C'est donc bien snmpget qu'il te faut utiliser.
Depuis les logs :
Status: dzVents: snmpget -v 2c -c password -O qv adresseip 1.3.6.1.4.1.2021.11.9.0
Debug: Synology Monitor v1.41 : Requete SNMP incorrecteCode : Tout sélectionner
if results[0] and results[5] and results[6] then
dz.log('Requete SNMP correcte ',dz.LOG_DEBUG)
dz.devices(NAS).switchOn().checkFirst()
dz.log('Requete SNMP incorrecte ',dz.LOG_DEBUG)
dz.devices(NAS).switchOff().checkFirst()
endCode : Tout sélectionner
print(results[0])Code : Tout sélectionner
2021-02-11 11:51:00.661 Status: dzVents: Info: Synology Monitor v1.41 : ------ Start internal script: ZZ Temp NAS:, trigger: "every minute"
2021-02-11 11:51:00.663 Status: dzVents: Debug: Synology Monitor v1.41 : last ifHCOutOctets : 0 at 60 seconds ago
2021-02-11 11:51:00.663 Status: dzVents: Debug: Synology Monitor v1.41 : last ifHCInOctets : 0 at 60 seconds ago
2021-02-11 11:51:00.705 Status: dzVents: 39
2021-02-11 11:51:00.705 Status: dzVents: Debug: Synology Monitor v1.41 : NASTemp : 39
2021-02-11 11:51:00.705 Status: dzVents: Debug: Synology Monitor v1.41 : Processing device-adapter for NAS Temp: Temperature device adapter
2021-02-11 11:51:00.706 Status: dzVents: Debug: Synology Monitor v1.41 : Upload : 0ko/s, Download : 0ko/s
2021-02-11 11:51:00.706 Status: dzVents: Debug: Synology Monitor v1.41 : Requete SNMP incorrecte
2021-02-11 11:51:00.706 Status: dzVents: Debug: Synology Monitor v1.41 : Constructed timed-command: Off
2021-02-11 11:51:00.706 Status: dzVents: Info: Synology Monitor v1.41 : ------ Finished ZZ Temp NASCode : Tout sélectionner
print(results[1])Code : Tout sélectionner
local les_oid = {
OID_NAS_TEMP,
OID_HDUnit,
OID_HDTotal,
OID_HDUsed,
OID_CpuUser,
OID_CpuSystem,
OID_MemAvailable,
OID_MemTotalSwap,
OID_MemTotalReal,
OID_MemTotalFree,
OID_HDtemp1,
OID_HDtemp2,
OID_HDtemp3,
OID_HDtemp4,
OID_ifHCOutOctets,
OID_ifHCInOctets
} -- Liste des oid séparées par une virgule
local i = 0
local results = {}
for _, name in ipairs(les_oid) do
local command = 'snmpwalk -v 2c -c '..CommunityPassword..' -O qv '..NasIp..' '..name
local handle = assert(io.popen(command))
for line in handle:lines() do
--dz.log(format(line).." "..i, dz.LOG_info)
results[i] = format(line)
handle:close()
i = i + 1
if results[0] then
dz.log('NASTemp : '..results[0],dz.LOG_DEBUG)
if NAS_TEMP then dz.devices(NAS_TEMP).update(0,results[0]) end
if results[1] then dz.log('HDUnit : '..results[1],dz.LOG_DEBUG) end
if results[2] then dz.log('HDTotal : '..results[2],dz.LOG_DEBUG) end
if results[3] then dz.log('HDUsed : '..results[3],dz.LOG_DEBUG) end
if results[4] then dz.log('CpuUser : '..results[4],dz.LOG_DEBUG) end
if results[5] then dz.log('CpuSystem : '..results[5],dz.LOG_DEBUG) endCode : Tout sélectionner
auteur : papoo
creation : 17/02/2019
mise à jour : 18/12/2019
https://pon.fr/dzvents-supervision-dun-nas-synology-avec-snmp/
https://github.com/papo-o/domoticz_scripts/blob/master/dzVents/scripts/synology2.lua
https://easydomoticz.com/forum/viewtopic.php?f=17&t=7022
https://www.domoticz.com/forum/viewtopic.php?f=59&t=24618
For this script to work you need to enable SNMP on your synology NAS and install SNMP on your Raspberry Pi
Enable SNMP on your synology NAS
Go toMain Menu>Control Panel >SNMP to enable SNMP service, which allows users to monitor
Synology DiskStation network flow with the network management software.
You can use V1/V2
And set a password (Community)
Install SNMP on Raspberry Pi
Log in to you Raspberry Pi and issue:
sudo apt-get install snmpd
Reboot your Pi:
sudo reboot
Check if SNMP is up and running, issue:
snmpget -v 2c -c PASSWORD -O qv NASIPADDRESS 1.3.6.1.4.1.6574.1.5.1.0
Replace PASSWORD with the Community name you entered while setting up your NAS
Replace NASIPADDRESS with the ip address of your NAS
You should get something like this:
"DS218+" which corresponds to your Synology Model
how to choose disk capacity to monitor?
snmpwalk -v 2c -c PASSWORD NASIPADDRESS 1.3.6.1.2.1.25.2.3.1.3
results of my DS218 :
HOST-RESOURCES-MIB::hrStorageDescr.1 = STRING: Physical memory
HOST-RESOURCES-MIB::hrStorageDescr.3 = STRING: Virtual memory
HOST-RESOURCES-MIB::hrStorageDescr.6 = STRING: Memory buffers
HOST-RESOURCES-MIB::hrStorageDescr.7 = STRING: Cached memory
HOST-RESOURCES-MIB::hrStorageDescr.8 = STRING: Shared memory
HOST-RESOURCES-MIB::hrStorageDescr.10 = STRING: Swap space
HOST-RESOURCES-MIB::hrStorageDescr.31 = STRING: /
HOST-RESOURCES-MIB::hrStorageDescr.36 = STRING: /tmp
HOST-RESOURCES-MIB::hrStorageDescr.37 = STRING: /run
HOST-RESOURCES-MIB::hrStorageDescr.38 = STRING: /dev/shm
HOST-RESOURCES-MIB::hrStorageDescr.39 = STRING: /sys/fs/cgroup
HOST-RESOURCES-MIB::hrStorageDescr.40 = STRING: /run/cgmanager/fs
HOST-RESOURCES-MIB::hrStorageDescr.51 = STRING: /volume1
HOST-RESOURCES-MIB::hrStorageDescr.54 = STRING: /volume1/@docker/btrfs
then modify OID_HDUnit, OID_HDTotal, OID_HDUsed variables with your last number choice (.38 on DSM 5.1, .41 on DSM 6.0+ or .51 on my new DS218)
if you have à DS2XX model, uncomment -- local OID_HDtemp2='1.3.6.1.4.1.6574.2.1.1.6.1' to show the hdd2 temperature
Then create:
1 device Switch
1 temperature device
3 percent devices
x meter device
-------------Fonctions----------------------
function format(str)
if (str) then
str = string.gsub (str, " Bytes", "")
str = string.gsub (str, " kB", "")
return str
-------------Fin Fonctions-----------------
local NasIp = '192.168.*.*' -- NAS IP Address
local CommunityPassword = '****' -- SNMP Password
local NAS = 'Synology' -- NAS Switch
local NAS_TEMP = 'NAS Temp'
local NAS_CPU = 'NAS Utilisation CPU' -- NAS CPU
local NAS_MEM = 'NAS Utilisation RAM' -- NAS MEM
local NAS_HD_SPACE_PERC = 'NAS Occupation Disque' -- NAS HD Space in %
local NAS_HD_SPACE = 'NAS Espace Disponible' -- NAS HD Space in Go (custom sensor)
local NAS_HDD1_TEMP = 'NAS HDD1 Temp' -- NAS HD1 Temp, nil if unused
local NAS_HDD2_TEMP = 'NAS HDD2 Temp' -- NAS HD2 Temp, nil if unused
local NAS_HDD3_TEMP = nil -- NAS HD3 Temp, nil if unused
local NAS_HDD4_TEMP = nil -- NAS HD4 Temp, nil if unused
local NAS_UPLOAD = nil -- NAS upload in ko/s, nil if unused
local NAS_DOWNLOAD = nil -- NAS download in ko/s, nil if unused
local OID_NAS_TEMP = '1.3.6.1.4.1.6574.1.2.0'
local OID_HDUnit = '1.3.6.1.2.1.25.2.3.1.4.51' -- OID HD Unit Change OID to .38 on DSM 5.1 or .41 on DSM 6.0+ or .51 on my DS218
local OID_HDTotal = '1.3.6.1.2.1.25.2.3.1.5.51' -- OID Total space volume in Go Change OID to .38 on DSM 5.1 or .41 on DSM 6.0+ or .51 on my DS218
local OID_HDUsed = '1.3.6.1.2.1.25.2.3.1.6.51' -- OID Space used volume in Go Change OID to .38 on DSM 5.1 or .41 on DSM 6.0+ or .51 on my DS218
local OID_CpuUser = '1.3.6.1.4.1.2021.11.9.0' -- OID CPU user
local OID_CpuSystem = '1.3.6.1.4.1.2021.11.10.0' -- OID CPU System
local OID_MemAvailable = '1.3.6.1.4.1.2021.4.13.0' -- OID Free Memory Available
local OID_MemTotalSwap = '1.3.6.1.4.1.2021.4.3.0' -- OID MemTotalSwap
local OID_MemTotalReal = '1.3.6.1.4.1.2021.4.5.0' -- OID MemTotalReal
local OID_memAvailReal = '1.3.6.1.4.1.2021.4.6.0'
local OID_MemTotalFree = '1.3.6.1.4.1.2021.4.11.0' -- OID MemTotalFree
local OID_Memtampon = '1.3.6.1.4.1.2021.4.14.0' -- OID Memtampon
local OID_Memcache = '1.3.6.1.4.1.2021.4.15.0' -- OID Memcache
local OID_HDtemp1 = '1.3.6.1.4.1.6574.2.1.1.6.0' -- OID Temperature HDD1
local OID_HDtemp2 = '1.3.6.1.4.1.6574.2.1.1.6.1' -- OID Temperature HDD2
--local OID_HDtemp3 = '1.3.6.1.4.1.6574.2.1.1.6.2' -- OID Temperature HDD3
--local OID_HDtemp4 = '1.3.6.1.4.1.6574.2.1.1.6.3' -- OID Temperature HDD4
--local OID_ifHCOutOctets = '1.3.6.1.2.1.2.2.1.16.3' -- OID ifHCOutOctets if not work try 1.3.6.1.2.1.2.2.1.16.1 or 1.3.6.1.2.1.2.2.1.16.2
--local OID_ifHCInOctets = '1.3.6.1.2.1.2.2.1.10.3' -- OID ifHCInOctets if not work try 1.3.6.1.2.1.2.2.1.10.1 or 1.3.6.1.2.1.2.2.1.10.2
--local OID_Raid_Status = '1.3.6.1.4.1.6574.3.1.1.3.0' -- OID Raid Status
--local OID_Physical_Memory_Units = '1.3.6.1.2.1.25.2.3.1.4.1'
--local OID_Physical_Memory_Size = '1.3.6.1.2.1.25.2.3.1.5.1'
--local OID_Physical_Memory_Used = '1.3.6.1.2.1.25.2.3.1.6.1'
--local OID_system_memory_total = '1.3.6.1.4.1.2021.4.5.0'
--local OID_system_vsmemory_shared = '1.3.6.1.4.1.2021.4.13.0'
--local OID_system_vsmemory_buffer = '1.3.6.1.4.1.2021.4.14.0'
return {
active = true,
on = {timer = {'every minute'}},
logging = { level = domoticz.LOG_DEBUG, -- Seulement un niveau peut être actif; commenter les autres
-- level = domoticz.LOG_INFO, -- Only one level can be active; comment others
-- level = domoticz.LOG_ERROR,
-- level = domoticz.LOG_MODULE_EXEC_INFO,
marker = 'Synology Monitor v1.41 '
execute = function(dz)
local i, results = 0, {}
local command = 'snmpwalk -v 2c -c '..CommunityPassword..' -O qv '..NasIp..' '..OID_NAS_TEMP
handle:close()
if results[0] then
local command = 'snmpwalk -v 2c -c '..CommunityPassword..' -O qv '..NasIp..' '..OID_HDtemp1
results[1] = format(line)
handle:close()
if results[1] then
dz.log('HDD1_TEMP : '..results[1],dz.LOG_DEBUG)
if NAS_HDD1_TEMP then dz.devices(NAS_HDD1_TEMP).update(0,results[1]) end
local command = 'snmpwalk -v 2c -c '..CommunityPassword..' -O qv '..NasIp..' '..OID_HDtemp2
results[2] = format(line)
handle:close()
if results[2] then
dz.log('HDD2_TEMP : '..results[2],dz.LOG_DEBUG)
if NAS_HDD2_TEMP then dz.devices(NAS_HDD2_TEMP).update(0,results[2]) end
local command = 'snmpwalk -v 2c -c '..CommunityPassword..' -O qv '..NasIp..' '..OID_CpuUser
results[3] = format(line)
handle:close()
--if results[3] then dz.log('CpuUser : '..results[3],dz.LOG_DEBUG) end
local command = 'snmpwalk -v 2c -c '..CommunityPassword..' -O qv '..NasIp..' '..OID_CpuSystem
results[4] = format(line)
handle:close()
--if results[4] then dz.log('CpuSystem : '..results[4],dz.LOG_DEBUG) end
if results[3] and results[4] then
CpuUsed = (results[3] + results[4])
if CpuUsed then
dz.log('CpuUsed : '..CpuUsed,dz.LOG_DEBUG)
dz.devices(NAS_CPU).update(0,CpuUsed)
local command = 'snmpwalk -v 2c -c '..CommunityPassword..' -O qv '..NasIp..' '..OID_HDUnit
results[5] = format(line)
handle:close()
local command = 'snmpwalk -v 2c -c '..CommunityPassword..' -O qv '..NasIp..' '..OID_HDTotal
results[6] = format(line)
handle:close()
local command = 'snmpwalk -v 2c -c '..CommunityPassword..' -O qv '..NasIp..' '..OID_HDUsed
results[7] = format(line)
handle:close()
if results[5] and results[6] then
HDTotalGo = dz.utils.round((results[6] * results[5] / 1024 / 1024 / 1024/1024),2)
dz.log('HDTotalGo : '..HDTotalGo,dz.LOG_DEBUG)
if results[5] and results[7] then
HDUsedGo = dz.utils.round(((results[7]) * results[5] / 1024 / 1024 / 1024/1024), 2)
if results[5] and results[6] and results[7] then
HDFreeGo = dz.utils.round(((results[6] - results[7]) * results[5] / 1024 / 1024 / 1024/1024),2)
if HDFreeGo then
dz.log('HDFreeGo : '..HDFreeGo,dz.LOG_DEBUG)
dz.devices(NAS_HD_SPACE).update(0,HDFreeGo)
if results[6] and results[7] then
HDFreePerc = dz.utils.round(((results[7] * 100) / results[6]), 0)
if HDFreePerc then
dz.log('HDFreePercent : '..HDFreePerc,dz.LOG_DEBUG)
dz.devices(NAS_HD_SPACE_PERC).update(0,HDFreePerc)
local command = 'snmpwalk -v 2c -c '..CommunityPassword..' -O qv '..NasIp..' '..OID_memAvailReal
results[8] = format(line)
handle:close()
if results[8] then
dz.log('memAvailReal: '..tostring(results[8]),dz.LOG_DEBUG)
local command = 'snmpwalk -v 2c -c '..CommunityPassword..' -O qv '..NasIp..' '..OID_MemTotalReal
results[9] = format(line)
handle:close()
if results[9] then
dz.log('memTotalReal: '..tostring(results[9]),dz.LOG_DEBUG)
local command = 'snmpwalk -v 2c -c '..CommunityPassword..' -O qv '..NasIp..' '..OID_Memcache
results[10] = format(line)
handle:close()
if results[10] then
dz.log('memcache: '..tostring(results[10]),dz.LOG_DEBUG)
local command = 'snmpwalk -v 2c -c '..CommunityPassword..' -O qv '..NasIp..' '..OID_Memtampon
results[11] = format(line)
handle:close()
if results[11] then
dz.log('memtampon: '..tostring(results[11]),dz.LOG_DEBUG)
if results[8] and results[9] then
MemUsedPerc = dz.utils.round(100-(results[8]+results[10]+results[11])*100/results[9], 0)
if MemUsedPerc then
dz.log('MemUsedPercent : '..MemUsedPerc,dz.LOG_DEBUG)
dz.devices(NAS_MEM).update(0,MemUsedPerc)
local OID_Memcache = '1.3.6.1.4.1.2021.4.15.0' -- OID MemcacheJe ne comprend pas. Tu demandes de l'aide, par MP également, je prend le temps de te proposer une solution propre qui te permet d'alléger ton script. As tu essayé la boucle que je t'ai proposé ?Tontonpat a écrit : 20 févr. 2021, 11:06 Bonjour,
J'ai tout regroupé dans un seul script, en tâtonnant :
Tout fonctionne, même si je penses qu'il y a moyen de l'alleger
if results[0] then
if results[10] then
dz.log('HDD1_TEMP : '..results[10],dz.LOG_DEBUG)
if NAS_HDD1_TEMP then dz.devices(NAS_HDD1_TEMP).update(0,results[10]) end
if (str) then
return str
local les_oid = {
OID_NAS_TEMP,
OID_HDtemp1,
OID_HDtemp2,
OID_CpuUser,
OID_CpuSystem,
OID_HDUnit,
OID_HDTotal,
OID_HDUsed,
OID_memAvailReal,
OID_MemTotalReal,
OID_Memcache,
OID_Memtampon
return {
active = true,
local i = 0
local results = {}
handle:close()
i = i + 1
--local command = 'snmpwalk -v 2c -c '..CommunityPassword..' -O qv '..NasIp..' '..OID_NAS_TEMP
if results[0] then
--local command = 'snmpwalk -v 2c -c '..CommunityPassword..' -O qv '..NasIp..' '..OID_HDtemp1
if results[1] then
--local command = 'snmpwalk -v 2c -c '..CommunityPassword..' -O qv '..NasIp..' '..OID_HDtemp2
if results[2] then
--local command = 'snmpwalk -v 2c -c '..CommunityPassword..' -O qv '..NasIp..' '..OID_CpuUser
--local command = 'snmpwalk -v 2c -c '..CommunityPassword..' -O qv '..NasIp..' '..OID_CpuSystem
if CpuUsed then
--local command = 'snmpwalk -v 2c -c '..CommunityPassword..' -O qv '..NasIp..' '..OID_HDUnit
--results[5]
--local command = 'snmpwalk -v 2c -c '..CommunityPassword..' -O qv '..NasIp..' '..OID_HDTotal
--results[6]
--local command = 'snmpwalk -v 2c -c '..CommunityPassword..' -O qv '..NasIp..' '..OID_HDUsed
--results[7] = format(line)
if HDFreeGo then
if HDFreePerc then
--local command = 'snmpwalk -v 2c -c '..CommunityPassword..' -O qv '..NasIp..' '..OID_memAvailReal
if results[8] then
--local command = 'snmpwalk -v 2c -c '..CommunityPassword..' -O qv '..NasIp..' '..OID_MemTotalReal
if results[9] then
--local command = 'snmpwalk -v 2c -c '..CommunityPassword..' -O qv '..NasIp..' '..OID_Memcache
if results[10] then
--local command = 'snmpwalk -v 2c -c '..CommunityPassword..' -O qv '..NasIp..' '..OID_Memtampon
if results[11] then
if MemUsedPerc then
}Code : Tout sélectionner
2021-07-05 21:10:00.599 Error: dzVents: Error: (3.1.7) Synology Monitor v1.41 : An error occurred when calling event handler synology
2021-07-05 21:10:00.599 Error: dzVents: Error: (3.1.7) Synology Monitor v1.41 : .../domoticz/scripts/dzVents/generated_scripts/synology.lua:165: attempt to perform arithmetic on a string value (field '?')Code : Tout sélectionner
