Tc2112
Messages : 44 Inscription : 12 août 2023, 15:48
Message
par Tc2112 » 18 mai 2024, 16:02
désolé mais toujours pareil ci dessous le log domoticz au démarrage
2024-05-18 15:59:11.037 zigate: Worker thread started.
2024-05-18 15:59:11.037 Status: zigate: Started.
2024-05-18 15:59:11.037 Status: zigate: Entering work loop.
2024-05-18 15:59:11.040 Status: NotificationSystem: thread started...
2024-05-18 15:59:11.040 Status: Ping: Worker started...
2024-05-18 15:59:11.041 Status: EventSystem: reset all events...
2024-05-18 15:59:11.045 Status: EventSystem: reset all device statuses...
2024-05-18 15:59:11.190 Status: PluginSystem: 1 plugins started.
2024-05-18 15:59:11.282 Status: Python EventSystem: Initializing event module.
2024-05-18 15:59:11.284 Status: EventSystem: Started
2024-05-18 15:59:11.284 Status: EventSystem: Queue thread started...
2024-05-18 15:59:11.551 Error: zigate: (Zigate) failed to load 'plugin.py', Python Path used was '/home/freebox/domoticz/plugins/Domoticz-Zigbee/:/usr/lib/python39.zip:/usr/lib/python3.9:/usr/lib/python3.9/lib-dynload:/usr/local/lib/python3.9/dist-packages:/usr/lib/python3/dist-packages:/usr/lib/python3.9/dist-packages'.
2024-05-18 15:59:11.554 Error: zigate: Traceback (most recent call last):
2024-05-18 15:59:11.554 Error: zigate: File "/home/freebox/domoticz/plugins/Domoticz-Zigbee/plugin.py", line 127, in <module>
2024-05-18 15:59:11.554 Error: zigate: from Classes.ZigpyTopology import ZigpyTopology
2024-05-18 15:59:11.554 Error: zigate: File "/home/freebox/domoticz/plugins/Domoticz-Zigbee/Classes/ZigpyTopology.py", line 19, in <module>
2024-05-18 15:59:11.554 Error: zigate: import zigpy.types as t
2024-05-18 15:59:11.554 Error: zigate: File "/usr/local/lib/python3.9/dist-packages/zigpy/types/__init__.py", line 4, in <module>
2024-05-18 15:59:11.554 Error: zigate: from .named import * # noqa: F401,F403
2024-05-18 15:59:11.554 Error: zigate: File "/usr/local/lib/python3.9/dist-packages/zigpy/types/named.py", line 8, in <module>
2024-05-18 15:59:11.554 Error: zigate: import attrs
2024-05-18 15:59:11.554 Error: zigate: ModuleNotFoundError: No module named 'attrs'
Messages : 4677 Inscription : 04 avr. 2018, 16:16
Contact :
Message
par pipiche » 18 mai 2024, 16:55
N’aurais tu pas une version lite de Debian ?
Il te manque des modules python3.
Tu as peut-être plusieurs versions de python installé…
Si vous appréciez ce que je fais, vous pouvez contribuer par un don
Paypal , ce qui me permettra notamment l'achat d’équipements et de les tester/valider pour le plugin.
Wiki
ici
Tc2112
Message
par Tc2112 » 18 mai 2024, 17:10
Debian est la version 5.10.0-29-arm64
comment vérifier si plusieurs versions de python sont installés et les supprimer ?
ou faut il installer les modules python manquant et comment ?
merci de ton aide
Messages : 6638 Inscription : 23 juil. 2019, 20:57
Message
par Keros » 18 mai 2024, 17:32
Tu avais quelle version du plugin avant de faire la mise à jour ? Tu étais déjà sur la branche stable7 ?
Tc2112
Message
par Tc2112 » 18 mai 2024, 17:35
Oui j'était sur la branche stable 7
Plugin: 7.1.011 [5.260]
Message
par Keros » 18 mai 2024, 17:38
Tu peux nous donner le résultat de la commande git status ?
Tc2112
Message
par Tc2112 » 18 mai 2024, 18:55
ci joint le resultat
Contact :
Message
par pipiche » 18 mai 2024, 19:16
Je sais pas ce qui a été fait sur ton système, mais je ne vois pas pourquoi il y a fichier .gitconfig a cet endroit.
que donne la commande
Peux-tu nous donner egalementr le resultat de la commande
Wiki
ici
Tc2112
Message
par Tc2112 » 18 mai 2024, 19:26
la commande python3 -V donne :
Python 3.9.2
Résultat de la commande
ci joint
Bibi49
Messages : 367 Inscription : 11 mars 2018, 12:42
Message
par Bibi49 » 18 mai 2024, 21:00
Question à la co.....
Dans Domoticz/matériel, tu n'aurais pas deux fois le plugin zigbeefordomoticz (ou zigate) d'activé ?
Ça aurait pu...
RPI 2 -> Bullseye Lite
DomoticZ -> 2024.7
RFXCom 433E -> Pro1 1041
PiTInfo v1.4
USB->ùSD = Rpi-clones
