home/pi/domoticz/plugins/Domoticz-Zigate/constraints.txt
2025-04-16 10:38:31.775 Status: Cle-sonoff: - zigpy==0.73.1 version required 0.73.1 installed 0.73.1
2025-04-16 10:38:31.783 Status: Cle-sonoff: - zigpy_znp==0.13.1 version required 0.13.1 installed 0.13.1
2025-04-16 10:38:31.791 Status: Cle-sonoff: - zigpy_deconz==0.24.1 version required 0.24.1 installed 0.24.1
2025-04-16 10:38:31.799 Status: Cle-sonoff: - bellows==0.42.5 version required 0.42.5 installed 0.42.5
2025-04-16 10:38:31.807 Status: Cle-sonoff: - dnspython==2.6.1 version required 2.6.1 installed 2.6.1
2025-04-16 10:38:31.815 Status: Cle-sonoff: - pyserial>=3.5 version required 3.5 installed 3.5
2025-04-16 10:38:31.824 Status: Cle-sonoff: - charset-normalizer==2.0.11 version required 2.0.11 installed 2.0.11
2025-04-16 10:38:31.832 Status: Cle-sonoff: - jsonschema==4.17.3 version required 4.17.3 installed 4.17.3
2025-04-16 10:38:31.844 Status: Cle-sonoff: - cryptography<=40.0.2 version required 40.0.2 installed 3.3.2
2025-04-16 10:38:31.845 Cle-sonoff: Installing plugin custom page /home/pi/domoticz/www/templates/Cle-sonoff.html
2025-04-16 10:38:31.845 Cle-sonoff: start_logging_thread
2025-04-16 10:38:31.846 Cle-sonoff: logging_thread - listening
2025-04-16 10:38:31.847 Status: Cle-sonoff: Please watch plugin log into /home/pi/domoticz/plugins/Domoticz-Zigate/Logs/PluginZigbee_43.log
2025-04-16 10:38:31.863 Status: Cle-sonoff: Z4D starting with stable7-7.1.018
2025-04-16 10:38:31.873 Status: Cle-sonoff: Z4D Multi-instances detected. Enable workaround
2025-04-16 10:38:31.884 Status: Cle-sonoff: Z4D loads ZCL Cluster definitions
2025-04-16 10:38:31.922 Status: Cle-sonoff: Z4D loaded 16 configuration from legacy database.
2025-04-16 10:38:31.924 Status: Cle-sonoff: Z4D loads 17 configuration from the local certified Db.
2025-04-16 10:38:32.274 Status: Cle-sonoff: Z4D loads 639 certified devices from repository version [6.438]
2025-04-16 10:38:32.275 Status: Cle-sonoff: Z4D loading database
2025-04-16 10:38:32.277 Status: Cle-sonoff: Z4D loads 0 entries from /home/pi/domoticz/plugins/Domoticz-Zigate/Data/DeviceList-43.txt
2025-04-16 10:38:32.282 Status: Cle-sonoff: Z4D configured to use transport mode: ZigpyZNP
2025-04-16 10:38:34.306 Status: Cle-sonoff: Z4D starting ZNP
2025-04-16 10:38:34.310 Status: Cle-sonoff: Z4D starts WebUI
2025-04-16 10:38:34.349 Status: Cle-sonoff: WebUI thread started
2025-04-16 10:38:34.354 Status: Cle-sonoff: WebUI Server started on 0.0.0.0:9460
2025-04-16 10:38:34.641 Status: Cle-sonoff: Plugin looks to upgrade the Certified Device package
2025-04-16 10:38:36.989 Status: Cle-sonoff: ++ Started radio znp port: /dev/serial1
2025-04-16 10:38:36.992 Status: Cle-sonoff: ++ Coordinator initialisation requested Channel 0(0x00) ExtendedPanId: 0x0000000000000000
2025-04-16 10:38:36.993 Status: Cle-sonoff: ++ Use of Zigpy Persistent Db
2025-04-16 10:38:50.022 Status: Cle-sonoff: Z4D Widgets usage is at 1.2% (252 units free)
2025-04-16 10:38:50.023 Status: Cle-sonoff: Z4D started with legacy Framework
2025-04-16 10:40:49.070 Error: Cle-sonoff: [120] I have hard time to get Coordinator Version. Most likely there is a communication issue
2025-04-16 10:40:54.798 Status: Cle-sonoff: Stop directive received.
salinois
Message par salinois »
hello,
voici les logs de la mienne quand ça démarre; la différence, c'est que je suis en POE, mais je pense pas que ça joue.
2025-04-16 10:36:34.531 Status: TCPServer: shared server started...
2025-04-16 10:36:34.532 Status: RxQueue: queue worker started...
2025-04-16 10:36:36.532 Status: ZigbeeSLZB06: Entering work loop.
2025-04-16 10:36:36.532 ZigbeeSLZB06: Worker thread started.
2025-04-16 10:36:36.532 Status: ZigbeeSLZB06: Started.
2025-04-16 10:36:36.533 Status: NotificationSystem: thread started...
2025-04-16 10:36:36.540 Status: EventSystem: reset all events...
2025-04-16 10:36:36.543 Status: EventSystem: reset all device statuses...
2025-04-16 10:36:36.644 Status: Python EventSystem: Initializing event module.
2025-04-16 10:36:36.644 Status: EventSystem: Started
2025-04-16 10:36:36.644 Status: EventSystem: Queue thread started...
2025-04-16 10:36:36.783 Status: PluginSystem: 1 plugins started.
2025-04-16 10:36:37.765 Status: ZigbeeSLZB06: Initialized version 7.1, author 'pipiche38'
2025-04-16 10:36:37.767 Status: ZigbeeSLZB06: Welcome to Zigbee for Domoticz (Z4D) plugin.
2025-04-16 10:36:37.767 Status: ZigbeeSLZB06: PYTHONPATH is not set
2025-04-16 10:36:37.767 Status: ZigbeeSLZB06: Z4D requires python3.9 or above and you are running 3.9
2025-04-16 10:36:37.769 ZigbeeSLZB06: Z4D loading PluginConf
2025-04-16 10:36:37.771 ZigbeeSLZB06: Loading PluginConf - from Domoticz sqlite Db
2025-04-16 10:36:37.772 ZigbeeSLZB06: /home/patrick/domoticz/plugins/Domoticz-Zigbee/Conf/PluginConf-03.json timestamp is 1737991674.355086
2025-04-16 10:36:37.772 ZigbeeSLZB06: Dz PluginConf is older than Json Dz: 0 Json: 1737991674.355086
2025-04-16 10:36:37.774 Status: ZigbeeSLZB06: channel set to 15
2025-04-16 10:36:37.774 Status: ZigbeeSLZB06: filename set to /home/patrick/domoticz/plugins/Domoticz-Zigbee/Conf/PluginConf-03.json
2025-04-16 10:36:37.774 Status: ZigbeeSLZB06: pluginHome set to /home/patrick/domoticz/plugins/Domoticz-Zigbee
2025-04-16 10:36:37.774 Status: ZigbeeSLZB06: homedirectory set to /home/patrick/domoticz/plugins/Domoticz-Zigbee
2025-04-16 10:36:37.774 Status: ZigbeeSLZB06: pluginData set to /home/patrick/domoticz/plugins/Domoticz-Zigbee/Data
2025-04-16 10:36:37.774 Status: ZigbeeSLZB06: pluginConfig set to /home/patrick/domoticz/plugins/Domoticz-Zigbee/Conf
2025-04-16 10:36:37.774 Status: ZigbeeSLZB06: pluginOTAFirmware set to /home/patrick/domoticz/plugins/Domoticz-Zigbee/OTAFirmware
2025-04-16 10:36:37.774 Status: ZigbeeSLZB06: pluginReports set to /home/patrick/domoticz/plugins/Domoticz-Zigbee/Reports
2025-04-16 10:36:37.774 Status: ZigbeeSLZB06: pluginWWW set to /home/patrick/domoticz/plugins/Domoticz-Zigbee/www
2025-04-16 10:36:37.774 Status: ZigbeeSLZB06: pluginLogs set to /home/patrick/domoticz/plugins/Domoticz-Zigbee/Logs
2025-04-16 10:36:37.774 Status: ZigbeeSLZB06: SSLCertificate set to /home/patrick/domoticz/plugins/Domoticz-Zigbee/certs/server.crt
2025-04-16 10:36:37.774 Status: ZigbeeSLZB06: SSLPrivateKey set to /home/patrick/domoticz/plugins/Domoticz-Zigbee/certs/server.key
2025-04-16 10:36:37.774 Status: ZigbeeSLZB06: ControllerInRawMode set to True
2025-04-16 10:36:37.774 Status: ZigbeeSLZB06: expJsonDatabase set to 0
2025-04-16 10:36:37.938 Status: ZigbeeSLZB06: Checking Python modules /home/patrick/domoticz/plugins/Domoticz-Zigbee/constraints.txt
2025-04-16 10:36:37.947 Status: ZigbeeSLZB06: - zigpy==0.73.1 version required 0.73.1 installed 0.73.1
2025-04-16 10:36:37.956 Status: ZigbeeSLZB06: - zigpy_znp==0.13.1 version required 0.13.1 installed 0.13.1
2025-04-16 10:36:37.960 Status: ZigbeeSLZB06: - zigpy_deconz==0.24.1 version required 0.24.1 installed 0.24.1
2025-04-16 10:36:37.965 Status: ZigbeeSLZB06: - bellows==0.42.5 version required 0.42.5 installed 0.42.5
2025-04-16 10:36:37.970 Status: ZigbeeSLZB06: - dnspython==2.6.1 version required 2.6.1 installed 2.6.1
2025-04-16 10:36:37.975 Status: ZigbeeSLZB06: - pyserial>=3.5 version required 3.5 installed 3.5
2025-04-16 10:36:37.980 Status: ZigbeeSLZB06: - charset-normalizer==2.0.11 version required 2.0.11 installed 2.0.11
2025-04-16 10:36:37.985 Status: ZigbeeSLZB06: - jsonschema==4.17.3 version required 4.17.3 installed 4.17.3
2025-04-16 10:36:37.991 Status: ZigbeeSLZB06: - cryptography<=40.0.2 version required 40.0.2 installed 3.3.2
2025-04-16 10:36:37.991 ZigbeeSLZB06: Installing plugin custom page /home/patrick/domoticz/www/templates/ZigbeeSLZB06.html
2025-04-16 10:36:37.992 ZigbeeSLZB06: start_logging_thread
2025-04-16 10:36:37.993 ZigbeeSLZB06: logging_thread - listening
2025-04-16 10:36:37.993 Status: ZigbeeSLZB06: Please watch plugin log into /home/patrick/domoticz/plugins/Domoticz-Zigbee/Logs/PluginZigbee_03.log
2025-04-16 10:36:38.003 Status: ZigbeeSLZB06: Z4D starting with stable7-7.1.020
2025-04-16 10:36:38.003 Status: [web:8080] Incoming connection from: 127.0.0.1
2025-04-16 10:36:38.015 Status: ZigbeeSLZB06: Z4D loads ZCL Cluster definitions
2025-04-16 10:36:38.056 Status: ZigbeeSLZB06: Z4D loaded 16 configuration from legacy database.
2025-04-16 10:36:38.058 Status: ZigbeeSLZB06: Z4D loads 16 configuration from the local certified Db.
2025-04-16 10:36:38.074 Error: ZigbeeSLZB06: Certified Devices load skip this Certified device Schneider-Wiser2-Thermostat requires Plugin version 7.1.021
2025-04-16 10:36:38.571 Status: ZigbeeSLZB06: Z4D loads 636 Certified devices from repository.
2025-04-16 10:36:38.572 Status: ZigbeeSLZB06: Z4D loading database
2025-04-16 10:36:38.594 Status: ZigbeeSLZB06: Z4D loads 3 entries from /home/patrick/domoticz/plugins/Domoticz-Zigbee/Data/DeviceList-3.txt
2025-04-16 10:36:38.599 Status: ZigbeeSLZB06: Z4D configured to use transport mode: ZigpyZNP
2025-04-16 10:36:39.883 Status: ZigbeeSLZB06: Z4D starting ZNP
2025-04-16 10:36:39.886 Status: ZigbeeSLZB06: Z4D starts WebUI
2025-04-16 10:36:39.905 Status: ZigbeeSLZB06: WebUI thread started
2025-04-16 10:36:39.918 Status: ZigbeeSLZB06: WebUI Server started on 0.0.0.0:9440
2025-04-16 10:36:40.071 Status: ZigbeeSLZB06: Plugin looks to upgrade the Certified Device package
2025-04-16 10:36:43.022 Status: ZigbeeSLZB06: ++ Started radio znp port: socket://192.168.0.213:6638
2025-04-16 10:36:43.023 Status: ZigbeeSLZB06: ++ Use of Zigpy Persistent Db
2025-04-16 10:36:49.742 Status: ZigbeeSLZB06: Z4D Widgets usage is at 2.0% (250 units free)
2025-04-16 10:36:49.742 Status: ZigbeeSLZB06: Z4D started with legacy Framework
2025-04-16 10:36:50.807 Status: ZigbeeSLZB06: ++ ZNP Radio register default Ep
2025-04-16 10:36:50.828 Status: ZigbeeSLZB06: ++ ZNP Radio register any additional/specific Ep
2025-04-16 10:36:51.068 Status: ZigbeeSLZB06: ++ ZNP Configuration {'device': {'path': 'socket://192.168.0.213:6638', 'baudrate': 115200, 'flow_control': None}, 'network': {'channel': 15, 'key': None, 'tc_link_key': 5a:69:67:42:65:65:41:6c:6c:69:61:6e:63:65:30:39, 'key_sequence_number': 0, 'tc_address': None, 'extended_pan_id': None, 'update_id': 0, 'pan_id': None, 'channels': <Channels.CHANNEL_25|CHANNEL_20|CHANNEL_15|CHANNEL_11: 34637824>}, 'znp_config': {'tx_power': 0, 'connect_dtr_pin_states': [False, False, False], 'auto_reconnect_retry_delay': 5, 'prefer_endpoint_1': True, 'led_mode': <LEDMode.OFF: 0>, 'connect_rts_pin_states': [False, True, False], 'async_response_timeout': 30, 'max_concurrent_requests': None, 'sync_request_timeout': 15, 'skip_bootloader': True}, 'ota': {'enabled': False, 'broadcast_enabled': True, 'broadcast_initial_delay': 14040.0, 'extra_providers': [], 'disable_default_providers': [], 'providers': [Ledvance(url='https://api.update.ledvance.com/v1/zigbee/firmwares', manufacturer_ids=(4489, 4364)), Sonoff(url=None, manufacturer_ids=(4742,)), Inovelli(url=None, manufacturer_ids=(4655,)), ThirdReality(url=None, manufacturer_ids=(4659, 4877, 5127))], 'broadcast_interval': 14040.0}, 'source_routing': False, 'topology_scan_enabled': True, 'database_path': ':memory:', 'topology_scan_period': 720, 'backup_enabled': True, 'backup_period': 1, 'validate_network_settings': False, 'additional_endpoints': [], 'watchdog_enabled': True, 'max_concurrent_requests': 8, 'topology_scan_skip_coordinator': False}
2025-04-16 10:37:10.611 Status: ZigbeeSLZB06: ++ ZNP Board Information
2025-04-16 10:37:10.620 Status: ZigbeeSLZB06: ++ Radio manufacturer : Texas Instruments
2025-04-16 10:37:10.620 Status: ZigbeeSLZB06: ++ Radio board model : CC2652
2025-04-16 10:37:10.621 Status: ZigbeeSLZB06: ++ Radio version : Z-Stack 20240710
2025-04-16 10:37:10.621 Status: ZigbeeSLZB06: ++ Network settings
2025-04-16 10:37:10.622 Status: ZigbeeSLZB06: ++ Device IEEE : 00:12:4b:00:31:dd:24:c5
2025-04-16 10:37:10.622 Status: ZigbeeSLZB06: ++ Device NWK : 0x0000
2025-04-16 10:37:10.623 Status: ZigbeeSLZB06: ++ Network Update Id : 0x0000
2025-04-16 10:37:10.623 Status: ZigbeeSLZB06: ++ PAN ID : 0x171E
2025-04-16 10:37:10.624 Status: ZigbeeSLZB06: ++ Extended PAN ID : 62:ef:33:a3:4e:10:49:b9
2025-04-16 10:37:10.624 Status: ZigbeeSLZB06: ++ Channel : 15
2025-04-16 10:37:10.625 Status: ZigbeeSLZB06: Number of devices recently active in Coordinator = 2
2025-04-16 10:37:10.625 Status: ZigbeeSLZB06: [00] DevID: 00 Network addr: f60c IEEE: 385b44fffe1c24a2 LQI: 000 power: ff Model: TS0505B ( )
2025-04-16 10:37:10.626 Status: ZigbeeSLZB06: [01] DevID: 00 Network addr: 25d6 IEEE: 385b44fffe210d49 LQI: 000 power: ff Model: TS0505B ( )
2025-04-16 10:37:10.626 Status: ZigbeeSLZB06: CC1352/CC2652, Z-Stack 3.30+ (znp)
2025-04-16 10:37:10.627 Status: ZigbeeSLZB06: Installer Version Number: Z-Stack 3.30+ (build 20240710)
2025-04-16 10:37:10.627 Status: ZigbeeSLZB06: Branch Version: ==> CC1352/CC2652, Z-Stack 3.30+ (znp) <==
2025-04-16 10:37:10.631 Status: ZigbeeSLZB06: Zigbee Coordinator ieee: 00124b0031dd24c5 , short addr: 0000
2025-04-16 10:37:10.631 Status: ZigbeeSLZB06: Network state UP, PANID: 171e extPANID: 0x62ef33a34e1049b9 Channel: 15
2025-04-16 10:37:18.059 Status: ZigbeeSLZB06: Z4D closed the Zigbee network
2025-04-16 10:37:18.075 Status: ZigbeeSLZB06: ++ opening zigbee network for 0 secondes on specific router None
2025-04-16 10:37:18.096 Status: ZigbeeSLZB06: Accepting new Hardware: Disable (Off)
2025-04-16 10:37:23.074 Status: ZigbeeSLZB06: Z4D coordinator set to Certification : 1/CE -> CE
2025-04-16 10:37:23.075 Status: ZigbeeSLZB06: Z4D starts Configure Reporting handling
2025-04-16 10:37:23.076 Status: ZigbeeSLZB06: Z4D starts Over-The-Air Management
2025-04-16 10:37:23.965 Status: ZigbeeSLZB06: Z4D loads the firmware images
2025-04-16 10:37:23.966 Status: ZigbeeSLZB06: Z4D with Zigpy, coordinator CC1352/CC2652, Z-Stack 3.30+ (znp), firmware Z-Stack 3.30+ (build 20240710) communication confirmed.
2025-04-16 10:37:23.966 Status: ZigbeeSLZB06: Sending Analytics information. (disable the MatomoOptIn parameter to stop this)
2025-04-16 10:37:30.819 Error: ZigbeeSLZB06: DNS resolution timed out for zigate_plugin.pipiche.net after 2 second
2025-04-16 10:37:33.991 Error: ZigbeeSLZB06: Unable to get access to plugin expected version. Is Internet access available ?
2025-04-16 10:37:47.664 Status: [web:443] Incoming connection from: 192.168.0.6
et la config dans domoticz
config-materiel_cle POE.jpg (76.48 Kio) Consulté 3795 fois
as-tu fait la MAJ de la clé ?
salinois
Wolfen38
salinois a écrit : 16 avr. 2025, 10:45
salinois
Non, ca se fait sur la console de la clé ?
salinois
sur cette page de la cle
firmware update.jpg (56.45 Kio) Consulté 3789 fois
Wolfen38
OK, je regarde ce soir en rentrant.
la première chose serait d'être sur la dernière version du plugin ! tu es en 7.1.018 et je ne pense pas que le mode socket était correct sur cette version
Wolfen38
J'avais essayé de passer a la dernière version mais ça dirait le bordel avec les zigate.
C'était d'ailleurs pour ça que j'ai essayé cette clé sonoff.
Je peux mettre a jour le plugin pour cette clé sans changer celui des zigate ?
Par contre comme je peux pas me connecter au dashboard de la clé pour le moment j'imagine qu'il faut que je fasse ça en ligne de commande ?
salinois
pipiche a écrit : 16 avr. 2025, 11:36 la première chose serait d'être sur la dernière version du plugin ! tu es en 7.1.018 et je ne pense pas que le mode socket était correct sur cette version
yes, c'est ce que tu m'avais dit de faire pour la mienne, en attendant la vrai version. Je crois
salinois
Wolfen38
Je voudrais pas foutre en l'air mes 2 zigate qui tourne sous la version 18 du plugin.
Pour le moment le plugin est dans le répertoire domoticz-zigate
Je me demande si je peux en créer une autre instance sous domoticz-zigbee pour avoir juste celle la dans la dernière version du plugin, ou si c'est pas possible d'avoir 2 instance du plugin sur le meme dz....
